Re: [CDO] Microsoft SQL does not create Tables [message #1392535 is a reply to message #1392330] |
Wed, 02 July 2014 13:24 |
Hi Samuel,
Have you already asked Tom Schindl?
Cheers
/Eike
http://www.esc-net.de
Am 02.07.2014 14:29, schrieb Samuel Leisering:
> Hi
> I tried to use the DBAdapter provided by Thomas Schindl
> (https://www.eclipse.org/forums/index.php/mv/msg/446871/998288/#msg_998288). On Startup i get the following error (For
> those who dont know german, it says "invalid objectname"):
> org.eclipse.net4j.util.lifecycle.LifecycleException: java.sql.SQLException: Ungültiger Objektname 'CDO_PROPERTIES'.
> at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:104)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
> at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1980)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
> at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
> at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:291)
> at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:116)
> at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
> at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
> at java.lang.Thread.run(Unknown Source)
> Caused by: java.sql.SQLException: Ungültiger Objektname 'CDO_PROPERTIES'.
> at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:372)
> at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2988)
> at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2421)
> at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:671)
> at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:505)
> at net.sourceforge.jtds.jdbc.JtdsStatement.executeQuery(JtdsStatement.java:1427)
> at org.eclipse.emf.cdo.server.internal.db.DBStore.selectSchemaVersion(DBStore.java:842)
> at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:607)
> ... 16 more
> CDO does not create any tables in the database. I connect with a user and password, with sufficient permissions to
> create tables. I also tested the official JDBC driver by microsoft instead of JTDS, but got the same error. When i
> create the CDO_PROPERTIES table by hand, CDO complains about missing columns, so it seems that CDO connects
> successfully to the database.
> Any ideas?
Cheers
/Eike
FUDForum. Page generated in 0.04351 seconds
