Home » Modeling » M2T (model-to-text transformation) » push and pop in Acceleo
push and pop in Acceleo [message #1408814] Sat, 16 August 2014 01:36 Go to next message
Where can I find documentation of Acceleo about syntax of push() and pop() instructions? I want to use Push() and ... in Acceleo but I don`t know, how do I write them Sad
Re: push and pop in Acceleo [message #1408855 is a reply to message #1408814] Sat, 16 August 2014 04:44 Go to previous messageGo to next message
What do you mean by push and pop? Neither Acceleo nor the underlying
MOFM2T (nor indeed C++ or Java etc) have any push or pop instructions.
push and pop are often associated with Stacks which you may find in
support libraries.
Acceleo has no built-in Stack class though you may access one using the
invoke capability.
Ed Willink
> don`t know, how do I write them :(
Re: push and pop in Acceleo [message #1408911 is a reply to message #1408855] Sat, 16 August 2014 09:06 Go to previous message
Thanks for your reply.
I mean use of context services. I want to learn use of context services in .mtl file in Acceleo 3. I understand, it is possible in Acceleo 2 but there is no equivalences in Acceleo 3. Is it possible that I can store objects in Acceleo 3?
Previous Topic:[Acceleo] Disappearing menu when using Acceleo
Next Topic:[Acceleo] cannot access the attributes of a uml interface
Current Time: Sat Apr 26 18:38:30 EDT 2025
Powered by FUDForum. Page generated in 0.03195 seconds
