Home » Modeling » TMF (Xtext) » How to launch the XTend compilation after having generating Xtend code?
How to launch the XTend compilation after having generating Xtend code? [message #1402832] Thu, 17 July 2014 13:22 Go to next message
I have a DSL, powered by Xtext, that generates Xtend code.
When I edit a model of my DSL the Xtend code is correctly generated in a dedicated folder (different than xtend-gen) but not compiled.
To compile the generated xtend code, I need to open the xtend files, add a space, and save (refresh, clean, and co do not work).
How can I (programmatically) trigger the Xtend compilation after the generation of my code?
ARno
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402849 is a reply to message #1402832] Thu, 17 July 2014 16:14 Go to previous messageGo to next message
what about call the builder (clean build) for the project?
(retrieve the IProject and call build on it?)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402850 is a reply to message #1402849] Thu, 17 July 2014 16:18 Go to previous messageGo to next message
I just tried that and it does not work (nothing happens, no error in the error console):
project.build(IncrementalProjectBuilder::FULL_BUILD, null)
My DSL is here:
github.com/arnobl/kompren/tree/master/kompren-editor/fr.inria.diverse.kompren.xtext
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402851 is a reply to message #1402850] Thu, 17 July 2014 16:20 Go to previous messageGo to next message
Same result for: project.build(IncrementalProjectBuilder::CLEAN_BUILD, null)
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402853 is a reply to message #1402851] Thu, 17 July 2014 16:30 Go to previous messageGo to next message
project.touch(null) or disabling the auto-build of the project to manually build have no effect. :s
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402857 is a reply to message #1402850] Thu, 17 July 2014 16:47 Go to previous messageGo to next message
make sure
- you called refresh on the project first
- the project has xtext nature and xtext builder added
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402860 is a reply to message #1402857] Thu, 17 July 2014 17:10 Go to previous messageGo to next message
The project has the xtext nature and text builder since the xtend files are compiled if a modified them manually.
I tried brutal things:
ResourcesPlugin.getWorkspace().getRoot().projects.forEach[proj|
proj.refreshLocal(IResource.DEPTH_INFINITE, null)
proj.touch(null)
proj.build(IncrementalProjectBuilder::CLEAN_BUILD, null)
myXtendFile.touch(null)
myXtendFile2.touch(null)
but the xtend files are still not compiled when editing my DSL model.
Is there something to add in the mwe2 or something to bind to chain the xtend/xtext builder to my dsl?
[Updated on: Thu, 17 July 2014 17:11] by Moderator
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402873 is a reply to message #1402860] Fri, 18 July 2014 01:07 Go to previous messageGo to next message
Last question: are the files within a source folder.
Can you give a step by step description on how to reproduce?
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402878 is a reply to message #1402873] Fri, 18 July 2014 03:16 Go to previous messageGo to next message
Yes, the files are within a source folder.
To reproduce the problem:
1. Download our Eclipse studio (https://ci.inria.fr/diverse-commons/job/diverse-studio/)
2. Download the following project (https://github.com/arnobl/kompren/raw/master/kompren-examples/eclipseProjectTemplate.zip)
3. Import this last as an existing project into our Eclipse studio and move to the Java perspective
4. Open the file mySlicer.kompren
5. Add the line slicedProperty: ecore.ENamedElement.name at the end of this file
-> The compilation process starts: Xtend files are generated into the folder kompren-gen
-> These xtend files are not then compiled in Java code (into the folder xtend-gen)
When opening one of these xtend files to modify it manually, the xtend compilation starts.
Sometimes (very rarely), the xtend files are automatically compiled. I remove the generated Java files to see whether they are re-compiled but nothing happens.
The problem also appears with a standard Eclipse (4.3 and 4.4) supplemented with the required plugins (this is my case). I pointed you our Eclipse studio just to simplify the replication of the problem.
[Updated on: Fri, 18 July 2014 03:20] by Moderator
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402882 is a reply to message #1402878] Fri, 18 July 2014 03:48 Go to previous messageGo to next message
where do i find the code that calls the refesh?
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402883 is a reply to message #1402882] Fri, 18 July 2014 03:53 Go to previous messageGo to next message
Here (I just commited):
https://github.com/arnobl/kompren/blob/master/kompren-editor/fr.inria.diverse.kompren.xtext/src/fr/inria/diverse/kompren/generator/KomprenGenerator.xtend
The eclipse studio I pointed you does not contain this commit, but it still does not work for me in my dev eclipse.
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402889 is a reply to message #1402883] Fri, 18 July 2014 04:41 Go to previous messageGo to next message
sorry i have no further ideas on that.
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402890 is a reply to message #1402889] Fri, 18 July 2014 04:47 Go to previous messageGo to next message
Ok thx :s
Is that possible to launch the compilation programmatically?
I tried that from lines 62 to 66 in the file KomprenGenerator.xtend (see my previous post) but I get the following error message while the files exist:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.FileNotFoundException: /KomprenSlicerTemplate/src/main/kompren-gen/myslicer/MySlicer.xtend
Re: How to launch the XTend compilation after having generating Xtend code? [message #1402892 is a reply to message #1402890] Fri, 18 July 2014 04:57 Go to previous message
I have finally a manual workaround better than modifying the xtend files.
If a remove the source folder that should contain the java files, there are re-generated (it works only when I remove the source folder, ie removing a java package has no effect).
Previous Topic:RFC: Can we remove these quirky grammar rules?
Next Topic:Question marks in text file generated by Xtend
Current Time: Mon Sep 01 13:59:12 EDT 2025
Powered by FUDForum. Page generated in 0.06776 seconds
