Home » Language IDEs » C / C++ IDE (CDT) » Scanner Discovery (Build Output Parser) doesn't work with -iquote
Scanner Discovery (Build Output Parser) doesn't work with -iquote [message #1385462] Fri, 06 June 2014 11:07 Go to next message
To me it appears as if the Scanner Discovery (Build Output Parser) is not extracting include paths prefaced with -iquote instead of -I. I've verified this by doing a build and then looking at the files properties and looking at Preprocessor Include Paths, then the Settings provided by CDT GCC Build Output Parser. Only header paths prefaced with -I show up there. If I modify my build system to always use -I instead of -iquote, all the header include paths show up properly.
Is this a bug or operational error on my part?
I'm using Kepler Service Release 2, Build id: 20140224-0627
Re: Scanner Discovery (Build Output Parser) doesn't work with -iquote [message #1746184 is a reply to message #1385462] Mon, 24 October 2016 12:36 Go to previous messageGo to next message
I entered a bug for this two years ago and it still hasn't been assigned to a developer.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=437537
Re: Scanner Discovery (Build Output Parser) doesn't work with -iquote [message #1764598 is a reply to message #1746184] Wed, 31 May 2017 11:21 Go to previous messageGo to next message
I'm wondering if I'm not adhering to the right process to get a bug looked into. I've entered a bug on this issue (https://bugs.eclipse.org/bugs/show_bug.cgi?id=437537) in June of 2014 and the bug still isn't assigned to a developer.
Re: Scanner Discovery (Build Output Parser) doesn't work with -iquote [message #1764599 is a reply to message #1746184] Wed, 31 May 2017 11:21 Go to previous messageGo to next message
Re: Scanner Discovery (Build Output Parser) doesn't work with -iquote [message #1764616 is a reply to message #1764599] Wed, 31 May 2017 15:32 Go to previous message
You are adhering to the right process. But sad to say that no one is likely to be assigned to fix this bug. There is no developer to assign it to as this is an open source project. I would be happy to review any fix you submit and can guide you through your first submission!
Previous Topic:include inside include - strange behavour !
Next Topic:[RESOLVED] How change the value of an IOption
Current Time: Thu Nov 06 06:57:52 EST 2025
Powered by FUDForum. Page generated in 0.04183 seconds
