| [SOLVED] OdaException - Unable to open a connection with the database connection profile [message #1386718] |
Thu, 19 June 2014 15:46  |
When I am running a .rptdesign file through the BIRT Viewer I am getting an error that is preventing my report from running.
I am using Postgres 9.2 and version postgresql920jdbc.jar of the PostgreSQL driver jar.
Running the report in the Eclipse designer works just fine. I can even go to the Preview tab and view the report running.
When I first go this error I had to follow the instructions at https://wiki.eclipse.org/Birt_3.7_Migration_Guide to get past the first issue. I set some properties in my $CATALINA_OPTS
export CATALINA_OPTS="$CATALINA_OPTS -Djava.io.tmpdir=/usr/local/tomcat/apache-tomcat-7.0.41/temp/tempdir -Dorg.eclipse.datatools_workspacepath=/usr/local/tomcat/apache-tomcat-7.0.41/temp/tempdir/workspace_dtp"
to take care of the default workspace problem here: http://stackoverflow.com/questions/14198752/birt-error-unable-to-determine-the-default-workspace-location-in-java
However, now I am getting the issue of the connection profile somehow being bad. Can anyone help point me in the right direction on what to try next?
Here is the full text of the error:
Jun 19, 2014 11:03:45 AM org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection open(Properties)
WARNING: Unable to open a connection with the database connection profile.
org.eclipse.datatools.connectivity.oda.OdaException ;
java.lang.NoClassDefFoundError: org/eclipse/datatools/enablement/ibm/util/ClientUtil
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:116)
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:62)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:250)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:165)
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:224)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:212)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:217)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:435)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:322)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:463)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:178)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:637)
at org.eclipse.birt.report.engine.api.impl.GetParameterDefinitionTask.executeQuery(GetParameterDefinitionTask.java:648)
at org.eclipse.birt.report.engine.api.impl.GetParameterDefinitionTask.getResultSetForParameter(GetParameterDefinitionTask.java:1374)
at org.eclipse.birt.report.engine.api.impl.GetParameterDefinitionTask.getChoicesFromParameterQuery(GetParameterDefinitionTask.java:1348)
at org.eclipse.birt.report.engine.api.impl.GetParameterDefinitionTask.doGetSelectionList(GetParameterDefinitionTask.java:521)
at org.eclipse.birt.report.engine.api.impl.GetParameterDefinitionTask.getSelectionList(GetParameterDefinitionTask.java:451)
at org.eclipse.birt.report.service.BirtViewerReportService.getParameterSelectionList(BirtViewerReportService.java:821)
at org.eclipse.birt.report.presentation.aggregation.parameter.ComboBoxParameterFragment.prepareParameterBean(ComboBoxParameterFragment.java:91)
at org.eclipse.birt.report.presentation.aggregation.parameter.ScalarParameterFragment.doService(ScalarParameterFragment.java:91)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
at org.apache.jsp.webcontent.birt.pages.dialog.ParameterDialogFragment_jsp._jspService(ParameterDialogFragment_jsp.java:116)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:749)
at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:605)
at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:544)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:82)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.callBack(AbstractBaseFragment.java:106)
at org.apache.jsp.webcontent.birt.pages.dialog.DialogContainerFragment_jsp._jspService(DialogContainerFragment_jsp.java:140)
at org.apache.jsp.webcontent.birt.pages.layout.SidebarFragment_jsp._jspService(SidebarFragment_jsp.java:79)
at org.apache.jsp.webcontent.birt.pages.layout.ReportFragment_jsp._jspService(ReportFragment_jsp.java:79)
at org.apache.jsp.webcontent.birt.pages.layout.FramesetFragment_jsp._jspService(FramesetFragment_jsp.java:279)
at org.eclipse.birt.report.presentation.aggregation.layout.FramesetFragment.service(FramesetFragment.java:98)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(ViewerServlet.java:181)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/datatools/enablement/ibm/util/ClientUtil
at org.eclipse.datatools.enablement.ibm.db2.luw.DB2LUWDriverValuesProvider.locateDB2DriverJars(DB2LUWDriverValuesProvider.java:38)
at org.eclipse.datatools.enablement.ibm.db2.luw.DB2LUWDriverValuesProvider.createDefaultValue(DB2LUWDriverValuesProvider.java:23)
at org.eclipse.datatools.connectivity.drivers.DriverManager.createDefaultInstance(DriverManager.java:1112)
at org.eclipse.datatools.connectivity.drivers.DriverManager.createDefaultInstance(DriverManager.java:1004)
at org.eclipse.datatools.connectivity.drivers.DriverManager.resetDefaultInstances(DriverManager.java:906)
at org.eclipse.datatools.connectivity.drivers.DriverManager.<init>(DriverManager.java:125)
at org.eclipse.datatools.connectivity.drivers.DriverManager.getInstance(DriverManager.java:67)
at org.eclipse.datatools.connectivity.DriverConnectionBase.getDriverDefinition(DriverConnectionBase.java:136)
at org.eclipse.datatools.connectivity.DriverConnectionBase.internalCreateConnection(DriverConnectionBase.java:100)
at org.eclipse.datatools.connectivity.DriverConnectionBase.open(DriverConnectionBase.java:54)
at org.eclipse.datatools.enablement.internal.postgresql.PostgreSQLJDBCConnection.<init>(PostgreSQLJDBCConnection.java:47)
at org.eclipse.datatools.enablement.internal.postgresql.PostgreSQLConnectionFactory.createConnection(PostgreSQLConnectionFactory.java:51)
at org.eclipse.datatools.connectivity.internal.ConnectionFactoryProvider.createConnection(ConnectionFactoryProvider.java:83)
at org.eclipse.datatools.connectivity.internal.ConnectionProfile.createConnection(ConnectionProfile.java:359)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionInfoImpl.initializeJDBCConnection(ConnectionInfoImpl.java:705)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionInfoImpl.<init>(ConnectionInfoImpl.java:690)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionFactory.createConnection(ConnectionFactory.java:38)
at org.eclipse.datatools.connectivity.sqm.core.SQMConnectionFactory.createConnection(SQMConnectionFactory.java:45)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionFactory.createConnection(ConnectionFactory.java:59)
at org.eclipse.datatools.connectivity.internal.ConnectionFactoryAdapterProvider.createConnection(ConnectionFactoryAdapterProvider.java:114)
at org.eclipse.datatools.connectivity.internal.ManagedConnection.createConnection(ManagedConnection.java:163)
at org.eclipse.datatools.connectivity.internal.CreateConnectionJob.run(CreateConnectionJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
[Updated on: Fri, 20 June 2014 19:16] by Moderator
FUDForum. Page generated in 0.05586 seconds
