Home » Eclipse Projects » Rich Client Platform (RCP) » Add standard Eclipse Menu to RCP
Add standard Eclipse Menu to RCP [message #1385652] |
Tue, 10 June 2014 09:07 |
Goodmorning,
everyone. I haven't found something similar on forum, sorry if exists.
How can add ALL standard eclipse menus (File, Edit...) in my RCP Product? I've got most popular dependencies (eclipse ide, platform...) but I can't see them (only Run and Search).
regards.
Re: Add standard Eclipse Menu to RCP [message #1403629 is a reply to message #1385652] |
Thu, 24 July 2014 17:03 |
i AqD Messages: 8 Registered: July 2014 Location: Taipei |
I have just done that but it's not complete.
Most of the actions/commands are defined in platform UI, but still they're only added by the IDE application, rather than by the platform UI itself. Assume your application doesn't require the IDE plugin, you have to add all these to your own ApplicationActionBarAdvisor plus some naming and localization because they're only in IDE plugin.
The code can be found in the WorkbenchActionBuilder class in org.eclipse.ui.internal.ide plugin (you should have source jar of it in Eclipse plugins directory).
Following is mine, but it contains only those in Platform UI, no navigator etc.
public class ApplicationActionBarAdvisor extends ActionBarAdvisor
private boolean isDisposed;
private IWorkbenchWindow window;
private MenuManager coolbarPopupMenuManager;
private StatusLineContributionItem statusLineItem;
private IWorkbenchAction fileCloseAction;
private IWorkbenchAction fileCloseAllAction;
private IWorkbenchAction fileCloseOthersAction;
private IWorkbenchAction fileSaveAction;
private IWorkbenchAction fileSaveAllAction;
private IWorkbenchAction fileImportResourcesAction;
private IWorkbenchAction fileExportResourcesAction;
private IWorkbenchAction filePropertiesAction;
private IWorkbenchAction fileQuitAction;
private IWorkbenchAction editUndoAction;
private IWorkbenchAction editRedoAction;
private IWorkbenchAction editCutAction;
private IWorkbenchAction editCopyAction;
private IWorkbenchAction editPasteAction;
private IWorkbenchAction editDeleteAction;
private IWorkbenchAction editSelectAllAction;
private IWorkbenchAction editFindAction;
private IWorkbenchAction winNewWindowAction;
private MenuManager winOpenOperspectiveMenu;
private MenuManager winShowViewMenu;
private IWorkbenchAction winEditActionSetAction;
private IWorkbenchAction winSavePerspectiveAction;
private IWorkbenchAction winResetPerspectiveAction;
private IWorkbenchAction winClosePerspectiveAction;
private IWorkbenchAction winCloseAllPerspectivesAction;
private MenuManager winShortcutsMenu;
private IWorkbenchAction winOpenPreferencesAction;
private IContributionItem winOpenWindowsItem;
private IWorkbenchAction helpContentsAction;
private IWorkbenchAction helpSearchAction;
private IWorkbenchAction helpDynamicHelpAction;
private IWorkbenchAction helpAboutAction;
private IWorkbenchAction scutShowPartPaneMenuAction;
private IWorkbenchAction scutShowViewMenuAction;
private IWorkbenchAction scutMaximizePartAction;
private IWorkbenchAction scutMinimizePartAction;
private IWorkbenchAction scutActivateEditorAction;
private IWorkbenchAction scutNextEditorAction;
private IWorkbenchAction scutPrevEditorAction;
private IWorkbenchAction scutSwitchToEditorAction;
private IWorkbenchAction scutNextPartAction;
private IWorkbenchAction scutPrevPartAction;
private IWorkbenchAction scutNextPerspectiveAction;
private IWorkbenchAction scutPrevPerspectiveAction;
private IWorkbenchAction hideShowEditorAction;
private IWorkbenchAction lockToolBarAction;
public ApplicationActionBarAdvisor(IActionBarConfigurer configurer)
super(configurer);
this.window = configurer.getWindowConfigurer().getWindow();
public void dispose()
if (this.isDisposed)
return;
this.isDisposed = true;
IMenuService menuService = (IMenuService) this.window.getService(IMenuService.class);
menuService.releaseContributions(this.coolbarPopupMenuManager);
this.coolbarPopupMenuManager.dispose();
getActionBarConfigurer().getStatusLineManager().remove(this.statusLineItem);
super.dispose();
protected void makeActions(final IWorkbenchWindow window)
super.makeActions(window);
this.statusLineItem = new StatusLineContributionItem("ModeContributionItem"); //$NON-NLS-1$
register(this.fileCloseAction = ActionFactory.CLOSE.create(window));
register(this.fileCloseAllAction = ActionFactory.CLOSE_ALL.create(window));
register(this.fileCloseOthersAction = ActionFactory.CLOSE_OTHERS.create(window));
register(this.fileSaveAction = ActionFactory.SAVE.create(window));
register(this.fileSaveAllAction = ActionFactory.SAVE_ALL.create(window));
register(this.fileImportResourcesAction = ActionFactory.IMPORT.create(window));
register(this.fileExportResourcesAction = ActionFactory.EXPORT.create(window));
register(this.filePropertiesAction = ActionFactory.PROPERTIES.create(window));
register(this.fileQuitAction = ActionFactory.QUIT.create(window));
register(this.editUndoAction = ActionFactory.UNDO.create(window));
register(this.editRedoAction = ActionFactory.REDO.create(window));
register(this.editCutAction = ActionFactory.CUT.create(window));
register(this.editCopyAction = ActionFactory.COPY.create(window));
register(this.editPasteAction = ActionFactory.PASTE.create(window));
register(this.editDeleteAction = ActionFactory.DELETE.create(window));
register(this.editSelectAllAction = ActionFactory.SELECT_ALL.create(window));
register(this.editFindAction = ActionFactory.FIND.create(window));
register(this.winNewWindowAction = ActionFactory.OPEN_NEW_WINDOW.create(window));
this.winOpenOperspectiveMenu = createSubMenu("&Open Perspective", "openPerspective", ContributionItemFactory.PERSPECTIVES_SHORTLIST);
this.winShowViewMenu = createSubMenu("Show &View", "showView", ContributionItemFactory.VIEWS_SHORTLIST);
register(this.winEditActionSetAction = ActionFactory.EDIT_ACTION_SETS.create(window));
register(this.winSavePerspectiveAction = ActionFactory.SAVE_PERSPECTIVE.create(window));
register(this.winResetPerspectiveAction = ActionFactory.RESET_PERSPECTIVE.create(window));
register(this.winClosePerspectiveAction = ActionFactory.CLOSE_PERSPECTIVE.create(window));
register(this.winCloseAllPerspectivesAction = ActionFactory.CLOSE_ALL_PERSPECTIVES.create(window));
register(this.winOpenPreferencesAction = ActionFactory.PREFERENCES.create(window));
this.winOpenWindowsItem = ContributionItemFactory.OPEN_WINDOWS.create(this.window);
register(this.scutShowPartPaneMenuAction = ActionFactory.SHOW_PART_PANE_MENU.create(window));
register(this.scutShowViewMenuAction = ActionFactory.SHOW_VIEW_MENU.create(window));
register(this.scutMaximizePartAction = ActionFactory.MAXIMIZE.create(window));
register(this.scutMinimizePartAction = ActionFactory.MINIMIZE.create(window));
register(this.scutActivateEditorAction = ActionFactory.ACTIVATE_EDITOR.create(window));
register(this.scutNextEditorAction = ActionFactory.NEXT_EDITOR.create(window));
register(this.scutPrevEditorAction = ActionFactory.PREVIOUS_EDITOR.create(window));
ActionFactory.linkCycleActionPair(this.scutNextEditorAction, this.scutPrevEditorAction);
register(this.scutSwitchToEditorAction = ActionFactory.SHOW_OPEN_EDITORS.create(window));
register(this.scutNextPartAction = ActionFactory.NEXT_PART.create(window));
register(this.scutPrevPartAction = ActionFactory.PREVIOUS_PART.create(window));
ActionFactory.linkCycleActionPair(this.scutNextPartAction, this.scutPrevPartAction);
register(this.scutNextPerspectiveAction = ActionFactory.NEXT_PERSPECTIVE.create(window));
register(this.scutPrevPerspectiveAction = ActionFactory.PREVIOUS_PERSPECTIVE.create(window));
ActionFactory.linkCycleActionPair(this.scutNextPerspectiveAction, this.scutPrevPerspectiveAction);
this.winShortcutsMenu = createSubMenu("Navi&gation", "shortcuts",
this.scutShowPartPaneMenuAction,
this.scutShowViewMenuAction,
new Separator(),
this.scutMaximizePartAction,
this.scutMinimizePartAction,
new Separator(),
this.scutActivateEditorAction,
this.scutPrevEditorAction,
this.scutSwitchToEditorAction,
new Separator(),
this.scutPrevPartAction,
new Separator(),
register(this.helpContentsAction = ActionFactory.HELP_CONTENTS.create(window));
register(this.helpSearchAction = ActionFactory.HELP_SEARCH.create(window));
register(this.helpDynamicHelpAction = ActionFactory.DYNAMIC_HELP.create(window));
this.helpAboutAction = ActionFactory.ABOUT.create(window);
this.helpAboutAction.setImageDescriptor(window.getWorkbench().getSharedImages().getImageDescriptor("IMG_OBJS_DEFAULT_PRO"));
register(this.helpAboutAction);
this.hideShowEditorAction = ActionFactory.SHOW_EDITOR.create(window);
register(this.hideShowEditorAction);
this.lockToolBarAction = ActionFactory.LOCK_TOOL_BAR.create(window);
register(this.lockToolBarAction);
protected void fillStatusLine(IStatusLineManager statusLine)
statusLine.add(this.statusLineItem);
protected void fillMenuBar(IMenuManager menuBar)
MenuManager fileMenu = new MenuManager("&File", IWorkbenchActionConstants.M_FILE);
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.NEW_EXT));
fileMenu.add(new Separator());
fileMenu.add(this.fileCloseAction);
fileMenu.add(this.fileCloseAllAction);
fileMenu.add(this.fileCloseOthersAction);
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.CLOSE_EXT));
fileMenu.add(this.fileSaveAction);
fileMenu.add(this.fileSaveAllAction);
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.SAVE_EXT));
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.PRINT_EXT));
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.OPEN_EXT));
fileMenu.add(this.fileImportResourcesAction);
fileMenu.add(this.fileExportResourcesAction);
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.IMPORT_EXT));
fileMenu.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
fileMenu.add(this.filePropertiesAction);
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.MRU));
fileMenu.add(this.fileQuitAction);
fileMenu.add(new GroupMarker(IWorkbenchActionConstants.FILE_END));
menuBar.add(fileMenu);
MenuManager editMenu = new MenuManager("&Edit", IWorkbenchActionConstants.M_EDIT);
editMenu.add(new GroupMarker(IWorkbenchActionConstants.EDIT_START));
editMenu.add(this.editUndoAction);
editMenu.add(this.editRedoAction);
editMenu.add(new GroupMarker(IWorkbenchActionConstants.UNDO_EXT));
editMenu.add(new Separator());
editMenu.add(this.editCutAction);
editMenu.add(this.editCopyAction);
editMenu.add(this.editPasteAction);
editMenu.add(new GroupMarker(IWorkbenchActionConstants.CUT_EXT));
editMenu.add(this.editDeleteAction);
editMenu.add(this.editSelectAllAction);
editMenu.add(this.editFindAction);
editMenu.add(new GroupMarker(IWorkbenchActionConstants.FIND_EXT));
editMenu.add(new GroupMarker(IWorkbenchActionConstants.ADD_EXT));
editMenu.add(new GroupMarker(IWorkbenchActionConstants.EDIT_END));
editMenu.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
menuBar.add(editMenu);
menuBar.add(new GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
MenuManager windMenu = new MenuManager("&Window", IWorkbenchActionConstants.M_WINDOW);
windMenu.add(this.winNewWindowAction);
windMenu.add(new Separator());
windMenu.add(this.winOpenOperspectiveMenu);
windMenu.add(this.winShowViewMenu);
windMenu.add(this.winEditActionSetAction);
windMenu.add(this.winSavePerspectiveAction);
windMenu.add(this.winResetPerspectiveAction);
windMenu.add(this.winClosePerspectiveAction);
windMenu.add(this.winCloseAllPerspectivesAction);
windMenu.add(this.winShortcutsMenu);
windMenu.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
windMenu.add(this.winOpenPreferencesAction);
windMenu.add(this.winOpenWindowsItem);
menuBar.add(windMenu);
MenuManager helpMenu = new MenuManager("&Help", IWorkbenchActionConstants.M_HELP);
helpMenu.add(new GroupMarker("group.intro"));
helpMenu.add(new GroupMarker("group.intro.ext"));
helpMenu.add(new GroupMarker("group.main"));
helpMenu.add(this.helpContentsAction);
helpMenu.add(this.helpSearchAction);
helpMenu.add(this.helpDynamicHelpAction);
helpMenu.add(new GroupMarker("group.assist"));
helpMenu.add(new GroupMarker("group.main.ext"));
helpMenu.add(new GroupMarker("group.tutorials"));
helpMenu.add(new GroupMarker("group.tools"));
helpMenu.add(new GroupMarker("group.updates"));
helpMenu.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
helpMenu.add(new GroupMarker("group.about"));
helpMenu.add(this.helpAboutAction);
helpMenu.add(new GroupMarker("group.about.ext"));
menuBar.add(helpMenu);
protected void fillCoolBar(ICoolBarManager coolBar)
this.coolbarPopupMenuManager = new MenuManager();
this.coolbarPopupMenuManager.add(new ActionContributionItem(this.lockToolBarAction));
this.coolbarPopupMenuManager.add(new ActionContributionItem(this.winEditActionSetAction));
coolBar.setContextMenuManager(this.coolbarPopupMenuManager);
menuService.populateContributionManager(this.coolbarPopupMenuManager, "popup:windowCoolbarContextMenu");
IToolBarManager toolbar = new ToolBarManager(SWT.FLAT | SWT.RIGHT);
toolbar.add(new Separator(IWorkbenchActionConstants.NEW_GROUP));
toolbar.add(new GroupMarker(IWorkbenchActionConstants.NEW_EXT));
toolbar.add(new GroupMarker(IWorkbenchActionConstants.SAVE_GROUP));
// toolbar.add(this.fileSaveAction);
// toolbar.add(this.fileSaveAllAction);
toolbar.add(new GroupMarker(IWorkbenchActionConstants.SAVE_EXT));
toolbar.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
coolBar.add(new GroupMarker(IWorkbenchActionConstants.GROUP_FILE));
coolBar.add(new ToolBarContributionItem(toolbar, IWorkbenchActionConstants.TOOLBAR_FILE));
coolBar.add(new GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
coolBar.add(new GroupMarker(IWorkbenchActionConstants.GROUP_EDITOR));
coolBar.add(new GroupMarker(IWorkbenchActionConstants.GROUP_HELP));
protected MenuManager createSubMenu(String text, String id, ContributionItemFactory factory)
MenuManager submenu = new MenuManager(text, id);
submenu.add(factory.create(this.window));
return submenu;
protected MenuManager createSubMenu(String text, String id, Object... items)
for (Object i : items)
if (i instanceof IContributionItem)
submenu.add((IContributionItem) i);
else if (i instanceof IWorkbenchAction)
submenu.add((IWorkbenchAction) i);
return submenu;
Current Time: Tue Mar 19 06:14:55 GMT 2024
Powered by FUDForum. Page generated in 0.02284 seconds
