Home » Eclipse Projects » Remote Application Platform (RAP) » Using Google Visualization on RAP 2.2
Using Google Visualization on RAP 2.2 [message #1386602] Wed, 18 June 2014 14:38 Go to next message
Michael Fritscher is currently offline Michael FritscherFriend
Member
I've trouble getting the Google visualization running with RAP 2.2.
I tried htttp:// git.eclipse org/c/rap/incubator/org.eclipse.rap.incubator.visualization.git ( htttp:// git.eclipse org/c/rap/incubator/org.eclipse.rap.incubator.visualization.git/snapshot/org.eclipse.rap.incubator.visualization-3c284a7b1eb5862022500481720bcdabe3f9b4a7.zip ), which seem to be from a Austin Riddler, and JSON from htttps:// github . com/douglascrockford/JSON-java ( htttps: // github com/douglascrockford/JSON-java/archive/master.zip ) and extrated the sources in my project.
I needed to adjust VisualizationWidgetLCA and JITWidgetLCA, because
org.eclipse.rap.rwt.internal.protocol.ClientObjectFactory and
org.eclipse.rap.rwt.internal.protocol.IClientObject
don't exists anymore. (I yust killed the offending lines)
If I open a view containing the BarChart I get following on the client:
Client Error
Details:
Error: Error: Operation "set" on target "w247" of type "null" failed:
objectEntry is undefined
Properties:
bounds = 0,0,1906,249
children =
tabIndex = 26
  Script: {"head":{"requestCounter":16},"operations":[["destroy","w215"],["set","w2",{"active":true}],["set","w209",{"enabled":true}],["set","w20",{"text":""}],["set","w33",{"children":["w244","w243","w77","w76","w60","w59","w34","w47","w64","w197"]}],["create","w244","rwt.widgets.ToolBar",{"parent":"w33","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["listen","w244",{"Activate":true,"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["create","w243","rwt.widgets.Composite",{"parent":"w33","style":["NONE"],"bounds":[3,674,1906,249],"children":["w245"],"tabIndex":-1}],["listen","w243",{"Activate":true}],["set","w243",{"clientArea":[0,0,1906,249]}],["create","w245","rwt.widgets.Composite",{"parent":"w243","style":["NONE"],"bounds":[0,0,1906,249],"children":["w246"],"tabIndex":-1,"clientArea":[0,0,1906,249]}],["create","w246","rwt.widgets.Composite",{"parent":"w245","style":["NONE"],"bounds":[0,0,1906,249],"children":["w247"],"tabIndex":-1,"clientArea":[0,0,1906,249]}],["set","w247",{"bounds":[0,0,1906,249],"children":[],"tabIndex":26}],["set","w76",{"visibility":false}],["set","w80",{"tabIndex":-1}],["set","w64",{"selection":"w248","selectionBackground":[76,166,210,255],"selectionForeground":[0,0,0,255],"selectionBackgroundGradient":[[[210,232,243,255],[76,166,210,255]],[0,75],true]}],["set","w75",{"bounds":[0,0,78,23]}],["create","w248","rwt.widgets.CTabItem",{"parent":"w64","index":1,"style":["CLOSE"],"bounds":[78,0,159,23],"text":"VisualizationView","image":["rwt-resources/generated/15dcb52e.gif",16,16],"showClose":true}],["set","w65",{"bounds":[237,1,1671,22],"clientArea":[0,0,1671,22]}],["set","w1",{"focusControl":"w2","activeKeys":["ALT+#39","CTRL+#45","CTRL+SHIFT+#106","ALT+#34","SHIFT+#45","CTRL+#69","CTRL+#32","ALT+#37","CTRL+#117","CTRL+#77","#123","CTRL+#121","ALT+-","CTRL+,","CTRL+.","CTRL+#78","CTRL+#87","CTRL+#115","CTRL+SHIFT+#87","CTRL+SHIFT+#119","CTRL+SHIFT+#111","ALT+#118","ALT+SHIFT+#118","CTRL+#119","CTRL+SHIFT+#118","CTRL+#118","CTRL+SHIFT+#117","CTRL+#89","CTRL+#90","ALT+#13","CTRL+#80","#113","CTRL+SHIFT+#83","CTRL+#83","CTRL+SHIFT+#115","SHIFT+#46","CTRL+#70","CTRL+SHIFT+#69","CTRL+SHIFT+#32","ALT+#33"],"cancelKeys":["ALT+#39","CTRL+#45","CTRL+SHIFT+#106","ALT+#34","SHIFT+#45","CTRL+#69","CTRL+#32","ALT+#37","CTRL+#117","CTRL+#77","#123","CTRL+#121","ALT+-","CTRL+,","CTRL+.","CTRL+#78","CTRL+#87","CTRL+#115","CTRL+SHIFT+#87","CTRL+SHIFT+#119","CTRL+SHIFT+#111","ALT+#118","ALT+SHIFT+#118","CTRL+#119","CTRL+SHIFT+#118","CTRL+#118","CTRL+SHIFT+#117","CTRL+#89","CTRL+#90","ALT+#13","CTRL+#80","#113","CTRL+SHIFT+#83","CTRL+#83","CTRL+SHIFT+#115","SHIFT+#46","CTRL+#70","CTRL+SHIFT+#69","CTRL+SHIFT+#32","ALT+#33"]}],["call","rwt.client.TextSizeMeasurement","measureItems",{"items":[["t1712806109","V",["Verdana","Lucida Sans","Arial","Helvetica","sans-serif"],12,false,false,-1,false]]}]]}
  Stack: rwt.remote.MessageProcessor._processError@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:71172:5
rwt.remote.MessageProcessor.processOperationArray@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:71014:7
rwt.remote.MessageProcessor.processMessage@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:70967:7
.members._handleSuccess@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:71646:9
rwt.remote.Request.prototype.setSuccessHandler/this._success@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:36706:35
rwt.remote.Request.prototype._onReadyStateChange@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:36757:13
.statics.bind/wrap@htttp: //1 27.0.0 1 : 10080/rwt-resources/rap-client.js:5739:1
  Debug: on
  Request: {"head":{"requestCounter":15},"operations":[["notify","w224","DefaultSelection",{"item":"w242","detail":null,"shiftKey":false,"ctrlKey":false,"altKey":false}],["notify","w224","MouseDown",{"button":1,"x":928,"y":504,"time":11498,"shiftKey":false,"ctrlKey":false,"altKey":false}],["notify","w224","MouseDoubleClick",{"button":1,"x":928,"y":504,"time":11498,"shiftKey":false,"ctrlKey":false,"altKey":false}],["notify","w224","MouseUp",{"button":1,"x":928,"y":504,"time":11558,"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w1",{"cursorLocation":[928,504]}]]}
What can I do to get the google Visualizations running?
P.S. sorry for the spaces in the URLs - the forum forced me to do that.
Re: Using Google Visualization on RAP 2.2 [message #1386606 is a reply to message #1386602] Wed, 18 June 2014 15:12 Go to previous message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Google visualization incubator project needs an update to work with
recent RAP versions. Unfortunately, the maintainer Austin Riddle does
not support this project anymore. We will appreciate, if someone want to
take the project maintainer position.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:Workbench and Sessions
Next Topic:Password text field without synchronization with Java client
Current Time: Tue May 07 05:09:46 GMT 2024
Powered by FUDForum. Page generated in 5.05290 seconds
