Home » Newcomers » Newcomers » An error occurred while automatically activating bundle org.eclipse.ui.workbenc
An error occurred while automatically activating bundle org.eclipse.ui.workbenc [message #243360] Mon, 17 December 2007 09:38 Go to next message
Originally posted by: rash.m2k.gmail.com
Hi Guys,
I had eclipse working before but I needed the GE - I tried to install it
but it didn't work as it kept on coming up blank with no icons. I then
removed eclipse and Java - everything I could, including dependencies and
reinstalled java and eclipse
Now it does not work, I have a number of different java versions installed
here they are:
# update-alternatives --config java
There are 4 programs which provide `java'.
Selection Command
1 /usr/lib64/jvm/jre-1.5.0-sun/bin/java
*+ 2 /usr/lib64/jvm/jre-1.6.0.u3.sr2-sun/bin/java
3 /usr/lib64/jvm/jre-1.4.2-cacao/bin/java
4 /usr/lib64/jvm/jre-1.4.2-gcj/bin/java
Enter to keep the default[*], or type selection number:
When I run eclipse with version 1.6 I get the following message:
'An error has occured please look at the log file.......'
After clicking OK the following comes up on the command line:
*** glibc detected *** /usr/lib64/eclipse/eclipse: double free or
corruption (!prev): 0x000000000053e780 ***
======= Backtrace: =========
/lib64/libc.so.6[0x2b0d527dc21d]
/lib64/libc.so.6(cfree+0x76)[0x2b0d527ddf76]
/usr/lib64/eclipse/plugins/org.eclipse.equinox.launcher.gtk. linux.x86_64_1.0.0.v20070606/eclipse_1017a.so(run+0x7cd)[0x2 b0d56bfebb8]
/usr/lib64/eclipse/eclipse(realpath+0x3c2)[0x4018ea]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x2b0d5278bb54]
/usr/lib64/eclipse/eclipse(strcat+0x42)[0x40157a]
======= Memory map: ========
00400000-00403000 r-xp 00000000 08:01 3550522
00503000-00504000 rw-p 00003000 08:01 3550522
00504000-0071e000 rw-p 00504000 00:00 0
[heap]
2b0d51487000-2b0d514a3000 r-xp 00000000 08:01 2322173
/lib64/ld-2.6.1.so
2b0d514a3000-2b0d514a4000 rw-p 2b0d514a3000 00:00 0
2b0d514a4000-2b0d514a5000 r--p 00000000 08:01 3386060
/usr/lib/locale/en_GB.utf8/LC_IDENTIFICATION
2b0d514a5000-2b0d514ac000 r--s 00000000 08:01 1815078
/usr/lib64/gconv/gconv-modules.cache
2b0d514ac000-2b0d514ad000 r--p 00000000 08:01 3417842
/usr/lib/locale/en_GB.utf8/LC_MEASUREMENT
2b0d514ad000-2b0d514ae000 r--p 00000000 08:01 3386920
/usr/lib/locale/en_GB.utf8/LC_TELEPHONE
2b0d514ae000-2b0d514af000 r--p 00000000 08:01 3402504
/usr/lib/locale/en_GB.utf8/LC_ADDRESS
2b0d514af000-2b0d514b0000 r--p 00000000 08:01 3402534
/usr/lib/locale/en_GB.utf8/LC_NAME
2b0d514b0000-2b0d514b1000 r--p 00000000 08:01 3417841
/usr/lib/locale/en_GB.utf8/LC_PAPER
2b0d514b1000-2b0d514b2000 r--p 00000000 08:01 3402582
/usr/lib/locale/en_GB.utf8/LC_MESSAGES/SYS_LC_MESSAGES
2b0d514b2000-2b0d514b3000 r--p 00000000 08:01 3402535
/usr/lib/locale/en_GB.utf8/LC_MONETARY
2b0d514ce000-2b0d514cf000 rw-p 2b0d514ce000 00:00 0
2b0d514cf000-2b0d515af000 r--p 00000000 08:01 3417844
/usr/lib/locale/en_GB.utf8/LC_COLLATE
2b0d515af000-2b0d515b0000 r--p 00000000 08:01 3386863
/usr/lib/locale/en_GB.utf8/LC_TIME
2b0d515b0000-2b0d515b1000 r--p 00000000 08:01 3417836
/usr/lib/locale/en_GB.utf8/LC_NUMERIC
2b0d515b1000-2b0d515f0000 r--p 00000000 08:01 3417843
/usr/lib/locale/en_GB.utf8/LC_CTYPE
2b0d516a2000-2b0d516a4000 rw-p 0001b000 08:01 2322173
/lib64/ld-2.6.1.so
2b0d516a4000-2b0d51a4c000 r-xp 00000000 08:01 1293485
/usr/lib64/libgtk-x11-2.0.so.0.1200.0
2b0d51a4c000-2b0d51c4c000 ---p 003a8000 08:01 1293485
2b0d51c4c000-2b0d51c52000 r--p 003a8000 08:01 1293485
2b0d51c52000-2b0d51c57000 rw-p 003ae000 08:01 1293485
2b0d51c57000-2b0d51c59000 rw-p 2b0d51c57000 00:00 0
2b0d51c59000-2b0d51c71000 r-xp 00000000 08:01 1293484
/usr/lib64/libgdk_pixbuf-2.0.so.0.1200.0
2b0d51c71000-2b0d51e71000 ---p 00018000 08:01 1293484
2b0d51e71000-2b0d51e73000 rw-p 00018000 08:01 1293484
2b0d51e73000-2b0d51eb2000 r-xp 00000000 08:01 802229
/usr/lib64/libgobject-2.0.so.0.1400.1
2b0d51eb2000-2b0d520b2000 ---p 0003f000 08:01 802229
2b0d520b2000-2b0d520b4000 rw-p 0003f000 08:01 802229
2b0d520b4000-2b0d520b6000 rw-p 2b0d520b4000 00:00 0
2b0d520b6000-2b0d52148000 r-xp 00000000 08:01 1293483
/usr/lib64/libgdk-x11-2.0.so.0.1200.0
2b0d52148000-2b0d52348000 ---p 00092000 08:01 1293483
2b0d52348000-2b0d5234b000 r--p 00092000 08:01 1293483
2b0d5234b000-2b0d5234e000 rw-p 00095000 08:01 1293483
2b0d5234e000-2b0d52363000 r-xp 00000000 08:01 2322018
/lib64/libpthread-2.6.1.so
2b0d52363000-2b0d52563000 ---p 00015000 08:01 2322018
2b0d52563000-2b0d52565000 rw-p 00015000 08:01 2322018
2b0d52565000-2b0d52569000 rw-p 2b0d52565000 00:00 0
2b0d52569000-2b0d5256b000 r-xp 00000000 08:01 2321998
/lib64/libdl-2.6.1.so
2b0d5256b000-2b0d5276b000 ---p 00002000 08:01 2321998
2b0d5276b000-2b0d5276d000 rw-p 00002000 08:01 2321998
2b0d5276d000-2b0d5276e000 rw-p 2b0d5276d000 00:00 0
2b0d5276e000-2b0d528aa000 r-xp 00000000 08:01 1242824
/lib64/libc-2.6.1.so
2b0d528aa000-2b0d52aa9000 ---p 0013c000 08:01 1242824
2b0d52aa9000-2b0d52aac000 r--p 0013b000 08:01 1242824
2b0d52aac000-2b0d52aae000 rw-p 0013e000 08:01 1242824
2b0d52aae000-2b0d52ab3000 rw-p 2b0d52aae000 00:00 0
2b0d52ab3000-2b0d52abc000 r-xp 00000000 08:01 801302
/usr/lib64/libpangocairo-1.0.so.0.1800.2
2b0d52abc000-2b0d52cbb000 ---p 00009000 08:01 801302
2b0d52cbb000-2b0d52cbd000 rw-p 00008000 08:01 801302
2b0d52cbd000-2b0d52cfe000 r-xp 00000000 08:01 801300
/usr/lib64/libpango-1.0.so.0.1800.2
2b0d52cfe000-2b0d52efd000 ---p 00041000 08:01 801300
2b0d52efd000-2b0d52efe000 r--p 00040000 08:01 801300
2b0d52efe000-2b0d52f00000 rw-p 00041000 08:01 801300
2b0d52f00000-2b0d52f01000 rw-p 2b0d52f00000 00:00 0
2b0d52f01000-2b0d53031000 r-xp 00000000 08:01 3337690
/usr/lib64/libX11.so.6.2.0
2b0d53031000-2b0d53231000 ---p 00130000 08:01 3337690
2b0d53231000-2b0d53237000 rw-p 00130000 08:01 3337690
2b0d53237000-2b0d53239000 r-xp 00000000 08:01 801996
/usr/lib64/libXcomposite.so.1.0.0
2b0d53239000-2b0d53438000 ---p 00002000 08:01 801996
2b0d53438000-2b0d5343a000 rw-p 00001000 08:01 801996
2b0d5343a000-2b0d5343c000 r-xp 00000000 08:01 802000
/usr/lib64/libXdamage.so.1.1.0
2b0d5343c000-2b0d5363b000 ---p 00002000 08:01 802000
2b0d5363b000-2b0d5363d000 rw-p 00001000 08:01 802000
2b0d5363d000-2b0d5363e000 rw-p 2b0d5363d000 00:00 0
2b0d5363e000-2b0d53643000 r-xp 00000000 08:01 3337843
/usr/lib64/libXfixes.so.3.1.0
2b0d53643000-2b0d53842000 ---p 00005000 08:01 3337843
2b0d53842000-2b0d53844000 rw-p 00004000 08:01 3337843
2b0d53844000-2b0d53861000 r-xp 00000000 08:01 3339464
/usr/lib64/libatk-1.0.so.0.2009.1
2b0d53861000-2b0d53a60000 ---p 0001d000 08:01 3339464
2b0d53a60000-2b0d53a62000 r--p 0001c000 08:01 3339464
2b0d53a62000-2b0d53a64000 rw-p 0001e000 08:01 3339464
2b0d53a64000-2b0d53a67000 r-xp 00000000 08:01 802227
/usr/lib64/libgmodule-2.0.so.0.1400.1
2b0d53a67000-2b0d53c66000 ---p 00003000 08:01 802227
2b0d53c66000-2b0d53c68000 rw-p 00002000 08:01 802227
2b0d53c68000-2b0d53c69000 rw-p 2b0d53c68000 00:00 0
2b0d53c69000-2b0d53d15000 r-xp 00000000 08:01 802088
/usr/lib64/libglib-2.0.so.0.1400.1
2b0d53d15000-2b0d53f15000 ---p 000ac000 08:01 802088
2b0d53f15000-2b0d53f17000 rw-p 000ac000 08:01 802088
2b0d53f17000-2b0d53f9b000 r-xp 00000000 08:01 801288
/usr/lib64/libcairo.so.2.11.5
2b0d53f9b000-2b0d5419b000 ---p 00084000 08:01 801288
2b0d5419b000-2b0d5419c000 r--p 00084000 08:01 801288
2b0d5419c000-2b0d5419e000 rw-p 00085000 08:01 801288
2b0d5419e000-2b0d5419f000 rw-p 2b0d5419e000 00:00 0
2b0d5419f000-2b0d541f1000 r-xp 00000000 08:01 2322000
/lib64/libm-2.6.1.so
2b0d541f1000-2b0d543f0000 ---p 00052000 08:01 2322000
2b0d543f0000-2b0d543f2000 rw-p 00051000 08:01 2322000
2b0d543f2000-2b0d543f3000 rw-p 2b0d543f2000 00:00 0
2b0d543f3000-2b0d5441d000 r-xp 00000000 08:01 3337740
/usr/lib64/libfontconfig.so.1.2.0
2b0d5441d000-2b0d5461d000 ---p 0002a000 08:01 3337740
2b0d5461d000-2b0d54626000 r--p 0002a000 08:01 3337740
2b0d54626000-2b0d54628000 rw-p 00033000 08:01 3337740
2b0d54628000-2b0d54638000 r-xp 00000000 08:01 3337841
/usr/lib64/libXext.so.6.4.0
2b0d54638000-2b0d54837000 ---p 00010000 08:01 3337841
2b0d54837000-2b0d54839000 rw-p 0000f000 08:01 3337841
2b0d54839000-2b0d54842000 r-xp 00000000 08:01 3337845
/usr/lib64/libXrender.so.1.3.0
2b0d54842000-2b0d54a41000 ---p 00009000 08:01 3337845
2b0d54a41000-2b0d54a43000 rw-p 00008000 08:01 3337845
2b0d54a43000-2b0d54a44000 rw-p 2b0d54a43000 00:00 0
2b0d54a44000-2b0d54a46000 r-xp 00000000 08:01 802014
/usr/lib64/libXinerama.so.1.0.0
2b0d54a46000-2b0d54c45000 ---p 00002000 08:01 802014
2b0d5/usr/share/eclipse/eclipse: line 8: 6048 Aborted
/usr/share/eclipse/eclipse.bin -startup $STARTUP_JAR ""
The logfile that it tells me to look at contains the following:
!SESSION 2007-12-17 14:25:44.945
eclipse.buildId=I20070625-1500
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments:
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2007-12-17 14:25:46.390
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.ui.workbench (167).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:149)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 37 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2007-12-17 14:25:46.395
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
"org.eclipse.ui.ide.application" was unable to instantiate class
"org.eclipse.ui.internal.ide.application.IDEApplication".
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:174)
org.eclipse.core.runtime.CoreException[1]: java.lang.NoClassDefFoundError:
org/eclipse/ui/application/WorkbenchAdvisor
!ENTRY org.eclipse.osgi 2 0 2007-12-17 14:25:46.415
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-12-17 14:25:46.415
!MESSAGE Bundle
update@plugins /org.eclipse.platform.source.linux.gtk.x86_64_3.3.0.v2007061 2-_19UEkLEzwsdF9jSqQ-G/
was not resolved.
!SUBENTRY 2 org.eclipse.platform.source.linux.gtk.x86_64 2 0 2007-12-17
14:25:46.415
!MESSAGE Missing host
org.eclipse.platform.source_3.3.0.v20070612-_19UEkLEzwsdF9jS qQ-G.
!MESSAGE Bundle
update@plugins /org.eclipse.rcp.source.linux.gtk.x86_64_3.3.0.v20070607-8y8 eE8NEbsN3X_fjWS8HPNG/
was not resolved.
!SUBENTRY 2 org.eclipse.rcp.source.linux.gtk.x86_64 2 0 2007-12-17
14:25:46.415
org.eclipse.rcp.source_3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HP NG.
!ENTRY org.eclipse.osgi 2 0 2007-12-17 14:25:46.419
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-12-17 14:25:46.419
!MESSAGE Bundle
[63] was not resolved.
14:25:46.419
!MESSAGE Bundle update@plugins/org.eclipse.ant.ui_3.2.100.v20070511.jar
[76] was not resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2007-12-17 14:25:46.419
!MESSAGE Missing Constraint: Require-Bundle: org.eclipse.jdt.ui;
bundle-version="[3.2.0,4.0.0)"
!MESSAGE Bundle
[89] was not resolved.
14:25:46.419
Somebody pleae help solve this. I am running OpenSuse 10.3 64 bit.
Re: An error occurred while automatically activating bundle org.eclipse.ui.workbenc [message #243380 is a reply to message #243360] Mon, 17 December 2007 11:43 Go to previous messageGo to next message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Hi Rashad. Try starting Eclipse with the -clean option.
Wayne
Rashad wrote:
> Hi Guys,
> and reinstalled java and eclipse
[snip]
Re: An error occurred while automatically activating bundle org.eclipse.ui.workb [message #243399 is a reply to message #243380] Mon, 17 December 2007 12:31 Go to previous messageGo to next message
> Wayne
> Rashad wrote:
>> Hi Guys,
> [snip]
Already tried it doesn't work. I haven't a clue whats wrong.
Re: An error occurred while automatically activating bundle org.eclipse.ui.workb [message #244164 is a reply to message #243399] Fri, 28 December 2007 08:34 Go to previous message
Can anyone else help me out????
Perhaps someone could tell me how I can completely clean eclipse and Java
out and reinstall it again????
Previous Topic:error while loading share libraries
Next Topic:Feature branding with "about.html"- missing linked file
Current Time: Fri Sep 26 06:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.26297 seconds
