Home » Eclipse Projects » EclipseLink » SecondaryTable causes invalid join (Bug)
SecondaryTable causes invalid join (Bug) [message #1391692] Tue, 01 July 2014 09:08 Go to next message
Omid Pourhadi is currently offline Omid PourhadiFriend
I have a simple model as follow :
@Entity
@Inheritance(strategy = InheritanceType.SINGLE_TABLE)
@Table(name = "cfs_document", uniqueConstraints = @UniqueConstraint(columnNames = { "uuid" }))
@SecondaryTable(name = "cfs_doc_access", pkJoinColumns = @PrimaryKeyJoinColumn(name = "doc_id", referencedColumnName = "id"))
@XmlRootElement
@ClassExtractor(value = DocumentClassExtractor.class)
// @Customizer(DocumentCustomizer.class)
public class Document extends DocumentVO
    @ManyToOne(fetch = FetchType.LAZY)
    @JoinColumn(name = "parent_id", table = "cfs_doc_access")
    @JoinFetch(JoinFetchType.OUTER)
    private Document parent;
after I run this query
select d from Document d where d.id in :ids and d.parent is not null
it produces this sql with 4 INNER JOIN of same tables how eclipselink do that?! which I assume is not correct
SELECT * FROM cfs_doc_access t3,
  cfs_document t2, cfs_doc_access t1, cfs_document t0 WHERE ((((t2.id IN (?)) AND NOT ((t3.parent_id IS NULL)))
  AND (t3.doc_id = t2.id)) AND ((t0.id = t3.parent_id) AND (t1.doc_id = t0.id)))
is this a bug ?
Re: SecondaryTable causes invalid join (Bug) [message #1395851 is a reply to message #1391692] Mon, 07 July 2014 13:43 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
The query shown seems to match what you have queried for. The query seems to be asking for t2+t3 rows, and has a join fetch on the parent relationship that brings in the t1+t0 rows. Since you have used d.parent in the query, the outer join is forced into an inner join since you are already restricting the results to only include documents with a parent.
Are the results incorrect?
Re: SecondaryTable causes invalid join (Bug) [message #1397086 is a reply to message #1395851] Wed, 09 July 2014 07:19 Go to previous message
results are correct although it's too slow. I was kind of hoping for this query
SELECT * FROM  cfs_document t0
LEFT OUTER JOIN cfs_doc_access t1 on
t0.id = t1.doc_id
 WHERE ((((t0.id IN (?)) AND NOT ((t1.parent_id IS NULL)))
anyway since there is no way to LEFT join secondary table I assume I expected too much Smile
thank you for your reply.
[Updated on: Wed, 09 July 2014 07:30]
Report message to a moderator
Previous Topic:JPQL passing binary enum instead of enum's ordinal as SQL param value for key in Map<enum, String
Next Topic:Hanging and long delays obtaining read locks
Current Time: Sat Apr 27 05:23:08 GMT 2024
Powered by FUDForum. Page generated in 0.03419 seconds
