Home » Eclipse Projects » GEF » Startup Performance
| Startup Performance [message #246221] |
Mon, 17 November 2008 09:44  |
Hi All
With a growing number of edit parts (> 5000) the initialization time of a
gef editor can increase to several seconds.
After some profiling we found that a great deal of the time is taken by
the org.eclipse.draw2d.EventListenerList.addListener() class due to a
System.arraycopy() for each listener added to the list.
The attached snippets demonstrates the slow down caused by the
EventListenerList class for a growing number of edit parts by measuring
the time for EditorViewer.setContents().
2000 edit parts: 141 ms
10000 edit parts: 1828 ms
20000 edit parts: 7109 ms
40000 edit parts: 31235 ms
By removing the array copy in the EventListenerList (see attached
EventListenerList.java) and replacing the internal array with a map, we
got the following numbers:
2000 edit parts: 110 ms
10000 edit parts: 375 ms
20000 edit parts: 594 ms
40000 edit parts: 1297 ms
The performance gain is quite obvious.
It boils down to a different approach on the array copy strategy: The
attached EventListenerList implementation does the copy of the array when
iterating over the list while the draw2d/GEF version performs the copy
operation when adding a listener to the list. However the attached version
may slow down updating the edit parts/figures. Our tests with and editable
editor hasn't shown a perceivable slow down though.
We hope somebody can look at this issue and let us know if there's a
chance that the EventListenerList implementation is changed for the next
release. We can also write a bug report if needed.
Iwan
Test environment:
- Intel Core 2, T7200 @ 2 GHz, 2 GB Ram
- JavaSE-1.6
- org.eclipse.jface 3.4.0
- org.eclipse.gef 3.4.1
- org.eclipse.core.runtime 3.4.0
- com.ibm.icu 3.8.1
To run the example just create a new Pluin project, add the dependencies
listed above to the Manifest and copy the attached
EventListenerPerformance.java. To replace the EventListenerList you need
to import the org.eclipse.draw2d plug-in into the workspace as a source
project and replace the org.eclipse.draw2d.EventListenerList class by the
one attached to this message.
| Re: Startup Performance [message #246234 is a reply to message #246221] |
Mon, 17 November 2008 10:00   |
--------------090301050702020400080603
.... and the attachments.
- Iwan
name="EventListenerList.java"
Content-Disposition: inline;
filename="EventListenerList.java"
package org.eclipse.draw2d;
import java.util.ArrayList;
import java.util.Collections;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
* This class is intended for internal use only. TODO: If this is for internal
* use only, we should move it to the internal package.
public final class EventListenerList {
private final Map listenersMap = new HashMap();
* Adds a listener of type <i>c</i> to the list.
* @param c
* the class
* @param listener
* the listener
public synchronized void addListener(Class c, Object listener) {
if (listener == null || c == null) {
throw new IllegalArgumentException();
List listeners = (List) listenersMap.get(c);
if (listeners == null) {
listeners = new ArrayList(2);
listenersMap.put(c, listeners);
listeners.add(listener);
* Returns <code>true</code> if this list of listeners contains a listener
* of type <i>c</i>.
* @param c
* the type
* @return whether this list contains a listener of type <i>c</i>
public synchronized boolean containsListener(Class c) {
return listenersMap.containsKey(c);
* Returns an Iterator of all the listeners of type <i>c</i>.
* @param listenerType
* the type
* @return an Iterator of all the listeners of type <i>c</i>
public synchronized Iterator getListeners(final Class listenerType) {
if (listenersMap.get(listenerType) != null) {
return new ArrayList(((List) listenersMap.get(listenerType)))
.iterator();
return Collections.EMPTY_LIST.iterator();
* Removes the first <i>listener</i> of the specified type by identity.
* @param c
* the type
* @param listener
* the listener
public synchronized void removeListener(Class c, Object listener) {
if (listeners != null) {
listeners.remove(listener);
name="EventListenerPerformance.java"
filename="EventListenerPerformance.java"
package ch.there.diagramxy;
import java.util.HashSet;
import java.util.Set;
import org.eclipse.draw2d.ColorConstants;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.FreeformLayer;
import org.eclipse.draw2d.FreeformLayout;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.LineBorder;
import org.eclipse.draw2d.PolylineConnection;
import org.eclipse.draw2d.RectangleFigure;
import org.eclipse.draw2d.XYLayout;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.EditPartFactory;
import org.eclipse.gef.editparts.AbstractConnectionEditPart;
import org.eclipse.gef.editparts.AbstractGraphicalEditPart;
import org.eclipse.gef.editparts.ScalableFreeformRootEditPart;
import org.eclipse.gef.ui.parts.ScrollingGraphicalViewer;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
public class EventListenerPerformance {
// Edit parts ===========================
static class DiagramEditPart extends AbstractGraphicalEditPart {
public DiagramEditPart(Diagram diagram) {
setModel(diagram);
private Diagram getDiagram() {
return (Diagram) getModel();
protected IFigure createFigure() {
FreeformLayer layer = new FreeformLayer();
layer.setLayoutManager(new FreeformLayout());
layer.setBorder(new LineBorder(1));
return layer;
protected void createEditPolicies() {
protected List<Line> getModelChildren() {
return new ArrayList<Line>(getDiagram().getLines());
static class LineEditPart extends AbstractGraphicalEditPart {
public LineEditPart(Line line) {
setModel(line);
return layer;
private Line getLine() {
return (Line) getModel();
protected List<Point> getModelChildren() {
return getLine().getPoints();
static class PointEditPart extends AbstractGraphicalEditPart {
public PointEditPart(Point point) {
setModel(point);
RectangleFigure fig = new RectangleFigure();
return fig;
private Point getPoint() {
return (Point) getModel();
protected void refreshVisuals() {
RectangleFigure figure = (RectangleFigure) getFigure();
figure.setPreferredSize(3, 3);
LineEditPart parent = (LineEditPart) getParent();
parent.setLayoutConstraint(this, figure, new Rectangle(getPoint()
.getX(), getPoint().getY(), -1, -1));
public List<Connection> getModelSourceConnections() {
Connection connection = getPoint().getSourceConnection();
if (connection == null) {
return Collections.emptyList();
List<Connection> list = new ArrayList<Connection>(1);
list.add(connection);
return list;
public List<Connection> getModelTargetConnections() {
Connection connection = getPoint().getTargetConnection();
return list;
static class ConnectionEditPart extends AbstractConnectionEditPart {
public ConnectionEditPart(Connection connection) {
setModel(connection);
PolylineConnection connection = (PolylineConnection) super
.createFigure();
return connection;
// Edit Part Factory ==========================================
static class DiagramEditPartFactory implements EditPartFactory {
private int editPartCount = 0;
public EditPart createEditPart(EditPart context, Object model) {
editPartCount++;
if (model instanceof Diagram) {
return new DiagramEditPart((Diagram) model);
} else if (model instanceof Line) {
return new LineEditPart((Line) model);
} else if (model instanceof Point) {
return new PointEditPart((Point) model);
} else if (model instanceof Connection) {
return new ConnectionEditPart((Connection) model);
return null;
* Clears the edit part count.
* @return the previous value of {@link #editPartCount}.
int clearEditPartCount() {
int oldValue = editPartCount;
this.editPartCount = 0;
return oldValue;
// Figures ====================================================
static class LineFigure extends Figure {
private final RectangleFigure rectangle;
public LineFigure() {
setLayoutManager(new XYLayout());
rectangle = new RectangleFigure();
add(rectangle);
protected void paintFigure(Graphics graphics) {
setConstraint(rectangle, new Rectangle(0, 0, 10, 10));
rectangle.invalidate();
static class PointFigure extends Figure {
public PointFigure() {
add(rectangle);
setConstraint(rectangle, new Rectangle(0, 0, 3, 3));
// Model ======================================================
static class Diagram {
private final Set<Line> lines = new HashSet<Line>();
public void addLine(Line line) {
lines.add(line);
public void removeLine(Line line) {
lines.remove(line);
public Set<Line> getLines() {
return lines;
static public class Line {
private final List<Point> points;
public Line(List<Point> points) {
this.points = Collections.unmodifiableList(new ArrayList<Point>(
points));
public List<Point> getPoints() {
return points;
static class Point {
private int x;
private int y;
private Connection sourceConnection;
private Connection targetConnection;
public Point(int x, int y) {
this.x = x;
this.y = y;
public int getX() {
return x;
public void setX(int x) {
this.x = x;
public int getY() {
return y;
public void setY(int y) {
this.y = y;
public Connection getSourceConnection() {
return sourceConnection;
public void setSourceConnection(Connection sourceConnection) {
this.sourceConnection = sourceConnection;
public Connection getTargetConnection() {
return targetConnection;
public void setTargetConnection(Connection targetConnection) {
this.targetConnection = targetConnection;
static class Connection {
private final Point source, target;
public Connection(Point source, Point target) {
if (source == null || target == null) {
throw new IllegalArgumentException("null not allowed");
this.source = source;
this.target = target;
this.source.setSourceConnection(this);
this.target.setTargetConnection(this);
public Point getSource() {
return source;
public Point getTarget() {
return target;
// Main ============================================================ =
Display display = new Display();
Shell shell = new Shell(display);
ScrollingGraphicalViewer viewer = new ScrollingGraphicalViewer();
viewer.createControl(shell);
shell.setLayout(new FillLayout());
viewer.setRootEditPart(new ScalableFreeformRootEditPart());
viewer.getControl().setBackground(ColorConstants.white);
DiagramEditPartFactory editPartFactory = new DiagramEditPartFactory();
viewer.setEditPartFactory(editPartFactory);
setContents(viewer, editPartFactory, 10, 100);
setContents(viewer, editPartFactory, 50, 100);
setContents(viewer, editPartFactory, 100, 100);
setContents(viewer, editPartFactory, 200, 100);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private static void setContents(ScrollingGraphicalViewer viewer,
DiagramEditPartFactory editPartFactory, int lineCount,
int pointCount) {
viewer.setContents(null);
Diagram diagram = new Diagram();
for (int i = 0; i < lineCount; i++) {
List<Point> points = new ArrayList<Point>();
Point lastPoint = null;
for (int j = 0; j < pointCount; j++) {
Point point = new Point(j * 20, i * 12 + j * 10);
if (lastPoint != null) {
new Connection(lastPoint, point);
points.add(point);
lastPoint = point;
diagram.addLine(new Line(points));
Diagram model = diagram;
long start = System.currentTimeMillis();
viewer.setContents(model);
System.out.println(editPartFactory.clearEditPartCount()
+ " edit parts: " + (System.currentTimeMillis() - start)
+ " ms");
--------------090301050702020400080603--
| Re: Startup Performance [message #246246 is a reply to message #246234] |
Mon, 17 November 2008 10:48   |
Hi Iwan,
Can you cut and paste this entire thread into a Bugzilla?
Cheers...
Anthony
"Iwan Birrer" <iwanbirrer@bluewin.ch> wrote in message
news:gfs0tm$8j3$1@build.eclipse.org...
> - Iwan
> internal
> * @param c
> * the class
> * @param listener
> * the listener
> * of type <i>c</i>.
> * @param c
> * the type
> * the type
> .iterator();
> * @param c
> * the type
> * @param listener
> * the listener
> import org.eclipse.swt.widgets.Display;
> setModel(diagram);
> @Override
> return layer;
> @Override
> @Override
> setModel(line);
> @Override
> return layer;
> @Override
> @Override
> setModel(point);
> @Override
> return fig;
> @Override
> @Override
> @Override
> return list;
> @Override
> return list;
> @Override
> .createFigure();
> return connection;
> @Override
> @Override
> editPartCount++;
> return null;
> return oldValue;
> add(rectangle);
> @Override
> add(rectangle);
> @Override
> lines.add(line);
> lines.remove(line);
> return lines;
> points));
> return points;
> private int x;
> private int y;
> this.x = x;
> this.y = y;
> public int getX() {
> return x;
> this.x = x;
> public int getY() {
> return y;
> this.y = y;
> return source;
> return target;
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
> int pointCount) {
> points.add(point);
> lastPoint = point;
> + " ms");
Current Time: Sat Nov 08 15:18:04 EST 2025
Powered by FUDForum. Page generated in 0.04264 seconds
