Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » ECP 1.3.x RAP target does not resolve
Re: ECP 1.3.x RAP target does not resolve [message #1391123 is a reply to message #1389020] |
Mon, 30 June 2014 13:28 |
Christian Reuter Messages: 34 Registered: October 2010 |
Member |
Hi Eugen,
thx for the update. It is working now in general.
However I can not use a view model to customize the views with RAP.
If I add one via the plugin extension point the object is not rendered and I get a NPE instead.
I guess I need to add some more bundles to the run config in order to use a view model.
I started by adding only the bundle org.eclipse.emf.ecp.view.editor.controls and pressing "Add Required Bundles".
This increased the number of plugins from 138 to 183.
Unfortunately this configuration throws a ton of errors already during startup.
Could you please give me a hint how to determine which bundles I must add to my run confguration? I am really having a hard time finding out which bundles I need. Seems like every time there are either some bundles missing or some conflictiong bundles.
Here is the NPE I get when I use the original "ecpRapDemo" run config and try to open a view with a view model attached:
2014-06-30 14:31:22.256:INFO:oejs.Server:jetty-8.1.14.v20131031
2014-06-30 14:31:22.511:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:52979
UIProviderDescriptor: org.eclipse.emf.ecp.emfstore.ui [36] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.ui_1.3.0.20140610-1229.jar
osgi> ProviderDescriptor: org.eclipse.emf.ecp.emfstore.core [7] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.core_1.3.0.20140610-1229.jar
Loading ECPProjectManagerImpl from E:\Develop\Workspaces\DataFlow\.metadata\.plugins\org.eclipse.rap.tools.launch\ecpRapDemo\.metadata\.plugins\org.eclipse.emf.ecp.core\projects
Loading ECPRepositoryManagerImpl from E:\Develop\Workspaces\DataFlow\.metadata\.plugins\org.eclipse.rap.tools.launch\ecpRapDemo\.metadata\.plugins\org.eclipse.emf.ecp.core\repositories
RepositoryDescriptor: org.eclipse.emf.ecp.emfstore.ui [36] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.ui_1.3.0.20140610-1229.jar
!SESSION 2014-06-30 14:31:09.796 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Command-line arguments: -dev file:E:/Develop/Workspaces/DataFlow/.metadata/.plugins/org.eclipse.pde.core/ecpRapDemo/dev.properties -os win32 -ws win32 -arch x86_64 -console -consolelog -data E:\Develop\Workspaces\DataFlow/.metadata/.plugins/org.eclipse.rap.tools.launch/ecpRapDemo
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:31:44.289
!MESSAGE Value not found.
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:31:44.300
!MESSAGE Error while instantiating location provider or none configured, switching to default location!
!ENTRY org.eclipse.emf.emfstore.client 2 2 2014-06-30 14:31:44.492
!MESSAGE No EMFStore migrator registered.
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.080
!MESSAGE Resource save options initialized:
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.089
!MESSAGE USE_ENCODED_ATTRIBUTE_STYLE: true
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.097
!MESSAGE USE_CACHED_LOOKUP_TABLE: []
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.105
!MESSAGE ENCODING: UTF-8
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.112
!MESSAGE FLUSH_THRESHOLD: 100000
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.120
!MESSAGE USE_FILE_BUFFER: true
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2014-06-30 14:32:04.389
!MESSAGE EMFStoreProvider received INIT for ECPProjectImpl efgt
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2014-06-30 14:32:04.399
!MESSAGE EMFStoreProvider received CREATE for ECPProjectImpl efgt
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2014-06-30 14:32:04.417
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 14:32:31.797
!MESSAGE An unexpected exception was thrown.
!STACK 0
at org.eclipse.emf.ecp.editor.internal.e3.MEEditorPage.dispose(MEEditorPage.java:224)
at org.eclipse.ui.forms.editor.FormEditor.dispose(FormEditor.java:409)
at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.dispose(SharedHeaderFormEditor.java:160)
at org.eclipse.emf.ecp.editor.internal.e3.MEEditor.dispose(MEEditor.java:322)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:703)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:464)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:599)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:310)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:265)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:64)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:479)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1262)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1215)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1614)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:508)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:106)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:494)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:115)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:65)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:775)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:633)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2855)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2763)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2755)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2706)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2702)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2686)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2677)
at org.eclipse.emf.ecp.explorereditorbridge.internal.EditorModelElementOpener.openModelElement(EditorModelElementOpener.java:58)
at org.eclipse.emf.ecp.internal.ui.util.ECPHandlerHelper.openModelElement(ECPHandlerHelper.java:448)
at org.eclipse.emf.ecp.internal.ui.util.ECPHandlerHelper.addModelElement(ECPHandlerHelper.java:203)
at org.eclipse.emf.ecp.ui.commands.NewModelElementWizardHandler.execute(NewModelElementWizardHandler.java:40)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:304)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:167)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:239)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:834)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:810)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:700)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:602)
at org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1212)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1193)
at org.eclipse.swt.widgets.Display.safeReadAndDispatch(Display.java:1176)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1168)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at org.eclipse.emf.ecp.rap.Application.createUI(Application.java:39)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:172)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:284)
at java.lang.Thread.run(Thread.java:662)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:105)
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 14:32:31.811
!MESSAGE Unable to create editor ID org.eclipse.emf.ecp.editor: There must be exactly one LayoutProvider!
Found 0 providers.
!STACK 0
java.lang.IllegalStateException: There must be exactly one LayoutProvider!
Found 0 providers.
at org.eclipse.emf.ecp.view.spi.swt.layout.LayoutProviderHelper.checkProviderLength(LayoutProviderHelper.java:142)
at org.eclipse.emf.ecp.view.spi.swt.layout.LayoutProviderHelper.getColumnLayout(LayoutProviderHelper.java:107)
at org.eclipse.emf.ecp.view.spi.horizontal.swt.HorizontalLayoutSWTRenderer.renderControl(HorizontalLayoutSWTRenderer.java:105)
at org.eclipse.emf.ecp.view.spi.swt.AbstractSWTRenderer.render(AbstractSWTRenderer.java:213)
at org.eclipse.emf.ecp.view.spi.core.swt.ContainerSWTRenderer.renderControl(ContainerSWTRenderer.java:155)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:80)
at org.eclipse.emf.ecp.editor.internal.e3.MEEditorPage.createFormContent(MEEditorPage.java:131)
at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:152)
at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormPage.java:150)
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor.java:477)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1070)
at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEditor.java:616)
at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.createPages(SharedHeaderFormEditor.java:103)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:668)
!ENTRY org.eclipse.emf.ecp.ui 4 0 2014-06-30 14:32:31.829
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.emf.ecp.editor.e3.MEEditorInput.getName(MEEditorInput.java:150)
at org.eclipse.ui.internal.ErrorEditorPart.init(ErrorEditorPart.java:82)
at org.eclipse.ui.internal.EditorReference.getEmptyEditor(EditorReference.java:795)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:485)
If I add the controls-bundle + required plugins as described above I get this:
!ENTRY org.eclipse.rap.ui 2 2 2014-06-30 15:07:22.662
!MESSAGE Could not start styling support.
!STACK 0
java.lang.NoSuchMethodException: org.eclipse.e4.ui.css.swt.internal.theme.BootstrapTheme3x.<init>(org.eclipse.swt.widgets.Display)
at java.lang.Class.getConstructor0(Class.java:2706)
at java.lang.Class.getConstructor(Class.java:1657)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2568)
!ENTRY org.eclipse.rap.ui 4 4 2014-06-30 15:07:23.222
!MESSAGE The proxied handler for 'org.eclipse.ui.internal.handlers.SaveHandler' could not be loaded
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 15:07:23.231
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveHandler".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:361)
at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:330)
at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
at org.eclipse.core.commands.Command.setHandler(Command.java:1025)
at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:457)
at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:247)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:118)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:110)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:105)
at org.eclipse.ui.internal.handlers.HandlerPersistence.readDefaultHandlersFromRegistry(HandlerPersistence.java:271)
at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:226)
at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:180)
at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:184)
at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:59)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:173)
at org.eclipse.ui.internal.Workbench$40.runWithException(Workbench.java:1899)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:230)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:1092)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:1895)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1593)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2655)
at org.eclipse.ui.internal.handlers.DirtyStateTracker.<init>(DirtyStateTracker.java:37)
at org.eclipse.ui.internal.handlers.AbstractSaveHandler.<init>(AbstractSaveHandler.java:38)
at org.eclipse.ui.internal.handlers.SaveHandler.<init>(SaveHandler.java:37)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 38 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-06-30 15:07:23.235
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveHandler".
!STACK 0
!ENTRY org.eclipse.rap.ui 4 4 2014-06-30 15:07:23.246
!MESSAGE The proxied handler for 'org.eclipse.ui.internal.handlers.SaveAsHandler' could not be loaded
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 15:07:23.255
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAsHandler".
at org.eclipse.ui.internal.handlers.SaveAsHandler.<init>(SaveAsHandler.java:32)
... 38 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-06-30 15:07:23.258
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAsHandler".
!STACK 0
!ENTRY org.eclipse.rap.ui 4 4 2014-06-30 15:07:23.269
!MESSAGE The proxied handler for 'org.eclipse.ui.internal.handlers.SaveAllHandler' could not be loaded
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 15:07:23.277
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAllHandler".
at org.eclipse.ui.internal.handlers.SaveAllHandler.<init>(SaveAllHandler.java:38)
... 38 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-06-30 15:07:23.280
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAllHandler".
!STACK 0
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.699
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.699
!MESSAGE Conflict for 'org.eclipse.ui.newWizard':
HandlerActivation(commandId=org.eclipse.ui.newWizard,
handler=org.eclipse.ui.internal.handlers.WizardHandler$New@2bb15387,
expression=,sourcePriority=0)
handler=org.eclipse.ui.internal.handlers.WizardHandler$New,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.708
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.708
!MESSAGE Conflict for 'org.eclipse.ui.file.import':
HandlerActivation(commandId=org.eclipse.ui.file.import,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Import,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Import@23f3329a,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.717
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.718
!MESSAGE Conflict for 'org.eclipse.ui.file.export':
HandlerActivation(commandId=org.eclipse.ui.file.export,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Export,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Export@666558bb,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.726
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.726
!MESSAGE Conflict for 'org.eclipse.ui.file.properties':
HandlerActivation(commandId=org.eclipse.ui.file.properties,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler@3e91cc3a,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.734
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.734
!MESSAGE Conflict for 'org.eclipse.ui.file.exit':
HandlerActivation(commandId=org.eclipse.ui.file.exit,
handler=org.eclipse.ui.internal.handlers.QuitHandler@6b8a3745,
handler=org.eclipse.ui.internal.handlers.QuitHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.742
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.743
!MESSAGE Conflict for 'org.eclipse.ui.window.newWindow':
HandlerActivation(commandId=org.eclipse.ui.window.newWindow,
handler=org.eclipse.ui.internal.handlers.OpenInNewWindowHandler@38e02fc4,
handler=org.eclipse.ui.internal.handlers.OpenInNewWindowHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.750
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.751
!MESSAGE Conflict for 'org.eclipse.ui.window.switchToEditor':
HandlerActivation(commandId=org.eclipse.ui.window.switchToEditor,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler@2635ee49,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.759
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.759
!MESSAGE Conflict for 'org.eclipse.ui.window.minimizePart':
HandlerActivation(commandId=org.eclipse.ui.window.minimizePart,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler@72de4f4b,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.767
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.768
!MESSAGE Conflict for 'org.eclipse.ui.file.closePart':
HandlerActivation(commandId=org.eclipse.ui.file.closePart,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler@61202afe,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.783
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.783
!MESSAGE Conflict for 'org.eclipse.ui.window.preferences':
HandlerActivation(commandId=org.eclipse.ui.window.preferences,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@361c98b2,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.794
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.795
!MESSAGE Conflict for 'org.eclipse.ui.views.showView':
HandlerActivation(commandId=org.eclipse.ui.views.showView,
handler=org.eclipse.ui.handlers.ShowViewHandler,
handler=org.eclipse.ui.handlers.ShowViewHandler@24f61f5c,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.803
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.803
!MESSAGE Conflict for 'org.eclipse.ui.help.displayHelp':
HandlerActivation(commandId=org.eclipse.ui.help.displayHelp,
handler=org.eclipse.ui.internal.handlers.DisplayHelpHandler@3864064b,
handler=org.eclipse.ui.internal.handlers.DisplayHelpHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.820
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.821
!MESSAGE Conflict for 'org.eclipse.ui.perspectives.showPerspective':
HandlerActivation(commandId=org.eclipse.ui.perspectives.showPerspective,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler@4b3ca972,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.830
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.831
!MESSAGE Conflict for 'org.eclipse.ui.navigate.showIn':
HandlerActivation(commandId=org.eclipse.ui.navigate.showIn,
handler=org.eclipse.ui.internal.ShowInHandler@219baf0b,
handler=org.eclipse.ui.internal.ShowInHandler,
ProviderDescriptor: org.eclipse.emf.ecp.emfstore.core [8] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.core_1.3.0.20140610-1229.jar
ProviderDescriptor: org.eclipse.emf.ecp.workspace.core [122] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.workspace.core_1.3.0.20140610-1229.jar
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.036
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.037
!MESSAGE Conflict for 'org.eclipse.ui.window.activateEditor':
HandlerActivation(commandId=org.eclipse.ui.window.activateEditor,
handler=org.eclipse.ui.internal.ActivateEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.045
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.046
!MESSAGE Conflict for 'org.eclipse.ui.window.showSystemMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showSystemMenu,
handler=org.eclipse.ui.internal.ShowPartPaneMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.053
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.054
!MESSAGE Conflict for 'org.eclipse.ui.window.showViewMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showViewMenu,
handler=org.eclipse.ui.internal.ShowViewMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.062
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.062
!MESSAGE Conflict for 'org.eclipse.ui.file.close':
HandlerActivation(commandId=org.eclipse.ui.file.close,
handler=org.eclipse.ui.internal.CloseEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.071
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.071
!MESSAGE Conflict for 'org.eclipse.ui.file.closeAll':
HandlerActivation(commandId=org.eclipse.ui.file.closeAll,
handler=org.eclipse.ui.internal.CloseAllHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.081
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.082
!MESSAGE Conflict for 'org.eclipse.ui.file.closeOthers':
HandlerActivation(commandId=org.eclipse.ui.file.closeOthers,
handler=org.eclipse.ui.internal.CloseOthersHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.091
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.092
!MESSAGE Conflict for 'org.eclipse.ui.ToggleCoolbarAction':
HandlerActivation(commandId=org.eclipse.ui.ToggleCoolbarAction,
handler=org.eclipse.ui.internal.handlers.ToggleCoolbarHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.100
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.101
!MESSAGE Conflict for 'org.eclipse.ui.window.nextEditor':
HandlerActivation(commandId=org.eclipse.ui.window.nextEditor,
handler=org.eclipse.ui.internal.CycleEditorHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.110
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.111
!MESSAGE Conflict for 'org.eclipse.ui.window.previousEditor':
HandlerActivation(commandId=org.eclipse.ui.window.previousEditor,
handler=org.eclipse.ui.internal.CycleEditorHandler:false,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.119
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.120
!MESSAGE Conflict for 'org.eclipse.ui.window.nextView':
HandlerActivation(commandId=org.eclipse.ui.window.nextView,
handler=org.eclipse.ui.internal.CycleViewHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.128
Current Time: Sat Apr 27 02:15:44 GMT 2024
Powered by FUDForum. Page generated in 0.03119 seconds
