Unresolved requirement: Require-Capability: eclipse.platform [message #1403713] |
Fri, 25 July 2014 14:01 |
Stephen Ranger Messages: 9 Registered: November 2012 |
We recently decided to drop Java 1.7 support and I have been working on updating our software to require Java 1.8 and in the process found out that the libraries we were using from Kepler had some dependency issues and it was suggested somewhere that the new Luna libraries fixed things. So, I've been migrating our libraries to Luna-based libraries.
Now, I believe I have everything updated and I have it in a compilable state, however, it doesn't run successfully. Currently, I have it to the point where I receive the following errors in the workspace/.metadata/.log file:
!SESSION 2014-07-25 09:23:07.218 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_11
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -pluginCustomization configuration/plugin_customization.ini
Command-line arguments: -clean -pluginCustomization configuration/plugin_customization.ini
!ENTRY org.eclipse.core.filesystem.macosx 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.macosx [122]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=macosx) (|(osgi.arch=x86) (osgi.arch=ppc) (osgi.arch=x86_64)))"
!ENTRY org.eclipse.swt.win32.win32.x86 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.swt.win32.win32.x86 [75]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86))"
!ENTRY org.eclipse.core.resources.win32.x86_64 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.core.resources.win32.x86_64 [9]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=win32) (osgi.arch=x86_64))"
!ENTRY org.eclipse.equinox.launcher.win32.win32.x86 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.win32.win32.x86 [29]
!ENTRY org.eclipse.equinox.launcher.cocoa.macosx 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.cocoa.macosx [55]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=cocoa) (osgi.os=macosx) (|(osgi.arch=x86)(osgi.arch=ppc)) )"
!ENTRY org.eclipse.core.filesystem.linux.x86 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.linux.x86 [90]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=linux) (osgi.arch=x86))"
!ENTRY org.eclipse.ui.cocoa 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.ui.cocoa [23]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.ws=cocoa)"
!ENTRY org.eclipse.swt.cocoa.macosx.x86_64 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.swt.cocoa.macosx.x86_64 [71]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=cocoa) (osgi.os=macosx) (osgi.arch=x86_64) )"
!ENTRY org.eclipse.equinox.launcher.win32.win32.x86_64 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.win32.win32.x86_64 [128]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86_64))"
!ENTRY org.eclipse.swt.win32.win32.x86_64 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.swt.win32.win32.x86_64 [118]
!ENTRY org.eclipse.core.filesystem.win32.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86 [124]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=win32) (osgi.arch=x86))"
!ENTRY org.eclipse.core.resources.win32.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.core.resources.win32.x86 [95]
!ENTRY org.eclipse.equinox.launcher.cocoa.macosx.x86_64 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.cocoa.macosx.x86_64 [133]
!ENTRY org.eclipse.swt.gtk.linux.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.swt.gtk.linux.x86 [127]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=gtk) (osgi.os=linux) (osgi.arch=x86))"
!ENTRY org.eclipse.core.filesystem.win32.x86_64 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86_64 [60]
!ENTRY org.eclipse.swt.cocoa.macosx 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.swt.cocoa.macosx [28]
!ENTRY org.eclipse.equinox.launcher.gtk.linux.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.gtk.linux.x86 [50]
!ENTRY org.eclipse.osgi 4 0 2014-07-25 09:23:09.756
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "<my.app>.workspace.ui.<application>" could not be found in the registry. The applications available are: org
.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Not sure what the eclipse.platform is referring to. There's a platform.jar in the eclipse luna platform but copying that to my plugins directory doesn't fix the issue. Also, I have gotten it running ifI run it from within Eclipse (which make me think my previous issue is a bundle missing or incorrect start order) but then I get the following errors:
java.lang.NoClassDefFoundError: javafx/scene/Parent
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2688)
at java.lang.Class.getMethod0(Class.java:2937)
at java.lang.Class.getMethod(Class.java:1771)
at <my.app>.cfp.container.FxGadgetContainerBeanInfo.<init>(FxGadgetContainerBeanInfo.java:10)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
at java.lang.Class.newInstance(Class.java:433)
at com.sun.beans.finder.InstanceFinder.instantiate(InstanceFinder.java:96)
at com.sun.beans.finder.InstanceFinder.find(InstanceFinder.java:66)
at java.beans.Introspector.findExplicitBeanInfo(Introspector.java:448)
at java.beans.Introspector.<init>(Introspector.java:398)
at java.beans.Introspector.getBeanInfo(Introspector.java:173)
at <my.app>.bean.ComponentUtils.getBeanInfo(ComponentUtils.java:51)
at <my.app>.bean.ComponentUtils.getDisplayName(ComponentUtils.java:332)
at <my.app>.bean.ComponentUtils.getName(ComponentUtils.java:358)
at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList$6.compare(VisualizationComponentList.java:207)
at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList$6.compare(VisualizationComponentList.java:1)
at java.util.TimSort.countRunAndMakeAscending(TimSort.java:351)
at java.util.TimSort.sort(TimSort.java:230)
at java.util.Arrays.sort(Arrays.java:1435)
at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList.updateListData(VisualizationComponentList.java:203)
at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList.access$0(VisualizationComponentList.java:198)
at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList$4.run(VisualizationComponentList.java:170)
at <my.app>.util.concurrent.RunQueue$1.run(RunQueue.java:33)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at <my.app>.util.concurrent.MonitoredFuture.run(MonitoredFuture.java:193)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at <my.app>.util.concurrent.Executors$1$1.run(Executors.java:90)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: javafx.scene.Parent cannot be found by <my.app>.cfp_3.1.0.qualifier
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 36 more
Here's my config.ini
osgi.splashPath=platform:/base/plugins/<my.app>.workspace.ui
eclipse.application=<my.app>.workspace.ui.<application>
osgi.bundles=org.eclipse.equinox.common@2:start,\
org.eclipse.update.configurator@2:start,\
org.eclipse.equinox.ds@3:start,\
org.eclipse.equinox.registry@4:start,\
org.eclipse.equinox.app@5:start,\
<my.app>.openglstuff@4:start,\
<my.app>.logviewer@start,\
org.eclipse.osgi@5:start,\
<my.app>.workspace.collab@start,\
<my.app>.workspace.collab.app@start,\
<my.app>.messaging.app@start,\
org.eclipse.core.runtime@3:start
osgi.bundles.defaultStartLevel=6
osgi.startLevel=6
Any help would be greatly appreciated. If anyone knows where to get some kind of runtime dependency debug or info about how Luna's libraries are different from Kepler or anything that might help me fix my issue I'd be greatly appreciative. (Also, some packages were obfuscated a bit; I don't think it'll cause issues determining what's going on)
FUDForum. Page generated in 0.04452 seconds
