Hashtable$Entry is referenced by ? [message #23658] |
Tue, 26 July 2005 08:21 |
Originally posted by: jan.luciad_nospam.com
Hi !
When showing the "object references" view of the profiling data I find a
number of objects referenced by Hashtable$Entry. Unfortunately I can't
expand that element in the view to find out which object is actually
referencing Hashtable$Entry.
Does somebody know how I can find this out ? Thanks !
Jan
Re: Hashtable$Entry is referenced by ? [message #23974 is a reply to message #23812] |
Thu, 28 July 2005 16:10 |
Hi Eugene,
Thanks for helping me out !
I thought I did that already. To make sure I did, I tried it. With the
same result.
I can follow the references of an object to Hashtable$Entry and there it
stops. There is no icon to expand the node any further. But when I look
to which objects are referencing Hashtable for example, then I see a
list of objects. I guess the one I'm looking for is amongst then. But I
would really like to go further then the Hashtable$Entry to be sure
which one it is.
Maybe it's the install that is wrong ? Or is this a known issue ? Maybe
inner classes are not supported ?
Linux Fedora Core 3
Sun JDK 1.4.2_08
Eclipse 3.1
TPTP 4.0 (tptp.runtime-TPTP-4.0.0-200507181519)
Are you able to check for the references of Hashtable$Entry. (Or
HashMap$Entry)
Jan
Eugene Chan wrote:
> Hi Jan,
> You can collect object reference information by click on the 'Collect Object
> Reference' button in the Profiling Monitor View toolbar, or in context menu
> on the profiling object (eg. process) you are profiling.
> Eugene
> "Jan Goyvaerts" <jan@luciad_nospam.com> wrote in message
> news:dc4rqg$co6$1@news.eclipse.org...
>>Hi !
>>Jan
Re: Hashtable$Entry is referenced by ? [message #40798 is a reply to message #23974] |
Wed, 16 November 2005 13:22 |
Originally posted by: kevin.mcmanus.dds.mediaocean.com
Hi All,
I am having the same issue, and the app that I'm profiling has numerous
HashMaps. So, it becomes a matter of guesswork to determine which
HashMap instance refers to which Entry.
So, in "Referenced By" mode, I see the following, where the Entry is a
leaf, not showing the HashMap, or [Entry, which references it.
MyClass.185761
|-----> HashMap$Entry.202499
Using Memory Statistics I can determine that instances of my class exist
when they should not, but not what is keeping the in memory.
Any suggestions?
Kevin
Jan Goyvaerts wrote:
> Hi Eugene,
> same result.
> which one it is.
> Linux Fedora Core 3
> Sun JDK 1.4.2_08
> Eclipse 3.1
> HashMap$Entry)
> Jan
> Eugene Chan wrote:
>> Hi Jan,
>> Object
>> menu
>> Eugene
>>> Hi !
>>> Jan
FUDForum. Page generated in 0.03508 seconds
