Howto setup EMFstore to only use my production server [message #1403604] |
Thu, 24 July 2014 14:44 |
Christian Reuter Messages: 34 Registered: October 2010 |
Member |
I have created a rap application which uses ECP and the Model Repositories view.
Now I want to get rid of the default "Local EMFstore" entry in the Model Repositories view and replace it by my production server (a manually configured EMF server).
This does not seem to work for several reasons:
1. If I delete the "serverInfos" entry which creates the "Local EMFstore" in the file <userhome>.emfstore\client\profiles\default\workspace.ucw it is automatically re-created when I start the client.
2. If I add another "serverInfos" entry to the file it is ignored (does not show up in the Model Repositories view)
3. If I try to add another repository using the UI I can not select a certificate as the select-button does nothing except deleting the name of the default cert. I checked the source code and found that there are important parts of the method selectCertificate() of the class EMFStoreUIProvider commented out. This may be due to the fact that I had to check out the latest development version however ...
Actually I do not need the GUI I just want to be able to set my production server as the only entry in the view. How can I achieve this?
Thx,
chris
[Updated on: Thu, 24 July 2014 14:44] Report message to a moderator
FUDForum. Page generated in 0.02572 seconds
