ProposalField in RAP and SWT [message #1403131] |
Mon, 21 July 2014 14:49 |
Dennis Geesen Messages: 46 Registered: June 2014 |
Member |
can someone confirm my potential bug!?
I want to have a proposal for a field, but it should also be possible to add own values. For example, add new cities: If it already exists, use it, otherwise create a new one.
After some investigations I found out that there was a "allowCustomText" property, which was removed in 4.0 due to redesign and the introduction of the proposal field.
So I used the proposal field to implement my content assits field.
First question is: Is this the new and correct field!?
It seems to work within SWT, but in my RAP client I cannot add any custom text, because I only can choose from proposed values. so in RAP the proposal field has the same behavior like in SWT. Therefore, my second question is: Is it a bug or is some setting missing?
The code is simple, but here it is:
@Order(20.0)
public class CityField extends AbstractProposalField<Long> {
protected String getConfiguredLabel() {
return TEXTS.get("City");
protected Class<? extends ILookupCall<Long>> getConfiguredLookupCall() {
return CityLookupCall.class;
thanks!
Re: ProposalField in RAP and SWT [message #1403184 is a reply to message #1403131] |
Tue, 22 July 2014 08:59 |
Jeremie Bresson Messages: 1252 Registered: October 2011 |
Dennis Geesen wrote on Mon, 21 July 2014 16:49After some investigations I found out that there was a "allowCustomText" property, which was removed in 4.0 due to redesign and the introduction of the proposal field.
This is correct.
It was introduced with Scout 4.0.0 and refactoring: „Add generics in LookupCall and LookupServices"
I never took time to look at this new field, so your question is a good opportunity for me.
In SWT it looks like this:
When I enter "Baden" that is not in the list, I can enter it:
The LookupCall is from type Long, see the list of LookupRow I use in the Server:
return Arrays.asList(
toLookupRow(1L, "Zurich"),
toLookupRow(3L, "Basel"),
toLookupRow(7L, "Bern")
Notice that the CityField is a Value Type form type String.
When I do "getValue()" on the CityField I get: "Baden" or "Basel" (and not the Long key 3L as it would be the case with a SmartField).
The behavior is exactly the same with RAP.
I imagine you have other expectations (or I have not understood your question). Can you describe what you expect?
FUDForum. Page generated in 0.03554 seconds
