Unable to acquire PluginConverter [message #1390990] |
Mon, 30 June 2014 05:27  |
in Kepler I used to create some private plugins which I shared across
several Eclipse instances. Thus, I have central folders with this structure:
MyTool1
plugins
features
MyTool2
plugins
features
Folders MyTool1 and MyTool2 then are symlinked into the dropins folders
of my different Eclipse instances. This way every of my Eclipse
instances always was up-to-date. It worked like a charme.
Now, I migrated to Luna and get the following errors each time I start a
Luna instance:
Unable to acquire PluginConverter service during generation for:
EclipseLuna/dropins/MyTool1
EclipseLuna/dropins/MyTool2
There are some bug reports reporting about the same message but with
other focus. All I've found didn't help to get rid of these messages.
The only solution I found was to move all plugins contained in
dropins/MyToolX/plugins directly to dropins. But, I really don't like
this because every tool then is mixed with the other tools. This way I
cannot deactivate one tool easily.
Any ideas to solve this?
cheers,
Jan
Re: Unable to acquire PluginConverter [message #1403670 is a reply to message #1403644] |
Fri, 25 July 2014 04:08  |
Thanks David.
cheers,
Jan
David Williams wrote:
>> But as I understand it right I'm not supposed to need the
>> PluginConverter because my Plugins have plugin.xml and MANIFEST.MF and
>> are not from Eclipse 2.0 times. And the error doesn't appear if the
>> plugins are directly located in the dropins folder and not in a
>> subfolder. So do I need to install the PluginConverter?
> I think you are seeing this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=437466
> (If so, no, you do not need to install it, it's an erroneous message).
FUDForum. Page generated in 0.03795 seconds
