| Gcov .c annotation failure [message #1403023] |
Sun, 20 July 2014 01:53   |
Eclipse User  |
I just learned of the Linux Tools project. I downloaded the 64-bit Eclipse Luna 4.4.0 CDT version on a 64-bit Scientific Linux box. I added --coverage to the compile and link lines and was immediately able to generate and see the coverage report and line highlighting for the created-by-eclipse "hello world" C++ project.
When I tried the same procedure with the created-by-eclipse "hello world" C project, I could get the coverage report view, but when I click on the c-file from the report, I get an error:
Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
java.lang.ArrayIndexOutOfBoundsException: 3
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModel.createAnnotations(GcovAnnotationModel.java:216)
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModel.updateAnnotations(GcovAnnotationModel.java:139)
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModel.<init>(GcovAnnotationModel.java:83)
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModel.attach(GcovAnnotationModel.java:106)
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModelTracker.annotateCEditor(GcovAnnotationModelTracker.java:157)
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModelTracker.access$1(GcovAnnotationModelTracker.java:149)
	at org.eclipse.linuxtools.internal.gcov.view.annotatedsource.GcovAnnotationModelTracker$2.partOpened(GcovAnnotationModelTracker.java:76)
	at org.eclipse.ui.internal.PartService$10.run(PartService.java:201)
	at org.eclipse.ui.internal.PartService.partOpened(PartService.java:198)
...etc.
I tried in a new workspace with the same results. Is it something I'm doing? Since this is an unadulterated new installation using the eclipse, new "hello world" C-project, I can't see what I might have introduced into the process. I'm left wondering if there is something missing on my Linux box, but it is working for the C++ project.
Any ideas?
FUDForum. Page generated in 0.06166 seconds
