Home » Eclipse Projects » GEF » Problem with mouse hover in draw2d figure
Problem with mouse hover in draw2d figure [message #249014] Tue, 19 May 2009 02:48 Go to next message
Originally posted by: sneha29.gmail.com
I am working on Eclipse RCP application which displays draw2d figures as
output. These figures are connected by draw2d connections.
My problem is that I am not able to drag and drop using mouse on these
diagrams in case of very complex diagram. Mouse hover events and drag
and drop seems not to work for elements in the middle of the graph.
Mouse Tool tip is also not working for elements in the middle of graph.
Is this a know problem with eclipse - draw2d?
Any pointers would be of great help.
Sneha
Re: Problem with mouse hover in draw2d figure [message #249173 is a reply to message #249014] Thu, 04 June 2009 01:56 Go to previous messageGo to next message
Were you able to reproduce this with GEF logic or shapes example editors?
Alex
Re: Problem with mouse hover in draw2d figure [message #249245 is a reply to message #249173] Thu, 11 June 2009 09:02 Go to previous messageGo to next message
I am getting this problem while working with GEF.
Sneha
Alex Boyko wrote:
> Cheers,
> Alex
Sneha
Re: Problem with mouse hover in draw2d figure [message #249276 is a reply to message #249245] Sun, 14 June 2009 15:51 Go to previous message
I understand that you got the problem while using GEF. However, to be able
to fix the problem we need a reproducible scenario. It is best that you
reproduce this issue with GEF logic or shapes example editors, so we can
reproduce the scenario and start fixing it.
Alex
Previous Topic:going from a create request directly to a direct edit
Next Topic:Null Pointer Exception in org.eclipse.draw2d.ToolTipHelper
Current Time: Thu Nov 06 15:44:19 EST 2025
Powered by FUDForum. Page generated in 0.05827 seconds
