Home » Eclipse Projects » Sirius » Diagram refreshing and Java service Debugging
Re: Diagram refreshing and Java service Debugging [message #1385011 is a reply to message #1385004] |
Tue, 03 June 2014 15:37 |
Le 03/06/2014 16:58, Wenjing Yuan a écrit :
> Hi all,
> I'm quite new in Sirius. Thanks for the info from
> https://www.eclipse.org/forums/index.php/t/632359/
> I'm now able to use my own java service, but the problem is no matter
> how I modify my java class, it will never reflect to the *.odesign. Even
> the method name has been changed, the auto-completion would still
> provide the suggestion of the previous name. I have tried to remove and
> add again of java extension declaration, but no luck :( , the diagram
> still follows the definition in previous java service.
> 1. Is this a common problem? or is there any force refresh button I
> didn't find?
Several changes done in the VSM are directly taken into account in an
open editor described in this VSM. Do you use the java service in a
service: expression or in an Acceleo3 expression ?
2. Is there any easy way to reflect my changes immediately
> to the representation?
When a change in the VSM is not directly reflected you have several
possibilities:
. Right clic > refresh (or refresh from the tabbar when the selection
is on the diagram. (For tables and trees editors, I think Right clic >
refresh should be available too).
. If the manual refresh did not reflect the changes, you can close and
reopen the editor.
. Close/Reopen the Modeling Project (or the session if you are not
working with Modeling Project)
> 3. How to debug my java service? There is an answer about debugging but
> using the Sirius interpreter which is not applicable for my issue I guess.
If you launch a runtime in debug mode from your Sirius environment, with
the Viewpoint Specification Project in the dev env and you session /
modeling project in the runtime, you can create standard JDT breakpoints
in your java services and debug them as any Java classes.
> Thank you for any hints.
> KR,
> Winny
Maxime
Maxime Porhel - Obeo
Re: Diagram refreshing and Java service Debugging [message #1385083 is a reply to message #1385079] |
Wed, 04 June 2014 09:06 |
Le 04/06/2014 10:48, Wenjing Yuan a écrit :
> Hi Maxime,
> Thank you for the reply.
> 1. I have tried both service expression and the Acceleo expression.
> For instance, I have myService() method in SampleService class. Three
> expressions are:
> [self.myService()/]
> service:self.myService()
> service:myService
> There would be an error when I use service expressions, but not for the
> Acceleo one.
In the Specialized documentation [1], see the intended limitation to be
more efficient: "The services should be in the same bundle as the VSM
and should be deployed". This is not the case with Acceleo3 expressions
whose interpreter is able to use the services in a non deployed mode.
> 2. Thank you. But none of them work for me, the diagram still shows the
> previous function. I have tried to close both of them and restart
> eclipse, no luck for that. The refresh seems only happen when I restart
> the computer :(
Before restarting your computer, you could just restart your eclipse
runtime.
> 3. The VSP is already in a runtime eclipse, should I launch a runtime
> over a runtime? Sorry to ask if this is common in this situation.
You can launch a runtime over a runtime.
You might also move your VSP in your "base" eclipse.
> PS: the attached image may explain the problem better. I have change the
> method to return "new" to label instead of "foo". But newly created
> representation still hold "foo" as the name
Your message does not have any attached image.
> KR,
> Winny
Maxime
[1]
https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#specialized
Current Time: Fri Apr 26 06:17:19 GMT 2024
Powered by FUDForum. Page generated in 0.06384 seconds
