Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1409603 is a reply to message #1409296] |
Mon, 18 August 2014 14:15 |
Le 18/08/2014 15:22, Hamza Ed-douibi a écrit :
> Hi all,
> First, I would like to thank OBEO team for such a great tool.
Thanks for your feedback!
> I'm using Sirius to create a designer for IFML language using the IFML
> metamodel. Source code available here github.com/ifml/ifml-editor.
> Everything is working fine in development mode, but when I build the
> plugin and install it for the update site, the queries from my mtl file
> are not working. My file is registered as a java extension using the
> Acceleo syntax (com::exemple::helper), I have the dependency
> org.eclipse.sirius.common.acceleo.mtl and my project has the Accleo
> nature. Is there something else I need to do to get it to work?
> NB. I'm working with eclipse Luna
Can you check that you have etml files in your plugin from your update
site? The *.emtl files are the binary/compiled files of *.mtl files
(like *.class files for *.java files). If these files do not exist in
your deployable plugin there is a problem in your build process.
That's my first idea.
> Thank you
Laurent - Obeo
Need professional services for Sirius?
Laurent Redor - Obeo
FUDForum. Page generated in 0.04256 seconds
