Home » Language IDEs » Java Development Tools (JDT) » Headless build errors on Java projects with ant builders
Headless build errors on Java projects with ant builders [message #241806] Mon, 19 March 2007 22:09 Go to next message
I want to use a headless build for my projects and it fails if the
projects have external builders (e.g. ant scripts to pre-generate Java
code). I tried the workspaceBuild task and the apt task to build the
workspace and both failed with the same error complaining that
"Workbench was not created yet" (see the exception stack trace below).
Does anyone know any solution/workaround for this error that allows to
run a headless build on projects with external tasks?
Valer.
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.debug.ui"
was unable to instantiate class
" org.eclipse.debug.internal.ui.views.breakpoints.WorkingSetBr eakpointOrganizer ".
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:159)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOr ganizerExtension.getOrganizer(BreakpointOrganizerExtension.j ava:84)
org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOr ganizerExtension.addPropertyChangeListener(BreakpointOrganiz erExtension.java:103)
org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOr ganizerManager.start(BreakpointOrganizerManager.java:80)
org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOr ganizerManager. <init>(BreakpointOrganizerManager.java:65)
org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOr ganizerManager.getDefault(BreakpointOrganizerManager.java:54 )
org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlu gin.java:401)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
at java.security.AccessController.doPrivileged(AccessController .java:242)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:383)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:563)
org.eclipse.ui.externaltools.internal.launchConfigurations.E xternalToolsUtil.getResourcesForBuildScope(ExternalToolsUtil .java:180)
org.eclipse.ui.externaltools.internal.model.ExternalToolBuil der.build(ExternalToolBuilder.java:75)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:603)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:167)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:230)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:233)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:252)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:285)
at org.eclipse.core.internal.resources.Workspace.build(Workspac e.java:271)
at org.eclipse.jdt.apt.core.build.AptBuilder.run(AptBuilder.jav a:50)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.core.runtime.CoreException[1]:
java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
org.eclipse.debug.internal.ui.views.breakpoints.WorkingSetBr eakpointOrganizer. <init>(WorkingSetBreakpointOrganizer.java:34)
at java.lang.Class.newInstanceImpl(Native Method)
at java.lang.Class.newInstance(Class.java:1243)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
Re: Headless build errors on Java projects with ant builders [message #241813 is a reply to message #241806] Mon, 19 March 2007 23:09 Go to previous messageGo to next message
External tools builders are in a UI plugin and have UI dependencies....so it
is a non-starter for headless builds
Sorry
Darins
"Valer" <valer_crisan@yahoo.com> wrote in message
news:etnfo5$43u$3@utils.eclipse.org...
> workspace and both failed with the same error complaining that "Workbench
> Does anyone know any solution/workaround for this error that allows to run
> Valer.
> org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.debug.ui" was
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Headless build errors on Java projects with ant builders [message #242932 is a reply to message #241813] Mon, 16 April 2007 20:13 Go to previous messageGo to next message
Is there a Bugzilla Bug open for this?
- I think it used to work in older Eclipses....
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:etnj67$ab7$1@utils.eclipse.org...
> it is a non-starter for headless builds
> Sorry
> Darins
>> Thanks,
>> Valer.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Headless build errors on Java projects with ant builders [message #242937 is a reply to message #242932] Mon, 16 April 2007 20:22 Go to previous message
To ensure we are all on the same page:
Headless Ant builds are possible and will remain possible using the
antRunner application entry point.
Running external tool builders associated with projects as part of a
headless build is not possible for the reasons I stated below.
No support is planned in this area.
Darins
"Barry Searle" <searle@ca.ibm.com> wrote in message
news:f013g7$4le$1@build.eclipse.org...
>> Sorry
>> Darins
>>> Hi,
>>> Thanks,
>>> Valer.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:Importing resources from other projects
Next Topic:Java Debug View not receiving events?
Current Time: Thu Sep 25 23:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.03689 seconds
