Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Query on multipackages metamodel
Re: Query on multipackages metamodel [message #24294 is a reply to message #24074] |
Wed, 22 February 2006 13:41 |
Hello, sf76,
In the validation case, all that you should need to do is to specify each of
your EPackages in <package> elements in your <constraintProvider>
extension.
Regarding the OCL query, can you provide an example of how you are
formulating your query? You shouldn't (AFAIK) have any problems with
multiple packages. For example, if your packages look like
pkg1
Class1
ref1 : pkg2.Class2
ref2 : Class1
pkg2
Class2
x : EInt
pkg3
Class3 -> pkg1.Class1
Then an OCL query such as
new SELECT(
new FROM(resource.getContents()),
new WHERE(new OCLConstraintCondition(
"ref1.x > 0 and ref2.oclIsKindOf(pkg1::pkg2::pkg3::Class3)",
Pkg1Package.Literals.CLASS1)));
should work fine to select all Class1s related to a Class2 with positive x
and referencing a Class3.
HTH,
Christian
sf76 wrote:
> Dear all,
> i'm trying to use the OCL/QUERY plugins functionality in order to create
> ocl query working on a metamodel defined with multiple packages, i.e
> pkg 1
> -- pkg 2
> -- pkg 3
> -- pkg4
> but i haven't found a way to make things works when the ocl expression use
> attributes (or features) of elements defined into different packages (i.e
> starting from an object defined into pkg2 look for all the related object
> defined into pkg4 using some attributes defined into pkg3...)
> It seems to me that all provided example works on models defined with just
> one package, whats the proper way to make the query works even in the
> general case?
> The same problem applys for the VALIDATION plugin too when it is time to
> define which package an (ocl) constraint works on in the plugin.xml
> file...
> Any help will be appreciated.
> Best regards
Re: Query on multipackages metamodel [message #25275 is a reply to message #24991] |
Thu, 23 February 2006 17:37 |
Hi, Ssf76,
See responses in-line.
HTH,
Christian
sf76 wrote:
> Dear Christian,
> here are the result of my trial:
> 1. OCL plugin
> Assume the MM is defined this way:
> - pkg1 which contain the following two packages
> -pkg2 which contain the real object and relationship
> -pkg3 which just contain classes that extend the one of pkg2
> I've got a gef editor that show instance of this emf MM and from another
> plugin (at least for now) i would like to perfomr ocl query on the
> selected object (which will be an instance of element defined into pkg3)
> Pkg3ElementX context = (Pkg3ElementX) selectedObject;
> //wanted is defined at pkg2 level and it is recognized well
> //name is defined at pkg1 level and works ok too
> String ocl = "self.wanted->select( name='xxx' and
> oclIsTypeOf(Pkg3ElementY))";
> IOclHelper helper = HelperUtil.createOclHelper( new
> EcoreEnvironmentFactory(
> context.eResource().getResourceSet().getPackageRegistry()));
> helper.setContext(context);
> helper.evaluate(context, oclExpression);
> Everything works if i use an element defined at pkg3 inside the
> oclIsTypeOf expression above, but i'm not able to use element defined in
> the other pkgs (i got an "Unrecognizable type" error).
Are you using, for example,
oclIsTypeOf(pkg1::pkg2::Pkg2ElementX))";
or even just
oclIsTypeOf(pkg2::Pkg2ElementX))";
to qualify the name of the classifier that you are referencing?
Either of these should work. Note that qualified names in OCL are separated
by '::', not by '.'
The trick, here, is that the default context package for an expression whose
context classifier is Pkg3ElementY is pkg3. When the parser fails to find
the referenced name in the default context package, it will look in the
super-package and so on to the root package namespace until it finds the
name. This is why both 'pkg2::Pkg2ElementX' and 'pkg1::pkg2::Pkg2ElementX'
should work.
Do your packages have namespace prefixes of the following form?
pkg1
pkg2
pkg3
or of this form?
pkg1
pkg1.pkg2
pkg1.pkg2.pkg3
If the latter, then I suspect that something may be broken in our parser.
> 2. QUERY plugin
> SELECT s = new SELECT(
> new FROM( complete ), //the list of obj contained into the resource
> new WHERE(
> new OclConstraintCondition(
> "self.rel1->select( oclIsKindOf( pathToObjType )->size() > 0 ",
> Pkg2.eINSTANCE.getContext()
> where pathToObjType is composed this way:
> - nsPrefixOfThePkg::ObjectClass and it is related to the pkg of the
> context element.
> This way (since context is of pkg2) i'm able to use object of pkg3 but not
> the ones of the others (pkg1, pkg2). Other ways of specifying
> pathToObjType gives me the "Unrecognizable type" error.
> I think that this problems are in fact related and could have just a
> common cause. Do you have any suggestion?
Yes, this will be the identical problem (the environment works the same way
under the hood).
> TIA
Re: Query on multipackages metamodel [message #25560 is a reply to message #25521] |
Fri, 24 February 2006 14:48 |
Yes, indeed, this looks like a problem.
I've always been a little disconcerted by the OCL parser's usage of nsPrefix
instead of names, and it seems some bad assumptions were made regarding the
structure of the nsPrefix generated by EMF.
I'll appreciate it if you can raise a bugzilla with details of your
scenario, so that we can reproduce and address this problem.
Christian
sf76 wrote:
> Dear Christian,
> after some test i come out with the following "rules" in order to qualify
> the name of the classifier in expression like oclIsTypeOf(p1::p2::Element)
> using the ocl and query plugins:
> - if the expr is of type pkg::Element then i could use either the name of
> the pkg either its ns prefix and this way i could create query to
> reference element present in any pkg of the model
> - if the expr is of type pkg1::pkg2::...::pkgN::Element then the first
> package should be defined with the ns prefix and the other via their names
> This is how my model (part of) looks like:
> Name Ns Prefix
> pkg1 --> a.b.c.pkg1
> pkg2 --> a.b.c.pkg1.pkg2
> pkg3 --> a.b.c.pkg1.pkg2.pkg3
> and pkg1 containt pkg2 which contains pkg3
> In the Rational Rose source file i've defined the ecore basePackage
> property for the pkg1 to be a.b.c, could this be the source of problems?
> Have i nice w-e
> Best regards
Re: Query on multipackages metamodel [message #25600 is a reply to message #25560] |
Fri, 24 February 2006 15:19 |
--------------040902000000080608010007
Christian,
Yeah. The nsPrefix should really be used only as a hint for the
preferred xmlns prefix to be used in serialized instances. There are no
guarantees of uniqueness and any XML Schema NCName is permitted, whereas
the package name must be a valid Java identifier.
> Christian
> sf76 wrote:
>> Dear Christian,
>> Name Ns Prefix
>> pkg1 --> a.b.c.pkg1
>> Have i nice w-e
>> Best regards
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Christian,<br>
<br>
no guarantees of uniqueness and any XML Schema NCName is permitted,
whereas the package name must be a valid Java identifier.<br>
<br>
<br>
<blockquote cite="middtn6ba$mm6$1@utils.eclipse.org" type="cite">
<pre wrap="">Yes, indeed, this looks like a problem.
Christian
sf76 wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Dear Christian,
Name Ns Prefix
pkg1 --> a.b.c.pkg1
Have i nice w-e
Best regards
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040902000000080608010007--
Re: Query on multipackages metamodel [message #568446 is a reply to message #24074] |
Hello, sf76,
extension.
pkg1
Class1
ref1 : pkg2.Class2
ref2 : Class1
pkg2
Class2
x : EInt
pkg3
new SELECT(
HTH,
Christian
sf76 wrote:
> Dear all,
> pkg 1
> -- pkg 2
> -- pkg 3
> -- pkg4
> general case?
> file...
> Best regards
Re: Query on multipackages metamodel [message #569500 is a reply to message #24991] |
Hi, Ssf76,
HTH,
Christian
sf76 wrote:
> Dear Christian,
> 1. OCL plugin
or even just
by '::', not by '.'
should work.
pkg1
pkg2
pkg3
or of this form?
pkg1
pkg1.pkg2
pkg1.pkg2.pkg3
> 2. QUERY plugin
> new WHERE(
> context element.
under the hood).
> TIA
Re: Query on multipackages metamodel [message #569744 is a reply to message #25521] |
Christian
sf76 wrote:
> Dear Christian,
> Name Ns Prefix
> pkg1 --> a.b.c.pkg1
> Have i nice w-e
> Best regards
Re: Query on multipackages metamodel [message #569770 is a reply to message #25560] |
Ed Merks Messages: 33218 Registered: July 2009 |
Christian,
> Christian
> sf76 wrote:
>> Dear Christian,
>> Name Ns Prefix
>> pkg1 --> a.b.c.pkg1
>> Have i nice w-e
>> Best regards
<html>
<head>
</head>
Christian,<br>
<br>
<br>
<br>
Christian
sf76 wrote:
</pre>
Name Ns Prefix
pkg1 --> a.b.c.pkg1
Have i nice w-e
Best regards
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Current Time: Tue Sep 24 18:34:31 GMT 2024
Powered by FUDForum. Page generated in 0.05355 seconds
