Re: Infinite Loop in DocumentTokenSource.computeDamageRegion [message #1387983 is a reply to message #1387792] |
Wed, 25 June 2014 21:48 |
Zoltan Ujhelyi Messages: 392 Registered: July 2015 |
I guess you might have introduced a non-deterministic case with regards to the keywords of the language: if your grammar uses the word 'MAX' or 'MIN' it could be either the keywords used in the rule
PrefixOperation2Operands or a newly introduced terminal, and that causes some issues during editing.
I am not entirely sure this is the issue, but it makes sense as before the parser runs, a lexer is used to identify these terminals, where no context information is available. This means, a single terminal/keyword should not conflict.
Additionally, I would check the output of the mwe execution: usually, some problems are only shown during generation instead of in the Xtext grammar editor. If you have no experience with grammars, they can be a bit cryptic, but they usually help determining the issue.
I hope I have helped a bit. Cheers,
Zoltán
FUDForum. Page generated in 0.03254 seconds
