| duplicate colors in pie charts [message #243386] | Tue, 19 June 2007 14:22  |  |
| Eclipse User  |  |  |  |  | Originally posted by: rbhardwaj.tier.com
 I am trying to generate pie charts using birt, it seems that whenever the
 number of columns is more than 4-5 (not even 8), the pie chart has sectors
 of duplicate colors.
 I have tried it on birt 2.1.2 and 2.2.1 rc 3.
 Am I doing something wrong? Is there any workaround for this?
 Rahul
| Re: duplicate colors in pie charts [message #243838 is a reply to message #243548] | Thu, 21 June 2007 07:47  |  |
| Eclipse User  |  |  |  |  | It is likely you are adding colors to the wrong palette. If you color by category (which is the case here), you need to add colors in the category
 palette, not the series palette.
 David
 "Rahul Bhardwaj" <rbhardwaj@tier.com> wrote in message
 news:f5bchc$cof$1@build.eclipse.org...
 > Yes, i did add quite a few colors. I even tried removing all colors and
 > then add complete new set of colors. I could see the new colors being used
 > but every sector after column 5 was colored using the same color.
 > Can you confirm that you have seen unique colors in use especially when
 > the number of sectors is more than 8? If yes, can you tell me the BIRT
 > version that you used?
 > "Peter Hoffmann" <petepack@gmx.de> wrote in message
 > news:f5baq2$1s4$1@build.eclipse.org...
 >> Did you trie to add some colors?
 >> "Rahul Bhardwaj" <rbhardwaj@tier.com> schrieb im Newsbeitrag
 >> news:f596u1$o23$1@build.eclipse.org...
 >>>sectors of duplicate colors.
 >>> Thanks
 >>> Rahul
FUDForum. Page generated in 0.04980 seconds
