| Compare editor difference between 3.2 and 3.3M5? [message #240905] |
Tue, 20 February 2007 13:40  |
Originally posted by: nospam.nospam.com
I just upgraded to 3.3M5 from 3.2, and am getting some different behavior
that I am curious as to whether it is supposed to be like that or not.
Basically, I used to right click on a java class, select Compare With>Latest
from Head and the compare editor would open. Now it opens up the Team
Synchronize view and I have to navigate down the tree and double click the
source to get the compare editor to open up.
Is this the way it is supposed to work? If so, is there any way to restore
the direct open path? Thanks.
| Re: Compare editor difference between 3.2 and 3.3M5? [message #240921 is a reply to message #240909] |
Wed, 21 February 2007 06:43   |
Konstantin,
I agree as well. This new approach seems disruptive. But all files do
this, not just .java files, so this is likely a better topic of
discussion on the platform newsgroup so that the CVS folks can comment.
I've added that newsgroup to the "to" list.
Konstantin Scheglov wrote:
>> With>Latest from Head and the compare editor would open. Now it opens
>> up the Team Synchronize view and I have to navigate down the tree and
>> double click the source to get the compare editor to open up.
>> restore the direct open path? Thanks.
> +1
> I more liked old way. Now, I loose my "synchronize context", so have
> to select projects to synchronize again. I have special plugin that
> allows me configure several "synchronize context's" and synchronize
> them fast, without reselecting projects each time, but still new
> compare behavior looks more heavy than old one.
FUDForum. Page generated in 0.03959 seconds
