Home » Eclipse Projects » Equinox » Create local p2-mirror from target definition
Create local p2-mirror from target definition [message #1387031] Mon, 23 June 2014 11:11 Go to next message
my question is: How can I create a local p2 mirror repository from a target definition (.target file)?
This seams to be a simple question, here is what I did and where I got stuck:
Try 1:
- Open target file, set wanted arch/ws/os options and click "Export".
(Repeat for all needed arch/ws/os combinations and all target files Sad )
=> Didn't work: Exported repo contains folders and so can't be accessed remotely.
ERROR: Artifact org.eclipse.update.feature,org.eclipse.jdt,3.9.2.v20140221-1700 is a folder but the repository is an archive or remote location.
Try 2:
- Convert target file to the p2.mirror Ant task call.
=> Missing feature bundles. The resolution seams to run differently compared to the target platform resolution.
So how can I create a mirror p2 repository containing only artifacts, that I really need for my projects?
Thank you very much for help!
Boris Brodski
[Updated on: Wed, 30 July 2014 07:15] by Moderator
Re: Creating local mirrors [message #1404162 is a reply to message #1387031] Wed, 30 July 2014 03:11 Go to previous message
I wrote an export wizard, that can export p2 repositories (Must be selected using checkbox below):
Source: https://github.com/borisbrodski/org.eclipse.pde.targetplatformexporter
Update site: https://github.com/borisbrodski/org.eclipse.pde.targetplatformexporter/raw/updatesite/org.eclipse.pde.targetplatformexporter.site
index.php/fa/18694/0/
It's implemented really "quick and dirty", but it works Smile
Pull requests and comments are welcome!
Boris
Previous Topic:Composite repository entry that does not bring in categories
Next Topic:osgi.configuration.area vs. simpleconfigurator
Current Time: Wed Aug 20 13:30:37 EDT 2025
Powered by FUDForum. Page generated in 0.05313 seconds
