Home » Modeling » UML2 » Cannot Apply SysML Stereotypes(Unable to apply stereotypes from SysML profiles but applying stereotypes from custom profile works well)
Cannot Apply SysML Stereotypes [message #1403459] |
Wed, 23 July 2014 20:17 |
Hann Wu Messages: 2 Registered: July 2014 |
Hey everybody,
I am facing a bit of a problem here, i cannot apply stereotypes from SysML package.
I can apply the profiles and all that, but applying a stereotype doesn't work at all.
Besides SysML i am using another profile package, wich works like a charm.
For example, the stereotypeSut is from the custom profile that is loaded, while Blocks belongs to SysML.
val Class sut = syspack.createOwnedClass("SystemUnderTest", false)
sut.applyStereotype(stereotypeBlock)
sut.applyStereotype(stereotypeSut)
When is ask for the applicable stereotypes for classSut, i am presented with this output:
Check the applicable stereotypes for SystemUnderTest:
Stereotype: Block
Stereotype: PropertySpecificType
Stereotype: SYSTEM
Stereotype: SUT
Stereotype: TE
Stereotype: SUT2TE
Stereotype: TE2SUT
Stereotype: interface
Check the applied stereotypes for SystemUnderTest:
Stereotype: SUT
As far as i understand it, the SysML profile has been applied successfully and the stereotypes are recognized, but applying them fails and returns null.
I hope you can help me out, i tried various thing suggested from other threads (and i am willing to try even more) but nothing worked so far.
The language used is Xtend, but since it's just a little enhancement to java i hope that wont be a problem (answers in Java are appreciated!)
package de.hub.uml2.rtt.transformation
import de.fokus.fraunhofer.mbt.productlines.loaders.savers.umlmodel.UMLModelLoader
import de.hub.uml2.helper.transformation.HelperFunctions
import java.util.Map
import org.eclipse.emf.common.util.URI
import org.eclipse.emf.ecore.EPackage
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.emf.ecore.resource.ResourceSet
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl
import org.eclipse.emf.ecore.util.EcoreUtil
import org.eclipse.emf.mapping.ecore2xml.Ecore2XMLPackage
import org.eclipse.papyrus.sysml.SysmlPackage
import org.eclipse.papyrus.sysml.blocks.BlocksPackage
import org.eclipse.papyrus.sysml.portandflows.PortandflowsPackage
import org.eclipse.uml2.uml.AggregationKind
import org.eclipse.uml2.uml.Class
import org.eclipse.uml2.uml.DataType
import org.eclipse.uml2.uml.Element
import org.eclipse.uml2.uml.Enumeration
import org.eclipse.uml2.uml.EnumerationLiteral
import org.eclipse.uml2.uml.Model
import org.eclipse.uml2.uml.NamedElement
import org.eclipse.uml2.uml.Package
import org.eclipse.uml2.uml.Port
import org.eclipse.uml2.uml.Profile
import org.eclipse.uml2.uml.Property
import org.eclipse.uml2.uml.Stereotype
import org.eclipse.uml2.uml.UMLFactory
import org.eclipse.uml2.uml.UMLPackage
import org.eclipse.uml2.uml.VisibilityKind
import org.eclipse.uml2.uml.resource.UMLResource
class RTTModelTransformator {
static boolean DEBUG = true;
* Expects an input path from where the model is loaded and an
* output path to store the output model. The output model is stored
* for future reference and debugging purposes.
* @param filePath: source file of the UML model
def static Model transformModel( String filePath) {
//load the helper functions
val helperFunctions = new HelperFunctions;
//create the new model
val Model newModel = UMLFactory.eINSTANCE.createModel
val Package syspack = newModel.createNestedPackage("SYSTEM")
syspack.setVisibility(VisibilityKind.PUBLIC_LITERAL)
//create the blocks profile with the block stereotype
val Profile profileBlocks = loadSysmlProfile( "Blocks" )
syspack.applyProfile(profileBlocks)
val Stereotype stereotypeBlock = profileBlocks.getOwnedMember( "Block" ) as Stereotype
val Profile profilePortAndFlows = loadSysmlProfile( "PortAndFlows" )
syspack.applyProfile(profilePortAndFlows)
if(DEBUG){
System.out.println("URI of profile Blocks: "+profileBlocks.URI)
System.out.println("URI of profile PortAndFlows: "+profilePortAndFlows.URI)
val Stereotype stereotypeFlowPort = profilePortAndFlows.getOwnedMember("FlowPort") as Stereotype
val Enumeration enumerationFlowDirection = profilePortAndFlows.getOwnedMember("FlowDirection") as Enumeration
val EnumerationLiteral enumliteralFlowDirectionIn = enumerationFlowDirection.getOwnedLiteral("in")
val EnumerationLiteral enumliteralFlowDirectionOut = enumerationFlowDirection.getOwnedLiteral("out")
if(DEBUG){
System.out.println("The stereotype "+stereotypeFlowPort.name+"... ")
for(Property p : stereotypeFlowPort.ownedAttributes){
System.out.println("...has property "+p.name)
System.out.println("The stereotype "+stereotypeBlock.name+"... ")
for(Property p : stereotypeBlock.ownedAttributes){
//create profile for the stereotypes that are used in RTT
val Profile profileRtt = loadProfile("platform:/plugin/de.hub.uml2.rtt/src/RTT-MBTProfile/model.profile.uml")
syspack.applyProfile(profileRtt)
val Stereotype stereotypeSystem = profileRtt.getOwnedMember("SYSTEM") as Stereotype
val Stereotype stereotypeSut = profileRtt.getOwnedMember("SUT") as Stereotype
val Stereotype stereotypeTe = profileRtt.getOwnedMember("TE") as Stereotype
syspack.applyStereotype(stereotypeSystem)
if(DEBUG){
System.out.println("Check the applicable stereotypes for "+syspack.name+":")
for( Stereotype s : syspack.applicableStereotypes){
System.out.println("Stereotype: "+s.name)
System.out.println("Check the applied stereotypes for "+syspack.name+":")
for( Stereotype s : syspack.appliedStereotypes){
if(DEBUG){
System.out.println("Owned elements of the "+syspack.name+" package:")
for( NamedElement e : syspack.members){
System.out.println("Element: "+ e.name)
System.out.println("Applied profiles of the "+syspack.name+" package:")
for( Profile e : syspack.allAppliedProfiles){
System.out.println("Profile: "+ e.name)
System.out.println("Check the applicable stereotypes for "+sut.name+":")
for( Stereotype s : sut.applicableStereotypes){
if(DEBUG){
System.out.println("Check the applied stereotypes for "+sut.name+":")
for( Stereotype s : sut.appliedStereotypes){
val Class te = syspack.createOwnedClass("TestEnviroment", false)
te.applyStereotype(stereotypeBlock)
te.applyStereotype(stereotypeTe)
return newModel
def static Profile createProfile(String name) {
val Profile profile = UMLFactory.eINSTANCE.createProfile()
profile.setName(name)
profile.setVisibility(VisibilityKind.PUBLIC_LITERAL)
return profile;
def static ResourceSet loadResourceSet(){
val ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eCONTENT_TYPE, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNAME, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_PREFIX, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/uml2/2.0.0/UML", EPackage.Registry.INSTANCE.get(UMLPackage.eINSTANCE.getNsURI()));
EPackage.Registry.INSTANCE.put(SysmlPackage.eNS_URI, SysmlPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put(BlocksPackage.eNS_URI, BlocksPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put(PortandflowsPackage.eNS_URI, PortandflowsPackage.eINSTANCE);
Ecore2XMLPackage.eINSTANCE.getEClassifiers();
val Map uriMap = resourceSet.getURIConverter().getURIMap();
val URI urii = URI.createURI("jar:platform:/plugin/de.hub.uml2.rtt/lib/org.eclipse.uml2.uml.resources_4.1.0.v20140202-2055.jar!/");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), urii.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), urii.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), urii.appendSegment("profiles").appendSegment(""));
return resourceSet
def static Profile loadProfile( String uri ) {
val ResourceSet resourceSet = loadResourceSet()
val Resource resource = resourceSet.getResource(URI.createURI(uri), true)
resource.load(null)
val Profile p = EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.PROFILE) as Profile
return p
def static Profile loadSysmlProfile(String profilename ) {
//val Resource resource = resourceSet.getResource(URI.createURI("pathmap://SysML_PROFILES/SysML.profile.uml"), true)
val Resource resource = resourceSet.getResource(URI.createURI("platform:/plugin/de.hub.uml2.rtt/src/profiles/SysML.profile.uml"), true)
resource.load(null)
val Profile sysMlProfile = EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.PROFILE) as Profile
if(DEBUG){
System.out.println("sysMlProfile: "+sysMlProfile.name+" with URI "+sysMlProfile.URI)
val Profile p = sysMlProfile.getOwnedMember(profilename) as Profile
if(DEBUG){
System.out.println("Called profile: "+p.name+" with URI "+p.URI+" and owned elements: ")
for(Element e : p.allOwnedElements ){
System.out.println("Element with name: "+e.toString)
return p
def static Stereotype createStereotype(Profile profile, String name, boolean isAbstract){
val Stereotype stereo = profile.createOwnedStereotype(name, isAbstract)
stereo.setVisibility(VisibilityKind.PUBLIC_LITERAL)
return stereo
def static Enumeration createEnumeration(Package pack, String name){
val Enumeration enuma = pack.createOwnedEnumeration(name)
enuma.setVisibility(VisibilityKind.PUBLIC_LITERAL)
return enuma
Stereotype: Block
Stereotype: SYSTEM
Stereotype: SUT
Stereotype: TE
Stereotype: SUT2TE
Stereotype: TE2SUT
Stereotype: SUT
Re: Cannot Apply SysML Stereotypes [message #1403718 is a reply to message #1403459] |
Fri, 25 July 2014 14:18 |
See some replies in-line, below.
HTH,
Christian
On 2014-07-24 13:50:02 +0000, Hann Wu said:
> Hey everybody,
> SysML package.
What does "doesn't work at all" mean? Is there an exception thrown?
If so, the message and stack trace should tell you what the problem is.
Are you able to apply this stereotype in the UML Editor? Or does the
UML Editor simply not show the stereotype applied, but without some
error dialog appearing? Does the UML Editor not even present the
stereotype in the list of stereotypes that may be applied?
Lots of profiles have been known to work. Profiles that don't are
usually broken in some way.
> with this output:
> Stereotype: Block
> Stereotype: SYSTEM
> Stereotype: SUT
> Stereotype: TE
> Stereotype: SUT2TE
> Stereotype: TE2SUT
> Stereotype: SUT
What fails? What returns null? The
Element::applyStereotype(Stereotype) operation? Or something else?
Have you tried stepping through
ElementOperations::applyStereotype(Element, Stereotype) and its call
tree in the debugger to see where it goes off the rails?
Xtend just compiles to Java, so that shouldn't be a concern.
But I don't know what your SysML profile is. Evidently it's not the
one provided by Papyrus, because this problems hasn't been reported for
that profile.
> import
> * Expects an input path from where the model is loaded and an *
> output path to store the output model. The output model is stored *
> * * @param filePath: source file of the UML model
> if(DEBUG){
> if(DEBUG){
> as Stereotype
> if(DEBUG){
> if(DEBUG){
> if(DEBUG){
> return newModel
> return profile;
> val URI urii =
> return resourceSet
> resource.load(null)
> return p
> true)
> true)
> resource.load(null)
> if(DEBUG){
> "+sysMlProfile.URI)
> if(DEBUG){
> return p
> return stereo
> return enuma
> Stereotype: Block
> Stereotype: SYSTEM
> Stereotype: SUT
> Stereotype: TE
> Stereotype: SUT2TE
> Stereotype: TE2SUT
> Stereotype: SUT
Re: Cannot Apply SysML Stereotypes [message #1403722 is a reply to message #1403718] |
Fri, 25 July 2014 14:39 |
I see, i should have written this more detailed, sorry about that.
With 'doesnt work at all' i wanted to express, that nothing happens. No exception is thrown, but a null-object returned and the code continues (up to the point where i try to set a property of the applied stereotype, that crashes with an IllegalArgumentException since the requested stereotype is not applied).
In the list of applicable stereotypes the stereotype is listed, so it's not unknown and it exists (more or less i think), but every try to apply it results in the problem described above. By the way i didn't use the UML Editor because the code is intended to be a plugin to transform another model. But using the SysML-Profile with the editor works well.
Yeah, this one.
Quote:But I don't know what your SysML profile is. Evidently it's not the
that profile.
That's the part i don't understand either. It actually is the profile from Papyrus, directly taken from the .jar/model/.
Thanks for your help!
Since i don't have much time left to complete the project i used a workaround suggested by a friend. I know it doesn't solve the problem or explains why this happened to me, but maybe someone else runs into a similar problem and finds this helpful:
I created a template model, that contains the root package. The profiles in question were directly applied. This way the stereotype problem doens't occure and i start the transformation with editing the template.
Current Time: Fri Apr 26 10:10:25 GMT 2024
Powered by FUDForum. Page generated in 0.70519 seconds
