Home » Archived » BIRT » inner tables and parameters from outer tables
inner tables and parameters from outer tables [message #245884] Mon, 02 July 2007 09:26 Go to next message
Hi!
I am testing BIRT2.2 and have some problems with
inner tables.
My inner table should take a report parameter from an outer table
(row["id_order_entry"])
It worked with 2.2M5, now it doesn't.
The error I get is the following:
ReportDesign (id = 1):
- Cannot execute the statement.
SQL statement does not return a ResultSet object.
SQL error #1: No value specified for parameter 1.
odaconsumer.CannotExecuteStatement ( 1 time(s) )
detail : org.eclipse.birt.data.engine.core.DataException: Cannot execute
the statement.
It seems that no parameter is passed.
Could you please help me ?
Thank you in advance,
Nico
Re: inner tables and parameters from outer tables [message #245946 is a reply to message #245884] Mon, 02 July 2007 10:53 Go to previous messageGo to next message
Nico,
Take a look at this example:
http://wiki.eclipse.org/MasterDetailOneReport_%28BIRT%29
Jason
Nico wrote:
> Hi!
> inner tables.
> the statement.
> Nico
Re: inner tables and parameters from outer tables [message #246758 is a reply to message #245946] Sun, 08 July 2007 04:36 Go to previous message
Originally posted by: aaa.aaa.it
Jason Weathersby ha scritto:
> Nico,
> Jason
> Nico wrote:
>> Hi!
>> inner tables.
>> Nico
Hi!
I solved my problem.
I'd like the all the newsgroup to know that a parameter in query NOW
(with BIRT 2.2) requires (mandatory!!!) a default value (even if the
message in query section says that you SHOULD not leave an empty-value).
In that way the query is executed and then the correct parameter from
inner table is passed.
Now my reports work good like before :)
I hope that it helps.
Bye Nico
Previous Topic:default values in cascading parameters broken
Next Topic:Problem with ODA driver after upgrade to BIRT 2.2
Current Time: Sat Aug 16 07:06:51 EDT 2025
Powered by FUDForum. Page generated in 0.04230 seconds
