[EMF / CDO] Unexpected "Class not found exception" [message #1396598] |
Tue, 08 July 2014 14:30 |
Bernard Sarter Messages: 88 Registered: August 2011 Location: Paris, France |
Member |
I've found following exception in the log of my EMF / CDO RAP application:
I'll investigate the root cause, but at a glance I've the feeling that the BasicIndexOutOfBoundsException "class not found" is probably a (minor) problem inside the EMF / CDO framework ... Right ?
My target platform is supposed to be in sync with Luna:
- org.eclipse.net4j.util_3.4.0.v20140308-0604
- org.eclipse.emf.common_2.10.0.v20140514-1158
[ERROR] org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException cannot be found by org.eclipse.net4j.util_3.4.0.v20140308-0604
java.lang.ClassNotFoundException: org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException cannot be found by org.eclipse.net4j.util_3.4.0.v20140308-0604
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at java.io.ObjectInputStream.resolveClass(Unknown Source)
at org.eclipse.net4j.util.io.ExtendedIOUtil$3.resolveClass(ExtendedIOUtil.java:168)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:177)
at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:129)
at org.eclipse.net4j.util.io.ExtendedIOUtil.deserializeThrowable(ExtendedIOUtil.java:424)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:47)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:331)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:256)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
[ERROR] org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=13, size=13
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:346)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadChunkIndication.responding(LoadChunkIndication.java:105)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:134)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:301)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)
best regards,
Bernard.
FUDForum. Page generated in 0.03140 seconds
