Home » Eclipse Projects » Sirius » Style of selected item in tree editor
Style of selected item in tree editor [message #1396624] Tue, 08 July 2014 11:10 Go to next message
I am currently building a tree editor. Thereby I am experiencing the problem that the label of the selected element is set to white, making it invisible as the background is white too. Is it possible to configure the style of the selected element? I tried to use a conditional style, however, I did not find a variable that holds the currently selected element.
Marvin
Re: Style of selected item in tree editor [message #1397378 is a reply to message #1396624] Wed, 09 July 2014 12:30 Go to previous messageGo to next message
Le 08/07/2014 19:38, Marvin Grieger a écrit :
Hi Marvin,
> element.
The conditional style and the style will change the background and label
colors of non seleted elements.
The selected background and label colors of a selected element are
expected to be the system selection color. On my computer I tried with a
tree where elements have a style with both colors set to white, when I
select an (invisible) element, it becomes gray with a black label (win
8, luna).
On which system are you ?
> Best regards,
> Marvin
Maxime
Re: Style of selected item in tree editor [message #1404938 is a reply to message #1397378] Wed, 06 August 2014 03:37 Go to previous messageGo to next message
Hi Maxime,
sorry for my late response.
Maxime Porhel wrote on Wed, 09 July 2014 12:30
Maxime
I am using Eclipse Luna 4.4.0 on Mac OS X 10.9.4.
Marvin
Re: Style of selected item in tree editor [message #1405953 is a reply to message #1404938] Fri, 08 August 2014 11:38 Go to previous message
Le 06/08/2014 09:37, Marvin Grieger a écrit :
> Hi Maxime,
>> Maxime
Can you open a bugzilla issue about this, and mention the fact you are
under Mac OS X?
Thanks.
Pierre-Charles David - Obeo
Need professional services for Sirius?
Previous Topic:How to syncronize an ongoing simulation?
Next Topic:Custom DSL with Sirius
Current Time: Sun Sep 21 14:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.03990 seconds
