| Scriped Datasource and Parent/Child relationship [message #248161] |
Mon, 16 July 2007 12:45  |
I already searched google and the 2 BiRT books but couldn't find a
solution to my problem.
I have the following class-structure:
public class Person {
private String name;
private ArrayList contracts = new ArrayList();
public ArrayList getContracts() {
return contracts;
public class Contract {
The resulting report should look like this:
Person 1
- Contract 1
- Contract 2
Person 2
- Contract 3
- Contract 4
In reporting the contracts are created using a subreport and now I face
the problem how to pass the person object on to the subreport. I tried
the following but it fails:
PersonDataSet:
fetch:
----------8<----------
if( iterator.hasNext() ) {
var node = iterator.next();
row["name"] = node.getName();
row["mobject"] = node;
return true;
} else {
return false;
And passing on the mobject to the child but this fails with:
-----------8<-----------
WARNUNG: An error happen during population of data. This might be caused
by including data of mixed type in a column of "ANY" type.
java.lang.IllegalArgumentException: An error happen during population of
data. This might be caused by including data of mixed type in a column
of "ANY" type.
org.eclipse.birt.data.engine.script.DataRow.setColumnValue(D ataRow.java:153)
Maybe someone could point me in the right direction? How do I pass the
Person object to the sub-report?
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: Scriped Datasource and Parent/Child relationship [message #248959 is a reply to message #248861] |
Thu, 19 July 2007 14:41   |
I see so the first limitation to resolve is the possibility of passing
objects as parameters.
Tom
Jason Weathersby schrieb:
> Tom,
> That is an option. You can also write your scripted data set in Java.
> Both of these options will still have a problem with nested data sets,
> where you need to pass a object as a parameter though.
> Jason
> Tom Schindl wrote:
>> Hi Scott and Jason,
>> If I got you both right the thing that is needed is to write a ODA
>> Driver that is backed by a POJO instead of e.g. XML?
>> Tom
>>> Tom,
>>> I checked bugzilla and can not seem to find a bug logged on this. I
>>> imagine that this will be a difficult thing to change. At one time
>>> there was some mailing list chatter about building an EMF based ODA
>>> driver, but I do not see a bugzilla entry for this either. If you
>>> would like, log a bugzilla entry for both of these.
>>> Jason
>>>>> Tom,
>>>>> I would not say it is primarily focused on SQL, but on known data
>>>>> types.
>>>>> You can add an Java Object to the script environment and call them
>>>>> as you are doing or add them to the application context and call
>>>>> them from the expression builder. The main issue is that ODA/BIRT
>>>>> does not support object types. In your case if the inner hash was
>>>>> keyed with a known data type then you would not have to use this
>>>>> hack. Hopefully we will get object support in the future.
>>>> So there are people working on it? How much work is this? My use
>>>> case is to create a report of EMF-Sources and if there's going to be
>>>> a chance that in future this hack has not to be used I could think
>>>> about use BiRT in my next projects Jasper-Reports once more.
>>>> Tom
| Re: Scriped Datasource and Parent/Child relationship [message #249166 is a reply to message #248959] |
Fri, 20 July 2007 10:47   |
Tom,
Either that or you need to pass a primitive as a key.
Jason
Tom Schindl wrote:
> Tom
>> Tom,
>> Jason
>> Tom Schindl wrote:
>>> Hi Scott and Jason,
>>> Tom
>>>> Tom,
>>>> Jason
>>>>>> Tom,
>>>>>> types.
>>>>> be a chance that in future this hack has not to be used I could
>>>>> think about use BiRT in my next projects Jasper-Reports once more.
>>>>> Tom
| Re: Scriped Datasource and Parent/Child relationship [message #249339 is a reply to message #249166] |
Sun, 22 July 2007 09:09   |
--------------070406010205050601010208
But what I don't really understand is that I was able to pass an object
to a subreport. I'll attach the projects.
The strange thing is that the subreport always gets the last object as
person parameter. So to me it seems that I can pass any type of Object
to the subform which is a good thing but the problem is the object I
want to pass (See the attached screenshot).
Tom
> Tom,
> Jason
> Tom Schindl wrote:
>> Tom
>>> Tom,
>>> Java. Both of these options will still have a problem with nested
>>> data sets, where you need to pass a object as a parameter though.
>>> Jason
>>> Tom Schindl wrote:
>>>> Hi Scott and Jason,
>>>> Tom
>>>>> Tom,
>>>>> I imagine that this will be a difficult thing to change. At one
>>>>> time there was some mailing list chatter about building an EMF
>>>>> based ODA driver, but I do not see a bugzilla entry for this
>>>>> either. If you would like, log a bugzilla entry for both of these.
>>>>> Jason
>>>>>>> Tom,
>>>>>>> types.
>>>>>>> them as you are doing or add them to the application context and
>>>>>>> call them from the expression builder. The main issue is that
>>>>>>> ODA/BIRT does not support object types. In your case if the
>>>>>>> inner hash was keyed with a known data type then you would not
>>>>>>> have to use this hack. Hopefully we will get object support in
>>>>>>> the future.
>>>>>> Tom
Content-Type: application/zip;
name="projects.zip"
Content-Disposition: inline;
filename="projects.zip"
UEsDBBQACAAIACd49jYAAAAAAAAAAAAAAAAnAAAAYXQuYmlzY2F0LnNvY2lh bC5zbGkucmVw
b3J0cy8uY2xhc3NwYXRolY/LCsIwEEXX9itC9qa6c9EHIhV0UaXUtdRkaKNx EvMQ/XstUnSj
4G7u5XAuk+S3syJXsE5qTOmUTSgB5FpIbFO6q5fjGc2zKOGqcc40vsui0TsA ensnJ4kipc5y
SvrydcZfQa5xALVtGXAljQN2FJ6pJiDvntNsXRX7xaas56uyqP6XGQGMawvM wiVIC2KrQivR
/TDp4E3wg+wgsWeT+OPxB1BLBwg/HFeoowAAACwBAABQSwMEFAAIAAgAJ3j2 NgAAAAAAAAAA
AAAAACUAAABhdC5iaXNjYXQuc29jaWFsLnNsaS5yZXBvcnRzLy5wcm9qZWN0 vZLPSgMxEMbP
9inK3k305iHdgoo3Rag+QDoZ15T8YyZbfHyzu2lxWwqC4CnfN/lmfpCJWn95 t9wjsY1h1dyK
m2aJAaKxoVs1729P13fNul2oRHGHkB+RgWzKJdwurlTQHludxdYylIMjWO0E OysIU6TMSo6R
EoXoPYbcKnlQpVin8qDlT7PtrTObhFBMdQ+lTQczFCo4UicQnE2MYmeygEhF 6L0e80hHeGnQ
1PUDlScrZ17JU8JvkMmgeNbBfiDn+38jbuATvf4zrxbqExdU7gmn6KTPwK+u 72x4GS8H7hi6
kJ9tI5y2HGTBHbc++1jfUEsHCMDnZWPwAAAAlQIAAFBLAwQUAAgACAAnePY2 AAAAAAAAAAAA
AAAAMQAAAGF0LmJpc2NhdC5zb2NpYWwuc2xpLnJlcG9ydHMvTUVUQS1JTkYv TUFOSUZFU1Qu
TUZ9j8sKwjAQRff5inyAGdRldwrurEgL7tN0LANpUicToX69hVofG1cDc+6D W9pAV0xiLsiJ
Yij0BtZqn0Pr0ZQv+GbbhZxsj4WucIgsSZ997gyFBdZj30RPbhZZgYaSm06K jqyH5Al4di6O
7/JP/c4J3a1E/h8Cb52q8JaJ0cwBhY7cATpPQ0LItFI/DxcZgXMQ6nFCfWzR g0xz1WFWmKN9
jLVYlkILZ1RPUEsHCE3na1KpAAAALQEAAFBLAwQUAAgACAAnePY2AAAAAAAA AAAAAAAATQAA
AGF0LmJpc2NhdC5zb2NpYWwuc2xpLnJlcG9ydHMvYmluL2F0L2Jpc2NhdC9z b2NpYWwvc2xp
L3JlcG9ydHMvQWN0aXZhdG9yLmNsYXNzjZJdTxNBFIbf6SddlyJgUQREkNZS k06MlxgTBDFN
GkKC9NZMl2EdXHY3s7PIz/LjgsQLf4A/ynhmuimJF8jNfJw5+5znnOzvPz9/ AXiJTh0lho4w
fKyygLYsCZSIeBYprmWaaJPx3cCoS2ESXUeFchMdchlEKs0kzxVPozxUMd8d Z0aLwJwMjlyA
oXE0PHk/OPw42GdYGJ6LS8EjEYf82GgVhzsMs3tJnBkRm5GIcjmDBsOqMP2J SH8i0ieRfiHC
UEsLdnd4N2OqUnutYmXeMJS72yOGyl5yKj2Ucd+Hj1mGuaGK5WF+MZb6gxhH 0somgYhGQit7
L4IV80mRQZWEtWFod4d2DkkWKn6mxYX8kujP/G0en0aS2jLyyuzYct67q0Cm RlGndTxiWLyZ
w/TF2jz28QCtBmgEPjzcY6gHEwzD5v9LkV9mktSSNnyso0WVQ2n25ZnII0L0 utt3n5h3nOQ6
kAfK9t2cvvStOjZIsUy/TgnLqKJGt7q7zZA1edO5QjGaLK1Nur2indFe7V1j 7ptLnafVox3U
cgUtLNDJnyRh0SGYHQZlLBW4hw51QBH7ldd7cY3l3g+s3PCaTmqVCGto4Ilj Lk2yC6Y9rdGL
1Vm/jc4IbCs8/ZfepuwO0Z/fSm9gE8+K5rdcV1TlO1a+Tmk1F+WOUnLdbrlT +y9QSwcIqU02
C/0BAACWAwAAUEsDBBQACAAIACd49jYAAAAAAAAAAAAAAAAtAAAAYXQuYmlz Y2F0LnNvY2lh
bC5zbGkucmVwb3J0cy9idWlsZC5wcm9wZXJ0aWVzK84vLUpO1dNTsFUoLkrW 58ovLSkoLQHz
kzLz9LmAhF5mXnJOaUpqMVDM1zXEUdfTz01fJ4ZLARXocQEAUEsHCB907fk8 AAAATAAAAFBL
AwQUAAgACAAnePY2AAAAAAAAAAAAAAAAOQAAAGF0LmJpc2NhdC5zb2NpYWwu c2xpLnJlcG9y
dHMvcmVwb3J0cy9UZXN0UmVwb3J0LnJwdGRlc2lnbu1abW/bNhD+7l/BadiQ oLMlO03SLIqL
xV23AG0aJFmHISgGWaJtrZIoSFQSo9h/35GU9Uq9OlnbLQbaQOLd8e54PD53 lP7y3nXQLQ5C
m3gnynikKQh7JrFsb3mi/Hb9evhCeTkd6AH2SUAREHvhibKi1P9RVe/u7kbY dGw/xCMSLNW5
HVB1omn7qoVDe+kpqeC90WQ0fq4g24JJlOkAwU/3A+LjgK6RZ7j4RDEDbFBs na6V6c9CKjo9
u7xGr7gwHKD3QhqagDBtdAszHWoHEw2dRrZjoe8depwf2R9qB3vaVFc3E8nn jTybhsrU9poI
TeK62GO0M+KvA3u5omjH3EVsOj49+/cHiQI0I65veGt0DnxohQM8LWuxoq4z LMwAfjMD26dg
JUzC/REiA80dw/uI4jW4s+kKeQT5AbbwwvawhUziUVBspKs5ofFEFN/T0kR2 6DvGmumnTE+5
+EsuXldz5HJH2DDha9sBVqB2QRCoqXIl/xRKjpb2omSwZVBjGIJ7TByKV/y1 sHiYGY1nebu+
4o8iag6UlIfzuZiuiBXTwkTgMf2bm9mrn65/urEi112/m/+FTYpOkIfvkHjY 2T3+8AGWQvDW
CTQdEuJqiZHjyCXpatme2H617IDYJ5hWOgTTWKFX8IiuMBXeOCx6w7HD0iIH OIwcCjy/2jxq
cxxiKhpEJo0CXB6TrbtPQlvE5ri4uk2sHo809n9XTuaH67UP3KAtpKU6fvB+ tUX9rZ30s9Yl
PF76GwwppJe1upoLhxahYhIncr2HihMh7bzVkj/okmUnbuH9ng5MmDazGuYK W28xNdgmlfmv
dndKGNrYLrO/wwaVsbffpDLuLhtVOLlpdbfyQOOmrfZAy41b74SGzdvogfoY rIxciT7xMTrd
HKhVatUeqbbLDvYLw/xoLPFO/DccucTCzgjOf7p7PBjYFAcGJQEckRcA1oj3 BkwYLTEVT+HO
7mhD0v4oXmBqrrKaLHbQRspoZYTnAFh2dtEu+sSF3BoBwCMLgw4JlcdJjvl4 QO5uxDp/YCc5
UDIFWc7IUcQxkBJRcsXDOqHiSGfGoNc9HYXCRjAXgNgvDpkbznsjsI25g3cU MwoCeC2coPzA
xCVCYAk9BGuJjwd/I+wA6P2UHVkY8AqGesIWn0951gmzYNoIRpjVgWHCYSGw 2eQJjnz5cETE
wswxwvArNHpvG6PPvJAaXnXme1S7n9BY++B75PnbxMETKHwChVumz6/AEY3p tMkRbVPqo/vi
M+Bk2c71jQD+AuB8iJSddfSjtQ9kzF0gFb73IV3xjuyme7kwIHu9N5yIZQzA m7qaErVTwA7P
PD+C9McgcVft7fBdRDk3h82PkOXrKiSxXKzsYBZcsHgIbxTxVvlwPDBj0MzR uJSGFSIJtGZ1
RoBNElgzEnmMR9umYsqJAlmbeinz/tkzXpTw8ieT7XgJJJ65guwdFHKFeijD tUkNWcYidVXd
Uyh7BqrKlE9dVyj4VJVZnyn5MpSbok/Q1Jd9MU1WK1VN9MqNxqrBcM+aLFXx pHNNtmkiJx1j
yCxrJ99PZy+SKxUSwlrMRZn2vFilFbbPHAIBB6eEUuLOiEMCZfrtjP8qM2GN hCumB2R44thW
H/7fbYtCEI/9yj6MnPsNXtBttGf8/XVn3H01v2Q3StuozgX0152z91X+mvjb qA7s/RUH5nq1
WbYH4Q27ZGhixxFbZf9pqzxtlSb2//5WiR82Z41vLDE7eyI/u5Ns13fw0DVC AL9DRhJPeMUH
0Fs+cAHvxdYq9Qq51AUhQCXBaay7yvn2qkriUtXPL8MFBGb34Y0oUnZBHkvJ HNv6LcO1Q7KY
svtkKOoBOOhq8pKf4pK789xMnKCIN6X2g+dLft2sSXEZ9DmxsitIWdeZ++xF Qxq7i0NB075r
G0a8UGL9ic2FdKcqaQ4402KcM96bebhaqVUrt1SxpC+UaWzYZYoTu1cvn61P 2u3CubUfkkuQ
bVzxOLfYorknMspYFkbyUJ+MDvcOxuJX/uInnVqIr5lzoqg1o3ul0RU2LGmC g8KE8xxV5TeG
SsSHU1oFCSdzjDkWdJMi0C/RyjIee6dMz/k+ashjiRyVT1rVtGGKN9okWzuJ TYfFL1462JRs
i3/RrFJ4CF5Y7GKkyQJDtzA1bMksSbSMK4/DVIe6MOBfHoloKWLdEmlVj1rk 8A69YV681oyn
B9dRYwh3P8maRCQnW9KCaS2psiF4anvsU0rZOVcS0qKfW6c+ny972dFW+0Rg 7bGQv+5etr/u
3m0+O3JaNPW9U8Ka46FE3BOMlORsuUjdLlNykh4cvDTp2rVLn5PVdhU58YM4 teP9TE5ga9/m
2qL/Uxd3ufnJyezo5bSN/JU4ultGysDFsfZcBheqyfcbyavgZokwgZ9NMCDV ZAMwjorfZNey
pVhurHVh5MzV4C637VsCvJL4OsBXJq4GgCXa1FdN+DXHlvVVsYZvZG7yVbp/ vyR3SbBxmaRN
VFdi5xJhEvptXZxZzqpqTa7RBmuPtS5hwHmbwPcWxx6X34DJ87R9Ih8geU9f dfEx523nq77n
F5/iEdzVKvLbBLVe1UQtESZVpFZXfudYMusprW2bmEodESlDG1c0WQl5jdUh W5XvdYdhGqJH
VUV4QtoUkV2+NK8JvZZWHbRuSsjCrTK80nCqym4ZHV5UxUGG5qiZZqK1tqXc Ws/Eh66K5jlw
8gJ3OvgHUEsHCOwja4nrBwAAEzkAAFBLAwQUAAgACAAnePY2AAAAAAAAAAAA AAAATAAAAGF0
LmJpc2NhdC5zb2NpYWwuc2xpLnJlcG9ydHMvc3JjL2F0L2Jpc2NhdC9zb2Np YWwvc2xpL3Jl
cG9ydHMvQWN0aXZhdG9yLmphdmGtUl1v2zAMfJZ/BdG9JAEq/4BgQLtmGDIM Q7Gtz4MiMw5R
VRIkOu0w9L+Pthwn7bCPDnuSQd8d70hGY29Ni2BYbyhbeXKwZJzOjnTCGBLn ZVXRXf8FIbUa
raOYUXeko+ta8vpykzkZyzfr66GwPIWH3JLeJnOH9yHd6jedbxxeBc/4wCJc LxYVLODLTixY
pr3hkMA6kzNYAaXgMrD87FudkwdHWwT7zToUWl3FbuPIjoTLSUC00TdSeeYM vleVquuh3UFx
varUKJPZsDxb8sbBZ07kW7j+cPNu/fHregWv4ex3UzpbHrXzziRsgLwoeovS IPXO8NDh6DSO
E1PClVGocRaSXZx3ViB9rZ4sTszZXMKox75noc188Ofvzd40wc6HykVG/MuV vRJjiWd/Wtj8
qZl9oAYK8wlsWF0Pl9WlcJ/h7YPFyBT6BSiVu4hJF94BKRNQxZvMmXckR/c/ w4X4j9mE+JJo
UwTfObc8ySo6J1FLshLtE3KXfLnyn+4GCuYiDaBfYernF3y8rxZ5hVvTOS4H o0al6e7EymP1
A1BLBwjMv3GhnQEAAAYEAABQSwMEFAAIAAgAJ3j2NgAAAAAAAAAAAAAAABUA AABtb2RlbC50
ZXN0Ly5jbGFzc3BhdGiVj8sKwjAQRdf2K0L2prpz0QciFXRRpdS11GRoo3ES 8xD9ey1SdKPg
bu7lcC6T5LezIlewTmpM6ZRNKAHkWkhsU7qrl+MZzbMo4apxzjS+y6LROwB6 eycniSKlznJK
+vJ1xl9BrnEAtW0ZcCWNA3YUnqkmIO+e02xdFfvFpqznq7Ko/pcZAYxrC8zC JUgLYqtCK9H9
MOngTfCD7CCxZ5P44/EHUEsHCD8cV6ijAAAALAEAAFBLAwQUAAgACAAnePY2 AAAAAAAAAAAA
AAAAEwAAAG1vZGVsLnRlc3QvLnByb2plY3S9ksFqAjEQhs/1KWTvJnrrIa7Q Fm+KYH2ANJmu
kWQSkqz08Tu7G6WrCIVCb/8/808+kolYfTk7PUNMxuOyWrB5NQVUXhtsltXh fT17rlb1RITo
T6DyGyQVTcgUridPAqWD2nkNlmVIWfC+QA3lnQPMteAXRcVyRuo0/2k+WmP1 PoAiU9wrjUnU
XaFgfGwYKGtCAnbSmSkfSciz7PMQr3AakLFpO2oaLB95wW8Jv0EGDWwj0XzS PV/+jbhXR3Dy
z7xSKE9MqNxGGKKDvgPvbNsY3PbNjtuHHuRH28DbkYsk3HXro2/0DVBLBwgi Hjar5gAAAIMC
AABQSwMEFAAIAAgAJ3j2NgAAAAAAAAAAAAAAAB8AAABtb2RlbC50ZXN0L01F VEEtSU5GL01B
TklGRVNULk1GVY7NDoIwEAbvPEUfwDbqsTdNvIkhYrzXspKN/cFla8SnlwRB uM7M5tvcBLxD
y/IK1GIMWmzUOtunUDmQ+U9Objuak/GgxaV3onCplhhGU3b+Fh3aofCxAqe4 70Y/3/kv7Szj
y3Ck+YmaaHaGZ0ICOeRaRKoVWIdNCyrhKlsAGwkUpcDoITsMUB7NpyvZEGvB lHr+biKxLIx9
mHr56RdQSwcIbAIPQp4AAAAUAQAAUEsDBBQACAAIACd49jYAAAAAAAAAAAAA AAApAAAAbW9k
ZWwudGVzdC9iaW4vbW9kZWwvdGVzdC9BY3RpdmF0b3IuY2xhc3OFkV9PE0EU xc+025Zdl6JA
KwiIIK2lJkyMjxASBDFNGkKC9NVMl2Ed3e42u7PIx/LPA4kPfgA/lPHOdFMS o/gyM/fO3d85
Z/bnr+8/ALxAu4YSw+IouZAR1zLT/CDQ6kroJK3BYWgnachlEKlxJnmu+DjK QxXzg2GmUxHo
896pbTC4p/3zN72Td70jhvn+B3EleCTikJ/pVMXhLsPsYRJnWsR6IKJczsBl 8KzsjpFlqI4L
UrP/NzdEqO6pWOl9hnJne8DgHNKYhzLu+/AxyzDXV7E8yUdDmb4Vw0gaI0kg ooFIlamLpqPf
q4yhQmZS0m11+iZjkoWKX6ZiJD8l6Uf+Ko8vIkmWtbzWu0bOe30dyLFWlKKG JYaF24zTG+Pm
kY9FNFwwrPrwcI+hFkwwDJv/lyJ/mU7GhrThYx0NUg6lPpKXIo8IsdTZ/tf7 eGdJngbyWJmU
9enNjjGKDTJUpl9ewjIqqFJVs9UMeSSXdHaoR+9Ia52ql7Qz2ivdG8x9saMP aPVoBwV00MA8
nfzJEBYsgpnoNNEscA8t6pg65iuv+/wGy91vWLnl1a2pVSKswcVjy2xOpgum Oa3RjbGzfhed
EdgoPPmT3qLpNtGf3Ul3sYmnRfgtm4pUvmLl85RWtV1uKSWbdsueWr8BUEsH COBQlePqAQAA
TgMAAFBLAwQUAAgACAAnePY2AAAAAAAAAAAAAAAAKAAAAG1vZGVsLnRlc3Qv YmluL21vZGVs
L3Rlc3QvQ29udHJhY3QuY2xhc3N1ksFu00AQhv9NHLt1nDa4SSnQQgoNOEbC 4sAJ1EuBU1QO
QTlw2yRLcOXYkr3hwFOBBELiwAPwUIjZtZNKZnvwzu7s/P98s8mfv79+A3iO 0EGD4WCVLUQS
SVHI6CJLZc7n0oHF0L3in3mU8HQZvZtdCZW1GXo6G2fRROQxT+IvfJYIBivl Kwr++Fo0kXmc
Ll8ytArJc0mG5eVaxkn0mktBV02RLhjsV3Eay3OGF8H/+rqofh5NqfsFzeCi ia4HD7fINxhN
d0HDeXCww7A/jlNxuV7NRP6+BPbH2ZwnU05D0LlKWvJTXDD0x4Y3IVrrY56t GBoyY3CWQl7q
mXvByDS1U2wK+oapFPUOWUzKp/E3HtdzKfxTD7twqbLYVh4EpgewyepNulCa xx7aSmMXOsXg
TrJ1PhdvYzVhZzPOM+WCUxI06WvR2lBPRX+MhuqpY1tHh+49dGjdo9MHylsU 3fAn9sOnP+B/
07U9WvfIBaSyoLg76NMpLKtxiNuA3qkuTO+O6Gvo3R24muMu7lV9IoqqqhV+ h/9128LWya62
9sqCyprhGCeV+JyqlbFdAyzb9UjT1w6HZdUWzq7gGO7jgQFkUAc5MoI8xCMT yKAOckyakxtA
1G+gGp8ZQYZ1kIER5IkZZFgHOSPN8AaQdgUSaM3oH1BLBwi2LdG78QEAAD4E AABQSwMEFAAI
AAgAJ3j2NgAAAAAAAAAAAAAAACYAAABtb2RlbC50ZXN0L2Jpbi9tb2RlbC90 ZXN0L1BlcnNv
bi5jbGFzc51Va3MTVRh+Tppk6fZI29xoEbAoYDa9RBRBm1qBQBUJobollXqb 03QpyyS7zmbb
Af8J/gG/4oyEQWccP/FB/5P6nrObJZfNMMN0unv2vTzv8z7vOSd///v7nwDO 4wcNCYbZtrtn
tcq+1fHLm5bXcR0NSYaZB+JQlFvC2S/f3n1gNX0NaYacstpu2bQ8W7Tsn8Ru y2JIOqJNr0zt
ZZLpe7azX2GYbLqO74mm32HIBwEHvt0qX/E88ahmd3wZY9r7jvAPPAJZiotZ q/WxrIaAlXVK
Ta/Zju2vE3ZxtLrRIG5VytQxgVmON5BhmCgaDQ05hmxMIR1ZzE6C4RjHJHS5 mufQcIRhumY7
Vv2gvWt5W0HbmZrbFK2GICnoOzQm/fs2tZqtjehKbLV9y68rrXJFI04trdML 4BRafSndsV78
iHgr8Z7xkvHOAPJcMRZYaleOdY1DlhmFQUke/diTZUrs7fViVc04DKMh9V/k WMIyDYpShuYa
bMWKscNwpBmh5WPBGI56Vts9tHoWif0+xwcSOx24aIb9Mm94bnvLZbjU3/c1 4VuV4e9xw6i/
XuY4SXXafx9xnMbbkvwqRwVr1LrtW57wXY/0Hhj+jdBemcI6Lmv4lPob9XJc wVV5aK2H/vBG
DAXWcI22cAwnHVVscHyGz4kGSWf6wiOQzAAN1aeOL1DTcJPGMOjhuIU6TWDX uufKA58dkczY
kWU2Ob6UZdJU5rqzJ/FMji2ZmxL3qBfZZINjG1/TubkvOnXVDx1v2h1a23Yk Fl1kw+jSKR4G
zoR3yKCb7oHXtDZstU+Ds7oik0h3wqP/FBL0R7cA3ZsJeS+QbUqtOdkY3StH 6TlNljsUn6B3
vvQMM6U/kL37DPmnKJQWn2LuV5VynJ4ZJOk5Rc9JSuPIEcSbZCkEyTiBk4Ba aaoAwym8FZYo
q28gVfoNc08iyLQyzigYHgSEMAwLEb911QlFDxHSlTVHOfk+IumISDoiQnuR fEH374wQKgwT
mosldAZnI5BzCmSzn1hBEpvoI3aCck+OIRaM492oirRwRakII2z7aoiuS4qL XZS2h1tfoKzT
fRX0qIKOlbDF98binR/BO0N4Z1+BdwEfRipcVLj/0CpNbzPcOfVSF5e6+Hg1 9Qsuzqee4xOG
v1BdTc4nu7hOhW88xim5vv0C0+q91MVXj6Evy4/Stky5w/Dzfy+Wn0SSHlcl ijRPg9ou4TIW
6UAbdNrKivAFEpsoRIRN3MWOktbEN7RKUOZNfAv5o7pAwst2ktEAAh9X5+Y7 1dr3/wNQSwcI
1PpS/8EDAAByCAAAUEsDBBQACAAIACd49jYAAAAAAAAAAAAAAAAqAAAAbW9k ZWwudGVzdC9i
aW4vbW9kZWwvdGVzdC9QZXJzb25MaXN0LmNsYXNzjVTbThNRFF2H20yHgV4o gohcvLYVqNxE
KSLXQmWESqHY+jS0ExzSzjTTqQmf4Bf47qO+KCZtYhM/wD/yxbjPFKjQktgm Pefss/Y6+7J2
f/358RPAJNICWhh682ZWy4VtrWiH45pVNA1FL9oC2hg8x+p7NZxTjaPwzuGx lrEZhIIDKZKf
4tyWbD0XXrYs9YS7RRhcCf3IUO2SpTGEmmEWlIYXI4vkKC5kcrqh24sMrYFg kqFtlXACuhh6
mtBIkOGW4YHE0LHgOLrA4JPRjg4BfgZvwzsibhD5npmX0IN+7nyTEgko9TwT tqUbR5FgUsAt
evcfhlXTsC01Y4u4zdCSnBQwzNBdD2xNtTUJQxjltHcopkAsFgsmJQzgHjfd Z5ht8pJymaHh
zBl68FBGAEGGTjWbPQ+EoT+gNAmQXEQ84jFO8RqNy5hAmNIm1yvJ1poaCaZF TBJgP2uKmOaO
0yJm+TrD4FZ0Q9su5Q81a089zFFTfYqZUXNJ1dL5+czIClStJo2V0Ao3tdJ+ p5Nm+hoRZ6qR
jjQ7fi6tvkDwGnGNNb9pLikXlrEqYOWSkBMnRVvLy1jDOqWsWdaFknUzHKeW 2NQYTc1HBGxQ
JFf7tVLSc1nNEhEjfUXX91Y3Y9sbI/H13cTO9vyIhCj6+Y8i4xW2SQRqoaAZ VPfxZnVvUMMZ
e4RTxGW8xi6NhW3WLhn8gUYXwu6B1Lp/PiWX05BxwDUuFLgpZ1ChE2bJymhR nXfNXe/BBHfG
KE1QK/05EI6PEa0CnVogklWEi6ykQbL8dnbAlyrkVAXd3+Gtoifl662gbytU xUDKN1jFUMqT
bm2rYKS29XR6hulQwd0yHtRAIefmrQNitYtTeENljB04fI/rfFP/wzdzPd83 J5En9Bui4EHp
SJSKnybkGbqwi26kaUqz8OIDfPhEQ/eZkp8jpEyp+vERTwnJS+O5KEOYVl6G 9lAF8/UHOhxj
3ZkAiGCBVheeY5FQtaq+cEiW0Ab+GTzFUhXRlG+zgpcUdRlbZeyUkaD91wtu iVagD/30nXOs
PKQ3zi71F1BLBwh4NPxFEwMAANsFAABQSwMEFAAIAAgAJ3j2NgAAAAAAAAAA AAAAABsAAABt
b2RlbC50ZXN0L2J1aWxkLnByb3BlcnRpZXMrzi8tSk7V01OwVSguStbnyi8t KSgtAfOTMvP0
uYCEXmZeck5pSmoxUMzXNcRR19PPTV8nhksBFehxAQBQSwcIH3Tt+TwAAABM AAAAUEsDBBQA
CAAIACd49jYAAAAAAAAAAAAAAAAoAAAAbW9kZWwudGVzdC9zcmMvbW9kZWwv dGVzdC9BY3Rp
dmF0b3IuamF2Ya1SXU/jMBB8dn7FintpK5H8gAgJuJ5QETohPp6RcbaphWtb 9rqAEP+dTZym
BXS6A91TpM3MeGZ3vFQPskVYuwZNSRipLgq99i4QuNCWqIz2EcukS29Sq215 ch8pSEW3i8t+
UO/DXWx1uQxyjY8uPJSnyTYGfzpL+NQJV7NZATO4WSGwgt5IcgGUkTGCYlBw JgLxz+6pQ23B
6CWCelYGmVYVPt0brQbCySjA2mgbnnxwBi9FIaqqf26ruJgXYpCJJIk/S22l gWsK2rZweXF7
tvh9t5jDERzsdnJQ75TiSgZsQFvmW4UsFzofuNXb+fLDfgRzObgYknNS9pkU Q7pZNRoamZMp
Wxev3ZuZNrHOHp7LjWycmvaT44j4jwf6wcYCTf52nul7MxunG8jMd7D+UB2c DxXcY4RfTwo9
adetW4iYPIYy87ZI3oDI3nirtNKx/q/hnP9mNiZ+JdoYwSZj6r2srLMXNSfL 0a6QUrC50596
AxlzHHrQnzDVx77u+tUizXEpk6FcGDEojb1jK6/FG1BLBwhqnM0TjwEAAOID AABQSwMEFAAI
AAgAJ3j2NgAAAAAAAAAAAAAAACcAAABtb2RlbC50ZXN0L3NyYy9tb2RlbC90 ZXN0L0NvbnRy
YWN0LmphdmGNkD1SxDAMhev1KVQuM4wvsEMFtDQ5gTYRweCfjK2kWGbvjryO F4dJQWc9Pb3P
0oT9F44ELgxkNVPik1LGTSEyfOKC2gTdUTRozQXPlk6b5szG6hdkkdU0n63p obeYEjwHzxF7
BnFbcuQ5QRsD3+owRbPIKHQcjR/Bo5OYu5pTITFG/iuSH0QSsQAr6tjkPBbn ewxufXJ4yMwD
f5ikswWeKvGq7llrxEj8Jr1jGYnEc/Q77iWYAdLqbej/Id0+JZwub7gF1aV3 SMX9e5qGdKsF
tTNdWa9+2JLKJXc42Vlv3TCkEkKduqofUEsHCJhyZJHoAAAAPQIAAFBLAwQU AAgACAAnePY2
AAAAAAAAAAAAAAAAJQAAAG1vZGVsLnRlc3Qvc3JjL21vZGVsL3Rlc3QvUGVy c29uLmphdmGV
UttOwzAMfW6/wk9TKqF8AGNIiMsTQkjjB7LWG4E0qZy03LZ/J1m7rKNl0x6q xPW52I4rkb+L
FUJpClTcoXXTNJVlZcjBm2gEl4bPkaRQ8lssFE4PkrWTit8Qia9HGZiD3J1w npJW9ULJHHIl
rIVnJGs0eKzCErWz0DeAnzSpSDaeCHNHUq9Ai9KLxL/R7+rWaEcid9eQdzcL M9D4MYZhmdfw
Km0pbRGs55AF58S9SstDGIRa300aWR18he7J51hLIXQ16RF0Y2QBtsOe6TTW pLfdBfbQO7Y/
XsCedXR2vbr68zwmLopiJ8R2l0gY0+OewSJgq5gcShKWpsEzVVvSv8KnpvlA pnwxLGwrlFKH
8wLaSHyGszUdk6HmxMolS0MMBm1c/n3O1iKRSxYx3EPmTpBjGV+g10HWVZfB ZAKsj7vXhReZ
+VpqpWC9hkGSi6VDYrGjaJlQM3iWJMxv++23jJrtWDfpL1BLBwint6raZwEA ADUEAABQSwME
FAAIAAgAJ3j2NgAAAAAAAAAAAAAAACkAAABtb2RlbC50ZXN0L3NyYy9tb2Rl bC90ZXN0L1Bl
cnNvbkxpc3QuamF2Ya1RXUvDMBR9bn7FpU8plrA4X3QqyJwfIHPs6z22YVTT JiS3kyH77yZt
N9QhKviU5NxzTk5yjMhexEpCqXOpGEqHA0KK0miL8CzWgtVYKHZlrdg8FGF4 MLsWKL2GmPpJ
FRlkSjgHE2mdroIC3khkbLH2LHAo0FP2buct7RJMszq4gEq+Hs5pMiARiTq5 N4zaAZhO0R5p
PNdlHLiRYSLPh7pCKzKkgbI/xEsepwEJwelpL+2lPPkEcJ72eZL8bHT80Yh3 RrVSnbR9VDCg
pkEC+CXxIte/SNz/r8Qnf0u8Dd/eFftteSuJ7dbRpClntnEoSyatZb75CpV/ 581oPry7H9/C
ZDSdPY7PIIajXe3N3VZibasd1Ny9Je9QSwcI9wCK1BgBAACeAgAAUEsBAhQA FAAIAAgAJ3j2
Nj8cV6ijAAAALAEAACcAAAAAAAAAAAAAAAAAAAAAAGF0LmJpc2NhdC5zb2Np YWwuc2xpLnJl
cG9ydHMvLmNsYXNzcGF0aFBLAQIUABQACAAIACd49jbA52Vj8AAAAJUCAAAl AAAAAAAAAAAA
AAAAAPgAAABhdC5iaXNjYXQuc29jaWFsLnNsaS5yZXBvcnRzLy5wcm9qZWN0 UEsBAhQAFAAI
AAgAJ3j2Nk3na1KpAAAALQEAADEAAAAAAAAAAAAAAAAAOwIAAGF0LmJpc2Nh dC5zb2NpYWwu
c2xpLnJlcG9ydHMvTUVUQS1JTkYvTUFOSUZFU1QuTUZQSwECFAAUAAgACAAn ePY2qU02C/0B
AACWAwAATQAAAAAAAAAAAAAAAABDAwAAYXQuYmlzY2F0LnNvY2lhbC5zbGku cmVwb3J0cy9i
aW4vYXQvYmlzY2F0L3NvY2lhbC9zbGkvcmVwb3J0cy9BY3RpdmF0b3IuY2xh c3NQSwECFAAU
AAgACAAnePY2H3Tt+TwAAABMAAAALQAAAAAAAAAAAAAAAAC7BQAAYXQuYmlz Y2F0LnNvY2lh
bC5zbGkucmVwb3J0cy9idWlsZC5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgAJ3j2 Nuwja4nrBwAA
EzkAADkAAAAAAAAAAAAAAAAAUgYAAGF0LmJpc2NhdC5zb2NpYWwuc2xpLnJl cG9ydHMvcmVw
b3J0cy9UZXN0UmVwb3J0LnJwdGRlc2lnblBLAQIUABQACAAIACd49jbMv3Gh nQEAAAYEAABM
AAAAAAAAAAAAAAAAAKQOAABhdC5iaXNjYXQuc29jaWFsLnNsaS5yZXBvcnRz L3NyYy9hdC9i
aXNjYXQvc29jaWFsL3NsaS9yZXBvcnRzL0FjdGl2YXRvci5qYXZhUEsBAhQA FAAIAAgAJ3j2
Nj8cV6ijAAAALAEAABUAAAAAAAAAAAAAAAAAuxAAAG1vZGVsLnRlc3QvLmNs YXNzcGF0aFBL
AQIUABQACAAIACd49jYiHjar5gAAAIMCAAATAAAAAAAAAAAAAAAAAKERAABt b2RlbC50ZXN0
Ly5wcm9qZWN0UEsBAhQAFAAIAAgAJ3j2NmwCD0KeAAAAFAEAAB8AAAAAAAAA AAAAAAAAyBIA
AG1vZGVsLnRlc3QvTUVUQS1JTkYvTUFOSUZFU1QuTUZQSwECFAAUAAgACAAn ePY24FCV4+oB
AABOAwAAKQAAAAAAAAAAAAAAAACzEwAAbW9kZWwudGVzdC9iaW4vbW9kZWwv dGVzdC9BY3Rp
dmF0b3IuY2xhc3NQSwECFAAUAAgACAAnePY2ti3Ru/EBAAA+BAAAKAAAAAAA AAAAAAAAAAD0
FQAAbW9kZWwudGVzdC9iaW4vbW9kZWwvdGVzdC9Db250cmFjdC5jbGFzc1BL AQIUABQACAAI
ACd49jbU+lL/wQMAAHIIAAAmAAAAAAAAAAAAAAAAADsYAABtb2RlbC50ZXN0 L2Jpbi9tb2Rl
bC90ZXN0L1BlcnNvbi5jbGFzc1BLAQIUABQACAAIACd49jZ4NPxFEwMAANsF AAAqAAAAAAAA
AAAAAAAAAFAcAABtb2RlbC50ZXN0L2Jpbi9tb2RlbC90ZXN0L1BlcnNvbkxp c3QuY2xhc3NQ
SwECFAAUAAgACAAnePY2H3Tt+TwAAABMAAAAGwAAAAAAAAAAAAAAAAC7HwAA bW9kZWwudGVz
dC9idWlsZC5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgAJ3j2NmqczROPAQAA4gMA ACgAAAAAAAAA
AAAAAAAAQCAAAG1vZGVsLnRlc3Qvc3JjL21vZGVsL3Rlc3QvQWN0aXZhdG9y LmphdmFQSwEC
FAAUAAgACAAnePY2mHJkkegAAAA9AgAAJwAAAAAAAAAAAAAAAAAlIgAAbW9k ZWwudGVzdC9z
cmMvbW9kZWwvdGVzdC9Db250cmFjdC5qYXZhUEsBAhQAFAAIAAgAJ3j2Nqe3 qtpnAQAANQQA
ACUAAAAAAAAAAAAAAAAAYiMAAG1vZGVsLnRlc3Qvc3JjL21vZGVsL3Rlc3Qv UGVyc29uLmph
dmFQSwECFAAUAAgACAAnePY29wCK1BgBAACeAgAAKQAAAAAAAAAAAAAAAAAc JQAAbW9kZWwu
dGVzdC9zcmMvbW9kZWwvdGVzdC9QZXJzb25MaXN0LmphdmFQSwUGAAAAABMA EwCGBgAAiyYA
AAAA
Content-Type: image/tiff;
name="screen.tiff"
filename="screen.tiff"
TU0AKgAAyxaAORzu1/gCDQeEQmFQuGQ2HQ+IRGJROKRWLReMRmNRuOR2PR+Q SGRSOSSWTSeU
SmVSuWS2XS+YTGZTOaTWbTecTmdTueT2fT+gUGhUOiUWjUekUmlUumU2nU+o R6BQSo1WrVes
VmtVuuV2vV+wWGxWOyWWzWe0Wm1Wu2W23W+4XG5WupwW53e8Xm9Xu+X2/X/A YHBYPCYXDYfE
YnFYvGY2tXXHZHJZPKZXLZfMZnNZvOZ3PZ/QaHRaPCZDSafUanVavWa3Xa/Y bHZbPabXbbeh
abcbveb3fb/gcHhcPicXjcfkcm8brlc3nc/odHpdPqdXrdfsdntTrmdvvd/w eHxePyeXzef0
en1S/uzd8Pl8gB4O94AB9fcAP67ev+bMBACgwDQEAAIAiCAAAQA4Dv7BkGwd B8IQjCUJwo7i
Bv2mp/w0AB0HSdIAAOA0Fg0DQMwrE7RHMcxzgAfJ9PiDALguAAAxrFEbxxHM dR3Hkex82z2p
kf0hgAchyHKAAMSUAAHAcBsfygxR5HkeaAAB0QMABwOBsAAKFACGQ2HQ+IRG JROKRWLReMRm
NRuOR2PR+QSGRSOSSWTSeUSmVSuWS2XS+YTGZTOaTWbTecTmdTueT2fT+gUG hUOiUWjUekUm
lUumUByOd2v+fP2qABxuRzAANhoMgAGg0GAB3O93w8JBEI021Wu2W23W+4Ru x2WHWe0vN5vQ
AOVzOcAB0OBoAAPCXHDYfEYnFYvGY3HY/IZHJZPKZXLZfMZnNZvOZ3KU+o1O q1es1uu1+w3O
zWjPa3Xa/YW3VXXWXi9Xy/YDBYQB7Hfb/gcHhcPicXjcfkcnlcvmc3nc/O6C pT2qP2rVitVy
vWCdvh5PEAPrBgAEguwgXewx+u4ANBjt6CjkaAAKenoff8fmQba932/sCwbC v1AcCQLA0DwR
BMFQXBkGwdB8IQizTpNE6zSOy07uJmfR0AAXRSlEABsvAiIFgAJo0DWAAQAA bQAEmTBYAAJQ
0DsAARgQyhxmIT4AFgZh1omCYUCEAAniQ+cTP0e4AGKUZJgAZx2okAsbh2J4 ACOGoRPHCThP
43D/t3AUvTLM0zzRNM1TXNk2zdN84TjCEKOo0bsNM7awok6aHgChs+IdPyKH eaxWAAUhdH4A
ArDULAAAsAcmHMcR1AACAPA+AAFn6+BOksW4ACGNUVBAAyIUAhtBI/VCGVUj 1WABVyInGYBN
R8aAL0WNAjAAfJtGEABYl8aIABeKY2gAHwOgSjdYVkjlnJDaKIH6cxggASxV GyAAoDUMy/1M
AFpobJhhE1KBog0JIADKIwPAAcRlFkABcmYdgACMMo4gAE8lVeiNn2bgFpYG kFxnMYlbFaaw
TgANAzB+AEq1PgtV4qk1x3GiUwP83UAvtOWQ5FkeSZLk2T5RlOVZXljkzonj quu0rtAYBl/J
gdJmFIABVmKfd8C8LwABMCOQIgfT4E8S5cWKIoXgAapdmMAB5IaE4fC6AAih iDCGvEbpiFmA
Bbma+CHAUDgbAAJwoYiAZsliABVGcCgAC+LgdgBHL2F+UEQnoFlHCaGmun6d 5oAAUpWUqKF2
gAByKnGYJLWCbQUAAM4yyKAtOAAShKFbfgljTrQST0fsgmEVhSgAaR0Z/iSu iSLgsxuBzenM
ZBUyaesWAudhj9b16GAfLgmCkKEV9u9T2GSWHQmWch4IeDYZiYAAmB4FOJAB JhmlTnZ3BGFQ
AHgYupncE+IgsbNrnKiILhmKwACqHlMopcpNkoABuBEKYAAxBDS41RxAlBPi 7AADUKob0bjs
F4AAVovxqgAdgQwApXQjBZdq0R3DuneAcPoOxqY1R2tPDCGcGIABjCjdYiOC pDALgweuFIH7
2wBj6feK8UIxAAAhBu10ZwvxlAAHs9wGQSwqgAAU3AAAxBuD1eICt+gWglAA AuuEfY7Bro+F
ULQAA6XYAFAw2oLIV2IgJHSMUAAmRUNTIglUGQUgzgAB0BovTqnWOujC7J2j tjej7HNGoU4v
ooArAy+8Y41EmBJDOGo8g1xbAAFmMKCcFQHAwf+F4H8Ayaj0HpFBMLHjeMtl JKWU0p5USplV
KuVkrZXIJZeTtmKF08AKAWAoABZHpm0AguJVKfyMqqH+hwAAvBRM7G1EWKwK AgqhCGDNSx6Q
AtIAAKcTArixH0AAEILQUQAAMHA0wWQxgGgADAG6Ko+hpu7FML9KYQQtBhAA CkBxehgCiFCA
AawDZmuOAAJsUcPAkBmgYCMeLUxKipjcA5tQaAwA+AAtZygsh40QDWE4Fkvl WzAIYOQYImwA
CyGi5AIoUQagAHYM8XoABnjglwE4MwWy/gIOsNMVojwALAmaGgKc0JAigpCN sEwAAzBgB0QK
j9IRongBED0KQAAegjAOAAY4qhTotASD1hwWz5jXpuAAYI7wXAACwF4IZXh6 jbAAKkUcXqsh
fAAFMGJYRiCgEq60eSVQcBOCuAAFAGAJHhG80wUwvBvgAB+FcMCNwIlhASAZ oyfE/LlE5Xcb
AGgkAAC8EJuozhas7GeOUDtZA3V9AIOOtQ8wGKZA2BE8QwxOCYf4CV+YYQfr vHLUkWNSwAAe
B1U+GppwEJMG2NxJgIQTkIHyOAXQABQiyHC9gNAZbej+PgKQTU2K82jCWFuz I9xiOsF8NyIo
EgXvXCWDFUwtRQTYAoEsNAAAiAjSYLASU+QAg9rgE+udVK7AAG6Ch2oXAcAV AANgWwlwAXjB
CAAKIYwigAAqAhUw2BYU4p0w6ntERi1AFlUJdlRgAD9HGL4AAnhXjOYkCCrQ UwgRSAcA5Jgt
L74jv1XEGID2qD1OsA8BazCHKwIlMKX5DCxy7IaWiXo9h6xFlCgCUcr8pZTy plXK2V8sZZy1
lvKUsSdSzTudoBIClmDwHeiSXwEAIy9InZIjNkjxDhGgtcXYwxpQUAAV0JQY gtAAA+Aaw4oJ
rwJC2HMAAK7AwUHHAgTiMgABhDaxEbIqkoDLAgE4AAZAiglIePscmjBYFZCg Gh5I0hMCcIYE
oMgAAXDlRkLUdGQB0pMCQGV5I2RN6oAOt0AAPFlkUOmOQYU+RZjSXuAliY93 YA6C5oYF5aT1
IdFiJZ1g5gFFdA9hMAA+B32HHUPJ8gXg2rrHeL7BQuB+WZ01g0hw8hrzYFKL 2coXg1AtAALj
ailglRzCGCNPR0xwi/wULYcbTwyBfhSMkTDlKK6rCWCrHRDh8DiF+AAT4sRs IzDQ6QD7EyMJ
MGOKFyg0GqkPASBesYQQkJFA+8s9QABzjacQNkcilR4jfGtLkENTwwBCwaOT c0kh6UQDSE6K
RDzpj9Hk+8ag1OcjsHiWUbQ3WqhHDLqsEQA9AiYbEDgMIbq/JKHwOFUAnxZg E0eG3CKOTxDE
EwlAfISI5hAARzkTQqxhnkAvaPbT5RwjjaoCPTAaQlac2FqgWY1gR6PDPM0B A/tpb52ttjbW
3Nvbgs0GxdYA9F8WFiPgAAWw2hNceQ88QztKAAGSOlKoHgXMRB2Dlp4EFwsC o2RPM2SE/Zqx
0PceyTMnpjaNlz4nxfjfH+R8n5Xy/mfNKNl4nOYGZldAR9WX2Qsi0aVj9v7G biGfeIYPiw4q
hOoyAQD9rITQTjzAAKITVzQgBjjmB5HKvRyQPFA3Gcwa6IDXFOruGcAweSDG CC3Ya8HIGAxO
Fi8ACYDMayH6GAEybGHYIQAsHmfeBOCqfmHeFeqAHaA6wa5iZ+CqDWiSAmIi /AHIGHAkFoG2
fIDKDEPmYStkGuASPmDAC6q0AOH6HSkkEwFM22BcV4B+BInKH2OsMGAMnKAs AsLSHIF/Akge
XXAIXeIcHeGoFWrWGCLSC6DQe2FqEwFUisCYviB8A+WYVU4DAkFuHIfJBwPm GSE0tkH4COvi
CHDO+0Hy/uAA/yG6AACS/kz8/qIsKkSYGKE8tkGyBCeSDFAK+2IkigGIFGVs GoAIe2CMCGhS
HoGVCyGWAOCWAAwgwbDUmKH4V5FE+0HsHDASraGeAABKB49IBaAmaqFmFiGW AACDEC6ysOFC
/eqhF2/qHvD2FC/0DADWCIb0e6rBDkABDoW+CAAS5yE2FWh4SIf+BOnKxGIa AMAWwNCaWZFI
FuG2YaDADMCAABB3B6FnB/CCV4CBCKPDCQAHCUUfCagpD2FAkinMDNGTEGWo 5gGuiGGOGGGQ
AAHUH2waCi1IUemkIqKkyI9u+0IgT8T8HxIuP6NyygTI+dI7I9I/JBJDJFJH JJJKTg+gJw+k
QwAAAMAOXC/AY1BQ+yOmHmHIG4ao2uK0AkRMH6HmW2FUFIVAAu6sm2A8UqFG E2gQB4DCW+BC
yAHwHGgeFEbEs0DVGSHqGgFQggGMZ+CQC8ayA8AWigGYFapAGcH4byDGCwpO H8HOh4E+FeGY
gscuC4DIsyHeR4AAFqGmPAASBSSwC7Ec6RJmIYHKYTL0GwS4C8DJH8HizuE+ FMxMAYkwfojq
n0FgSgGIHeoyCmC5GSAmAIOsHsHm9AAOAcRMHQGGR6FqGwwMCWCsXWA2Ac9A GSFSpAGiAYV4
DMCYYaGmFYSgGOH4PmC4CwB4iUHosOFeFEbjOEdqCqBqx0GEtjGcXzKKSUUF B5FwE6FaiGB+
C0viBOAfIcYoVa9AGKE+tkG8BBMBME/AH28AFOE2dCAYB8rgCaBQOsGEFGZ2 G6A6euDCCGBI
XgGCVsF6H4wjQA3YUEHKGNNWGgLSUYeSRageFUF4PgCKC/KaAKsOFGE5KVKY h6/qHwHLKkXn
KrH822pyE3DnOqCEA8SYFuEuZ2HYBMV4CwCGfIAKmmAAHmigK8AUVMHWGfK0 FeGQLCCsDSeu
AgACOsGtMwibM2rjM8ABNBNFNJHSAaRMH2HDKlH2C8DTH8VUH6lAHMSYAwA6 bqH8Vo4sFmgm
CKDERUBCqnIk/AT2Yq+8H0HyPE+CY/JNT9T/UBUDUFUHUJULUM+eKg+wJrJU TwAIAK7Q9tEe
+0YCIbMMqAFuGo5KIiASA8bUCcCUBwK8H2HArWE6geBsDA1WBDREHIpWFIFy IYC4DGrORy9A
GmFyZ2GSG+mUIcASRYCSCo0wA2X9B5L0E2d2HwBgm8CmBwtGH2HPINGKiGBi CkviBmAs9qIx
UsbGG604C4C+bzEGHcGkXmFcGNVIBpWqAABhFohUFbCAGsPYIgASafW+YiHa rqbGW2AAAIH2
aqUUIaATQECeiowk48HwKyF4FSUMHASY5Mt8wcCUPmlw9AGNF8V6/jFyA+Zu IaLKGGFKFGRE
/YK8BYm8Cu18Iq9AGVYuG+BHZNZQIoPEGsFzCAGMG/U0SqAyA0cgHOHMSmBV Aaz8HAZ2F2Hz
GSDACGRYIcH8HaGmmqFW4rYdX4AkIQAbAulyAJXqC0UyFjVMABVRVVVZVdVg ABVlVpRSGME6
VtaMDHY1S0Ha5yFsFWgeSDXmBS0wC2B+RYH8Hg5yFWFQgfZGABaAW+B0AyL0 GNXen1Xk5NXq
C+YiABVaUPbJbNGUIbPeggE6FelyIiAiBSCOwcB+YaAFEJMJIkIyH4H2UVT4 yjUPdddfdhdj
dldndpdqy1JQJvUYO0AEAHdIIxIiT6o4ImT8H8H2SZIujCWYAUAQ48yC+zed dPIeABeKHzHk
N6+rUhUldLei+/efele5Umzfe8H2HwSYOs7Q+reaKsGEE6AA4qwiC8B8IQHs HsZ+AUAVTne0
InfJfNJYb0AQPtTre/f1fIPEAGwoISIvgFe7fAIhf4IYAQWZYPfLJZgjgTe3 EeH6Z+HwH2Kk
+qXCH69AHwH8SreZgDe9gZf02BhRGc22HxYAAHhKPRJkIYUVg5ghUffHIwOt euAReyYDgWIj
geH7Hob1hnhSIteAUDeEIoH8H6H9IyTFT7dtipiritivixizi1i2OLdwJtd0 K6IcLyL0IcZq
LDeBjQT+UEACYziRefiVdMY1jhTpjddPjnUkOnjliZjiYvjvIiVhAQpAF6H6 rPaQk5j5IpiX
jrjxkWVdj8o5j1kbkhj7j3jpInjfkrkZkvjtkzj/kpklgZkjk3k1lFjblHkd k7khjXjzdNk0
AAk9jIIaLAT1UqY7I2+Hi5lzl1l3l5l7l9l/mAJLi9UWTs+mxHidlek+IeZr Y5gbgHiAmDfF
d/mkIvUphpmrmpiTmyIheKV7iJHTiOzbmiIxUVeDnJnHgVnRgxm1nPmnnbmx nfnZnTndnnnh
nrmthWIck9R8IbmYMHd5iilFI5mDoJoLoNoPoRoToVI/mGJpjAgoH4UUskH+ VYACT9ooVbjZ
UnlYYKyJIrowyDos+5lOmBo+VQH/pFovpJe7pM6RpS+vTu+3jZpPpeKljbpb pDIrphkTpYVj
pBjVp1ptpjpxqBpHpvp9ppqDpWl9qI+/prqXIhqRpdqVqPpnqnqNqHqlpzqx p5qZq1qLpVqr
p/qdqpqzqtq3rDrNrGXFqeYzorjVTppQVimFqTUlUe7RdZoHoXr3r5r7r9r/ sBsCQloaJmZi
HIHIfeAzsUPCH2PE9uyE+8UFomyLpBpEmBopjXhpotiDptrlhUo1s3hZs7sz PJtDfBtHtPoz
s4XFs9mhrntXsxtTtftFtZtJMHtntTtjs+OntNt3trtlt7mht1tduDJluHs1 o1tztbuRthuX
tLuTt9uPufubttehuKYpultvuvMHtjsso1udiRgWVcKkAMAKVMHPvQIKIPin sFvbvdvfvhvj
vlvmMbsIJkZiHVvzHSAORznLvpv+JmVUHyHy9BCYAtvZwBwTwVwXwZwbwdwe o7USJ8H9woiI
9+aoO+AAHqyblHwhw8I2VUAWluceAcx1fuWYIVd9w/xXxZxbxdxfxhUBvsJj ooKkZjojolpB
rXxjx5pTpEAJyBT7otnxx5yLyNyPyRyTyUTdxmJpxrtZs7v9yXw/yHrnIru9 ynyzy1y3y5y7
y8OFyby/zFzHzJzLzNzPzRzSMvzDzVzbzdzfzhzjzlznzoIrzZzrzxzzz1z3 z5z7z9sBzvz/
0F0H0J0L0N0P0Q+V0D0T0Z0b0d0f0h0j0kQX0X0n0t0v0x0z010304Ld0r07 1B1D1F1H1J1L
1MIj0/1P1V1X1Z1b1d1fzR1T1h1n1p1r1t1v1xsF1l1z1517191/2B2Dxlwl 2F2L2N2P2R2T
2Vdv2J2X2d2f2h2j2l2mQj132p2v2x2z212324LaICCAORzu1/gCDQeEQmFQ uGQ2HQ+IRGJR
OKRWLReMRmNRuOR2PR+QSGRSOSSWTSeUSmVSuWS2XS+YTGZTOaTWbTecTmdT ueT2fT+gUGhU
OiUWjUekUmlUumU2nU+oR6BQSKJNIIqo1mtVuuV2vV+wWGxWOyWWzWe0Wm1W u2W23W+4XG5X
O6XW7VypwWJ1asIi/XfAYHBYPCYXDYfEYnFYvGY3HY/IZHJZPKZXLUG81Wrg C/IjL5/QaHRa
PSaXTafUanVavWa3Xa/YbG3Zm95vO7Lcbndbveb3fb/gcHhcPicXjcfkSzaR K+Zy/8nodHpd
PqdXrdfsdntduIPh1uYAO4CBIABoIgjuen1UXlxHm7f1/HEPMAKAoA4AGFYw wggBVmuWwACo
FD0IQfBsFMAAEhSLaGk+aR5AAMAWga+ULQvDEMw1DcOOw+hTC6/AtlIhQuQe ABRwmjJ8G7BI
EhJBqEFicB7gAJwPwKoB8HeAB3n3CoIgaAkOyI1z2og97nyLJa1HmbAAEGJ4 UgAPxfoYJ4AG
EdxYAAHoIoUfh1l8AAZgsIYAD6a8IwHCsmTdN84TjOU5zosh5mSAD7hwAD9o MJ5ImaABYDcG
SMnmaZMgABwXDQhJIwgAA3Qon76FAIT8HGQ53TQG8vzrT7HSOh8ks9UFTKeb BQC6AAUjDEiG
hcQQAG4Zo+gAEchoO+hJCFVYbljLgbzbU9iWLY1j2RZNTnwZwAC6BIZgBV4A CeTBr0EM4UI2
dYAFwUxXAAcIDBUAArCoHoAU8nZ8AAXxFCwAAhju/ZMGlGozhbHNlX22aBr0 5jbSVfmBpvRA
oAAFxUwqJ5fxJPsSk+8MU3THoAV4MIABjYEu2GAB+AAbBcE6ABHkwVIAGQb8 rGkAD+jMJYrg
AM44i+AAZAqfYAFYPQ1T4doKAABR7IMH4zCkAB5lIP4AEsZB2oMCc9kSTZCA AEBq4iNQ+lKA
GngmAAljiQ4AEEMAbgBXIAHwc08EWO48yoUkrBcIIuAANQ7EBmQkBHgm/b/w HA8E4r6Z3npY
5/oOhgBouj6Tpem6eAGogBqeq6vrOt67yewbFsmzbQhB3yeTJBEKAA0EhaYX AALg8jiABADy
MFb2HZlnWhaSEywLgnm/aXf5aHEGkiRA7AAFtPH4cJcAANY3lfyYZg4gx3Rq Hw2D8AG+PRte
27fuO57ru+873vqEnmbr6kPvQwkPlggiDr4HBeJEqZ4ABvDlCoq2mg7dD+gT A2/YTYn3jq4c
HAkp6oiHKkgVA8kwzleAADoAcSyfAfrNAcgwhoQREjCXaHYGrFghLwY0lwHq bUDigQUq1PzE
R5EAWBcADFPRGABJQ6/AAAFyRADqaJuAANcK4AA3EBJADShkehhmRKJAD2Up 3ACkjsfhhBOA
AQQlaIAPyahcfTDSeQAM4YZYAIQWIYAhcDZrySwAeCHHgAIaHjqRZDuABuG4 RldYrNardcrt
er9gsNisdkstms9otNqtdsttut9wuNyud0ut2u94vN6vd8vt+v+AwOCweEwu Gw+Ivj4i0YjU
crMhkclk8prMtl8xmc1lc4nRnEDbABdBwzlEezoALT7UwA0hoj0ubj7R4AEb 8Z2iBOlUkrJ4
AWLI16/M0bSEqhiCADgf59AAfjzhXyDAAgIZ+laRZtTNwdZ8/oNDAFFo9Jpd Np4AqPbF7knY
JFwATUeVbgqYdVJTAA4O82MyxAA3RiVMUQ4GFj0MHAny9aIM3PCoLQjAACGJ hSFYWheGIZhq
G0fOQ5ztP9YiTJAigAIiJ4cimKoriyLYuW4ziSEIABhPgjAANEdgygAsh6AA JBPIdWx5LEwg
ABgnnyDEoyjAAPQNQw8zTJlrQua+CAAOU/20BIySSAACQ4G9Hm+Mg8iwRgBW 4F1ummQwTyJM
gACwHYNwANgmRdAAKRobxDR5co0SGc48zDT8Dg+eFDHZVMPDEgYMxvf8ABPJ gAD3LAZ5ZKam
gkFt8gAHB/2zE4AAEi+qKpqqq6sq2rqvrCsayrOtK1rat64rU+Jrm2fqUnGc 51neeZ7n1DAu
oA4KCoShhCoiinpdoABBMtE5Wn4QUPO4vkTBE+DTbl8K+GYpTXAAmRSPZuW7 mROJzGcLQAO+
XgABKYmcTlOwtlCUpUA6VnYtKjqQpKb6WpimjlpyP6fgh/zPC8qwADEYZ+pW l6ZAA6SsHF1B
VJDDgAPsiwhjQBbiac0j3vqE65y7L8wzGtYeiCIokiaKMyzrO88z1YoxjONY 3jmO0fMMiozD
5/Fdb5RpoDKUEMPg6wAMkwDBAA11TAADDzbggxokJx5vADTgADKarrm6lHZn Mbo7lOerXwYA
JnpoDa72qvnZOJrSCB6NKTWNDgAO5EgAVfPuK4vjON47j+Q5HkuT5TleWXje Zsuyb9tLDbwA
3FDbGpSlt2RTma9R7fGtI/gMVR4QaWtumreNh7gpfFHguIKCzRHUEN6mTnef Pg2CgmAKYGR+
5LmJkWgoAC/ZVlfqjN30Dt/4FZQuiUjghHYABy4LF+mlA+AAOs5lTAgFgaRR t/Bou0tv4nl/
2/f+KxzSIVhiOJUTiIfzAKAcBC0tARojZHCOisjvAAKALoEkaK+N62VM7Z2o gAMXA4QQfEaC
HN4EEPInwABXHabQNAmjjtNgs2hXjm22DNbc3BYjc1pulF83d1EL3VgHeyGh wQLiRjlGaHJe
o/B+ErAIARCcSoCxOifFCKMUopxUirFaK8WIMwubWE94cM25Ojdi3WHDp4tt 7esACHrgIfuw
W0txxAABwgAEGC8EBMzjqiUuIcDgAAyupc5DFzyOx+DhFkAAGYIDfHHDyLcc AABDBIOe9Jf7
1H5N9jUACNix4hREiNEgj8Sh9gAE6FQB0mYgEjIi+ACpXodNrOyTpt8GIsy0 lrLZ/bNn/s5l
tLyXqtBpoyPFAlohXB+DdAAHoAoJAAJCI/Ctp7URktIP00skAABuD/SoAQUy egQBbV8QNlST
V4xmeFIFz7oYavkYy3icr8ipgsFqfk6xNiGgAPpDEKgH1TpRAAM4ZI5SGg3e hPyX1BqD0IoT
QqhdDKG0OVfK5X0XZzxfdExZ0s7KIvVKmDGeQAAfB+JtOuHJuAoJtfGu4WAX 5ROai5F6DKU0
wMAJuvleC/KYyUYDPCj09HdT3HBPmfZHh5z+GS30cQqAtAACicanwsagAACd UIj4+B51EAIA
U0IYY/gATiTpYT0R8JQAay2h9Zqzqylw/1m8AK0VureXho4L6PjnOmPcR6pa ylbHWoYKAFlE
n/mfBd84sg4p2CfU0lgABMCxDUncPoVQAWJWPV0WMIw0hBIYaM0r46XpTCg6 JwRsTZm1UKT8
CSiZ6qMRoAAVRrQZyVWOS4XonwpAAGoI9RKY2JD3FGFRCVcLg3CuHcS4txrj 3IVq14AAUDSG
/nNDJ0AmbQJWtFNe0gI7TBCtQtC1YagJqGALIl2AABerbJ+Pwi4LwLEbI7Zk Xo6hfE/AbO4h
geUFj/EMjMaYoFNAuDCqB3aWRonNfclGnFM6N2stca4rALrZ21tvbkAFu15B 7Ho4h5JWSBix
GaHsAAFxvCiP0FUds1x3hiAAHMCIOLnrHJCAAJYyCTgQE/V9qFycc46LxWos D/mcQBx3kKuF
RFOFMU+2M2DWa7gABRXorCUnjr/NoMIeRMknkMIsdMjR1ysWZEETAmZNCsBc EvYsAAaZMwTI
/ZkTApbQCpC2mOery0FAAB+NFjoW7JkfnDb0AABRdHTBSE/LpWgzQjHKJkMA AMDZD0fpDSOk
tJ6U0rLXIpowATfK1m3N4AM45zMhnbPGes+Eez8k0DA1jWBXBmFs8NmbMkLI Wb4VY0oRhUBa
4kfAySfphAAC8kQABvh3JON8IJ8BpC/JUnAjgn3wa6Kwt9Kh77Y2rfoncWWg 9Clc0QlnRejT
oC+S+E4IaY8kkfJcMgdQiyMAVZXkbTUKSVhBd4AAXQfUZ0F0tvzS2PSv4/rb v3geQx3jmHMq
YDT7pZkeH4PNqg6h8KnAkBUq9ZeH8I4klDivDEK1VfQO6oiYII8VyfwTk/KO U8q5Xyzlrj+H
AAHMOUqcogC4gA++7k3DXojviQA0CLLeYDmHVyIAqUANAVgxA3bQeJ7j3B+A AOwTx9ENQLTo
qgMn6ke4+OvkJDAE8k6AWAfEDRzDpJ0AABUpukdaKzEgeY74GvnQnxzl3drj 7/K9wGXfd++9
+7/4DwPgvB+E8L4aKdpgXrPI6QMW4wihBJB88paYABhXnB723w/mvN95K73v IPm/Q+i9H6T0
vpvT+o9T4WojHCmMf3QR4PIpSOiGC0vH1XuOWedK55/3Pvvf/A+D8L4fxPi/ GVxxgiA9pRAS
Auc/sXx/o5C92Vv3v0vr/Y+z9r7f3Pu/e+/+D8MUvqFa+t+L8/6P0/q/X+z9 v7v3/w+1+QrP
5v4/2/v/j/P+v9/8/7/5/85R/MVh/WACAWAaAeAiAmAqAuAyA1/6AISuASA6 BOBSBWBaBeBi
BmBqBtcSBAR93th9A9KY68W8FwJhDEKMGc0WByCyC2C6C+DCDGDKDODQWSB4 R6CAucs4AAMQ
FcgsIkFYDUvUPcNAAAFgBtYBEEcoMkRMA4OkNYAAJsGEaULgFBDEtyCuDWFq FuFyF2F6F+GC
GF7+DcQx3sScJIF0JQpQKMc0c91tGZSMRRw08YjQLI7gKNWCGKHqHuHyH2H6 H+ICIFL2GQAC
BIVpRGHFx0VwPM7YJIHRY4J0aEQwL8QsshCMIAHlowCM1EO8N0bgLcLUk0Jw MsyUHxZEAAHE
E9ucC5ZkJEI9CMFkBoTIHIFcb4ZUpQIILcACGwEiHKIKL+MCMGMKMOMSMWF+ ISIYVmIhRg3d
K0uAGce8fEGYxIPIJlb8ncKwAADwClZER0S4NcPdu0PEKgdcGYGE2JmwSMMI Ic9AKQGYb5vM
mRPcMIoAO2O5JlvNLB1iIqMaP2P6P+QCQGQKQN8eMhWx3wVyMs3VOwV0NhNw nsFsR1fATIEJ
KwSsN0xwj8x8eIJ8uYKMGBMsKAFBzYGEPJKkL5KsR5Z86ITpfBfKRUR4OYRc AEBsRttd1mQS
TmTqTuTyT2T6T9kOQZLp6AV2Qo+UVtEgLgHoaUQkyU2ZjgSs8U8cAlhpRM24 CVA5c0jQPJDe
M0QyRgx0CQFUN9BVNB1suBSYfAEI/OTiUCW6W+XCXGXKXOXQ46UJkB2OHCMy L6MoAAxwAkAA
x8b55Ymh5iMouAmwfAOU20tyViSKCOVxGOV5Bkng8gKlBVfKVBFpr4aWFYdu W2XWaGaKaOaS
aWaaacXmXdwKM4uESiIkV1OksaPpLIStIRIZeIb4pUR0plHaY+VuV2XwvMl8 vZfKU9Bg3lSY
aUEIvkG4vuaic+dCdGdKdOdSUCaqQgVuTJsCTURwtk4VG95kVidoC+dwNJvU coL6G0R6Q4po
CkFsaEVJfIVY+eSKYCSWcBBiSslaWSRMT+RY+hfJesUIEsLdQFJBo6dWgmgq gugyg2g6Byde
USRdtoj9twVsC4b4LEK4KhVECNzoQwO8NONkGEC5ZFYEqEGYToJAqALENcf8 E4ChzYL4IoGU
U0HdmsFwIIKUAAGYC8OwAAGyKogdbIAALcJRZkLkH8b4JBnQfAJEL1IYG4EK G6g+lWlaleli
lmlp9ihEYU+c+kOk3UPtzYBtzhcClumimmmqmumym1+ql2m6nGnKnOnSnWnZ /+nCnenqnuny
n2n6n96enmoCoOoSoWoaoeohcaoKomoyo2o6o+pCpE5WoupKpWpapepipmpo hmpSpup6p+qC
qGqKqMV0QECAORzu1/gCDQeEQkAJNIIoAIiIQqJROKRWLReMRmNRuOR2PR+Q SGRAB+PgAO93
vODAQCAACAkGgAGgiWwZ+AB5vObg2ZyOfT+gUGhUOiUWjUekUmlUumU2nU+o VGpVOqVWrVes
VmtVuuV2vV+wWGxWOyWWzWe0Wm1Wu2W23W+4WSBQSNwyHRBEXG9XuRusALhJ IYAEk3pCDi4A
E8nwZYrFpAAgmZEgArhxjABUgA8gBfH0VABQF0HAAwqSFJhmvIAGcZTG+a/Y bHZV6VKYzjwA
FtNY+MC7Ntdk4IUAiyPh3yd9zEIg2a7Pnc/odHpdPqdXrdfsdntdvud3vd/w eG3XOCxq7Q+I
+L1Ut5tMAHEHYjDQcuJgAOVRmcABqEPNugASQuhIAA3ligwnkiZoAFgNwZIM dZcAAF4LCSAD
eABBJ3ABBoIvXD0PxApBnEyLoABmNDTIQIJBGEzg+h6tCVFAITRnGQ8ND6G8 OxDHkex9H8gS
DIUhyJIsjSPJEkyVJafPIuqGvQvMmSE45QCgCTSQMg7FmQeRYAAG7XIqcwAE UF4NgAUoxwUa
MGoMfBnAALoEhmAEUwwZsNQ5Kc+T6vj2kyAD4jQhMEQVBkHLGkxfEULAACGO 8DEwaR7tWFri
T9TNNU3TlO09T9QVDUVR1JUsPyc80oLwsCTFkQY3gAVZyAUAAKAAewAASDgR gAe5mlKABIS0
IIniWAA+EizYhA/MU3nMZIAEWO7Nj8UhfgAFwgi4AA1DsQDViRNFXVhWVaVp XAViKKNBGvYB
Hj8x4XEiR4AE+NQUQWQ5AgAQY/E0g1s2wFzRgoIZBgAR4wBagx3mwABMkEQo ADQSE7sQLg8j
iABADyMAABGBqVFYPQ1AAWJ21sBVcAAH4wiaAB2FSQgAE6ZB2oMCYhAARJNk EAAkZAAB8GxQ
IEhTQiEjMVdekyKgAUwjB+HDCJDl/NA+4VN84znOs7wzDbWgAbBcE7hBMMyZ Bv2ux4ggAMwl
iu1Y4i+AAZArTB+TIVl9X5f2AbaF2B1rg2EC4CYAb3fd+3/bHAcFguD4ThdT KzVtX1jWda1v
XNd17X9g2HYtj2SAFl2boVn2jaYAWra9s23btvjPcIAXHzFzc3dN1gdduEXh bF53re988Vv3
G4FgnCclhmHYhiWKYsAGMY1jmPZBkWSZNlAAZUg2W5fmOZ5rm4AZznee5/oL +mnQNB0LBMFj
cEvEezk+U5X7+YZlmmbZxnTPGfNANc3lxDfHFt/eQ4MPgAAdi9BqAAKqdzDh BbaBMDYSAACb
E+HIAA+xeNlEe2cADaW1mQbc3BuTdG7D7foyV+z3H8Muf0+J/r5X/vogEQo/ xoBDrfDCIdtg
QXDgOBfBgPweoON2JaPh1K0lqLWca7Bby4FeOUitFeLEWYtRbi5F2L0X4wHX VQRk86qywj4a
mAAJQIEKrXIUIIWItwAAPFWHdAgpELrbNSKNuo+BfOlAsEMAC149DyEsAAeA hzcBDiAhgZCG
gzAUF6rkEgVSOryhGHEZYAAcGlekKscAABRhQJuIoGaAxShbTYGkgxomukHU maoLQ+xTKCRO
QcOAABuD7XoBscIrJKSWImGYQTPh0h+D8yZFQnwADyF8x4cptgAApN0oVSaC wzuTKCnBOSdE
7EHa+GYBSBmjBhQPMxLy2xih6CMYNqrABIgAHUm0AA7TQzTk8FyUEopSJllO mmVRmALL0BTP
mfco5Sz/lSmwOyiYwlNjQhGNcbSJRwjlHSOwb48H0ABHuPsfwhSBkG9Kjshp ESKUfI0SMj23
SSmDJeeIyJNScoNKGhE/pUUBGjKxOQDpXkGliACWctafNIABLmXcvZf0vmHM UAEx5kpaIMEG
dEzyZEHUAoIF1RkDvwUQ0IbswAEyVIpMSY0yJlEHqpM2qw5Z70FNNPqm0/ZT U5QULIH5jwnS
dQtLgT8kwugzA+AAEQBRhgAAjQWc8zRYTqnZO6N0mJ5huJlWGphEqzVPrRVI yFVWPANHwe4M
4CTEOMViOBDQHRUhTk4HeNwZkDD7EIAwAARqRSEpLIeRMi6VUsDcjqh9wbhX DuJcW41x7kXJ
uUeqMZGIynpjO1ubyd0EDIfiDdoQzhJK5BmrAhAghejlAAEsajJbupaCefYe 4sD9TRP0CSat
R7YiHA4AAKk3qpBBDzHIWIdU0CQDcH0AA7ghwcBmMcH6cnGAuCez4TQljNg3 AKi0RQuwKmDH
mQ6raKQgzxHcL6ygEbQzdMQncMwpRrsPCkrgKF+K1CJRaL4OyMH2BQWwGhYZ 9sPn6HSKA/VB
bTVdUOm4oU3GuTfIM18MIBRVVaqNLkco/16ASGTdsBIOLvGJhGPIVAABuh0A SbnBeDQAYPwj
hNMouzRgcGDA++ODMHYQTBmjCuFw7Bam1cubd0qfmJpXde7OVrukJvBeK8l5 kCoHvVew+80r
4OMDhfO+t90635v2ya/ywcA4DwKibBGCmAZkzNnPCmFsMYaRRVPD2ILEYjTn iUg+J8UiZxWA
DFulcX4xxmADGuN8c4DF8fpHZOH2ZOffkNRM3Nb1pMhjAzmu9e1b1/h9ugt7 R5i1DnHM+pc7
BWlaAXWFQFKKWOJVl9xBsoZSABlTK2WEt5bS/hJOOy787OxljQTONtpVTx1s EAA5J7guk8Yn
RePBWMaBAFU+ekQADKBCJ4AANtE8EV7oy9wANH7otiI8JxLs9cf5ByHkXI+S clIAAIFA4JBY
NB4RCYVC4ZDYdD4hEYlE4pFYtF4xGY1G45HY9H4m5HO7X/EEmkEUAERK5BHn wzgAXQSMwApI
GT0izQAsDcMoE72SACgEhwAFjAyCkWGAC8vh6ADDR4kLkiAHcyR4ADdM5rN0 xOlgZ59CGmmS
gABcaKlByCZkwAE+kS0AF+ZQdUJtAiDb3cvjOAAi+GwADOCRSAE1Axcgl6AG idQhMa5eQBOL
BPQBZS7aDReb2AHlfgA5VBfxSYcTBJwyJ2bhvLphMpplJy7q0Kn4AGSwGCAG vtgADHnMEGaE
OAGlBSeAGa8lgAAKprPabXBrbb7jf3koenaoT17gkb+HwRLfN5/R6Y5L8ls5 vOdbY6BQqJRq
RSqZTqh1YfVKsrCtMmrywLEhKyu6/iCPAuK5rqu4wsoz6+r+wLBsKw7UrQxj HMg9quoEyz4s
yTLNrSzy3tCv4GoGeaygABy0uU+CeLG9jZQ+ysZswzTORO0DRHAszOQSpC3P C8YANjASBNqr
QZAigR8HW3TeN84DhOI4zkOU5jnAAGQCyU90QR0n0eRMvUUF8ubpLu70QRQs IARWfAAHWczb
AQC0VlaKkHyIhj/HcaI3MA9VD0RRNFUXRlG0dR9IUjSVJ0pStLUvTFM01TdO U7T1P1BUNRVH
UlS1NU9RJEkiTJQlSWU7G0lxyy8ammyQXRwnCliS/U3rQRLRmaOQAAkfjcoI AgCPKAh+TFXM
yoWd4AFYPQwgAKpD0BEBOgASYADGAA2rWpKrF9QsoHCABBheEAAD85KBDgo5 7kODgADLWUQx
pEcSs7NMfr/EcXxigrPxTOb12c2hmtsNwVHkABQEEPioEOmwgjyT4ACudpHg ANBNXgysuueG
QG2lalrWxbTKlKAB7lgJIAFpatr2yhQn5dmC5vLVGfUtWMx1nEQAHxWyZVwy ldABXin18F1g
HLYViWMgtk2XZsPaVaCFZRmuV5xblvXBcT73Lc4AXTdd23egd5Zfet73zaEz 38AGDNFFaBRa
TOBjRGVaSjhT38DusfYPFevZVm6E5zl5UBRuWhJziCe70fF04ligw4tu+M43 juP5Cm+SS/MO
tcJEXDX+0M2ChNy16gAB1GiOwAAqhJ5gAs3YMVqOp2LY6B6uAFk5/4/keT5X l+Z5vnef6Ho+
l6fqer63r+x7Pte3T9VJKh6TpSlZEU9oNckw5KwhaAB+G6VjoBIKqCkSZB1A AGhdCuAAhj8X
7FAAFWOAnQVAPgERYkkZI5S0AvHsVBubgSDJ1FYHEPIAARCHY8C4dxMBLCLE EAAN4kC1hwJq
H8aIAAuCBf8ZVOKKj2BQK4WsJ76CdhfH26hMjhUSI9TgaBOSKxzLqBeBtdzI i0FGgEAAJ0BS
Gj4fcAALAih9AAFGJkuYDXzGUfQxAGAtzlg4DvCsAAZgADcH+30AgpjNggC2 ZQLhyB7ibAAN
kPMFYLwZg2ACDsH4QlrDYAASIboDA8ETHiDkHoQQibcb4fbHgUQGe5JEgsWS vPpDO+t9r7wC
vxfm/V+7+X9v9f/AGAcTG9wIgUC6BkDmhL6MxBFacFILQYLRHmPciYRwlhPC mFcM4fQuJhDA
mkMoaCwhtDhoa+3Vwsl+whKKLgEsEdSvtorg4cuqh2miZhzgvgAFzLKO8tZD x8kUvE3w8zNi
FAa0J+jEA7GvAAL4Qxywhh7jFGSM0aI1AAjZG6OAowAPrmtMlHc2W7S+OcuA X4cSaBPEgyJX
AsYkxLkgQMfA83dDDEgcsI0oiBK4lIACAlFXdDOgSWgG7kaKySpZS2l1L6YU xplTOmlNabU3
pxTmnVO6dveVY+JV6nJKGKgqNIYAcQADfEW/oJ4h57m+Hu30DY1m+gOBm38g oLoSC9E+FIAA
1BHg+hBABl4mwRRQhifc1i5p4EFd0JkIRdxLBBMaM0PoQnitZCEAUmgv0JCf AysQEByy9AAF
6X0AAQh+C4AAC8CzMjkhBsMOoX1iQETBqsfaa6+xkiSLODgN5UggrAso7Z3B Ah+DhFkAAI1g
y6IKgqM0VIfkvgVZ6PxaQzhYCUAADMKttA8ixG4AAQwTgRk/KWUOsRawzClG gAAJYywvGVoe
UgAAmBYhqAANgPr8rqv/ESLESoAADiQKeJ6uhzK715JhXuvoQRIAAvjCS9Fd b1rMvbXwujeE
VU8ejUOj9Raj1JqWZWpxA4yDXqiACqdVarkGq1YartX6w1jFXWWs4WK0l6Ej Ws1xB631xj1e
mu1eL8WJv1X4vlgLBWEbvYaxFirGWOshi8XtlLLWYmHNMzFnbP2hL1aQX1pi BjOh3VcymQRh
TxDsU8ABwyhWZhktDHwALQWiyEGkAArsRVzvtiavWKWDCxBgTEBxRXYhmWAE sZAdwADmBYCs
AAoRTDVutdi7V3LvRGVxeFjQabJZmx3ZvHtnsrZAbvkJ2wDRsCgAAYZaxBo3 ixGaHsAAFxvC
iysFUdpjhlE+BeDarBBMI1cq9WCsQb6yD3FGFQADPb/ax1lrPWmtdba31xrn XWu9ea918qin
z4FWvjfLQMhxyxYjXoAE4FDeiBjYFkIMAAKQn20ISGZjQ5RMhTAAMAM5dwto ZIOFwT5yRRhg
fXKeuCboxHfAAKUaQrQABaBalAdYzhTMbBmFu19krJP+f8csVY0mNBUBbAaN W4MkoKkAJ8JA
ABOhhzdEaSpO5LkGHeYMTIgg8MfnKQ3gQ0o5cGtPk9iIXUH8LIKJETwfYQBi 2kdYAAghBAlX
cH7cRAguCXAAIscuWg67tIRZLeAocnhvA8x/oRbN37x3nvXX6p8AbHKNsqJW zSC7Q2ltTaxC
NsGj23t3b4ANwkK3JubdEB919KIZ0Tp29N7b431vx/2/rX8BgBwSkXBwAcJ7 JyqwokeHcQ4k
lsg0MzWBWGdGTcPFDvsUEcBkQgAA5b56Z4Lh/EeJkH8Q0wVJRQ0dL5lvDeW9 OEBnKz41gqGx
OA1GKAAEYSeu8M5pzYP3ONJc8Lflpu3MvMeE834eYvFxwi+ElEoIeqvHSLfq IsAANwKwG61t
PapCuv7aDAAADXUdYp1HMOF3QFgPu4pWR1Oo4RsDgReCRyIEfy/c/geqi60q MD3ABDcAujwJ
JQAiAj955pOpO42wfYAoBL7QCpKAiQ3Id4dZaQfhZR24CLZwiEAJPD+8AsA8 BIj4d4cIbp9g
C6462z+MEcEkEsE0E8FC/zYIhx8JVx8hWCgbs6KgLhdocwdR3QBoCz7YBr/4 hCi5Owdx3T/U
CLWAlwd5aQAgCJKC3BKYdwe6G8HMHcHogYfh3QcwcsAY6DS4D77cIpS8KpKY cIcrTqG4gQAo
BwC4AELhKEKYi0MB2YfCAwCUBDV5FhO5ooAhFcBBOkI54sJR9kBgq0J5OcHR OaSAfEPsJMJc
QMJ0KEQsHkFJULAEGQUcGjN8G8QkKQh8H4dcIIgQBICUIglsREJEP8JkQUR0 TQhUKrN8LD+8
LQC8LkOql8UkP0RcJsQcKMQwhA3IecPpOo8sPYgsN4dUOJYkOjWAecO8OMPU CRR0RDN4dJiA
AABQu4DUOiJp3UTsIUUEUUSKmA3L4wNZ/YN41JQRQhQwjBOoXwRQMp/YO4yh XAZAeSE4G8Ca
mpOoWQPQJTAz0RnAMyD4NANhv4JAFrksb4gwcwZy1YRYOg5YSDdpXBXA5KIw J6D4ZASIOr54
8hRsKpdIWAS5igKoXArJxBaIaZ94KYFx+UfwJ5YAbgVB2wEcLxOzuQMrfazS rILgqoWQTZQs
jggod8lAAElUlghElyMsmL2EmgggZwSQzYGYN7wA1SOA54FspkhErMrUrcrk rsrxQ8FYhsFr
YhTofho4AppLHgscr8tktpSsswmMtBZ6CEt0usu0u8VaIISQIyIjVRNS/o9a eIRUfgIYO4u4
5pkse4hy1IAAXAYQ3IJAIS45TMxkx0yEyQispws8qIo4RIYSBQOwHJFYboZo WYAAOYHDfgtY
RIXs0AIT7cFJrzbhbB/0nczoMIJz7UxUQA3QVT501I45JonsDQ8yJx94LAKQ SwowaSFa/iZw
gweYoKuIooKAXo5ILIFD/IWoRa7QMMiAAAPM1q4k165CxoCSsRqBlwMJXAAA VIO7fh0YgQPI
W7+4Qzh4Ak6KxLM4oU6wAE7E7U7gqE788KBQQ08itwoJ14ooC6OoAACYgYe4 e7ToDIHapAOw
KhyMvFDVDdDlDtDynksIhksaoJTEcIRTV0wpbQPIUo1gQQLQ18NtD9GVD1E1 FAO9FVFjmdF5
4tGdHtHzXpOqNUAwLYcsv854jhA4zggUxBL83Z3JabsYQYEYnR2stZSh3QVl KNKYxwO1KwiJ
1ZyhJ0e44bByrAJ5jQ5z7NJzXo3IXAPT/IJIQ6yQVYa7eVDBKAfAcwwYYwaT 9QAoCxdoEYDE
AzR8NIBodwWj9Yo4a4fagCR5RBOoUCGAqAeVI03ZFrfIVoeAIoAAMAHsg5wS xIrgDYUoa6Kg
LRyIaYSSvARQCk5QUdVCCJWwwpXATRcgvpQoAgadTNTdTtT6CK9tUdUtU9DL ItVa3oTrh4bg
YBQoEb/tH9aFaNaVadahT1EIhdEcF8yhOwbq4bTr/L/IgiG6G9B4FAEdUFat dMrg3IddboAF
b8LVcUV9ctc9dVe1e4d4bomAW4WqgATgZYEIAAPh+QAAOIJ75QFyyQSIR5jQ LIDSE4OQK45Y
UheEi0+gUYPrh8CYeYwYSQOi7QTobYgYX5/wFxz4QAPL7IEdS4wYRQNR/QO4 aVB7f4uhkShC
H8KgcwpYPwLisTA4vSN4UoQ5YFF82AgdJJglJhkwhwWQM4AIyrcUiQAFgIQc mAAAJQBIZZd1
noAFn5u9oNobeYG9oxOoYYTKCoNgSwb9qYCZiFtYooUgWIQypIOlp4J9qKI9 qlqy40rAgtMB
hhJ04h9jRo6A05EFNAWD7IBNnVrdnyMQINsFogG4CxtIaYY8xoU4xIbAD7fg IIfJl1g4mwQQ
W4bIAAIAcLnltNtYENtqpLKwmtuSgLZ1jgAFj1kFkQgVkgtFk9lL2ABo3Ibo ZIWwAAVoVDC4
Uob4EwAAPoKwgQKoLbro5YUoZpjQLRJ8oKzpYi0CQAZBhoG5KAZKHYHBfyrQ t4NQBM5Q4xeA
IJjQfYXz7IYQOKvAZgLreVLsDQ3IaYWQRyEBxwBywgWIWNB96YVLeYGVdCtx 3Z15j9SpgFI4
iYboWSpAEgJ8AzBVuYFBnsZSIIAoCsLohNINSYLeBpCcdIhuCOCeCqqGDDWB owoSaMnIhAQQ
VYnQPoKlL1e+HOHWHeHlada4hVbOHuIWIeImIuIwjQ3IZIUC2gMxzjwzIIAA YQQ5yIUgMw5c
+JECAAYSCoduKp0Q5NMJhz9VWgxAMzC4eQTLVy7Z94HgFJ+Q5KEjBSRwAkDw OKTa+QOGM4R7
V1xayoKgDYIYo05xk4pYIU84oQZCBQNwGaG4SQKhdrRAUobj+wLUmZEY7tJZ L1pYhoeeCIAA
HmClB10c9oNg15FYalq+Q4KGRIrWRl2uR6EAqWST+wKwAlRIAoEB+QWIdQko JwCpdIPQALVQ
JJLwGAdS1eUA5YCeUYVOUpOcP9vogx1Z9D+yS+DUD0p4EmWLnVYYUYJJKeQy sWVeRWV2R2SG
WQbAcQAAAwVQNpa4Pw/gtqMgdoTQxIFoRgRrd4OgOYo2XiJWX4AGYOYZLwHo AtWeGATWMw0G
NIgQbGNmNxLeOIe75zbs5QK4JL5QghIwYQKIgQP4JJv7FWBzZ1VSvAFwTos8 ehQpJNMrnVND
c7R5F0tBv8+b9U+wD4zLQwWAGJjQPoHsBIcyxgAIDZmU8J+1Ax3AYZdYAAHw PzVwcof7l1o0
6BiOBYMOBskwhweYcImAT4QwOiEATSFYxY3wZLl2DIiZ9tguO4aI+Bc2HBFm rguGr+sOsaD4
a+swAGtCixtIbr9QdAbYmAWIUpYBizimmq4gJGnGI+xmxux2x7WeH4hOIOyG yuy2y+zFGmqr
/Oq7RR29o5IQtJiDG6yoITkuoIAGoZmRJoIwbBQoFILY5LG6E+0wgx92CYKq +LclUwQgCRvq
waE8eaysewglSNSeq9IwawRSvCMAgQT4WJ2wCQAwgQcAV5mUcqj5+lLg19pC rFpVNdWWF89g
r7iwnwZO5bKzNwuG6BYm6YAG6u68c27QYgJK55GBv4OF6YAAR96wAAoB995L VwGQBJWyGG8Z
AmuAhyZaI4FwF0ijxwOATAxoQQM6vG5W5m9W5+6O92+GsO7I1h2oFR3bERv4 qo0JQqLBOoeA
bbowCJGO/InW/gn2/6pIEzVwBQW4ze2G2R2ixNdG24AB+O3QT9Uzc6IgSQF4 u4N4CYqtXBQw
3KNT/NIlSwgYX2pYIYZqpAfdxI5DQ0zguDBVTutEzS3oN+0bHG01SIIQ14Aw TYoOSpnodeQo
CysQMgbiG+SogQYdE+pgO5iG4T59Jx3VSRB+rBvKJo3QVgVA3weh+wWDwo6t M6H1NQh7RvHQ
MIBQ5GNF2UH3RPRYa/RonfSA1VxHSgh2CLaWCjaxCQ0VwWzPV/WHWPWR7okZ 78FjYdEnWfXX
XfXnXqnHQeq3Q0wAAHIB+Nte76i3AuGAIQZp+wEwVgIhpgQ9gPZCSdwjSBHI ZRj4b4GxpgSD
BLBevaU/QlShNQuYVuq08Dd4LgFggSKYgQA26YBggYAwEQH4AAJGA+S9JR0u TaJqYIrgeWtw
Nzm3chayCoUvdnd3eneXene3fAEocbQRHAtDSYUj44JzqCauF4mngQnWt4ip 1YQTSgpgF4B5
9jR4AACwDcVXcfdPhHhQAHd+dfhveHh/fI8vg3YVI7KDlBoXioo3i6JQFpFd NwmlOPamTUxQ
wTR3bCV3gvYPKggVpASxmUenYcpyvAGYWB/Qe40Qbe0INFtYYUegAAHoBIwe Oww4SBcnrxQo
fcpxF4GZOodwf523V2vl/QxIN9g614giN45qgHf2BPnXqQiwwRdQJQw5/o5c eY5+4mEAbDfI
wzfgW4cqG4JADVGIhfxAQfxRdwX/xpL3yAiHPavAH0wwAHx3QPX31v131/2A iOyQhGyn2P23
2/3H3JT/YHQvwwwRvow2Ao5qyvfw9gIQrgKAZqIIDQUb7e3I5YYQdw5+n4g+ FxpA0YSJ/wKA
WCyQN4X6N4aTVigMIv3ncpH/c7lAqAed9vLnzYg+7uTMxMTfgHjvgfgv9IMP 9b+/9utIgDrZ
wAQ5lGYAPyxAELhiJYTqAB2GrjABQBMHeSRZoAXxuGUMkEhkUMaaZLoAFxoU gATDSeQAM4tB
sjmjzACgLoOABheafAD7WBgAAEmlFmygKE6MLyTAAeS+M4AmcifkCgkGhEKk MOcQAESuDwAK
qQJ4AYTuWAAHoRkb4aYALoJFwAcsajhuEs3pM7plOqFSkiZIUoSxXpzRqNTA DYU0nFJbhbXf
ajAATXhxAAWJKQACCWLCAAjX4+ABbzkMLgAVaxHliJ5o1Tce4AKgjBFUboAQ YzEkIaR5ADXe
6Ghaox08ADNeVpGWKkNHvdLptPxNF600bE4AApMLlADIp4AG/OhjzZIAIQOH EVZruAEetnX+
Uh7PH73gX3i8nzZySwYZjevLhEyAAUNu+cEQTBUFwZBsHQfCEIwlCcKQrC0L wxDMNQ3DkOw9
D8QRDEURxJEsTRPFEUwychznaf8FEmSBFAAREaxCfAAHCbBwAABwSBQAAIqJ FUiSLI0jyRJM
lSXJkmydJ8oSjKUpypKsHOgpS+uowCFneZJJAACQcPy5TmMUfCBosg4hJcAA gmMNSUJUACNJ
ejzyH4cJZAAAoQLKJ6WvecLUiGQ5pAAT7hAAMEDIZHCkASnZvkiw4zAAWa4t KlYAFKa6Xi0F
D9neYaKimZ9EI6AByEyKE5IXMoAObBM0Iqi6F0CWAzryxtIi3TdO0/UKRVHU tTkmRgDgAV59
i097xgAbpcTAKQkjeABpDMVYAHuSIRAALFbJZQ9chbB6SpOlKVpal6Yv2osc V5TSF2AAFQVF
UgoVNVAwgAWLooyAB3VS+IAHmZ0CE/ZlnJnaNp2ra9sgAZYZIUGs5zq99ZJB PM9z7P9cDOEC
9SypuBKjgiS1aFxLCSw7qoYfjcjiArekgOCFH2R4nAAbhZQIR5PFuAAOCs4A 0CAhZPkWVAAH
OBIQgAKQx34HoR3chZulMqISC2TV+nLF4nA0hZsVY7bYOSe7mQOkUsJ2linV zLkJ7KwYUjQJ
AAHUf47AACuNnC3QZ5EA5KIgOwe7+kXAkyRRo3qO2d6uke67PvO977xUFmSR QXgAHBjDvbZY
WbtkrdP1HU9V1fWdb13X9h2PZdnI0WRdGEZRpG0MRwXxFDKAAhjvTaUO+eXH 2f2nleX5nm+d
5/oej6Xp+pKlHosvjpr+xWUzkb4AF6dXHiFzR1vyF4LCGAAllu7xDBdQ4Xg3 lppCCQQAHAXw
+gAD6GMYVEx42zvsCAACob6BAHAzbQAA1IvRuCOAAC0fZGwrgpZaL8ABZRPi 9EG8EBbQgPA4
dEQsuYiRViPAADkBhXQ/hJX4Dh8IABDPkAANMSTKlrNpbWQsfBjAAAJMfAxR IABRhYHsrUg4
sQuFNGkHYDIABai0VIHkPQjCGQlhPCmFYAIWwvhiHkCAp0eh0WSyZIIAB+AA EyC8AoAA0BUN
AP8OoC4kL9iWteJwABfjZBMAAMwLCBxAMgFyIYo1GAAP6q1ABCg8ixR4IYJz /UFJeRmmKEbx
YTQohVCyFzn4YwzIWIoIQFgAB3F+/cdw/39sEYMmAB0ZGAl/LZGmNcbY3xxD GPUAD8n6P2fw
/p/j/mtHbC3AIZEBAbgRJsYInRsCmj3L+bdeCmVfBwZ4P+FAIy2rRAAEoEkF wniJWuJsN0EQ
KumJGTYZwshLgABmE8t40h7mUBbOiGp2gXBhJWGYTDQg4g1HoAANQMwqx6Tc SwWIfAAA/Bya
QFAFUhgAeupEMIsVLDgH+gSSRIR8TcDyIAXMuwzBsgY1WNA4RcHiBAy0MZ7W MsEHWXqUlFSF
iCEipQAA8R4khG0KwPwAAFB9G4nQGMAqP0hBfSOks2k80pBvSsAFLT3HwMWK YzBj3vifGEI1
RdJiBCgMyDNfgqzZG0Ns9WtFaa1VrrZW2t1b64VxJG7ZF6CUYozRqIhDrvRF BKeCHcnSsGNV
ysJYWw1h7EWJsVYuxh86+PAeE8QhYXBBClj8C8dgAA2BPWsoeK81hbiUCCAA XIfyyiQgxFdO
gvU9hdAqMsnYLqCkKLKHAMxLxINeX6NchQTlhEgGmKwPRKAqiHPmC4Lk1gxh PCkXAKgOQADa
FAHVz4YTTkjEEKtQ4fQqF5F8JJawQw326iuEGawjxP3GBsPKsADQXBpAAE4S BGxYhvLmL4QY
Rngh+tTBl8A5SVgLF0/sHF1ii3Zu2FRco8ySo9JSQsIKlg4AbGQAASA0jBjC FvcYHoGiiX4v
0EO/hDCyi9HK0wGw7b23vviJAY1UR0ziCeIcrRIwnyNAAKiSAAJ7EjjSMm6d 1brkiwQAAPoU
AFAAEUFS5odxY2eIZhEpopBKmJGvAjB6bsJYUwthgs2Gy1AaNuO+4NsbZ3+t tbi3QsbeXxBR
G0XAgwsAACSQkkIZhIkKCiAeDASQ0ZDTdjgW2O8e0ScCKwSVCgqvDtUEG0YA B2i/UPlDG5Ph
EBxznQ/QtJ6UhUqhjVNz9xSheNmFsMNxiFqWPagQFw91SB1DUH/Cwsb+4QCf NYOwjbjBIrPR
0U0P2uFFBdhEAAiRLV6CQChghCxpz4n08UheUDrGpOUZQFQ6tfgJ2CTTYalt jbI2USFPRmE/
aAJCC6a1rH7hCA+5Oxu794bx3lvPem9d7IMro7ivDu0OvdyzYLd29+BcD4Jw Xg3B+EcJLaAA
dY5h0lOH3G0DYH2x6bLaTYd5sypARJmAQfkaSh0ROsPweY7wADvHxGkBAEW/ gN5EhQfA9KAg
EAYAwoZIY08lNmAnjnNyqcl5PynHnLCpcvKKPwfBNh58aAjz3kbBeMw/570a iXMih8158iPk
nJuUcq6Jy5DnSOldM6dY7hnDuIcS4pjxJ/SOGDqPcnyNpCyicsLZ1RBiOB5k 2KkA2dHSEcAE
ARxZC3bulj7IWAVSPfu8Ik8MPfxCfPFgI8aTTsTBR78gAIpHjnhOFef9B6H0 Xo/SelIXvmuz
ua8nWHmNgAAkg6JxvHf0udlHRCJDys3D2zGzb/OWrEBsaRpiyggG8J9lgHFl X6LECanBmipX
qDJzSOBhiZOAGwSz3wQgTJe989YpBYnEJl9T61mvsgA+391z4APwfi4D6b+H 8f5fz/p/X+39
/8f5/1/v/n/f/P/wAN5PUEEK7ndK9OcPXGZgUgAFJjQBWA3AekchWDMASCxo GFOoiFQIavem
0LBB5qUgAn5gAA8pPoaBhhBnPAfA/AqC6JVDMhwhWE+AQLZm9r4gKnAg9AAl rAkvfgch3QYk
+waGwwbgAQcwdvfgev3wAwlwmQmwnQnwoQowpQpwqQqwrQrwsQsv4wBj5wCv ViQBuhWCTwKg
KH8JsJgjyi3g9LOH+BDvoAzgbm/t/QOvfgZB8FSJRjSAyBuPEAtJtAABhslg AAfA7iXj8ICh
wMsDYA4BSiNhHgtCPkvQYhvgTQWASlVsHRFxGgARHxIhkxJxKlYtlwtRSRSx TRTxURUxVRVx
WRWxXRXxYRYnlwuD5QvN+EcBWAzlIgqhkFKHjpywlCRQ5lXw6jnEcPhmvPjF rNaoGDkh5DKC
PiBiciDrJLkF+hSEwAnAWj4mDC4IEv2CQRrBYxsL4xtxZRzx0R0x1R1x2R2x 3R3x4R4x5R5n
TxaDrxbQDmCgADGidFfH7mwH9mxkGRhxnDmAEjcjdjeg/DfjgjhjijjibOAC FiqiBiCiDs7C
tiHiInEo0CrSLCsiRCHHDyOR6SSyTSTyUSUyVSVyWSWyXSXyYRZkWq6wCPVN +I0hfA9CDlCl
DhEsTCIghSBGYE9DaA+KAhUBRlmhtwORiC0gHhZmtmumvmwyBGylWm7lXm1A AAShrGEGFA3F
nmGmomHlsFtB1gzh2x9yvywlpSxrOmIh7hMwWPPSYx5EcBzBwibALAPm/vKk IkcEdEeEfEgE
hS6nqukuTO9jZvEI2gEgJC2AIvKK1h5h1nAhwBvB0KgATCDgRzCkLh8KYhwh 3DbuKRgzDTTz
UTUzVTVzWTWkUx7DrR8DnsGgHMsiGA4BMFtAggGhvIMgtnRBSqyw/DbobIcS si0gCjjCUNnp
+J/KAKBKCKDLRhMKEgAAaAFlDgaBClIozJZo1I2I3I4CnAllTpXoypZI0Tvp bTxJVQIzXR2y
cBJA1ngrxoSFKB3BopyxRkHLHq/niC5jwHkTTK1kcBZA9K/MZxmD5AngzH7g 0A2DYAkAWnNP
8hzJ1gABFg6LTtai5i5tJiQAnn7xerqAbgPy6EJlaC4xqEGhMDlCYLBiRB1h pqUg+AuGWhNB
pC5g4BEjMAxAwjU0Jy/Drk8slAwl+HhoMAXBEsKhog7Abz30oUo0pUp0qUqz VzYCizZCaFok
ZlqHRNpHihMMNCYAegJCOLwT6LyISLzAABGBCLRhKgdiytQJfNRtStTiGFLB hhiCPgegeG0N
iMJsKsLsMswAYB2hQxMsIMt1BsvMNMOMxUrR0h+BzPXgjANgAFrHtGXkKq+K /HhLAxikG0iB
cBhI0gkAhQ/kl1SVTAAVUVVEGJEp3A3iFCHDvA7AcmGBmhZgAA5gcDIMayfV bygv5OTLhApi
xBDoMAuM8tigwmdgNF3B+OTBkhVBFnPgtrjCNKpgZT9kKwwmtgqoBBBBEm8l kiGPBmmhOlrM
Liypji0pkmNxABMz5gfA0GvAghEmhBYg7G80BkGqOk9ttE/i7BYCPVJWEWE2 FWF2GWGwp0sC
aUtD5O3B3ulofgGi2TJVOmCu+AGu/OcB8PA10vLOkvMCFumwlPL2LEguy2HR zpplehy1Nm5k
LSCSJEEibRcidBBgRiN0miPkk2cgz2d2egAWflzCTE5CVmME7jnmDkeoFCFg nifDlihV/t6I
0hcA9I2gkhDrRhVhrhWjaNwh8BzPXBjBpEeACgLGRARgMFIofgLipB3BaEeg SCFDJDKAUUhE
FCbBTA9DOAUA8n90YCRBnJRJ3BjAyHRnSiGQwwKQLH7GhH9G8kRlaE1Fblxi Y2XXOXO3PXP3
QXQrFWICR2JXRSSh3huiBhbhajKBOBlmoA+KCgAA4w2UcrRhIr0AAAsgNHHg 5AriyhSLPUQm
hBRg+1/CQPWvXvYgABOoBCFhf0kg8ifBAA8ihGrJ0vXBFA1DDA7hpPmrRoMN JMSDpm5DFVKF
SA/AuDSVlMojUhShDpxAtAbyhPeGVQ6EzEEBZAzgAoM01UOv0DdBuGmAlAEr YX1X2L+gg333
4l636FHV5vrvzv0wGP1v2wGA6X+gn3/nimoBB4Br4qzj5Fz2lE6KXKqGNjsk +DuWpWqCgofh
zX031iCYFYGX5AbpSBwhphjgABcBTmvBsAPjIAgh8rLLOCVhBBbhsgAAgBwp 2vsPtPuYKvvv
woIjFXlPYE43nCGXoiUXpgAXq3rvgloBkhbAABWhUFtBSxKMjArCFgqgtqf2 pPnCfRIRRkvE
wExFrBIpjlnC2Bk2kgcE5t0Cmg1AEhLI3FDMICfB9hfChBhA4jBhmAu2xA7V uucYYiEYZ32s
IYbYHX6kEGYiYGaKgH2xOAkSBBzKUpeFrqDhShehAgAAGB3OHgDALgTgAAdg elyk8IaviVMv
jkevlBYvmPnPoRIHFXLlbB5A8imjDGhA0MaCUYFsjBIkwMFGCPhZfvjPkZh5 ixG5jvpXT5x5
yZy5zZz50Dr3SCRXTZ0x1MfhQKfgzU8NpV8izBDkgBSAzCy0cUQDVBhDgB25 9I3Z+2mAVEeR
dC5hNGIh5S5GyQYgeAUqClDprDhIUW9mZZSGbFtB5BHwWAEhzD8gqANn1BYg g2ZgGliAhAJD
SAoBkDvA3AZvEBJNPVMitTgjZzhwN37ymvgEEB5huk9geASCygJ4kgABUg2U niZhqJu6WCK6
Xj36ZPX6a1aF5qygrACW6wgl+wagnQiQjM6PfgYB1ahaiDK6j6k6lumu2EEY SF0lxDZiYkD6
gPXguje6rQLhroiAkqY6V6W6o6Y6Z6q6bhsCugDBVA2ixSMMogzFLB2hNGvA WhGKuBSg6A56
uwhwcQdaxC0gegCi36EgAaF6OaHDF6IaJZW6Kh71rgABgZEAryyCQJ+CzAoi FoWjYBf6Ti/V
OIbDBgXBOlWxfiF2noEm0JCCnJDIfsGgCsHg8hbpHgkH+zigABYAYifA+i1k uw8an6XaYap6
aGRa86cF64RDrsGMsPoJjj814uGL8DMsRNzgzDgAcBtrjBNL+gnlKBy2DAAA NZVAAQQmWwSC
IIZm/wTwUwVwWyA0UlbHiUQifArAHnHgtg3rrrRnwj8ghB9wQQRcCIZQTQUR B8FSAb/Z3cT8
UcU8VcVzDZ1iQ528WRZI0ikI2ilpxB1BfHMjA37iX8Mj0HNcAcBYTD3AjBsJ yjHlDnwnx0KG
sQJgAQKjOJCa9hCAJECE/HHxDnkoeC9KKEtC/hrXEIRGk1+EwgDCFhwBXmWz 6iUUl2jUnadl
XSC6fEEC3Fai5iWCNlciPnODB8xFEcyAJczH8c01MrdUlMKhiAkhoVFRGRHR IOTxPwGRQgZA
Ei3iLc70W7qgz2gEG63k5oSCUH4Fr0wAATcBejOgzjB8wc+oRhP9AdBc0c1d Dc20mgVI1D0o
3E6C/RgWQgAB4Bt1EgIsH9GxOdHxJdJQWAFBbjHAt8knxcfiRXH8nwLcpIiA wVMBJAXidA3g
Jz7mBz0jGo2gt2ZbeG5r8HPAhhmjMCgChBpIb1ZiFFEjZlGDb1ZEAce8ccfl HghUngDBNjz6
dc+HP9W9X8z9Cc19D83Unj5QT3+gfBmrLG1XGveF0E57n7oqNuTCcUzNno/K yI1Af1Kw8gAQ
9w+w/xAwWRCRDDwgbgCk05liHCOHECQtmiop8mvFAFxgpB4D0ALQ9Q+byiF+ URBxCnjb2Wr8
Y+k+lel+memwAcXCQcYenRVG3DpdyjFdpQKnv2bqJdLC5D0BmiIATBWAiM6B DmoeuFHYVIgF
+b9BlI3BvgbM6BIFLEBkCnTeq8vFmhWjowRlOAuAWCFh9CGADczObCFgDARA f1XZxWbVRc6e
XiMC7COi8ikCle/BS/AfBfCfDfCfFVXASiKRpxwIrjUxxxsxzKJfIinfJ2Dk HdPYkBYiNgvA
XgHz0lIgLANmxuwDymRm3jgfM/AgAfB/EfO/EfPgkAZDb/LHs+r3kxpRvxq/ TRyRtCZ2tCD2
u+0fHiQIeqwe2IM2Ci8fferEtnuPemWGXG5j+j/hYDDJoCoyl37nvhhHji1A EwEgCwFhIAgl
KCAPdfG4APtnJIAA4ZvgAO5/nYABEAPMAKAoA4AGEAHkAKUuCwAAB9SEAAYD AAGSQDCIfgAk
DIKySZSR+N0AGcCiQAApYuAAI8nB+ZtNQF0AC4wqSOtx7gAtCMETN8NhQAAE imNE9Is0ALA3
DKSQxprJNAA3k83gBfzMuABmvJRgAZAVnAAoAkZyFMVxYGewTN1rgAC8LEkA CGt12v2EAWOy
2e02uZW233EZA2Z5nNZvOZ3PZ/QaHRaPSaXTafUanVavWa3Xa/YbHZbPabXb bfcbndbveb3f
b/gcHhcPicXjcfkcnlcvmc3na1yOd2v/RpNIIoAIjtc/ud3vd/weHSxSLRgw vJMAB5L4zgDM
SGppmrClU2713L3gB8XUhXi7GacwAA0UYNAAKpICeABhHcWAAB6iTMnwaYAC 6BIXAAcpIrWK
BYCCsxfraaR7riFqopI8iLoy9D1F8LQAFaLrzHmT6ClgMAAAI0xpkyKCjjQk K3way7RP2uz/
HkxKBhKisYozGcaxvHLSn4da6kOMq8j8WLMkSYR1AAOwanHIy8yQriBr/HRM qMFw0KUTBpHk
m4Wvyz7ySaMMnn3G0cNJFDzRW9b2zqmkqgBK8sy2mcunEAARFcD0DQRBUGQd CCpQnCsLwzM4
3SW8sVPTQT3JJHYhKOSwrvUaNBpIbBTKMFItpCa59riCZeDiADCkgABBFiYQ ABGX4fAALdep
ItpVliHkDCfH5VqYAAqKhE8mRlGk9yi1x5x2hIXEtSho0szMdzZNwAThOQzz ozJ+UyAtNySN
QHgAQYZp0PxpI4a57kMkJUVjPL7SEukyPVJLF0xCkLQxed63vfN9gBft/gBg IAKwikgvw8WP
Y/kGQ5FkeSZLk2T5RlOVZXlmW5dl+YZjmWVui6bquu7Lt5m0iGHMcKKAsD6Y yk2SGHCbCfAc
EgUIjomd6fqDTz/UMWVakJ3mShAJBwX2CY6+C6ruvIhTiAAgmMNUfKUrc5K/ Qh+HCWQAAKEE
EifOAADccK2iGQ5pAAT9+gAMAURM/SKrujJvkjVYzAAWcK2MpSOmvOQtBRQg AHeYa7CmZ/AI
GAByR5H0gHlIXMs5IuxL1v6+yXWAE8kkJS8qp3MMzzfO8+SZGAOABXn3Fw3B uzBulwhApCSt
JpDMVYAHuSIRAALD/XT112NRc21evdd2tChnY9nynLdwmfdChz3QI0WMUvPx h3dDS55mc+RP
+FvPigB4/k+WADzXnjLBklsGq6G2N5SGTJuDcm6N2bwX0EDiFAHpfie1S6O0 ergMMPJVipCa
E2DiTkAAkA4JbH2UAAA3BZHyEeJ4W4AAOBWI4GgIBIRPiLFQAAc4CQQgACkG MjQPQRupfC5E
Lbk3avlcy+h9Qn35GaGGIMAIAAfC/RoetG8RBuimKsCRWYcFok/WoZkcxggX gbMMC4T7fxAA
GEoACLxZRYjlOoE5AoABsOkBSj8tw90hAAbC9YvZXS/RkMEAGNAAISk+DYPR f8cQARzjrHeP
KPY9pAj8XJwzUZOSdk9J+UEoZRSjlJKWU0p5USplVKs8LNTqGiOsdg7QiJQj 8AAL4SQawABD
DeWUo78BokEUuakhgvhFBll2HdyZRwADIg4AB/UrHDiyD0EoAATxDmSNEE8M wggABoDYj8JA
LSYzSNsQwizsjzqiPZB4xrpE2jfAAL0dS4whTlAAOtrphAhgACWLccoABDAu b/Gcww0ggzeH
AL4PoAChEhVee1WQ25mvxAACob58iFR8AAW0Xo3BHAABaPsrgVwUmGLWgkT4 vRBy7AXC8DwO
A7kkQuIkVYjwAA5AYo0P4SSNA4npQKe5jRJQZLTH1ISJipxcKurMLjgQACjC wPZg4sQuHpGk
HYDIABai0c4HkPQjKaAAptTinVPKfAAqAl8PIEBTkJDo7+CpEQAS2EyC8As3 wqLBH+HUBdVa
rv/q0WobIJgABmBYXWptHaoCjcJICooAAZhvS2HkntAigmkawdhrdMyQ01pv TmnYAKe0/qCI
ZU4ABFBCAsAAO4v5vEOoa/Mg9cK5TtIlXavFeq+BjHqYORNCKFUMocq4U1Eg t0UGRRYG4ESK
CZCERhH56SBHtKjEV2URw4QpH/TgEZmh8PHAAEoElKAniJf+Jsgk5JNmaIoM 4WQl7JBPQmiJ
El7XNDJs5TKsdZbRVotMl+1E+IPk3hEACMImYxmdIYKwM7sgqiaLbcsuNzSQ lETYwNjgBUYF
HKTYcTELw4g1HoAANQMwqlqbMukWIfAAA/Ba78NQIlmi/hKQWFCOSKTUIxNi b0dKGjtKLh4p
QZsQgAxHiXE+KS1oeExi3F4OVigoAq06c2V8sZZy1lvLmXcvZfzBmHMWY8uS uZvLJnUoh+IB
EkEYDZZl0tVnca2YoiprBDDuRhjkCTSNwAALgYUtgkBCu+czP2gNBaENQQdH tk0tpdoCHYHL
xhmizAAHMHCs1FVkF7pEIUd8yGezrMjPEyyQhcEEKWw4Lx2AADYWh/5MgXXb FuJRDwuQ/oJE
hNqZgkRetyC6BUZZGQXYpS2gkOAZk5CQl8LEa6WwnPmVKKwPRRwqiHNAC4Ll 2wxhPCkhQKgO
QADaFAHWtQYVkGaEEKtv4fQqJLlwWmXkvqaBBu2I8T+2AbDyKqA0FwaQABOE gVwWIb0Li+EG
EaXYfptIJ06UoBYuqGg43QZzde7QqAtImt4BybSQhBccHADYyIRjSVOMIW+2 AegaRzwjhQQ+
GEk4cOWHINshHu3/wESAxgABjHTeibGmzMhPssxcQwTgAX4M1LYZO5dz7pMz xcAAfQoAKtUF
Tb4dxYt/JlyA9IpBKqDGvRrjzZuQ8j5LyflKDgNFRHeNMVmxNjTXkVsqEezd n8BBRXkXAgws
AACSlomYZhIpbCiActYSQ0dQbN0UW3R+kmbHwOEAArBJYuCrMqsYQUPAAHaL 9v/XJrh5RoIg
OPf8qdKgUADpu5uKeMJl1Ld3GjNrdIRx0tM9DqVDNEOvyoelVbXHbNcJ7fxY ixQSLEbhcQnR
DrqOEwQVAQGG6FQkjoXimhbDDtgkLjhmjurEOoTbaQk+as+STrgXHGDXEsQR 8zcPo/Tkj12b
wpfsLG+2ST7w7j5AymG1DABADAFAHAJALANAPARATAVAWOIzMlgZwlmlKuwW MHKnYasNggwd
Ka8z4NAIowcIwEGBGK4GiDsTSOPA8DPBBBEABBJBMNIe2TabWLegQUIfoo0B mj4CeiuT4dTA
YOKIYHWHMHSPUH2ryA2A+QK9U8kIoHeKaPcAiMwAIH4lsRwysM2H4HmHec0H wlsAQAiJiAbC
sNWHwHoxKAIAYJSysltCyKaATCgT6XdCzC3C7C+PdDE6WHwIoHnCcAjDeM7D XCaKtDfDFDJD
NDRDgN5CxC0HfC46TDrDCNqH5DyInD5D8NBCBCFCJCNCQ8iOdEknyHUHcJCA KryJCRzC+IlD
uNNEVDnEdDBFUXcIZD2H2PcAbB6Z5DkHmIYPcAqIlCUJlFkIpFqvbEkIYAIA RF/E/D2Kalsd
lChF+KkInGFFtGIHxGNGRB9GzG1G3G5G7G9G/HBHDHFHGNlAcNCliZyloJkH eG6LqFuFqLiE
4GWh6D4xSyQ1gGkBcQ8Ei3wAACyA0XGDkCuQSFI64CeEEheFGD6CQzmHmGwA AEkDobSE6ooJ
CF+LWBc9IAAEADyRu+cMzIctUDUVUDuGkAmxWLW9A5kVEL6nczWc4D8C4WKm yJICCLaFKEOv
QC0Bu1Awungj4z3FuJmFkDOimCe3omYQuh6EGG4hyCUAS2HJjJmm1JsI7JyK dJ4MYGGEyI4D
YEsnkBCAmTknkBwAAFIFiX+G+DpKNKQQvKUXtKa4CWqM/BggM++gQ/+H4Kob mKwJDB0PUT4A
SHNJhJkUPKpJvKvJ2taHCGmGOz+FOLKGwA+VmCCHy1ULQKVIQGyAACAHCvlK 9LBLEABLJLNL
QpEPzJDIjInIqLVIxI1I5I8AalsG6GSFsReFQeeFKG+sMD6CsJCCqC2D85kI 6GaRoC0/9HJO
TOVOXOZObOdOfOhOjOlOnOpOrOsZoOklfHPAgzS6YFBOEDM/y9EbMvQGEEOa YFIDMQSE1PGQ
SFWGEI4HbPSm/PYAAgODcBUJ8weQuE0ecPUwUog7iB4BSxSb+u2X6pwBQAIh AhEhIeeHkEeC
oKsHMa6CoA2n6FiCDAsPcd0CEAkWKCgGQoCDcBnFoEk+kLMUUFKWkKeKjAy7 LKCNCHmG6bkB
4BIQSAnIQAAFSDYBuVIGovHQ+LtREbzRLIhRQsodoWkCsAIFobmBA2MHUjqA q8oD0ACLSCSd
OAABgHVRrRuABRyhfR5R8AbD7E6NBLqTeRETmRNRnIgC6J1SSo6dqqiCS99Q 9RBSJRJRNSRR
UGwUaAMFUDaQM8E66DMccHaE0LKBaEYEaI6DoDmkjSk4DSoABStSxS0B6AKQ nP2ABP7QfQAj
xQFQI1jQOHuEWJCGAXCCuf9PGyMQUCiJCp6R+F/Q0zlKFOvVzV1V3V5V7V9V /WBWDWFWHWJW
KNaICIA5HO7X+AINB4RCQAk0gigAiIhCgA/AAoCgBQAYXkiQA6l8dgAFYO00 yUAALjQ8gAvY
8ACFIoM5lwAACGySAEizXcACM2DcABSW2lK3U0ZdMIQ3VYcQAJCqkAAXE+1w AhAkmQAICfRm
Q8l8ABuDYQ+IqUATGXkmABXjOAGsiiEABwd4Mn1jIAkBoM4FfNzemoMLkSyA A0TsNwBJJNKI
MzXksAAMrFEok+GmALMLoMmGaAFgZxkAGTcLldABdrxegBfL9gJPgwAxCS0A ADsYcFLnUeWt
C72SrAA3xMVMiCcvmc3nc/ocpzZGmS7JzQpIPmhcLqG0qHCTgmF6AEEZ7jb7 jc7rdwBeb3fQ
Bf8DsMMKgAmSEDgAaJxa19Pwa+LIeBtlCAAItu3IAN23rfuC4YAAUW7oqCoa WKMl6FKUpinK
gqSqFGMANgASQXvsN4JkiAB3P3AaJgAUwuowLZyrUtgAMm50bRvHEcx1HceR 7H0fyBIMhSHI
kiyNI8kSTJUlyZJsnSfKEoylKcqSrK0ryxLMtS3Lkuy9L8wTDMUxzJMszTPN E0zVNc2TbN03
zhOMoIEgkdoYhyIEQiR5rK+yNRkXy2xrC6miqb4AMcyDJIOyzMASzQhGadQA BMVgiAAJJDhD
RDHsjGtGGwUAAASFIwgAJ5ImU+5vhtTBIDMABrnurAUAQhE+ItPy0v0LQAFa KE/AAPIAFKLg
WIMfSDgMvQGWUEQfgAJAZJExTpMbTtFxyfBnUcGa1pyAD9hLPqM2FYljWRZV mWdaAkBKcYAC
6B1vOo6ouAAWJSEkAAnBaCKDW3btvs6/bmR8kjopQ6hBFizovBeB8VrOCwNg 1GgCVvclTWHY
tjgBZKDWWAFm5DZ9ohlW1crRQFBVvbl5XohAXXvfN936sRcD1b1M03RNPIUf FQ1HUtT3AWA3
XHlU/v1lqDWqFxLJueRo6bOWravrGs61reua7r2v7BsOxbHsmy7Ns+0bTtW1 7Ztu3bfuG4xv
OiCx1O6HoihVcWBlemRpUCsVIVNOK/bIAYCIQE28KBmnMAANFHiynieABhHc yAe3/oDLi7R4
AHKSJfswWAgvaX97mke5RgAFtbIPvddUBXpW3kjJ5k+AB9lgMAAYxHunvxTl FU/G2ArNbx5X
BcSK9qMPb9z3fex8fh124Q4y28PxYoURJhUmOwa3h4+B3CN2Dd+6DpOoTBpJ UM4W+I51ceb5
/dd530ddhvsZ/iifqgAeu9l7ZCXujiAACIVwHgAOTcq5cADmTKucc86BgjSG NK7f4c8uLUAr
lrao39uUIYRQjhJCWE0J4UQphVCuFkLYXQvhhDGGUM4aQ1S03ROxDW8J6b1B dlkIAAG+X2BI
HBX2fOGeM4olz7QABBGMGp9RODHAAfM8Qfg4RZAAAKVpU77IqDhXuEMQ5Qyp j3AAGBWqjCyl
nDCN9EzU1YCzc6AALa9RSjXJUFoFD8R3jDMwFMZ5p0UjkJKtZ4TP1tLcfGAC Lxn1xotLPHUg
0d48x7IVH2P8gRJiMAOAAV4+1ehuLCAAbouF9hSCSG8AA0gzCrAAPcSIIgAB YiVIwoZnwWpA
YRFF9j7n4I6LJJCOkdo8AAj1HyPwUJASCVMLFvhGkTIoJ+5oAA8xnFYE/KCK ko5SynlTKuVo
ABlgye2DU6cUiVRVITFeLMW3KBPkaGcEEPkTqBRU06QrUGpQff7Daf0/6AUB oFQOglBaDUHo
RQmhVC6GUNodP6HDdodJ5MrGt/c9kavAUOhMo5Bx1lfBeBYIYAAli3HKAAQx 2AAAvJtKsIIg
jVi+D6AAD5BxsCmLaUEbYABkIoAACob5WF5vBKiSsbgjnWD7M6FcFJN3ROUE +L0QYAAhgLFu
AADx5jAgAESKsR4AAcgMgMH8JKpgcEspQhUaYkjFyqUQPdRTrmgimaGFsqJU wACjCwPZgQsQ
uFqGkHYDIABai0j8HkPQjDq1cq9WCsQAKyVmrQHkCApzah0k6igtq/yKCZBe RgNAVBhAAH+H
UBdfa/yrsEAAX42QTAADMCxbipK7IbrzGgAAzq2AABmG97YeRYjgpQE6mqOz fEOiIaYk9jKv
1hrHWUuVaBDFxAAXACwAA7i/pgO4f9M5qTWX2A6zE9bNors9aC0VpAxj1pXS 0aVL6Y0zuKAC
m9OQt07p6V8G4EU+H0PsfgtQ957K2mDHOOocAADcH/V8EdD8HYPwhhHCWE8K YVwthfDGGcNY
bw5DOiKOW70UYAuERQZaqB3XqQcLgghS2wBeOwAAbAnyqO2YHBAtxKOlFyH9 ygkHRWLEiL2L
IXQKjLIyC4Kq+FTgADgGYlQkDXCxGu9sJ0liEDTFYHok4VRDo4ZnggMYTwpL xCoDkAA2hQB1
LkGEqBlBBCrKGH0Ki4xfCSlUEM9zMgg4IEeJ/LoNh5KiAaC4NK/BIGdFiG8z QvhBhGqoH7H+
SxejlOoAsXVMwcZsObm/OIVJcjzJIbUxkTVYBwA2YQSA0i4jCFvl0HoGmMaM 0cEPSBB3KaTF
QAAGw7dBaE0MMYAAYx0kcCeIeAZEgn3AAAKgQwTgAOuRsRQZOac15tIlpwAA fQoAKuqFTMYd
xY41IMEEMxahSCVUENeoWo9yZM1OADVOq9WwPA0rYd+WMj5Je25TJuT8o5TX 4CgjAuBBhYUw
9ohIZhIvbCiAd0QSQ0bW3HsoW2zdn4d4xxnjXG+Ocd49x/kHIeRcj5JyVJOH 0cYhbymgsg6x
zDpLWPsjAGwPsW2gjgfCfB3xmRoBEsQBB+EUd6/g5w/B5jviCPgigCAIkiAb 0RIo+B6D0d6A
xZvUCKdHjMAnnz0iFdG6QO/pWz+msXRyPznM1eeAR670WavO1R9d6gwDqfVe rpW7B0npfZen
pN7Qnwefa+284ABy7mA8uZAA5pzbk3jfHeP8h5HyXk/KeV8t5fzHmUm8oRvy qHnmvQeh9F6P
0npfTen9R6n1Xq/WethuQNuuIKJ8r9d7X23t/ce5917v3nvffe/+B8FJ3nEb ee+F8f5Hyflf
L+Z8353z/ofR+knD4hzvjfT+x9n7X2/ufd+99/8H4fxUN+qc36/4/0fp/V+v 9n7f3fv/h/H9
f5TKfn/l/f/H+f9f7/5/3/z/8ACGr+giT+0AMA0A8BEBMBUBcBkBsB0B0AYh
| Re: Scriped Datasource and Parent/Child relationship [message #249341 is a reply to message #249339] |
Sun, 22 July 2007 09:21  |
Tom Schindl schrieb:
My current solution for now is to restore objects with a primary key
(e.g. "person_" + node.getId() ) and pass the person as a parameter to
the subform which can use the passed Object.
Tom
FUDForum. Page generated in 0.11809 seconds
