Re: [CDO] more detailed logs when CDOSession is null... [message #1385573 is a reply to message #1385557] |
Mon, 09 June 2014 15:33 |
Am 09.06.2014 13:06, schrieb Arek Kowal:
> thank you, but I haven't information from cdo code in logs...
Please read https://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_enable_tracing.3F and add the following:
OMPlatform.INSTANCE.setDebugging(true);
Severe exceptions don't require that, though, as they're always logged and not just traced conditionally.
> it is surprising for me, you catch all exception in your code (without any stack trace or something like that ;) ) ?
That's totally new to me. Can you please point me to the code that swallows an exception?
> my code:
> public CDOSession openSession()
> CDOSession session = configuration.openNet4jSession();
> for (EPackage ePackage : getEPackages()) {
> session.getPackageRegistry().putEPackage(ePackage);
> return session;
> private void init()
> OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
> OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
> IManagedContainer container = ContainerUtil.createContainer();
> Net4jUtil.prepareContainer(container);
> TCPUtil.prepareContainer(container);
> CDONet4jUtil.prepareContainer(container);
> container.activate();
> IConnector connector = TCPUtil.getConnector(container, servedrAddress));
> configuration = CDONet4jUtil.createNet4jSessionConfiguration();
> configuration.setConnector(connector);
> configuration.setRepositoryName(repoName);
> etc.
Where is the code that refers to this variable/field "cdoSession"?
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
FUDForum. Page generated in 0.03932 seconds
