Sometime raising exception. [message #1404292] |
Thu, 31 July 2014 01:10 |
What to do?
os : Mac
browser : Chrome 36
An error has occurred. See error log for more details.
org.eclipse.rap.rwt.internal.protocol.ProtocolUtil.getJsonForColor(Lorg/eclipse/swt/graphics/Color;Z)Lorg/eclipse/rap/json/JsonValue;
Thanks.
[Updated on: Thu, 31 July 2014 01:12] Report message to a moderator
Re: Sometime raising exception. [message #1404306 is a reply to message #1404304] |
Thu, 31 July 2014 07:18 |
thanks replayed.
I using RAP version is rap-2.3.0-R-20140610-0925.
exception trace..
!ENTRY org.eclipse.rap.jface 4 2 2014-07-29 12:57:50.962
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.rap.jface".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.rap.rwt.internal.protocol.ProtocolUtil.getJsonForColor(Lorg/eclipse/swt/graphics/Color;Z)Lorg/eclipse/rap/json/JsonValue;
at org.eclipse.rap.addons.d3chart.ChartItem.setColor(ChartItem.java:76)
at com.hangum.tadpole.mongodb.core.editors.dbInfos.comosites.InstanceInformationComposite.createConnectionChart(InstanceInformationComposite.java:618)
at com.hangum.tadpole.mongodb.core.editors.dbInfos.comosites.InstanceInformationComposite.<init>(InstanceInformationComposite.java:152)
at com.hangum.tadpole.mongodb.core.editors.dbInfos.MongoDBInfosEditor.createPartControl(MongoDBInfosEditor.java:95)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:668)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:464)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:599)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:310)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:265)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:64)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:479)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1262)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1215)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1614)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:508)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:106)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:494)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:115)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:65)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:775)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:633)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2855)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2763)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2755)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2706)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2702)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2686)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2669)
at com.hangum.tadpole.rdb.core.actions.connections.AbstractQueryAction.run(AbstractQueryAction.java:83)
at com.hangum.tadpole.rdb.core.viewers.connections.ManagerViewer$2.doubleClick(ManagerViewer.java:118)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:828)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:52)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:177)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:826)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1424)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1230)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:242)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:304)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:700)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:602)
at org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1212)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1193)
at org.eclipse.swt.widgets.Display.safeReadAndDispatch(Display.java:1176)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1168)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at com.hangum.tadpole.application.Application.createUI(Application.java:44)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:172)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:284)
at java.lang.Thread.run(Thread.java:745)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:105)
FUDForum. Page generated in 0.04034 seconds
