| Home » Eclipse Projects » Eclipse Platform » 3.0M9 startup problem
 Goto Forum:|
| 3.0M9 startup problem [message #244305] | Mon, 24 May 2004 11:40  |  |
| Eclipse User  |  |  |  |  | Originally posted by: sinleeh.hotmail.com
 For both Linux GTK2 and Motif version, upon startup, I got this error:
 "An error had occurred, See the log file
 I got this message not long after the splash screen first display.
 Any help appreciated.
 Thanking you in advance,
 Cinly
 The log file entry is:
 !SESSION May 24, 2004 16:43:35.728
 eclipse.buildId=I200405211200
 java.version=1.4.1_03
 BootLoader constants: OS=linux, ARCH=x86, WS=motif, NL=en_US
 !ENTRY org.eclipse.core.runtime May 24, 2004 16:43:35.730
 !MESSAGE Exception trying to create the fileManager for the area:
 " /home2/co224/bin/i486-pc-linux/eclipse_3.0M9/motif/eclipse/c onfiguration//org.eclipse.core.runtime ".
 !STACK 0
 java.io.IOException: Permission denied
 at sun.nio.ch.FileChannelImpl.lock0(Native Method)
 at  sun.nio.ch.FileChannelImpl.tryLock(FileChannelImpl.java:773)
 at java.nio.channels.FileChannel.tryLock(FileChannel.java:967)
 org.eclipse.core.runtime.adaptor.Locker_JavaNio.lock(Locker_ JavaNio.java:28)
 org.eclipse.osgi.service.datalocation.FileManager.initialize InstanceFile(FileManager.java:105)
 org.eclipse.osgi.service.datalocation.FileManager.<init>(FileManager.java:98)
 org.eclipse.core.internal.runtime.InternalPlatform.getRuntim eFileManager(InternalPlatform.java:1214)
 org.eclipse.core.internal.runtime.PlatformActivator.startReg istry(PlatformActivator.java:97)
 org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:62)
 org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
 org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
 org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
 org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
 org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:366)
 org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:992)
 org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:572)
 org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:483)
 org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
 org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:443)
 org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
 org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
 !ENTRY
 initial@reference :file:/home2/co224/bin/i486-pc-linux/eclipse_3.0M9/motif/ecl ipse/plugins/org.eclipse.core.runtime_3.0.0/
 0 0 May 24, 2004 16:43:35.847
 !MESSAGE FrameworkEvent.ERROR
 !STACK 0
 org.osgi.framework.BundleException: Exception in
 org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle
 org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
 Caused by: java.lang.NullPointerException
 ... 10 more
 Root exception:
 !ENTRY
 initial@reference :file:/home2/co224/bin/i486-pc-linux/eclipse_3.0M9/motif/ecl ipse/plugins/org.eclipse.update.configurator_3.0.0/
 0 0 May 24, 2004 16:43:35.910
 !STACK 0
 org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
 bundle org.eclipse.update.configurator.
 Caused by: java.lang.Exception: Cannot initialize the Update Configurator
 org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:103)
 org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:70)
 ... 10 more
 Root exception:
 !ENTRY org.eclipse.osgi May 24, 2004 16:43:35.958
 !MESSAGE Startup error
 !STACK 1
 java.lang.IllegalStateException: Bundle
 [1] is not active.
 org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:286)
 org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:125)
 at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
 at org.eclipse.core.launcher.Main.run(Main.java:638)
 at org.eclipse.core.launcher.Main.main(Main.java:622)
| Re: 3.0M9 startup problem [message #244335 is a reply to message #244305] | Mon, 24 May 2004 12:42   |  |
| Eclipse User  |  |  |  |  | Originally posted by: pascal.ibm.canada
 Does it happen even for the first startup when you just installed eclipse?
 PaScaL
 > Cinly
 > !STACK 0
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at java.security.AccessController.doPrivileged(Native Method)
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > !ENTRY
 > !STACK 0
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	... 10 more
 > Root exception:
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > !ENTRY
 > !STACK 0
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	... 10 more
 > Root exception:
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > !STACK 1
 > [1] is not active.
 > 	at
 > 	at
 > 	at
 > 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 > 	at
 > 	at
| Re: 3.0M9 startup problem [message #244340 is a reply to message #244335] | Mon, 24 May 2004 12:40   |  |
 Dear PaScaL
 Yes. It is a fresh installation.
 thanks,
 Sinleeh
 > PaScaL
 > > Cinly
 org.eclipse.core.runtime".
 > > !STACK 0
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 1214)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 954)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 572)
 > > 	at
 > > 	at
 273)
 > > 	at
 443)
 > > 	at
 > > 	at
 > > !ENTRY
 > > !STACK 0
 > > 	at
 975)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 572)
 > > 	at
 > > 	at
 273)
 > > 	at
 443)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 954)
 > > 	... 10 more
 > > Root exception:
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 954)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 572)
 > > 	at
 > > 	at
 273)
 > > 	at
 443)
 > > 	at
 > > 	at
 > > !ENTRY
 > > !STACK 0
 > > 	at
 975)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 572)
 > > 	at
 > > 	at
 273)
 > > 	at
 443)
 > > 	at
 > > 	at
 > > 	at
 103)
 > > 	at
 70)
 > > 	at
 > > 	at
 954)
 > > 	... 10 more
 > > Root exception:
 > > 	at
 103)
 > > 	at
 70)
 > > 	at
 > > 	at
 954)
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 572)
 > > 	at
 > > 	at
 273)
 > > 	at
 443)
 > > 	at
 > > 	at
 > > !STACK 1
 > > [1] is not active.
 > > 	at
 > > 	at
 > > 	at
 > > 	at
 > > 	at
| Re: 3.0M9 startup problem [message #244406 is a reply to message #244340] | Mon, 24 May 2004 13:52   |  |
| Eclipse User  |  |  |  |  | Originally posted by: rndzank.comcast.net.not_this.net
 Just to confirm - you didn't extract the new version into old installation, right?
 Are you using a workspace created in older version?
 Can you try to delete the 'configuration' directory?
 r.
 Sinleeh wrote:
 > Dear PaScaL
 > thanks,
 > Sinleeh
 >>PaScaL
 >>>Cinly
 >>>!STACK 0
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 1214)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 954)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 572)
 >>>	at
 >>>	at
 > 273)
 >>>	at
 > 443)
 >>>	at
 >>>	at
 >>>!ENTRY
 >>>!STACK 0
 >>>	at
 > 975)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 572)
 >>>	at
 >>>	at
 > 273)
 >>>	at
 > 443)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 954)
 >>>	... 10 more
 >>>Root exception:
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 954)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 572)
 >>>	at
 >>>	at
 > 273)
 >>>	at
 > 443)
 >>>	at
 >>>	at
 >>>!ENTRY
 >>>!STACK 0
 >>>	at
 > 975)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 572)
 >>>	at
 >>>	at
 > 273)
 >>>	at
 > 443)
 >>>	at
 >>>	at
 >>>	at
 > 103)
 >>>	at
 > 70)
 >>>	at
 >>>	at
 > 954)
 >>>	... 10 more
 >>>Root exception:
 >>>	at
 > 103)
 >>>	at
 > 70)
 >>>	at
 >>>	at
 > 954)
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 > 572)
 >>>	at
 >>>	at
 > 273)
 >>>	at
 > 443)
 >>>	at
 >>>	at
 >>>!STACK 1
 >>>[1] is not active.
 >>>	at
 >>>	at
 >>>	at
 >>>	at
 >>>	at
| Re: 3.0M9 startup problem [message #244412 is a reply to message #244406] | Mon, 24 May 2004 13:55   |  |
 Dear Richard,
 right?
 No. The new version is in its own directory.
 No. I haven't got that far yet. The crash was between the first splash
 screen and the (expected) "Choose Workspace" Dialog.
 Yes. I tried that. Both versions still generate the same error.
 Sinleeh
 > Sinleeh wrote:
 > > Dear PaScaL
 > > thanks,
 > > Sinleeh
 > >>PaScaL
 > >>>Cinly
 > >>>!STACK 0
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 1214)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 954)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 572)
 > >>>	at
 > >>>	at
 > > 273)
 > >>>	at
 > > 443)
 > >>>	at
 > >>>	at
 > >>>!ENTRY
 > >>>!STACK 0
 > >>>	at
 > > 975)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 572)
 > >>>	at
 > >>>	at
 > > 273)
 > >>>	at
 > > 443)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 954)
 > >>>	... 10 more
 > >>>Root exception:
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 954)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 572)
 > >>>	at
 > >>>	at
 > > 273)
 > >>>	at
 > > 443)
 > >>>	at
 > >>>	at
 > >>>!ENTRY
 > >>>!STACK 0
 > >>>	at
 > > 975)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 572)
 > >>>	at
 > >>>	at
 > > 273)
 > >>>	at
 > > 443)
 > >>>	at
 > >>>	at
 > >>>	at
 > > 103)
 > >>>	at
 > > 70)
 > >>>	at
 > >>>	at
 > > 954)
 > >>>	... 10 more
 > >>>Root exception:
 > >>>	at
 > > 103)
 > >>>	at
 > > 70)
 > >>>	at
 > >>>	at
 > > 954)
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > > 572)
 > >>>	at
 > >>>	at
 > > 273)
 > >>>	at
 > > 443)
 > >>>	at
 > >>>	at
 > >>>!STACK 1
 > >>>[1] is not active.
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
 > >>>	at
| Re: 3.0M9 startup problem [message #244428 is a reply to message #244412] | Mon, 24 May 2004 14:14   |  |
 Did you check you OS permissions and any related (who installed the eclipse,
 who is the effective OS user when Eclipse is run)?
 Note the exception:
 r.
 sinleeh wrote:
 > Dear Richard,
 > right?
 > Sinleeh
 >>Sinleeh wrote:
 >>>Dear PaScaL
 >>>thanks,
 >>>Sinleeh
 >>>>PaScaL
 >>>>>Cinly
 >>>>>!STACK 0
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>1214)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>954)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>572)
 >>>>>	at
 >>>>>	at
 >>>273)
 >>>>>	at
 >>>443)
 >>>>>	at
 >>>>>	at
 >>>>>!ENTRY
 >>>>>!STACK 0
 >>>>>	at
 >>>975)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>572)
 >>>>>	at
 >>>>>	at
 >>>273)
 >>>>>	at
 >>>443)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>954)
 >>>>>	... 10 more
 >>>>>Root exception:
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>954)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>572)
 >>>>>	at
 >>>>>	at
 >>>273)
 >>>>>	at
 >>>443)
 >>>>>	at
 >>>>>	at
 >>>>>!ENTRY
 >>>>>!STACK 0
 >>>>>	at
 >>>975)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>572)
 >>>>>	at
 >>>>>	at
 >>>273)
 >>>>>	at
 >>>443)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>103)
 >>>>>	at
 >>>70)
 >>>>>	at
 >>>>>	at
 >>>954)
 >>>>>	... 10 more
 >>>>>Root exception:
 >>>>>	at
 >>>103)
 >>>>>	at
 >>>70)
 >>>>>	at
 >>>>>	at
 >>>954)
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>572)
 >>>>>	at
 >>>>>	at
 >>>273)
 >>>>>	at
 >>>443)
 >>>>>	at
 >>>>>	at
 >>>>>!STACK 1
 >>>>>[1] is not active.
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
 >>>>>	at
| Re: 3.0M9 startup problem [message #244448 is a reply to message #244428] | Mon, 24 May 2004 14:39   |  |
 Dear Richard,
 I was the one installing all J2sdk and eclipse stuff. It works well for
 eclipsse 2.1.3.
 Anyway, I did the unthinkable by chmod 744 everything in eclipse and j2sdk
 directory. I still end up with the same problem.
 > Note the exception:
 I did. However, I thought it is related to the line before:
 There is a double slash. I know it cause some problem on some Linux
 machine (but my machine handles this OK the last time I checked) and
 thought it might be the problem.
 Thanks for your patient. Hope to hear from you sson
 Sinleeh
 > r.
 > sinleeh wrote:
 > > Dear Richard,
 > > right?
 > > Sinleeh
 > >>Sinleeh wrote:
 > >>>Dear PaScaL
 > >>>thanks,
 > >>>Sinleeh
 eclipse?
 > >>>>PaScaL
 > >>>>>Cinly
 > >>>>>!STACK 0
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>1214)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>954)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>572)
 > >>>>>	at
 > >>>>>	at
 > >>>273)
 > >>>>>	at
 > >>>443)
 > >>>>>	at
 > >>>>>	at
 > >>>>>!ENTRY
 > >>>>>!STACK 0
 > >>>>>	at
 > >>>975)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>572)
 > >>>>>	at
 > >>>>>	at
 > >>>273)
 > >>>>>	at
 > >>>443)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>954)
 > >>>>>	... 10 more
 > >>>>>Root exception:
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>954)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>572)
 > >>>>>	at
 > >>>>>	at
 > >>>273)
 > >>>>>	at
 > >>>443)
 > >>>>>	at
 > >>>>>	at
 > >>>>>!ENTRY
 > >>>>>!STACK 0
 of
 > >>>>>	at
 > >>>975)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>572)
 > >>>>>	at
 > >>>>>	at
 > >>>273)
 > >>>>>	at
 > >>>443)
 > >>>>>	at
 > >>>>>	at
 Configurator
 > >>>>>	at
 > >>>103)
 > >>>>>	at
 > >>>70)
 > >>>>>	at
 > >>>>>	at
 > >>>954)
 > >>>>>	... 10 more
 > >>>>>Root exception:
 > >>>>>	at
 > >>>103)
 > >>>>>	at
 > >>>70)
 > >>>>>	at
 > >>>>>	at
 > >>>954)
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>572)
 > >>>>>	at
 > >>>>>	at
 > >>>273)
 > >>>>>	at
 > >>>443)
 > >>>>>	at
 > >>>>>	at
 > >>>>>!STACK 1
 > >>>>>[1] is not active.
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
 > >>>>>	at
| Re: 3.0M9 startup problem [message #244464 is a reply to message #244448] | Tue, 25 May 2004 03:38   |  |
| Eclipse User  |  |  |  |  | I am getting a similar error, however the exception does not say Permission denied.  Main difference is that I am using eclipse on aix.
 My install is located in a distributted fileset using AFS.  I need to do
 this so all my users can access the install.  If I change the location
 to local filespace, the problem goes away.  But that is not a solution
 that I can live with.
 Here is the error I get:
 java.fullversion=J2RE 1.4.1 IBM AIX build ca1411-20030930 (JIT enabled:
 jitc)
 BootLoader constants: OS=aix, ARCH=ppc, WS=motif, NL=en_US
 !ENTRY org.eclipse.core.runtime May 24, 2004 14:21:59.561
 " /afs/awd.austin.ibm.com/proj/p6/da/apps/eclipse/dev/rs_aix51 /configuration//org.eclipse.core.runtime ".
 !STACK 0
 java.io.IOException: A system call received a parameter that is not valid.
 at  sun.nio.ch.FileChannelImpl.tryLock(FileChannelImpl.java:801)
 at java.nio.channels.FileChannel.tryLock(FileChannel.java:983)
 sinleeh wrote:
 > Dear Richard,
 > eclipsse 2.1.3.
 >>Note the exception:
 > Sinleeh
 >>r.
 >>sinleeh wrote:
 >>>Dear Richard,
 >>>right?
 >>>Sinleeh
 >>>>Sinleeh wrote:
 >>>>>Dear PaScaL
 >>>>>thanks,
 >>>>>Sinleeh
 > eclipse?
 >>>>>>PaScaL
 >>>>>>>Cinly
 >>>>>>>!STACK 0
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>1214)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>954)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>572)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>273)
 >>>>>>>	at
 >>>>>443)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>!ENTRY
 >>>>>>>!STACK 0
 >>>>>>>	at
 >>>>>975)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>572)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>273)
 >>>>>>>	at
 >>>>>443)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>954)
 >>>>>>>	... 10 more
 >>>>>>>Root exception:
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>954)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>572)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>273)
 >>>>>>>	at
 >>>>>443)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>!ENTRY
 >>>>>>>!STACK 0
 > of
 >>>>>>>	at
 >>>>>975)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>572)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>273)
 >>>>>>>	at
 >>>>>443)
 >>>>>>>	at
 >>>>>>>	at
 > Configurator
 >>>>>>>	at
 >>>>>103)
 >>>>>>>	at
 >>>>>70)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>954)
 >>>>>>>	... 10 more
 >>>>>>>Root exception:
 >>>>>>>	at
 >>>>>103)
 >>>>>>>	at
 >>>>>70)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>954)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>572)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>273)
 >>>>>>>	at
 >>>>>443)
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>!STACK 1
 >>>>>>>[1] is not active.
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
 >>>>>>>	at
| Re: 3.0M9 startup problem [message #244491 is a reply to message #244335] | Mon, 24 May 2004 16:25   |  |
 Try running with the following vm arg:
 -Dosgi.locking
 set to
 either
 java.io
 none
 java.nio
 java.nio is the default value.
 Whether or not you are successful please enter bug reports against
 equinox / general with the details of your set ups for the original problem.
 Note that running with none or java.io might be dangereous, since the
 some runtime information will not be protected, and the workspace may be
 open twice.
 PaScaL
 > PaScaL
 >> Cinly
 >> !STACK 0
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >> !ENTRY
 >> !STACK 0
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     ... 10 more
 >> Root exception:
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >> !ENTRY
 >> !STACK 0
 >> of
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     ... 10 more
 >> Root exception:
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
 >> !STACK 1
 >> [1] is not active.
 >>     at
 >>     at
 >>     at
 >>     at
 >>     at
| Re: 3.0M9 startup problem [message #244763 is a reply to message #244464] | Tue, 25 May 2004 07:55   |  |
 Dear Brian,
 Thanks for the tip. I copied the GTK2 installation to a local drive and
 got it working as well. Originally, the directory is on NFS.
 Unfortunately, like you, it is not a solution I can live with.
 With the motif version, it does not work on the local directory. I got
 more display from the terminal screen.
 org.eclipse.osgi.framework.internal.core.PackageAdminImpl.pr ocessDelta(PackageAdminImpl.java:467)
 org.eclipse.osgi.framework.internal.core.PackageAdminImpl.re freshPackages(PackageAdminImpl.java:350)
 org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1. run(PackageAdminImpl.java:319)
 at java.lang.Thread.run(Thread.java:534)
 and the error log file:
 !SESSION May 25, 2004 12:54:52.347
 ---------------------------------------------eclipse.buildId =unknown
 java.version=1.4.2_04
 !ENTRY org.eclipse.osgi May 25, 2004 12:54:52.350
 !STACK 1
 org.eclipse.osgi.framework.internal.core.PackageAdminImpl.se tResolvedBundles(PackageAdminImpl.java:696)
 org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:469)
 org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
 org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
 org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:423)
 at  org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
 org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:213)
 Tried the vm trick proposed by Pascal to no avail. However, I need to
 check whether I invoke it correctly.
 I will file a bug report with your contribution to it and post a note here.
 Sinleeh
 > jitc)
 > !STACK 0
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
| Re: 3.0M9 startup problem [message #244773 is a reply to message #244491] | Tue, 25 May 2004 08:14   |  |
 Dear PaScaL
 > -Dosgi.locking
 > set to
 > either
 > java.io
 > none
 > java.nio
 I tried but still get the same error. the command I use is
 /eclipse -Dosgi.locking
 /eclipse -Dosgi.locking=java.io (and similarly for none and java.nio
 This time I got a different error:
 eclipse.buildId=unknown
 Command-line arguments: -Dosgi.locking
 !ENTRY org.eclipse.osgi May 25, 2004 13:18:26.775
 !STACK 1
 In another subtread, Brian told me to try putting eclipse on a non-NFS
 system, i.e. local system. I tried it and it works for GTK2 but not Motif.
 Unfortunately, putting it on local system is not an option.
 I do plan to. I will collect all information and put bug reports as you
 instructed. Thanks for telling me where to put it to.
 > open twice.
 Thanks for your help. Any more pointers appreciated.
 Sinleeh
| Bug Report 63834 [was: 3.0M9 startup problem] [message #244784 is a reply to message #244491] | Tue, 25 May 2004 08:40   |  |
 Dear Pascal,
 Submitted as bug report. I just put the message here as a marker for
 others to see as I note that you were one of the receipients of the bug
 report.I used my official email address in that report.
 Many thanks for your help. Do you have any more ideas that I can try out?
 Sinleeh.
 > -Dosgi.locking
 > set to
 > either
 > java.io
 > none
 > java.nio
 > open twice.
 > PaScaL
 > > PaScaL
 > >> Cinly
 > >> !STACK 0
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >> !ENTRY
 > >> !STACK 0
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     ... 10 more
 > >> Root exception:
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >> !ENTRY
 > >> !STACK 0
 > >> of
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     ... 10 more
 > >> Root exception:
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >> !STACK 1
 > >> [1] is not active.
 > >>     at
 > >>     at
 > >>     at
 > >>     at
 > >>     at
| Bug 63834 [was: 3.0M9 startup problem] [message #244796 is a reply to message #244464] | Tue, 25 May 2004 08:41   |  |
 Dear Brian,
 As promised. I filed a bug report with your contributions.
 Sinleeh
 > jitc)
 > !STACK 0
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > 	at
 > sinleeh wrote:
 > > Dear Richard,
 eclipse,
 > > eclipsse 2.1.3.
 > >>Note the exception:
 > > Sinleeh
 > >>r.
 > >>sinleeh wrote:
 > >>>Dear Richard,
 installation,
 > >>>right?
 > >>>Sinleeh
 > >>>>Sinleeh wrote:
 > >>>>>Dear PaScaL
 > >>>>>thanks,
 > >>>>>Sinleeh
 > > eclipse?
 > >>>>>>PaScaL
 > >>>>>>>Cinly
 > >>>>>>>!STACK 0
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>1214)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>954)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>572)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>273)
 > >>>>>>>	at
 > >>>>>443)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>!ENTRY
 > >>>>>>>!STACK 0
 > >>>>>>>	at
 > >>>>>975)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>572)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>273)
 > >>>>>>>	at
 > >>>>>443)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>954)
 > >>>>>>>	... 10 more
 > >>>>>>>Root exception:
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>954)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>572)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>273)
 > >>>>>>>	at
 > >>>>>443)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>!ENTRY
 > >>>>>>>!STACK 0
 > > of
 > >>>>>>>	at
 > >>>>>975)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>572)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>273)
 > >>>>>>>	at
 > >>>>>443)
 > >>>>>>>	at
 > >>>>>>>	at
 > > Configurator
 > >>>>>>>	at
 > >>>>>103)
 > >>>>>>>	at
 > >>>>>70)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>954)
 > >>>>>>>	... 10 more
 > >>>>>>>Root exception:
 > >>>>>>>	at
 > >>>>>103)
 > >>>>>>>	at
 > >>>>>70)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>954)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>572)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>273)
 > >>>>>>>	at
 > >>>>>443)
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>!STACK 1
 > >>>>>>>[1] is not active.
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
 > >>>>>>>	at
| Re: 3.0M9 startup problem [message #245517 is a reply to message #244464] | Wed, 26 May 2004 08:23  |  |
 Dear Brian,
 Rafael@ibm and PasCaL suggested using -Dosgi.lock vm flag. The instruction
 from Rafael is as below:
 Please try again specifying -vmargs -Dosgi.locking=none after deleting the
 configuration directory:
 I tried with NFS and it works. Can you test it and tell me (via the
 private email I send you, or by filing an amendment to the bug 63834)
 whether you succeeded or not for your AIX.
 sinleeh
 Current Time: Fri Oct 31 03:01:33 EDT 2025
 Powered by FUDForum . Page generated in 0.58701 seconds |
