Eclipse Installation Problem [message #1386449] |
Tue, 17 June 2014 15:48 |
Warren Tolentino Messages: 4 Registered: June 2014 |
i recently downloaded eclipse (eclipse-standard-kepler-SR2-win32-x86_64.zip). i am getting this problem
A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run Eclipse. No Java virtual machine was found after searching the following locations:
C:\Program Files\eclipse\jre\bin\javaw.exe
javaw.exe in your current PATH.
i tried to copy an existing javaw.exe from an oracle installation and it will still not work. i will get other errors.
please advise.
[Updated on: Tue, 17 June 2014 16:01] Report message to a moderator
Re: Eclipse Installation Problem [message #1386508 is a reply to message #1386467] |
Wed, 18 June 2014 02:39 |
On 06/17/2014 11:53 AM, Warren Tolentino wrote:
> thanks. i installed the java and it works. when i opened the eclipse and
> the window label says Java - Eclipse? i was looking for php? i think i
> might have installed the wrong tools for php? please advise.
Yes and no.
You need a JRE to run Eclipse, since it's written in Java.
However, for PHP development using Eclipse, go ask in the Eclipse PDT
forum, or try installing PDT through Help -> Install New Software (or
Eclipse Marketplace).
FUDForum. Page generated in 0.08876 seconds
