Home » Eclipse Projects » Sirius » Style Customization extension point
Style Customization extension point [message #1385412] Fri, 06 June 2014 05:18 Go to next message
Hi all,
I'm new in sirius! Thanks for the great job.
Is there any tutorial or a sample code showing how to customize style using the org.eclipse.sirius.diagram.ui.styleConfigurationProvider extension point ?
[Updated on: Fri, 06 June 2014 08:58] by Moderator
Re: Style Customization extension point [message #1385449 is a reply to message #1385412] Fri, 06 June 2014 09:47 Go to previous messageGo to next message
Hey Adel,
there is the official documentation for sirius which can be found here [1].
However you won't find anything related to the extension points there.
On the obeo network site you can find a more detailed documentation for obeo designer (sirius before it got contributed to eclipse).
You can find the documentation for the styleProvider here[2]
In order to see the full documentation[3] you need to create an account here[4] and join this group[5].
Keep in mind though that this documentation is out of date and propably misleading at some points.
Florian
[1]http://www.eclipse.org/sirius/doc/
[2]http://docs.obeonetwork.com/obeodesigner/6.2/viewpoint/developer/general/extensions-provide_custom_style.html]
[3]http://www.obeonetwork.com/group/obeo-designer/page/obeo-designer-reference-documentation-6-2
[4]http://www.obeonetwork.com/
[5]http://www.obeonetwork.com/group/obeo-designer
[Updated on: Fri, 06 June 2014 09:54] by Moderator
Re: Style Customization extension point [message #1385468 is a reply to message #1385449] Fri, 06 June 2014 11:38 Go to previous messageGo to next message
Hi Florian,
thanks for all this links. I will test some Obeodeigner code with Sirius.
Adel
Re: Style Customization extension point [message #1385656 is a reply to message #1385468] Tue, 10 June 2014 05:13 Go to previous message
Hi Adel,
As said by Florian (thanks to him), a documentation exists for this
extension point. This documentation is not yet in Sirius, because as
said by Pierre-Charles in this thread [1],
> "we used to have a "Developer" section in the documentation (before the product was open sourced as Sirius), but it was inconsistent and sometimes completely obsolete. We did not have enough time to rewrite it for Sirius 1.0, so it has been removed to avoid confusion.
> We certainly want to have such a documentation in the future. Feel free to comment on https://bugs.eclipse.org/bugs/show_bug.cgi?id=426583 to tell us what kind of information you expect in priority for such a document (for us who have been working on Sirius for years, it is not always obvious what a newcomer needs).
Laurent
[1]
http://www.eclipse.org/forums/index.php/mv/msg/781375/1385080/#msg_1385080
Previous Topic:merging uml2.odesign to another .odesign
Next Topic:Drill Down on Double Click
Current Time: Sat Nov 08 11:05:43 EST 2025
Powered by FUDForum. Page generated in 0.03299 seconds
