Action set of GEF application do not work in a multipage editor [message #244269] |
Sun, 13 July 2008 15:40 |
Originally posted by: npchala.yahoo.com
For a project that i'm currently working on i implemented a small GEF
application. (GEF 3.3 and Eclipse 3.3). For this to work out i made a
org.eclpipse.ui.editors extension in the MANIFEST file. Class is as
follows,
public class NesCGraphicalEditor extends GraphicalEditorWithPalette {
Thereaftr i needed to call this thing through a multi page editor. For
that i used the eclipse sample multi-page-editor example. For this also i
had to make a org.eclpipse.ui.editors extension in the MANIFEST file.
Class is as follows,
public class MultiPageEditor extends MultiPageEditorPart implements
IResourceChangeListener{
Both are working fine independently. But when integrating the action set
of GEF application (such as undo, redo, delete) are not working at all.
(Other functionality works fine)
I'm new to GEF, and eclipse MANIFEST.MFs. So is this because there cannot
be two editor extensions? or else how can i solve this problem?
Thanks in advance,
chalani
FUDForum. Page generated in 0.03598 seconds
