Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [ECP] How to properly extend EMFStoreUIProvider
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1391693 is a reply to message #1391261] |
Tue, 01 July 2014 09:08 |
Jonas Helming Messages: 699 Registered: July 2009 |
Hi Oliver,
the UI Provider uses the content provider, which are generated by EMF
(edit bundle). So, I would adapt the item provider in order to change
the structure of the tree.
Best regards
Jonas
Am 30.06.2014 19:08, schrieb Olivier Labrosse:
> I wish to support synthetic items with specific child descriptors, in
> the Model Explorer, while using EMFStore for persistence.
> Is there a proper way to extend the EMFStoreUIProvider in order to
> override the fillContextMenu() method? The point would be to check for
> instances of said synthetic items, and act accordingly to fetch their
> list of child descriptors.
> From what I could find out, the provider name has to match the
> EMFStoreProvider's in order to get share/commit/etc. functionality in a
> 3.x application. I'm concerned about contributing my own providers with
> a name that clashes with the EMFStore ones.
> Thanks very much once again for your much appreciated support.
> -Olivier
> P.S.: if it were proper for you to add an "else if (element instanceof
> IChildCreationExtender)" in the
> DefaultUIProvider#fillContextMenuForProject() method, I could submit a
> bugzilla for it. Anyone wishing to use synthetic items could then
> simply implement that interface.
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1391726 is a reply to message #1391693] |
Tue, 01 July 2014 10:09 |
Annamalai Mising name Messages: 126 Registered: July 2009 |
Hi Oliver
I have tried to do that for my Model Explorer. I followed this link Have
a look http://www.eclipse.org/forums/index.php/t/230983/
But i also need to customise the ContextMenu based on the selected
Synthetic node and didnt find any facility to achieve the same.
Malai
On 7/1/2014 2:38 PM, Jonas Helming wrote:
> Hi Oliver,
> Best regards
> Jonas
>> Hi,
>> -Olivier
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1391891 is a reply to message #1391726] |
Tue, 01 July 2014 15:09 |
Olivier Labrosse Messages: 49 Registered: November 2011 |
Member |
Thank you Malai and Jonas for your replies.
Thing is, the problem is not in the tree structure. You'll notice I suggested a possible fix to my issue that involved changing the context menu; herein lies the problem.
The context menu is already being filled with "create child" menu items (see ModelExplorerView#fillContextMenu()), and I intend to make use of this for synthetic items as well as EObjects, if only for consistence sake. As you know, synthetic items aren't EObjects, and although the EMF book suggests making them into full-fledged ItemProviders, they can be simple POJOs if the Viewer's ContentProvider is your own custom implementation that supports them.
What I'm suggesting is that any UIProvider, or at least the DefaultUIProvider, should support synthetic item child descriptors. Maybe, instead of what I previously suggested, it's the ChildrenDescriptorCollector that should accept any Object, and deal with both EObjects and IChildCreationExtenders. All I know is that, without this, I would have to create my own view, which is overkill for such a simple requirement.
So I guess my question is threefold: Am I missing something? If not, should we update DefaultUIProvider and/or ChildrenDescriptorCollector in order to support child descriptors coming from synthetic items? And if not that either, then is it safe to simply contribute an extension of EMFStoreUIProvider or will it break patterns due to identical names?
Thanks again!
Annamalai Chockalingam wrote on Tue, 01 July 2014 06:09Hi Oliver
Malai
> Hi Oliver,
> Best regards
> Jonas
>> Hi,
>> -Olivier
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1392384 is a reply to message #1391891] |
Wed, 02 July 2014 08:47 |
sorry, I misunderstood your question in the first place. An simple
alternative would be to add the menu entries you need using the default
Eclipse menu extension point. Have you tried that?
Best regards
Jonas
Am 01.07.2014 17:09, schrieb Olivier Labrosse:
> simple requirement.
> Thanks again!
>> Hi Oliver
>> Have a look http://www.eclipse.org/forums/index.php/t/230983/
>> Regards
>> Malai
>> > Hi Oliver,
>> > Best regards
>> > Jonas
>> >> Hi,
>> for
>> in a
>> with
>> >> -Olivier
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1392475 is a reply to message #1392384] |
Wed, 02 July 2014 11:44 |
Hello Jonas
Then i have a question, i have overriden fillContextMenu when i was
extending ModelExplorerView and i have given my own actions to it.
But my synthetic nodes that i introduced in my itemprovider like for
example in ECP Example, user > tasks[Synthetic Element] > task
Now when i right click on tasks, i cannot add Task. I still need to
right click on User to create a Task.
I would want to know how to i contribute a Right Click on a Synthetic
element using the Item Providers. Coz you are generating the ContextMenu
for new item creation using the NewChildDescriptors in the Item providers.
Correct me if i am wrong.
Malai
On 7/2/2014 2:17 PM, Jonas Helming wrote:
> Best regards
> Jonas
>> simple requirement.
>> Thanks again!
>>> Hi Oliver
>>> Regards
>>> Malai
>>>> Hi Oliver,
>>>> Best regards
>>>> Jonas
>>>>> Hi,
>>> for
>>> in a
>>> with
>>>>> -Olivier
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1392583 is a reply to message #1392384] |
Wed, 02 July 2014 14:43 |
Member |
I thought about it, but there are two things I don't like about it. First, it adds another 3.x extension contribution I'll have to deal with once we switch to E4 completely. Second, I'm not 100% sure I can place this extension exactly where the items appear for EObjects, and I would want that because it makes for a consistent UI. I might give it a try with a "popup:org.eclipse.emf.ecp.ui.ModelExplorerView?before=global_additions" locationURI.
Honestly, though, I really think the DefaultUIProvider should deal with the pretty standard concept of synthetic tree items, especially since the EMF book covers it. Rather than trying out the menu contribution solution, I would instead create a bugzilla and provide a suggested patch, which is now obvious to me it should rely on the editing domain to get child descriptors for whatever element is currently selected (without changing the EObject case here).
Jonas Helming wrote on Wed, 02 July 2014 04:47Hi,
Best regards
Jonas
> simple requirement.
> Thanks again!
>> Hi Oliver
>> Regards
>> Malai
>> > Hi Oliver,
>> > Best regards
>> > Jonas
>> >> Hi,
>> for
>> in a
>> with
>> >> -Olivier
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1392587 is a reply to message #1392475] |
Wed, 02 July 2014 14:49 |
Member |
Malai,
If you followed the EMF book, your synthetic element should be an ItemProviderAdapter, which means you can override the collectNewChildDescriptors() method where you can add the relevant descriptors for your case.
Consider customizing the UserItemProvider to remove those descriptors, so the option only shows up on the synthetic element, to prevent any possible confusion as to what the difference would be between creating them at one place vs. the other.
Olivier
Annamalai Chockalingam wrote on Wed, 02 July 2014 07:44Hello Jonas
Malai
> Best regards
> Jonas
>> simple requirement.
>> Thanks again!
>>> Hi Oliver
>>> Regards
>>> Malai
>>>> Hi Oliver,
>>>> Best regards
>>>> Jonas
>>>>> Hi,
>>> for
>>> in a
>>> with
>>>>> -Olivier
Re: [ECP] How to properly extend EMFStoreUIProvider [message #1393053 is a reply to message #1392587] |
Thu, 03 July 2014 07:10 |
Hello Olivier
I have already done that. UserItemProvider now doesnt hav support for
NewChildDescriptor for Child and only my TasksItemProvider [Synthetic
Element for Tasks] returns Task as part of NewChildDescriptor method.
But i suppose ECP isnt considering the same.
@Jonas : Correct me if i am wrong. Not sure if this is a bug in ECP.
Malai
On 7/2/2014 8:19 PM, Olivier Labrosse wrote:
> Malai,
> Regards,
> Olivier
>> Hello Jonas
>> ContextMenu for new item creation using the NewChildDescriptors in the
>> Item providers.
>> Regards
>> Malai
>> > Hi,
>> > Best regards
>> > Jonas
>> context
>> items
>> can
>> with
>> without
>> >> simple requirement.
>> And if
>> >> Thanks again!
>> >>> Hi Oliver
>> >>> Regards
>> >>> Malai
>> >>>> Hi Oliver,
>> EMF
>> change
>> >>>> Best regards
>> >>>> Jonas
>> >>>>> Hi,
>> descriptors, in
>> >>> for
>> their
>> >>> in a
>> >>> with
>> >>>>> -Olivier
>> instanceof
>> submit a
Current Time: Fri Apr 26 20:50:48 GMT 2024
Powered by FUDForum. Page generated in 0.04297 seconds
