| a bug with builder.resourceCopyExclusionFilter [message #243738] |
Mon, 14 May 2007 18:52  |
Originally posted by: cyrille37.news.eclipse.org
I think there is a bug with "Building / Filtered Resources" =>
org.eclipse.jdt.core.builder.resourceCopyExclusionFilter
It works fine with file pattern but seems to does not works fine with folder
pattern like ".svn/"
when I set option like :
org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=*.l aunch,.svn/
folders .svn from source are copied to the output folder.
BUT not all .svn content, only .svn sub-folders are copied to the output folder.
for example :
the file src\.svn\dir-prop-base is *not copied*,
but the sub-folder src\.svn\text-base *is copied*.
I'm running :
Eclipse
Version: 3.2.2
Build id: M20070212-1330
Eclipse Java Development Tools
Version: 3.2.2.r322_v20070104-R4CR0Znkvtfjv9-
On a Windows XP SP2.
Cyrille.
| Re: a bug with builder.resourceCopyExclusionFilter [message #243886 is a reply to message #243738] |
Fri, 18 May 2007 16:22  |
Originally posted by: jacek.pospychala.pl.ibm.com
cyrille37,
it looks like bug bug is fixed in development release - 3.3.
If this issue breaks your work, please try with this release.
Here are details about bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154693
cyrille37 wrote:
> Hello,
> folder
> folder.
> for example :
> I'm running :
> Eclipse
> Version: 3.2.2
> Cyrille.
FUDForum. Page generated in 0.05508 seconds
