EMF Forms to RCP App [message #1407723] |
Wed, 13 August 2014 05:50  |
so what I'm basically trying to do is embedding a EMF Forms View into my RCP App.
As I wrote this
try {
ECPSWTViewRenderer.INSTANCE.render(formChild, gep );
} catch (ECPRendererException e1) {
e1.printStackTrace();
I got
!ENTRY org.eclipse.ui 4 0 2014-08-13 11:35:03.277
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.emf.ecp.view.internal.swt.SWTRendererFactoryImpl.getRenderer(SWTRendererFactoryImpl.java:217)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:70)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:58)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:45)
at reiseapp.swt.TableClass$2.mouseUp(TableClass.java:298)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at reiseapp.swt.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Does anybody know how to fix this, or maybe some source where I can look up for the steps necessary to successfully embed the form-based UI?
ps: I followed the steps from the "Getting started with EMF Forms" tutorial.
FUDForum. Page generated in 0.28719 seconds
