Home » Language IDEs » Java Development Tools (JDT) » How to extend the Java Compiler in your application
How to extend the Java Compiler in your application [message #246297] Sat, 28 July 2007 08:39 Go to next message
Originally posted by: abaketa.yahoo.com
hii alll
i need to add the JavaCompiler into my RCP application, as i may create
some classes in a Text files and need to compile it before i save it.
So i take a compiled Code for the class (.class files).
please if u know any suggestion, give it ASAP
Re: How to extend the Java Compiler in your application [message #246365 is a reply to message #246297] Mon, 30 July 2007 16:31 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Moutaz,
Eclipse Java compiler is in org.eclipse.java.core plugin. From what I
see, there is one compiler class exposed in API:
org.eclipse.jdt.core.dom.CompilationUnitResolver
However I am not sure if using CompilationUnitResolver is the suggested
way to compile your own source code.
The core compiler stuff is in org.eclipse.jdt.internal.compiler.*, and
it's used by two tools: JavaBuilder - for compiling source code in
Eclipse environment and batch builder, that can be called from command
line. You may take a look how these tools do compiling.
Moutaz wrote:
> hii alll
> create some classes in a Text files and need to compile it before i
> save it.
Re: How to extend the Java Compiler in your application [message #246374 is a reply to message #246365] Mon, 30 July 2007 18:09 Go to previous messageGo to next message
Jacek Pospychala a écrit :
> Moutaz,
It is rather org.eclipse.jdt.core.
This should not be used to simply compile Java code.
You can either use the batch compiler or use the JSR199 support.
For the jsr199 support, you would need the plugin
org.eclipse.jdt.compiler.tool and org.eclipse.jdt.core.
You don't actually need the whole org.eclipse.jdt.core contents. You
might want to add the ecj.jar on the classpath of your plugin.
ecj.jar contains all the required types for the batch compiler and the
jsr199 support.
Let me know if you need more details.
Olivier
Re: How to extend the Java Compiler in your application [message #246379 is a reply to message #246374] Mon, 30 July 2007 18:50 Go to previous message
Olivier,
thanks for clarification.
I didn't know ecj.jar is stripped to have even less than jdt.core. I'll
have to look into it.
>> Moutaz,
>> and it's used by two tools: JavaBuilder - for compiling source code
>> in Eclipse environment and batch builder, that can be called from
>> command line. You may take a look how these tools do compiling.
> jsr199 support.
> Olivier
Previous Topic:resolve type binding for argument list?
Next Topic:Java model event delivery question
Current Time: Mon Nov 10 07:15:40 EST 2025
Powered by FUDForum. Page generated in 0.04475 seconds
