[Zest] A couple of questions about graph connections in ZEST [message #240284] |
Fri, 14 December 2007 10:45  |
Originally posted by: s0452900.sms.ed.ac.uk
--------------030109040609040403090101
Hello all,
I was wondering if you could help with a small problem I am having using
graph connections in Zest as part of my University Honours project. I am
using Zest to create a graphical representation of the modelling
language PEPA. For this, I have nodes that are either processes or
intermediate steps and activity arcs with labels. The activity arcs are
each different and can connect to either the same node or a different one.
There are two problems I have experienced so far. First, when an
activity arc loops back to the same node, the arc label is partially
hidden behind the node. Second, when two different arcs go between the
two same nodes they are placed one on top of the other, even if the go
in different directions. I have attached a picture to help illustrate
the problem.
Therefore, my questions are as follows:
* Is there a way to move the label on an arc that loops on the same
node, to make it more visible?
* Is there a way I can separate connections, or have curved
connections, that do not over lap one another?
I have enjoyed using Zest and I hope any help you can give will mean
that I can continue using it to produce some informative and pretty
diagrams to representing PEPA models.
Thank you,
Paul McEwan
Content-Type: image/png;
name="Picture 1 Alt.png"
Content-Disposition: inline;
filename="Picture 1 Alt.png"
iVBORw0KGgoAAAANSUhEUgAABAAAAAMACAIAAAA12IJaAAABSmlDQ1BJQ0Mg UHJvZmlsZQAA
eJyVj79LAnEYh5+vBEmBGR3R0HBTFBSd2qA1eSoSBJk16G3eeViI3nH37Ydr zY0NgUNL0NjQ
3NTYEPSDpiCov6Bwcmi44AgH6Zme98OHl/eFiJbN64VIHFpt6ZWLulqpGuro A1HGmSLFWs3y
3WyptAHQdto2A/ReEACPS9m8Xni7Ojl+PX/uffo3yeLqe3qw/4cxy/Uk0AeS ddu3QGhA81C6
EkQXUMymK0FcA4q3U86BuANijcCfgJgZ+AcQ8ypVA8Q3oDQqVQMiUUAxA58F FGkfSYCc43a8
vcauVJOapqnZumPa6nbHl3bLV9fbluO5jleTdh0I7gNgMiiWi7o6n8hk0gtD /vw3laqhBva1
hQDE9H2YhVj73sGvikhq+Bzu6M7A5iWM9MNs5RQuFmHiLMzmEhBfhtvuD2jb Wg5OFLZ9AAAg
AElEQVR4nOzdd3hUVf4G8PdOzaR3UkgIJCSEXhJ6k7aCgoKoIK5lLaz+RBeX VVBAsYtY0NVF
XVdFccECrCAiHQtFegsBQgmppPfMZObe8/vjknFIJkNAkgHzfp48cPOdc879 3jKZc+Y2CbWS
kpIeeOCBUaNGxcTEgIiIiIiIrn1bt27dsmXL6tWrd+/erUa06n9Tp05dtGjR 0KFD/f39f/9s
dqRaHnqv6F/flQ/r6uHvrfn9DRIRERER0WWIiYkZOnTowIEDZVnes2cPAB2A Bx544M033zSZ
TLIsAxBCAJAkSZIkdVolSZJjW44vOcopkl9YWlpuET1jDZGBktqm0xbqtGaf nTqhFnZv3O0J
MM4444wzzrgb445Be/yyG6zfCBy6E020UL8/7ctYzKtnC/6e+EU339WT6tUc d/pWcqG6BptS
sOMEDpzFmXwIgTbB6BaNfu0xvDNMhos24ISaXseOHefPny+E+OCDD6SePXt+ +eWXMTExVqvV
sahGcwnf3Dsuz39/Mn++xRLoL8262bNTtP5SU7SvxKsk7vYEGGecccYZZ9zt ccfg72nQjZ/m
rquknS3cuDPnVI4ot3oJXYDe5AvAWl0m2Yp99JXtwqXhfcLjooMuadZX1Ra8 jLiLYldbqldz
vE6ZOmOAOtV/OS4t2yFtOyWZ/CS9NzR6KDIs5aguFSVFuL6bmNxfDOpw8VFE Q/R6/dGjR++6
6y7dmDFjoqOjzWZz/b328ppWZCUpXju5vyE+UuP49T8REdG1btJL6QAyasov WjLK4DOws+GR
ceFNnxT9Lr/szVj1U0FOZZjRtxugnhuBmmr1xWDogi0CBdn46dP0cK/dYwcF D+gZ5b5k6Y/s
uwOaj37UlEiakAQICYoMRYZQoPOCp0Ey+mFjCk7k4v9GKGN7KZc3C1mW4+Pj x4wZI61du3bg
wIGKUrehix4BsA8YiiqxJkV7OEcT6Cmuay+3CVIkCftztD+lamtkdItQbuxi 8zY2Kq2GDo6o
8ezs7F27doWFhcXExLRq1aq0tLS8vNzX19fX11ctlpWVpdPpWrVqpZYvKiqq rKx00X5YWJhe
r3cx30YmxjjjjDPOeEuI3/FKRmO6/nZRBp8vZka5aD8jIyMwMNDLy6tOvKCg IDg42Gmbajs1
NTVms9n+8afGZVlOS0sLCgoKCgpymr8sy2fOnGnbtq1Go6mTT0FBQVBQkCRJ TvN0DNYpkJaW
ds899/z888+NWYFNtLFSU1M7dOjgonxDLymKeP3Tgym5IUa/dpKEHvFSp2i0 CZFC/CRfTwAo
q0J+qUjPF0fOYt9xIQQspacSW+XNuKebRiO5aP/EiRMffvhhaWmp02RcmDt3 bmRkZEMtnz59
um3btkKIjIwMk8kUEhLSyCW1x61W68mTJw0GQ7t27VyXr/Nq/e2YmZnp7+/v 7e2tBgsLC2VZ
Dg0NVX+tqanJz89Xl+Wi2/Hw4cMPPfTQl19+GR4e3lD59PR0q9UaFxfnGCws LNy9e3fHjh2j
opyMytR2ZFnOzs52DEZFRTm2f/r06ZSUlF69eoWHh7vOMz09vaampn379o7x mpqavXv3AujT
p4/aN3a9HzqNA9h2QvP6Wl2Zh8bgj+Ic1FRCCECGokBngIcvFBmyDWW5IjpA nn2zbWBiQy1d
hCRJP//8s5Senh4QEOD03V5nAZwmfSBL8+RqjzxFY/SGoqCyWCT6K8VV0jmL xsMXMmApRTtF
fm2yOSFCcbHY9Y+PqL+qE3v37p0+fbq6flUnT57csGHD1KlTp0yZsmjRIiFE Xl5eXFycj49P
ZmamOnq5/vrrAfzyyy8NzXTnzp2JiYku5nvRxBhnnHHGGW8h8SmvZl5S71/1 45xEp+2XlJTc
dtttOp0uJyfnvvvue+SRR9T4c88999133x09ejQvL8/Dw6N+PmvXrn377bd3 7969cOHCyZMn
2+PLly+fO3duYmJiWlra8OHDFyxYUGe+27Ztmzp1amxs7OnTpz/77LOuXbuq cfscz507ZzKZ
6uTp2Ej9BTl58uS9994L4Keffmr8ilWnUduvcDqL+smPHj16//79MTExb7zx Rm5ubqtWrWbM
mCGEWLJkSXFx8SOPPNLQRsSFHRj7S2nphe+vyK4w9gYwtLvUr4PUMeq3YvWl ZIjtqWLLfgHA
2/Lr1PERcW2cnBEkhMjNzV28eLHepyA4QqP3sPejBCA5TKjx8xVtNdKpfZ49 e/YcN26cPe06
Lc+fPz85Ofm6665r06ZNYmJiVVVVZWXlypUrW7duLUlSaWlp69at7YU/++yz m2666eeff/7s
s88AzJgxIz4+HsCcOXMSExM1Go3FYrnrrrtc7PlOt4XjdO/evYcNG/bKK6+o 8REjRpw9e/bE
iRPqr4sXL/7kk082bdrUmDfXzp07R4wYcejQoTZt2tQvP2PGjDVr1mRkZMyZ M+eJJ56wx4cP
H37ixImePXvu3r27ffv27777rr1T59h+enp6586dHTdleXm5vf1nn332s88+ 69Gjx6+//jpv
3ry//OUvTvOsk4M9/vrrry9YsKBLly75+flVVVUzZ85U3xH1V1edRa7DbMVT XxsOleiMwTh3
CsltpBu6YlC8BIGfjolVu7E9VXiFQlZgq0HZOflPnatfu1tz2dcDFBcX6/z9 /UUDwx24HKkA
KKzE37/1sAVrwvygDlMCQqV8sxZ+CNKiqgawQm9C6l5Ndq6mQ+RFvmJXJ9QV ZP9VnZg6dWpq
auorr7wyadKk3NzcQ4cOeXt7Dxo0CLV/dCRJ2rZtG4Dy8vKjR4926tSpoqJi 586dc+fOnTdv
ntrUe++9t3z58ltuueWhhx5SIzExMa7ne9HEGGecccYZbyHxjJryKIPP/57v 0PPJXbgUTtt/
6qmnkpKSXnrppdLS0j59+vTt2zcpKQnA6NGjJ0yY0K9fv4byiY2NXbRo0Z// /GfH9lNSUqZP
n/7jjz+2adMGQE1NTZ35WiyWKVOmLFu2rHfv3uvXr7/zzjv37dunHgewz9Fp nnWCjtMnT578
v//7vyFDhmzduhXA1q1b33333Q8//NDPz8/FgtdZKHsxFyu/tLT08ccfV78b Li8v37lz55df
fnn77beXlpZmZ2evX7/+k08+uehGrP/Sys1ZFcY+YcEY10fTr4Ok0yCzUBw+ K45nIyNPFJUC
QKAfokKl+Ah0jpY6RknxkVJ8pPh2p5Jb0Hvl5p0z7glyuphpaWmnT58eNtE7 KsbPoPN26PrX
ZlLndyA9+3BOTmloaKhw9sWrEOLLL788c+aM2v09duyYOjj885///O9//9ve z/Hy8srJyVHL
q9+EvvTSS59//vnRo0cXLVr0xhtvbNy48dy5c88//zyAW2+9NSoqatiwYQ2t tIbeCPbpIUOG
bNmyRf3VbDbv27fParWeOXMmJiZGkqT169ePHDnyirwZx4wZ8+ijj44ePbpO /LXXXuvWrZtW
q7VYLIMHD3788cfXrl1bvx11IjU11cfHp87O8M033yxevHj79u1hYWEpKSmD Bg3q0qVLcnJy
/XxGjx5tz8ExfuONN95///3qPv/cc8899thjo0ePDgsLa2iflxo4OLA1Vbvj jDYkAUXZSG4j
PTlaah+GHTkCAhN6S50i8ZIVv54WOm/IVmH01ny/D6O7W29IvrRLbe35+Pv7 a6QGNKahZXv1
BZLG5Ae5BpZqVFtQVQWrFVVmlJXCUgprOSoOirlDLdf1tDld4IbUKWyz2dSJ wMDATp06TZo0
ydPTMyoqqk2bNmfPnk1PTxdCbNu2TU17x44dAH7++WebzTZy5Mg+tcLCwgCE h4f36dOnd+/e
ffr08fT0dD3fiybGOOOMM854C4kDGNj5ty/c9r6avPfVZNcTDbVfXV29bNmy O+64A4Cfn98N
N9zw6aefqvNNTk527Kao5WfMmPHxxx+rv7Zv377+2Q7vv//+uHHjoqOj1fIG w/k87RW/++47
f3//3r17AxgxYkRlZaXaaweQlJRUZ44XXQ8A0tLSHn300eTk5FOnTqkRWZYT EhK+/fbbxqxY
IYTTYk6D06ZNe+KJJ9QPcXv/RKPRVFdXP/XUU2+++Wb9TouL5O0vzbina5jP ubuHawZ1lEoq
8M025fUVypINYleKyC1AjRU1VuQWYFeKWLJBvL5C+WabUlKBQR2lu4drwnzO /f3uLg21n56e
DsDoU9I/cXpS+weS2j+Y1P4B9adX7P2rVn+7evW3q1Z/aw8mtX9ArvQDEBMT k5aW5jT5L774
YurUqeq02vsHcObMmdjY2DpjBsd+Z01NjcFgMJlMFoslPz//lVdeef3119Xy DzzwwLJlyxq5
0pwaMmTIkSNH8vPzAezatatXr14+Pj5qH8xqtW7evHnEiBEAcnNzb7311sjI yD59+qjf1apy
cnImTJjQunXr6667bv/+/Q2tTADDhg2Ljo6uM5YD0LNnT61WC8BoNHbs2NFq tdoX4Z577lm4
cKFjUz4+Pr617MHXX3/95ptvVnetjh07Dh48+K233lLbr9NC/RxU8fHxfn5+ 6nx79OghhHC8
/LXOPq9OOO11/3pK6+knQUJ1OW7sivZheHSj8tR34h8rxENfKwkRGNsL1grY rMJWA9kGITTb
jtY01Id33bdXpxs80V9cDIANqTrfQCg2VFlQYUZFFcorUVGB6nJYKyBXQy5F O5ty2yjbRQcV
9jalC8edanzixIkAZs6c+dBDDxUUFNjjAwcOBPDTTz9JkrRt27axY8eidgCw ZcuW4ODgTp06
1d8G9dt3Ot/GJMY444wzzngLiV+2+u1nZWXV1NRER0er8TZt2pw+fdpxvuqE vfyoUaPUvoXT
fIQQJ06cCAgImDx5crt27W699dbc3Fw1PnLkyB49ekiSpJ47bq8SHR1tn6Pr 9eAYVKfbtWs3
ePDgqVOndurU6dSpUxkZGWqxYcOGlZSUOJ7y4bRB+791lrehZD755BN/f/8J EyaocW9v7z59
+syYMSM5Ofmll1568sknAwMDG5qXPd7QS3On+AR64WiG+M9GeeUvorQcSYnS 3aOk5+/WfPCY
9oPHtM/frbl7lJSUKJWWY+Uv4j8b5aMZItALz9zp62Ix1a/hZX1OVtEvWUW/ ZBVtq/1325w3
xlSby9WfJ14e+sTLQ9VXSwslAH5+fgsWLFi/fn2dloUQu3fvjomJUeOZmZlv vvnmxIkTR4wY
MXnyZHsmVVVVt99++6uvvqqe4iJJ0i233DJv3rx33nnnpptumjZt2ssvv+zj 46OWb9Omza+/
/trQmqkz9zr7gDo9cOBASZLUEzF+/vnnfv369erVa+fOnQB27typ1Wp79eol y/LYsWM9PT3X
rl07ePDgSZMmVVVVAVAU5eabby4oKPjvf/87Z86cjz76yMU+4/RN4Vi+pKRk 8+bNw4cPt8c7
dOhgv/xAjbzwwguffPJJaWmp47IcO3asY8eO9nY6dux47Ngx9dUOHTq0bt3a xZuufp7Lly9P
SEiIiIhoaJ9Hww5mSHpvKDIADGwvbc8SO/eishhVJfj5AH49LQZ3kmw2xWaB bIVig5C0+9Mq
XTRYh6hHZ1+nl0oIUVAu6UNQY4HZjBorhAwhQ6mBsAlhhbBBrhDtAqv0OlHv GmNX+dVfR088
8URlZeU777yzZMmStWvXvvfee+r5/QMHDlyyZMmPP/544403Hj58eN68eT/8 8MPOnTsVRdm8
efOQIUPsWwgOO3T9K56dztdxzTSUGOOMM8444y0z3kj2TxzHdkpKSgB4enqq QQ8Pj9LSUseS
akVZltXy6jepwqE3prJXycvLW7Jkyccff/zGG2888sgjb7755ssvvwxg5MiR AGRZLi4uNplM
9vKenp4lJSX29tW4Y8tOuztq0Gw2q7mlp6erPV21gLe39/3333/vvffW+ZCt 0+AlreRjx44t
XLhwyZIlp06dMpvNGRkZ4eHh06dPB7B06VJFUVasWPHVV1/16NFDPZziYmM1 9JK3vnzZXs9D
aVJiW4zoqukdf0GBmFApJlQa0Q2/HhcbDiqH0qDXyH8ZWqkorhZB3b42Tf7J gpUCkgSxc1OR
VgcIFJZk2atMuutPgHSqYIUASgoMAHQ6HYDly5erW9zeckpKiiRJPj4+6rqt rKw8ffp0Wlqa
p6dnbm6u2tP19PT84Ycf9u7d+80333z99ddbt2718PD461//mpKS4u/vv3Ll yp49e546dWrH
jh133XWXt7d369at09LSCgsLAwMDnW7x+hP2Yuq0r69vt27dNm/efPPNN2/b tu3hhx/W6XRr
1qxRFGXdunVDhw6VJGn16tWpqanLly+PiIh4+umn33///XXr1o0bN279+vUp KSkbN27s1auX
JEkLFy4cOXKkoiiOO7nT/cS+0zoG77///oSEhOnTp9v3PfVcKbVBb2/v6dOn Hzhw4JNPPnnm
mWe++uqrpKQkIURRUZHVavXz87PX8vPzy8nJUX+1X2xQf9mdvqmXLFmybt26 tWvX1n8TOU43
9JfkbIEUHAxFBhQAsFqgCOj1sFpgNQtrjSQEZAskKxQbFAUaje5UVlX9Dq1r wqFnqzObzQ0V
klxeBCxJkrB6QRE1ZlgtUGqgdvoVK4QVihVCgVwlSqotsqytcz5iQ7NzzM++ otWJ2bNn9+jR
Y+bMmXl5eZMnT/7222+Tk5OTk5MB/Pjjj+pBgG7dunXt2nXXrl179uxJSUm5 7777qqur7e2o
B2VkWa6urq7ffkPzvWgBxhlnnHHGW0j8MpjN5vrtqCch5OXl+fv7AygqKgoK CrJ/YFksFrWi
63zUGwGp076+voMHD1a7NXffffeMGTPmzJkjSZK9vL+/f0lJib18SUmJv7+/ xWJR21fnqH44
1lkPdWZqn5Zl2d77V7O13w3G8ZO3oRWrBusUq7+whw4dCg8PnzFjBoCTJ08+ 88wzb7/9dmxs
bFpa2qpVq/72t78tXbr0xRdfHD9+/Pjx413My/X2ndLP7OMZNLqnJjJIOn1O 7D0pjpwVWQUA
EBmMTtFSz1ipd7wUGaT53k8Z163IYmnUfqI3KnnV529DcjD1/LrS6n7bN/Kr fwGEBAmApLnO
viEct77ack1NjaIo9hXbunVr9dLb22+/fd68eQsXLlTjXbt27dat25gxY3r2 7Lly5cqbbrpJ
kqR27dodPHhw48aNN9xww4EDB7p37z5z5swFCxaom9tisTS0pzluF6f7gBCi f//+3333XXl5
+a5du7p27Wq1WhcsWHDu3LkffvjhwQcfNJvNBw4c0Ov19msv9Xq9Opbbt2+f TqeLi4tTd0K1
l2ixWOzLWD8lIYTNZrPvtGpcluVHH300MzNzxYoVjqvIMU8PD48nn3xSkqSa mprBgwfff//9
6qki6ulDFRUV9jdpRUWFt7e3i16imkP9N/WqVatmzpz5ySeftGvXzt6vdrEf 1qcIkyIDEoSM
n46JCclSfIBIyYGlSvRsLQ3qIH21VVFkyFYoCoQCKIBS4/iedc2+Z9ondOpw 00XRhkiS5KUR
lWZYLLBVnf/iX7GcHwYIGRDQ6LEvVTlXqA8P8bCfx3/Zxo0b169fv1tuuSUl JWXFihV9+/aN
iYmJiorKyMj4+uuvO3fu7Ovrm5SUtGvXrjfffBPA0KFDHZdOXe+SJDW0yERE RFeW2smoIyIi
wtfX9+zZs+r9Ok+dOhUfH2//bFKraLVap3UdW7YXiImJKS0tVX+NjIwsKSnR arWOt/Pu0KHD
xx9/rBZQbwaakJBgr65O6HQ613NU6fX6wsJCrVbr4+Oj3kpbbaGqqmrXrl3d unW7gh+y48aN
U++KAyA5OXnRokUxMTFms3nu3Lnvvvtubm6uRqNR18PvnOn4niXVCNx4UFm7 R+QW/BY/kYET
GWLHMXF9LykhUhrfswS4+Cry8/MrLCz09gyulnMlABC3PtRKPRTw1b/O2ccA qz/LATDhgVYA
gsO1Jw6ev+Jx3LhxdTZEYmKiEKKystJ+gbVq3Lhxr7/+ep1lj4iIiI2Nzc3N VeOVlZWzZ8/+
6KOPnnnmmYcffrhLly6vvvqqVqvNyclp165dQ3ebbaQhQ4a89957a9eujYyM DAkJSU5OFkJ8
//33KSkpw4cP12q1siwbjcZJkyapfbDJkyd37txZq9VWV1d7e3vbb4Br3+dd b0d1cztGnn76
6YMHD65Zs0YdS7tmMpkefPDBWbNm5efnh4WFeXl5BQYGqm8WtUBRUVF4ePil 5rB169a//e1v
ixcvHjx48EVzaGgMEB2olFRotCboDFi1B50i8cUDmm3HhQRpQIIkBHq1l7x0 KCsQWj8JEhTZ
3CZYNGa3r9Ofv/gA4KKHFSRJ6hQmfiyBTUAxQ7GI8wcBrOd7/wAkg2QO8Hnm n8XvzfXV688f
T3A9tGjo6xY1Hh4e/qc//SklJeXMmTPqBhg0aNAXX3yxYsWK+++/X6vVJicn /+tf/1q1alVM
TExsbKxjO2oLGo1GXWSn7btIz3VijDPOOOOM/+HjPx+u+cft54P2ewG5mMCF AwB7O1qtduLE
iV9++WVSUlJhYeH69etXrFih050/Kbd+ZygzM9NkMqknu6vtSJLk2BG57bbb pk2bVlxcHBIS
sm7duoEDB6pd86ysLJPJFBQUNGrUqOnTp+/cubN///6rVq1q1apV3759HfOB w4jC6XqQak8K
OHnypCRJu3fvHjVqVHx8vHpBqlar3bdvX3p6+rBhw+wL4nTFOnaA6rTveuXb M5w7d+706dPD
wsLCwsKWLl06e/bsSZMm2VeFi09z17PwQdnmg97nCtG3k5QcJ8VHSgCOZ4ld aWJnith8UPSK
LlN7/xdNNTw8/NSpU0YpTPZwuP08hBD406SAH5YWq5E7pofW3g9IhETLAKqq qqZPnx4XF1en
ZZ1Ol5SUlJWVFRgYKMuyzWYzGo1CiA0bNsTFxdVZ4SdPnjx27Fj37t3V+NNP Pz19+vTIyMh2
7doVFhZWVVVFRkZqtdrMzMzk5GQXW7w+6cJHAQAYOHCgTqdbsGBB7969tVpt aGho27ZtX3/9
9Y4dO6r3JE1MTKyoqGjTpk3//v0dZzFo0KA33ngjKytLvW+V+k2245i2oZ3Q /qYQQnz22WdL
lizZuXOn+ggL1xvFsQtqf3MNGTJk165d9pn++uuvo0ePdtFLVN96jm/q7Ozs e+6557nnnlPv
p+R0vo7TDT1lq0uUWH9CeOglDz9sPypeMGNcEgZ3kgD8d5PSIUpKSpC+fFY7 cY5caYFkgGIt
7x5nbPwAQD184bhcrgYALt6o6rIN7yh//6WkaaVRKiHbe/8KoNTe3laBNsC4 7rTPtOfPffhC
mOsdS1x4yMkxPnHixL59+w4cODAnJ2fp0qUARowYodVqJUkaOHDgF198IYTo 16+fTqfr06eP
WmvIkCF1hmjqSq+z5VzMtzGJMc4444wz3kLiUQafjJryS70HqL0zUaf9efPm TZw48cYbb8zM
zHz88ce7d++uxseMGXP69GkAffv27dmz5+LFiwHMmjUrKSnp8ccfF0IsXLjw o48+ysnJmT17
9iuvvLJp06aQkJBRo0ZNnDixR48eCQkJFRUVy5YtU+erVpw+fbrRaFy8ePH9 998fFxenPgdA
7R1KklR/jnXWg2Py9n/79Onzyy+/jBkzJiIiQq/Xa7XawMDAY8eOzZgxw/FD tv6C11/JDcXr
1D148CAARVEefvjhhIQENf7aa69ddCO6eKlOfObN1T8c8ryl329dtN7xUu94 KSxA+VOXKkDX
yHZiYmJ++eUXS2mAIUIAQkCScL6rHx6ju2dmCAABgfN9JSEBxvAiwOPs2bP2 bkydlidMmPDp
p5++9dZbeXl5PXr06NWrV1ZWVrt27V577TV1he/bt+++++6LjIzMy8t75pln 1P7oN9984+3t
fcMNNwgh7rzzzpdffnnFihWPP/64Tqf79NNP77rrLrUrddGN4nQfkCRJPfNi x44d06ZNU5vq
3bv3smXLHnvsMXUPHD9+/Msvv/zSSy+9+OKLPXv2zM3NtVqtUVFRAwcO9PDw eOGFF+bOnXvk
yJG5c+eitl9efyXbrw1QM1FnVFZWNm/evCFDhlRUVKSmpgohjEaj+qwDABs2 bAgODu7evbsQ
wmw2a7Vag8GQk5OzbNmyTp06qVf3SpL04IMPjh8//ujRo126dFm1alVaWtq9 996rrs8NGzaE
hIR069ZNLameRi5qz+SxdynnzZsnhOjVq1dqaqo669jYWJPJ1NA+39AAoF97 sXQ7Qr0h2+AR
iJ1pyk/7hXq6vyJDJ+M/M7Wj+0hfP6cd94JiBYS5aGAXn8sYAPy2FA1dA9CY CwvKqqTRM+X8
YKOtXFKsEDZAAQSEQ1VJC2GrTjadXf52O+FyAOBCeHi4/XF6PXr0uPHGG2fO nKmuzfT09MTE
RACpqanqHdBiYmLy8vIWL16s3jvI7oknnvjnP/85bdq0V1999fLSICKilmzS S+mX+iTgpU+1
cVHg9OnTISEh9rPnf6fi4uKCgoLY2NiGOhlWq/X06dOxsbGNOdWnMfbu3Xv9 9dfHxsZu374d
gMViMRqNV6RlNzpb5HE4Xew4JgD0TZA6t5GiA533lBqSk5Pz8ccf+0aci4yV jF7Oe1NSbfdf
VVOt2fuDb69evdQT9532l6ZPnz5lypSkpCSLxXLmzJnw8HDHO1oqipKVlSXL ckxMjD2YkpIS
Gxtbf6OsWbPmwIEDs2bNuqTlcuq555575ZVX9u/fr3a+Fy1a9Pjjj69Zs2bo 0KFqgbS0tKlT
p27fvl292vi1115Tr9hetGjRk08+abVaO3fuPGvWrClTpqSkpDgmbxcXF+f4 KN9Zs2bNmTMn
JSVFfXSGYzF1lAhg4MCBAwYMUPt7a9asueOOO+Li4lJTU3v16vXhhx/axwlq GrNnz46KisrO
zv7444/HjBlTv4WGcgDQo0cP9cZBdjt27LA/Za++ht6b1TX4xxLtlmOS3hzw eBsAACAASURB
VEeyms/f61N99K9QYC2GziY+eUr7a6p4+3sBUTC6Y84/H483GV29kYXDV/7q IMpxv5KsVqvT
aoqi1N8F6w8Q//2t9dl1EDCKGkCBEA57tAQJkPRQyrM/ethjdH8/uGQfZTqN nzt3LiMjIzo6
2v7ga9flf3/8ijfIOOOMM874tR6/9flTABozDIgy+AzsbHhsfOurKv/LiDsG 6xfYtWvXTTfd
ZH/+lOsGG+raOo1fwU/zS60y57/a7DwAiAjF85Pli5avHz9x4sR7771n/+6y 8Z5//nn1rj71
W5Zlec+ePerDHH7nytm+fbv6sDnXXSDHr//R8D7QmFmXlpZWVFSot8i0xy0W S1FRkXob/ktd
hMbHbTZbenp6QUFBZGSk+tTkOuUrKytPnjzZsWNHvV7f1L3KhgYAAH5KxXNf S6fyoDHAZoVQ
zt/wR+1aK5bzE0JT1d43/YW/hAztGdRQU46EA8cv952/FQE4PsjABbNF3PFa +Y4ck7DohAxo
hQQZGghoJUWCFpK2/Ib2xe8/Fq3R1B08OA4nnP51cPu02xPgNKc5zWlOc9qN 03ZN1Lj912ZY
kEuq8tTnAPDSnZe5+E23IM0z3Wz7QEubdn3wbeWv4q3v5GNZQqvTqHf7EaK2 3y+gCAhzQfvA
ghm3+k8cFumiHZU6U+HAfsNfoOEBQONlFtjufqP4QIYWMiSlum1wjU6Ds0WS RegBW59Yy6f/
aBfkwxvvEBERERE1aOsR+bNNltW7bAIaIWklSQdAtpoVa7mwFI1NUu4dE35d r5BLbVbt/Tue
CHQFBgAA8kvkZT9WVFvkpPbGwV08tVppz4nKbamVvibc3C/Qz4u9fyIiIiKi i6iuEev2mH86
XLXnWMWprAoh17RtpenV3jSom+/1fUNcn/fvguNBAFypAQAREREREV21HE8H 0m3ZssVpoYve
BtSFhmo5xp2mZS8mLrx9klviV21ijDPOOOOMM95s8TrB39Ngnek6xZpoodyy 3q6qLXh5Kw0X
bhfHYldVqld/3PFfFxcBNwVRS+3V268BEEJIUX3vgFAsFYU1ZfkTxw2/49ab 4+Pa6nS6gICA
5kyRiIiIiIiuoOLiYkVRMrKyV6z6fvE3q72DwgNCozV6nRTdb4qlLC+utf+c fzzcv3cvSZLU
qwTcnTAREREREf0uGo1Go9EIIQ6npL74xrsnckoDIuOk8G43tAvzWvDcPzp2 iFcc2A9hEBER
ERHRNUc978juzNmzT72w4EyhRQpqP+CjN+cO6pfErj8RERER0R+M4zDg4JGj 9/5tjm7yzaP6
9Ooqy3JDZ/4cOnRo/fr127dvT01NBdChQ4d+/fqNHDmyS5cujZnlwYMHN23Y sG/b9jNHUwG0
SUzo2b//sBEjXDwnuU71DRs21Jn7iEZXJyIiIiJqyYQQsiyrl/8mxsfdOX60 tHL1ugF9etij
dSosWbLk66++CvXz79mje0REhABysrP37tufV1oy8dZbp0yZ4np+X3z++YZl yyL8Ajr36hkS
GSEB+VnZR/bvzygqHHn77Xfceafr6p9//vmXX34ZGBjYvXv3iMgISUJWZvaB AwcKCwtvu+22
Oy9WnYiIiIiIAEiSJEmSVqs9dOSoLiYq3GazCYdHA9h9vmTJB2+/Par/gFGj RsV37x4QFChp
NCWFhV3bx29Yt27RW28pQky5446GZvPfzz9f+96/hib3HTBmZOse3X38AwGU Fxd16xD/85r1
a/+5CEJMangI8fnnn7//3vu9B/YeOXpkt87dAwODJSiFxcXtu8Rv/H7De+/8 Swhx0REIERER
EREBUK8GbhUSpH3kkf8zGAyod5v/Q4cOffT2O138Awa1T4gNDfEVEIWFtrx8 TUmpoazMUFEl
V1bsOngwvnPn0NDQ+jM4dOjQNwveSgr379e7fXT7MD9fSWsr1tQUGESFQa7w tlVoS8v27dgX
0bXB6gsXLgyMDWzfv314fJiHr6hWistthVUoLdNVlqK8orJs3/Z9nRuYOxER ERER1aEoitls
1vn6+tY5+Ud9VMHOHTv88wu7hEd6HjxQce5sjb+vBhIgZCFsJeWeecWdhKYk v3Dnjh2dOnWq
3/r+HTuCKwt6dI8K1B7SnjtuqTBA0gAQiixVWgN0lk6tUZZdsn/nzs6dO9ev vmPHjjJdiW+C
R77HgeMlx7KrPDQanSTBJtsqLNWFHjXaBFFeWLKzgepERER0rXN6V5I6D6ty XZgaz+mKbWit
NrQV6Gpmf2CZr6+vzumFv0KI/Vu2Jpq8WhXneWgErGVKmTf0RgmAzSJKKjyL y0MVKcHkeXjz
VuXee+u3cHLL1o5tPcNCin11Jbpq6OCl1RqEBsJWo7VUKnqEh/knxHru3LzZ afUft2/17GjS
hRTKxooSs2SDr0anF0IIxVZlq5RNNl2Yt6mDaeu2Lfc6q05ERER/SOzoN5FL WrHcCtco+4bT
NbQJqw+nRAe3CtZK3v7epsAADz8/ndEgAUqN1az3MGiFrqS6QtYcOZLitAX9 6ZQOo0NDWxX5
+tmMXkFazwCNwShJkpAtcmWhSV9s0JWXVgTuXZvqtPqJgiPtercKDa0O8JV8 PAN8vIL0Oq0E
yapYDdU6ja7IoKm2lfunHT7CXZCIiIiIqPGcHwEAEKSIQJ3wbxXq6+/jGRho 8vbTm4ySJNms
NRav0ioPvdFUVpRT7C87v3loYJASHAK/YJOvf4DOJwwevoreqNEAihnVJo8S g8ZQFVQuggJk
5wl4KyGBCA/29vX19PMK9vbyM+gMgGSVrRVmT6OH3kNfXRUs0v0aqE5ERERE RM40OAAI6dJJ
X5HvGezvHxTo6xug9/XTmowAFHONVafV67Q2jUZfXBTapZPTFkzxHfWGPA+/ QF2gr+TjD88A
rd4ISYJsQYVeI0kGTYXRUOoZ77x6x7adPIy5/j4hgUF+vqZAby8fD4MRkGpk i7FSp9NJGpR5
GPM6tOvMAQARERERUeM1OABoPaBfxf++9vDy9fYPNPn4wNdH8jRBkqRqs1YD RZIqzdbqamvk
n/o5bcGv84BKy2fCGCG8AyVfH8nLWzJ5QisJsxlaRYGkWER5dZZv5/FOq/eO H5BStdika+Pj
6e/r6+Pt5WPyMElCsig1Gj2EkCyVirnyTO/YARwAEBERERE1XoMDgJ7Dhv2y ZXNilTnC5CP8
/TXeXjB6QKuRDHpF0uhlUWnJOOsX2HfYMOdf4fe97tDy76OrbQYPL4NfgOTj BYMRWkky6IRO
UqyiuDr3YFFI4vihTqsP7n3doR/WVJqtJp2Pv2+At4enAUYNpBpYtH6aGrMw V2cpeSGDRjqv
TkRERERETmkffvhhp9fRBgUHFxpNp9avDQ9vZQwNlXx8ND5eMBhlSJYaa2Fu zoadu/3/fG+P
Pr1lWXZWPSSz0vtkyoagMD+PoFDJ5CUZfIQw2gBLjS0/J3fj1uPa9n/tntTX afWQ4BBR6r37
2KbQKL9A3xBPrY+35KkTBptNspgt54pydq47NiRyau9ezqsTEREREbVAde7v 7/RV6dChQw2V
8PX1/eHbbwu2bmjvbWrTISGkVZhWr83PPnf2+PET5eV+A4dfP25cWVmZq+pr /lecsTK+I9om
tA8ND5eElF9wLuP0idQDwids3J/G3OS6+nff/29f7v9ad9YntosNC26l0+hy 8wuOZRzPSLF0
9B87drSr6kREREREVJ904MABFy/7+fnlZGfv3rql/OhhS0mBBHgFtfJo3yF5 2PCwsLDS0lLX
rfv5+eVkZ+3etbmyYpdsy4YEk2ekwZCU1HtEI6tnZ2dt27Mlq3x3pTVH0ki+ pogwj54Dkho1
dyIiIiIiqkPat29fnZD9OWEqk8nk5eWl1+ttNpu9QGVlZXV1dWNm4N7qRERE 9EfC5/80Jz7x
94/EsYcv7d69+6IVJEnSarVarRaALMuyLF/S28+91YmIiIiIyK7BuwDV8Tuv tXVvdSIiIiIi
Uul+/PFHd+dARERERERERERERERERERERERERERERERERERERERERERERERE RERERERERERE
RERERERERERERERERERERERERERERERERERERERERERERERERERERERERERE RERERERERERE
REREREREREREREREl8sXuBP4H1AC/A+4E/B1d0pERERERHSFGWv7/aUO/f76 ESIiIiIiuuZ1
BQRwuoFevjoS+B4QQCs3ZEdERERERFdOIHAKmNyIkvcDp4DAJs+IiIiIiIia hgZYD8xvdPn5
wDpA24QZERERERFRk7nUDv2lDhiIiIiIiOhqcftlndKjnjJ0e5NkRERERERE Tabici/qbQVU
XOFciIiIiIioiQk31SUiImoJNO5OgIiIiIiImg8HAERERERELQgHAERERERE LQgHAERERERE
LQgHAER01am88C5AOoc/VTqXf7ZaAZVNmBcRERERETWB24EzQA0wFQCwGXi2 9iXH6Tou9TkA
BmAA8DTge/mZEhERERHRlbAGEIAZWAlsbcQA4FKfBGwCCoBdgLjcZw4QERFd o3TuToCIyIkc
AIARuAGQgUMXK/8KIIBZjW7fDEQAccCRy8+RiIjomsRrAIio+SwHptROvwus qJ0eBHwFAJgG
/AjkA7fUvqQDjMBU4MELm/IDNgO3AQAmA7cBRUAWkAN8AgTUFlsMTANmA+nA NqB3bVwANVd8
8YiIiK4FHAAQUfM5DkwEABiA24GxtT31ycABAEAW8AjQGjBeWFEHvA2srP2b ZQCWA2mAATgN
fAFkAcHAUGAYEAUsqa0YBTwFhAJjgBxgZjMsJBERERERqYYAZYAe+BOwBtgP 3AJogBygw4Ul
bYCo9yMDVuAt4GcgFygF/gfcCXQABDC2tu5NgACiAQCbgS9q4/cBZy+cS0de A0BERC0PrwEg
oubzC6AAA4GbgJVAHDASyAMKgVQAwE3AU4C2gaOTGkADPApIwHPA60AZAOA6 AMDu2mLqRExt
d/94bdwCSE2xVERERNcUfhoSUbP6Cvg1PO7Lv76R7uUPRW6+GWu0/mUFX/1n 1sjMY/ZYR+AI
EAaca748iIiI3IwDACJqVje1Tvj2sQ+EUBCdCJ0BUrP8FRICthrknZUs1eKN +5CTpoY5ACAi
ohaIAwAialbaed/KIVFoFeOe2Z/cj4piPDfBE8gGtIA3UAaYeSUAERG1GLwG gIialezlj4Bw
t80+OhGZxwFUAf5uS4KIiMideBtQImpeigy9wW1z1xma9cIDIiKiqw+PABBR s2MXnIiIyH04
ACCiZifb6kbST8FcBUgwGhEUAh+/83EhkHEGhXmoroKPL3z8EBEFgxHmauRm IS8XfgFo0w4e
pt+aqijHyWOw1iAmDsGhzbRERERE1w4OAIio2dUfABzYBUWGfyAK81BWiqHX I7otzNXYug7l
pYhNgH8gykuRlgq9HmGR2L4FsozIaJzLwo4tmDAFnt4AUFGGtSvRLgEmT2xY hQHDEBHV/MtH
RER0NeMAgIianZNTgATCW6NnHwDYsBrHDqN1NPbuQGU5xtwCD4/zpdQCiowB 152/f2hcAooK
cOwIuiUBwME9CItE9yQA0Gmx6xeMvbU5loiIiOjawYuAiajZyba6P0JAKOen vX1RWozqSqSl
IrEr9Don5RX5t2mDAdVV56fPpCGi9fnpsAiptBgFeXXrEhERtWw8AkBEzc5J L7x2AFBehjMn
ER2DkiIJEAGBF+myFxeiIA8du0K2wWKWbDZhNJ6votcLSUJ5CXx9m2g5iIiI rkUcABBRs6t/
CpAAMtKRlYHyMkRGoUsP5J8DAJ3O1S2DKsrx82b07I2gYCgyLGYA0Ei/VdFq UWPhTYeIiIgc
cQBARM3O6REA/wC0aw9v7/O39DF5AEB5KYwNPDSgvBw/b0bnbmgdbf/KHwDM ZnjbAEAoks0m
DAae9kNEROSIAwAianb1e+RCwGRCQMBvr3qYhMGA9FPng3WYq/HzZnTohIjI 31qTILy8UVp8
vkppiZAkeHlzAEBEROSIAwAianZO7wIkxAVxCUhIxKED8PJCuzhIEoRAXi68 vOHtg0P7odcj
OBhVlQCg1Zx/unBMW6SfRusoaDQ4dQJhETDoeQoQERGRIw4AiKjZOTkCgPMX ATtqHQUAqSk4
dhQmE2wyfH2R2BGyDQX5ktWKDWvP1w4LR49eABAVjdISbFoPnQ46HZKS+fU/ ERFRHZK7EyCi
Fmb+Zmi0l1bFbIbNBi+v8/f+vyiLBYoMk6fzVxUZT1x3aQkQERH9gfAIABE1 u0s9J8egh0EP
oUA0rrxeB7i8fRAREVELxgeBEVHzEkpLT4CIiMitOAAgouZVmN3SEyAiInIr DgCIqHn95ymI
Rp7K0wSEwKdz3DZ3IiKiq8AlXopHRPQ7VZXh0FbEJ8Hk3diLeq8IoaAwC+9O Q/7Z5pspERER
ERFdcdm52V0Hd3V3FkRERERE1CwyczLz8vL69+/v7kSIiIiIiKjprf5udX5+ fmZWJscARERE
F8WLgInomrdp4yYARoNx6dKlHAMQEREREf3BtW3bNi8vLz8/Pz8//+zZsxwD EBERERH9wWVn
Z+fX4hiAiIjIBZ4CRER/BBkZGfZpk8m0dOnSYcOGuTEfIiKiqxYHAET0R7Bn zx51QhHKD+t/
2LVr16JFi9ybEhER0dWJAwAi+iNYvXp1VVXVypUrq5XqHv16rFu3rmtXPhmA iIiIiOgPSqvV
nj59+v3337/977en5KV4hXq5OyMiIiIiImoW7+5/9x/f/cPdWRARERERUbNo 3af18fzjwR2C
3Z0IERHR1Ujr7gSIiK6wsqyy0LGhA28euPE/G92dCxERERERNb2A2IAT+Sei B0S7OxEiIiIi
ImoWf//274sO8k6gREREREQtg2ew5+G8w51v6ezuRIiIiIiIqFnc+/G9y9KW uTsLIiIiurb4
AncC/wNKgP8BdwK+7k6JiBpHa9TuOrdrwCMD3J0IERERXf2Mtf3+Uod+f/0I EV3dxs8fvy5z
nbuzICIioqtcV0AApxvo5asjge8BAbRyQ3ZEdAkkbMzaeOMLN7o7DyIiIrpq BQKngMmNKHk/
cAoIbPKMiOj3GDJ9yPbc7VojH3tCRERE9WmA9cD8RpefD6zj49SIrnbfnPrm rg/vcncWRERE
dBW61A79pQ4YiMgdut3e7VDeIQ9/D3cnQkRERFeV2y/rlB71lKHbmyQjIrpS Pjz84WMrHnN3
FkRERHRVqbjci3pbARVXOBciurLaDm17LP+Yf1t/dydCREREVw/hprpE1Czm 75g/b8s8d2dB
REREVw8OAIj+0EI6hqTlp4X3DHd3IkRERHSV4ACA6I9u1g+zFu5Z6O4siIiI 6CrBAQDRH513
hPfRvKPxo+PdnQgREZHbSO5O4Goifsf6+D11iagZ/fW/fx3Qc8CfE/7s7kSI yM3i4uJee+01
f39/WZbtQa1WW1BQMHv27GPHjrkxNyJqLnXuAqQDNM6m6+NdgIiuHQYfw75z +5L/kuzuRIjI
nRISEjZt2rRhw4bMzMy8vLz8/Pz8/Py8vLzMzMzt27dv2rQpLi7O3TkSNRU+ w9bBSWAZMB/I
A/YAG4EYYAuAC6frCAR+BR4FjjRiFiHA9cB9QDSQDlRfqdSJqLHkGrk4qvix vz72xVtfuDsX
InKbf//736GhoQkJCTqdTpLOH8SXJEmn0wUGBubm5g4YMOCrr75yb5JETcTF 19otzzIgBdAD
C4GVjVs3GmAZ8DWwrHGzWAjcCRwHBgDZQOTvypeILs9Xj3/lZ/Ab9fQodydC RG7j7+8fFhbW
0KsdOnQIDg5uznyImhMHABfKAQAYgRuAPsBF3/uvAAKY1ej27wQmAB8A9wIp wAOXnykRXTYh
i+f/+fycR+ZIWl67Q9RCybJsMBgaetVgMDheGED0B9MyBgDLgSm10+8CK2qn BwHqwb1pwI9A
PnBL7Us6wAhMBR68sCk/YDNwGwBgMnAbUARkATnAJ0BAbbHFwDRgNpAObAN6 18YVh6aKgJAr
tYREdGnWvbiupKbktrduc3ciROQ2sizbGsDeP/2xtYwBwHFgIgDAANwOjK3t qU8GDgAAsoBH
gNaA8cKKOuBth9OBDMByIA0wAKeBL4AsIBgYCgwDooAltRWjgKeAUGAMkAPM rJdSD6AfsLQp
lpaIGmXeM/Nm3TbL4NPgV4BE9MfWUO9f5e7siJpQyxgAfA8MB/TAdcCvwGFg GKABxgNfAwCW
AwcBC6CvV9cIjAX6A/7AJqATcBtwKzAHSAT6AwuBVOAo8DYwGoiurbi59srg NUDShW22A1YC
U4Gfmna5iciF3Z/sPlh88L4P73N3IkTkHrJL7s6OqAnp3J1As/gFUICBwE3A SiAOGAnkAYVA
KgDgJuApQNvAgEgDaIBHAQl4DngdKAMAXAcA2F1bTJ2IAc4CAI7Xxi0XPiIg HtgIPAnwBiRE
7vb8355f9dmqzyI+q8jmrXyJWhx+zU8tVou5AO4rIDMOAW+g0B/NOazXaKEt wPWzkHgMAMKB
X4HZwKfNlwIRufDWnrfyCvNeGvWSuxMhoma1YcOG1q1buyiQmZk5YsSIZsuH qDm1jCMAALYm
oO0HyFMQHQ+dAVKzjHyEgK0GeR5Y8wHC70NOGhYCRcA6IBwAUA2UNEciRNSQ Vx94desPWz/q
8tG5Q+fcnQsRNSue50MtVsu4BgBA2Gsw+SK2O/TGZur9A5Ak6I2IbA9ZwQPz AeA6oCuQXfvz
YTMlQkQNydmb88XhL2Z8OMPdiRBRc+NFwNRitZgBgIc/AsLdNvfoRPgGA0AI IDn83Oq2jIjI
7s173hwXO67dde3cnQgRNSteBEwtVosZACgy9O672Z/OAIV/SoiuUqXppe/+ 9O5T/3zK3YkQ
UbPiEQBqsVrMNQAAu+BE1JAP/vLBruO7uk3uduC/B9ydCxE1E/byqcVqSQMA ud77PP0UzFWA
BKMRQSHw8TsfFwIZZ1CYh+oq+PjCxw8RUTAYAUCWUXAOuVlI7AbHR4hXlOPk MVhrEBOH4NBm
WR4iumLMJeb5K+c/89IzE/47wd25EFEz4Xk+1GK1mFOAAMi2uj8HduHoQeRk YM82fL0Yp09A
tqGyHN8vx/bNkG3wD0RVJfbtRH4uZBssZiz7CDt/lPbuQI35t3ZKi/DdV6ix wMOEDauQcdrJ
vIjo6rbk/5ZEmCKGTB/i7kSIqJnwFCBqsVrSEQAnpwAJhLdGzz4AsGE1jh1G 62js3YHKcoy5
BR4e50upBRQZEjDhTpSXYfVXUOTfGjy4B2GR6J4EADotdv2Csby8l+gao1iV F/79wtwZc4e/
NRzC3dkQUdPjEQBqsVr2EQAhIJTz096+KC1GdSXSUpHYFXqdk/KKDAgoNgCQ 5d/iZ9IQ0fr8
dFiEVFqMgjweASC65qyevVoW8vhXx7s7ESJqcoqi/M4CRNeulj0AQO0AoKQI Z04iLAIlRRKA
gEAnhX/7kQFAqf21qkKy2WA0nv9VrxeShPISDgCIrkXPvvjs03c/rTO1pKOj RC1STk7O7yxA
dO1qSQMA9aQdxx8BZKTj+5X4fiVahaFLD1RXAYBO56Twb7WUC1qzmAFAI/0W 0WpRY6lbi4iu
Bdv+tS2tPO2uf93l7kSIqGnNnj1bCFdn+z333HPNlgxRM2tJAwCnRwD8A9A9 CaPHoXd/aCSY
PACgvNTlEYALTwHS6wHAXHtNsK1GstlgMPAIANE16vl/PP/3MX/3DPZ0dyJE 1IQyMjKsDzxg
ysrChaf6KIqSlZWVn58/YQLvCUZ/WC3pMHf9XrgQMJkQEPDbqx4mYTAg/dT5 oFPq1/n2br0E
4eWN0uLzVUpLhCTBy5udfqJr1JEVR3589seHP354wdgF7s6FiJrKEOD6M2ek u+8+AzwJfHnh
q61atdq6det3332XkpLilvSImlRLOgJQ/2QeCAhxQUQCEhJx9gxOpJ6/6le2 IScTZSV1z+cR
Dr/GtEX6adisUGScOoGwCBj0PAWI6Nr10l9ferDvg0HxQe5OhIiahBb4CpAA AKVAVL0C586d
e/bZZ9955x2tVtvcyRE1vRazW4+8B5IGQrngJ+MsTCYEBl0Q9PWDyYTjqTie isyzSDuB6moE
B0Ong82K9Wtx9owkBM6ewak0xLQ9X6W0BEcO42w6bDZ07w5JqjsvRcb6T929 FoioUcoyy8Jv
Cu87ru+mjze5OxciuvLeAIbXTqcDZcAP9cocPnz4hhtuiIiI2LFjR7MmR9T0 JHcn0Fzmb4bm
Ekc7ZjNsNnh5QWrcWrJYoMgwNXDesCLjiesuLQEicp+g+KDtv2wf2qpwSQAA IABJREFUPm54
xvYMd+dCRFdSG+Ckwzeg+4E0wOnje8LDw7ds2TJ27Njjx483X35ETa9lnwLk +segh6fp/Jf3
jfnR62A0NvgqEV1TCo8Xfrjzw1mLZrk7ESK6wr678PwHP2enAKlycnJefPHF d955R6NpSf0l
agFazA4t3P04D7cnQESX6L2/vDckfEjHmzu6OxEiupKigSJgH1AMZAB6oE3D hRcvXlxZWfnQ
Qw81X35ETa/FDAAKs1t6AkR0iSrzKt/4/o05r81xdyJEdCUFAEOAVwEDcAio AAJdln/sscem
TZsWGxvbTPkRNb0WMwD4z1Nw+byPpiUEPmUfguja8+lfP433je/3137uToSI rhgZOAzsAMqA
G4BEwOiyfEZGxvz5899++22pkdcEEl31WsxdgKrKcGgr4pNg8m7sRb1XhFBQ mIV3pyH/bPPN
lIiuEMWmFIQX/P2hv3/+5ufuzoWIrqRRQBCwtHGF9+3bN2nSJB8fnz179jRt WkR0Ncs5l9Mh
uYO7syCipidhc/bmMfPGuDsPIrqSFgCXdI1/TEzMsWPHYmJimigfIroG5OXl 5ebl9u/f392J
0P+zd99hTZ1/H8e/SQgrJCAgQQVRcaB1TxT3qnuP1ipYLfykztai1j2KdaF1 VQsqDhS3uBcy
VByIIrIShjJURqxWcCvk+SOVxzoZybkT8nldvXrFcMY71lNznwmgcZ1+6XQ5 +zJfqDfnTALo
gfPvPAqgmMaNGxcUFKSRGgDQCam3UxUKRebdTIwBAPTBoTuHRm4cyboCANRD QPSESFLCuXg8
3okTJ77//nuNNAGA9ouKilIoFAqFIiMjA2MAgHKv8YjGt3JvGVsYsw4BADVo RJRQqhkdHR1l
Mpm9/aeeHAAA5dqJEycUb2EMAKAPNsdvnnhgIusKAFADd6KtpZ13woQJBw4c UGMMAOgMPz8/
xTswBgAo92p0qiFXyM0dzFmHAEBZbSIq9ZO9+Hz+mTNnRo0apc4gANAJM2fO VPxXRkZGx44d
WXcBgAb5RPrMPTeXdQUAlNUtomZlmL127dpyubxSpUpqCwIAnTBo0KCir/63 s277+/sfO3Ys
OTmZdRcAaJC0gTRZkWzbxJZ1CACUnojoKZGwbAv56aefdu8u5lMEAKC8qFWr VlZWlr+/f9CR
oJzcnMPnDg8ZMsTQ0JB1FwBo1qyzs1ZFrWJdAQCl14HoUpkXIhAIQkJChg8f roYgANAh6enp
AQEBQ4YM8Qzw3Jm0k3UOAHBBXEUsU8hqdq/JOgQASsmL6A91LKdevXoymUwq lapjYQCga4Qi
4c2cm01HNWUdAgBc8NzjuU22jXUFAJTSfqJv1bSoadOm7dixQ00LAwBdM3Lj yP2397OuAAAu
GIoNY3JjmrmV5RpCAGAmg8hRTYsyMDA4f/78oEGD1LQ8ANApAiPBtZxrrce1 Zh0CAFz4dv23
h9MOs64AgBKTEj1U6wIbNmyYmJhobW2t1qUCgI4YtnoYvhAA6AmegBeRFdF1 RlfWIQBQMv2J
Tqh7mbNmzdqyZYu6lwoAuoAn4F3Ovtx+SnvWIQDAha/nfh1+P5wn4LEOAYAS 8Caar+5lGhoa
RkRE9OvXT90LBgBdMGDpgFOZp1hXAABHjmccH/rHUNYVAFACZ4l6aWCxTZo0 SUhIqFChggaW
DQBajkcXsi7grAAAPdFybMvonGihqIwPFAIAjvCIHhNZaWbh8+fP/+uvvzSz bADQbr0W9Dp3
7xzrCgDgSIA84H+7/se6AgCKxYkoVWMLNzIyunr1ao8ePTS2BgDQYufuneu1 QBMHGAFA69Tp
XScxN1FkK2IdAgBf5ka0S5PLb9myZWxsrLm5uSZXAgBaqdvMbufvnydcGQig H9bcWDPj1AzW
FQDwZeuJpmh4Fd7e3uvWrdPwSgBAK53KPDVg6QDWFQDAhcrNKycrkivWq8g6 BAC+4BpRGw2v
wsTEJCoqqmtXXA0IoH/aT2l/Ofsy7g8IoCcWhC1Yenkp6woA+BwjomdExppf UZs2bW7duiUW
izW/KgDQMkfSj+D+gAB6wqK6RZIiqVr7aqxDAOCTnImuc7WuZcuWrVq1iqu1 AYDWcPZwjsqJ
EhgJWIcAABemBE3xjfNlXQEAnzSJaANX6xKJRNHR0R06dOBqhQCgNfbf3j9y 40jWFQDABRNL
k9jc2IbDGrIOAYCP20k0msPVtW/f/ubNmyIRbhEGoGeajmp6M+cmHhIEoCfc NrvtS93HugIA
Pi6ZqB63a1y1atWyZcu4XScAaIGdSTvHbB3DugIAuCAwElzNvtpucjvWIQDw Pkuix0R8bldq
ZmZ269atNm00fechANAyDYY0iM2NNTI3Yh0CAFzo93u/4LvBeAwIgLbpQXSO xXq7dOkSFRVl
amrKYuUAwM7WxK3jAsexrgAAjgTfDe6/pD/rCgD4j7lEvzNa9bp167y9vRmt HAAYcerjFJ8b
b2qN0T+AXmg7sW1kdiTuAAagVY4TsXo8p7m5eWxsbKtWrRitHwAY8Y3znXhg IusKAODI3tS9
o7eMZl0BAP/vAVEldmv/+uuvIyMjjYxwPjCAPnHs6ihTyES2uBcYgF6oP7h+ XG4cjvsBaInq
RHdZN2zcuHHBggWsKwCAW+ui1/1y9BfWFQDAkY23Nv58+GfWFQBARPQN0QHW DRUqVIiPj2/a
tCnrEADgkENbB7lCbu5gzjoEALjg0NYhSZFUwbEC6xAAoJVE01k3EFG/fv0i IiIMDQ1ZhwAA
h1ZeW/nr6V9ZVwAAR5ZcWrIwfCHrCgCgCKKOrBtUtmzZMmvWLNYVAMChKi2r JCmSLGtasg4B
AC5YO1knK5KrtKzCOgRArxkQPSUyY52hYm1tnZCQ0KhRI9YhAMChpZeXzguZ x7oCADgy7cS0
ddHrWFcA6LUmRHGsG941aNCg8+fPGxgYsA4BAK5IG0mTFckV61VkHQIAXBDZ ihJyE5z6OLEO
AdBf44g2s254z44dO6ZNm8a6AgA4tDB8ofdFPBEQQF94BHgEJAWwrgDQX1uI /se64T1SqVQm
k9WrV491CABwxdrJOkmRVKkpwweSAAB3hCLhjZwbrdzxEFAANuKImrBu+NDw 4cNDQkIEAjwy
HEBvzAmes/zKctYVAMCRIauGnMg4wboCQB+JiZ4Qaefp9rt37/7pp59YVwAA VyyqWyQpkuxb
27MOAQBO8Cj8fniPeT1YdwDonU5EF1k3fEqlSpVkMlmdOnVYhwAAV6admLb6 +mrWFQDAkS7T
u0RkRfCFfNYhAPplBpEP64bPGDVq1JkzZ/h8/J8BQD+Iq4jlCnn1jtVZhwAA R4LSgkb8OYJ1
BYB+OUg0nHXD5x04cGDChAmsKwCAKz8d/mlDzAbWFQDAkabLm8bkxhiZG5Vo LqvaVr0X9V4Q
tmDkxpEVHCtoqA2gvLpLpOV72uzs7ORyuaOjI+sQAOCEyEaUmJtYq0ct1iEA wIkA8s/wH79v
fIlm2nhr49bEra5+rmturLmnuGfbxFZDdQDlT2UiBeuG4vj+++9PnDjB4/FY hwAAJ8bvG78p
fhPrCgDgiGNXR7lCLq4iLv4sPMH/fycIuRfiddxLA10A5dNAomOsG4opKCho 3LhxrCsAgBPG
FsbxufH1BuBRIAC6ZiLReWqhaLHv9r7k28nR0dHW1ta0nWgyWW228lf4J6ck X7pzyWWlC20g
ekjrfdd7hHssP7n8bvbd8/fPe+72LFrSkktL3Da7EZFVbSv/RP9kRfKlrEsu E1w+XOfBOweX
Xl7K3WcE0HG/E81l3VBMDg4OSUlJ1apVYx0CAJxw3+G+Q76DdQUAlNAgooZ0 /ORxj/MetJvs
7e2FQiGFEuXS/qj9Ppt8zCRmo2NGh+eG03SiWhQUFJSYlTjx8MQWvVqkK9Kj c6KJR0RkWdMy
Q5Fh18qOiPbf3u8T6WNW2Wz0ltHh98PfW2GDIQ0yFBnOHs7cf1YAHRVC9DXr huLz8PA4cuQI
6woA4ISh2DAmN6bxiMasQwCgxIKCgvZc2mN3x+7fX4eSww4HhULRs2fP2rVr N7rcKDs3WyqV
qqb0kfvQfCKiheEL7yvut/mxDRF57vbcnbKbiBzaOigUip7ze9buWbvR8EbZ imxpA2nRihza
OkTnRA/9YyjXnxBAZ/GJ8oh06MJ5Ho93/PjxMWPGsA4BAE64bXZTfQMAAJ3R n+gqVYmusjdj
b1Zu1ty5c42NjSmUXPxcFArF8ePHjx07dizt2LFbx1q1akVEQUFBXvFeqgGA xF6SqcjcmriV
iC5lXeq9qDcRuUxwUSgUxzOOH0s/pvqnlXsr1aocuzjG5MYM8hnE6KMC6KSv iJJYN5SUo6Oj
XC63t8dzQgH0gIGJwY2cGy3GtGAdAgDFU4voNVFXIiIaTc7pzomJiWPGjKFQ cljpoFAoOnbs
SEQUSqpv/PTfAQARLb+6PEuR1XVG17jcOIGRgN4eAeg4teN7q5I2kMbkxgxf q+W3MgfQOt8T
BbBuKIXx48cfPHiQdQWUf3j4HHtvnr9ZcWDFr3N+ZR0CAMVjTUREt6l1n9aC roIrZlcyMjJU
z/JMz0s/f/785MmT7ezsiEgkFIlEog8XMLv7bCL6c+qfgTGBBS8LiCj9Yvr5 /POTJ0xWXQ8g
shGJbEVE5L3b+9GbR2G+YdIGUmkDqcRewtmnBNBpLYkiWTeUwoYNG0Qikaur K+sQANA8vpAf
mR2pOicYAHTAQaLndCX3SkpGynXF9YDEANUpQDSfbGxsdu3alZ2dHXk3Mj49 vnXr1vTBEQAi
CpAH5CpyHdo6FL1j85XNruRd2YrsyOzI+Nz41uNaE5FMIVO8Y3P8Zq4/KYBu ukHUinVD6dSq
VUsul1euXJl1CABo3uCVg4+l68oNiwGAyIqITyKRSGQjog/28puamlasWPEz c/OF/EtZlzpP
6/z+jNamFet9bkYA+CJjomdEJXvstjaZMmXKnj17WFcAgObxBLyIrIhOv3Ri HQIAHOk5v2fY
/TDC0z8B1K0N0TXWDWUhEAjOnTv3zTffsA4BAM3r93u/M3fPsK4AAO6czDw5 eOVg1hUA5c1P
ROtYN5RR3bp1ZTKZ6j7CAFCu8Sjsflj32d1ZdwAAR5w9nK/nXBeKhKxDAMqV QKJycBWtl5dX
QIAu3soIAEro67lfh94PxSkBAPpjZ9JO9x3urCsAypXbRHVYN5SdgYFBeHj4 4ME4SAigB4Lv
Bvf5rQ/rCgDgiFMfp4TcBNVNPwGg7KyJ/qFysietYcOGCQkJn7+jAACUB52n db6YdZEnKB//
7wKAL1t/c73XcS/WFQDlRC+is6wb1GjmzJn+/v6sKwBA845nHB/kM4h1BQBw xK6VXZIiydrJ
mnUIQHmwgOg31g1qJBQKIyIi+vfvzzoEADSs7cS2V7Kv8IV4TjOAvlh0ftHv Eb+zrgAoD04S
9WPdoF6NGzdOSEiwtLRkHQIAGhZ0J+ibdbgBMIC+qOBYIUmR9O6DgQGgdB4S lb97Z86bN8/X
15d1BQBoWIsxLW7k3DAwMWAdAgAc+fnwzxtvbWRdAaDbahKls27QBCMjoytX rvTs2ZN1CABo
2J6UPa6bysGNjAGgWEytTeNy4+oPrs86BECHjSDax7pBQ1q0aBEbG2thYcE6 BAA0qfGIxjG5
MYZiQ9YhAMCR7/2/35Oyh3UFgA5bTfQL6wbN+e2339avX8+6AgA0LEAe8MP2 H1hXAABHBEaC
aznXXCa4sA4B0FWXidqzbtAcExOTa9eudevWjXUIAGjSVwO/isuNM7YwZh0C ABwZsHTA2bvl
6SbmANwREj0lKt8P1WvTps2tW7fEYjHrEADQpM3xm3/c+yPrCgDgCo+C7wX3 9e7LugNA9zQn
imHdwIGlS5f+8ccfrCsAQJNq9aglU8hMrU1ZhwAARzr81OFy9mWBkYB1CICO +ZHIj3UDB0Qi
0Y0bNzp27Mg6BAA0aeOtjVOCprCuAADuHLh9wNUPNwEDKJmtRO6sG7jRrl27 mzdvikTl+3Qn
AP1Wo1MNmUImroIT/gD0RcNhDWNzY00sTViHAOiSRKKGrBs44+Pjs2LFCtYV AKBJa26s8Tru
xboCALjjF+c3+dBk1hUAOkNC9IRIf86cMzMzi4mJcXHBTcMAyi/7n+2TFEkW 1Uv8+A+hSNhy
bMufDv9kVtlME2EAoCHVO1aXK+Sl2OoB9FNXonDWDRzr3Lnz9evXTU1xlSBA eRVAK5JXzD47
u0QzGVsYyxXys3fPKhSKivUqaigNADRk2ZVlC8IWsK4A0A0ziZazbuDe2rVr Fy9ezLoCADSm
UtNKSYokayfrEszDI6FIWLtnbQwAAHRRxXoVkxXJlZtXZh0CoAOCiIaybuCe RCKJjY11dnZm
HQIAXzSR6Dy1ULTYd3tf8u3k6Ohoa2tr2k40maw2W/kr/JNTki/dueSy0oU2 ED2k9b7rPcI9
lp9cfjf77sX7Fz13exYtacmlJW6b3YjIqraVf6J/siL5Utal9x4jigEAgO6a cWrGmhtrWFcA
6IAsoqqsG5jo3r17ZGSksTGeGQqg5QYRNaTjJ497nPeg3WRvby8UCimUKJf2 R+332eRjJjEb
HTM6PDecphPVoqCgoMSsxImHJzbv3jxdkR6dE008IiLLmpYZigy7VnZEtP/2 fp9IH7PKZqO3
jA6//5/TIDEAANBdIluRTCGr3bM26xAArWZPlM26gaGNGzcuWIDTBQF0QVBQ 0J5Le+zu2P37
61By2OGgUCh69uxZu3btRpcbZedmS6VS1ZQ+ch+aT0Tkfd77vuJ+mx/bEJHn bs/dKbuJyKGt
g0Kh6Dm/Z+2etRsNb5StyJY2kBatCAMAAJ02LnDcDvkO1hUAWm0w0RHWDQxZ WFjEx8c3a9aM
dQjoDD7rAL3Un+gqjXcYz7PjXRNdmzt3rurInd0LOyKaMGHCypUrvSt5R2VH VatWTTVH9pt/
d234jPFRknLs+LFENKrDqB2BO4jIrrEdEU0YM2HlxpXey7yjnkVVc67G4HMB gAZs8dhS36J+
izEtWIcAaK9WRFdZNzD0zz//TJs2bd26dYaGhqxbAOCjahG9JupKRESjyTnd OTExccyYMRRK
DisdFArFvw/3DiXVLn8iCgoK8or3KvrlnzF/3lfc7zqja1xunMBIQG+PAHSc 2vGjK8QRAABd
N2z1sGPpx1hXAGivMKJurBuY27x58+zZJbtbIOgtHAHgnOouPrepdZ/Wgq6C K2ZXMjIy+Hw+
EaXnpZ8/f37y5Ml2dnZEJBKKPvqU71/7/con/vqp6wNjAgteFhBR+sX08/nn J0+YrLoeQGQj
Etni8eAA5ce+n/dJhJLus7uzDgHQRnyiZkTXWGcwN23atBEjRjRq1Ih1CAB8 1EGi53Ql90pK
Rsp1xfWAxABjY2PVLn8bG5tdu3ZlZ2dH3o2MT49v3bo1fXAEgIgOpx3OVeQ6 tHUoesfmK5td
ybuyFdmR2ZHxufGtx7UmIhNLk1RF6h3FHYVCcVtxOyE3getPCgBq0m1mt4tZ F3kCHusQAK3T
gEjGukFLDBo06Pz580KhkHUIAHyUFRGfRCKRyEZEH+ysNzU1rVjxc2fsmFU2 kylkjl0c35/R
2hSn+gCUV0fTjw5fO5x1BYDWGUu0nXWD9ti+ffv06dNZVwCAZkw6OOmv2L9Y VwAAd5q5NYvJ
jTEU4yI/gP/wJRrPukF72NjYJCYm1q9fn3UIAGiAqbVpQm5Cnd51WIcAAHe2 y7a/+yhAACCi
m0S4Sda7hg0bFhoaKhAIWIcAgAZ47vb0T/RnXQEA3KnVo5ZMITOrbMY6BEBb mBI9JcJxsfcE
Bgb+/PPPrCsAQAOMzI1ic2MbDGnAOgQAuPPH9T9mnpnJugJAW7QjusK6QQvZ 2trKZDInJyfW
IQCgAWO3jQ1ICmBdAQDcqdS0UpIi6d2nfQPos6lEa1g3aKeRI0eePXtWdZ9x AChXhCJhTG5M
k5FNWIcAAHfmhcxbcXUF6woArbCX6DvWDVpr//79EydOZF0BABowynfUvtR9 rCsAgDvmDuZy
hbxGpxqsQwDYSyOqxbpBa1WpUkUul9esWZN1CACom8BIEJUT5ezhzDoEALgz 6eCkTfGbWFcA
MGZD9Ih1g5YbPXr0yZMneTw8QxCg3Bm+dnhQWhDrCgDgjrGFcWxubKNvG7EO AWCpL9Ep1g3a
LygoyNMTtw8GKHf4Qv7l7MvtJrdjHQIA3BnlO+rgnYOsKwBYWkS0kHWD9qta tWpSUlL16tVZ
hwCAug1cNvBk5knWFQDAHdXIv+PUjqxDAJg5TdSHdYNOcHd3P3r0KOsKAFA7 Hl3MuthlehfW
HQDAnd6LeofcCyGc3At6iUf0iKgi6wxdcfz48bFjx7KuAAB1672od/C9YNYV AMCpM3fPDFw2
kHUFAAO1ie6wbtAhNWrUkMvlVatWZR0CAOoWci+k5/yerCsAgDttPNtE5UQZ mBiwDgHg2iii
3awbdMuPP/548CAuHAIod7rP6h5+PxznAwDolcDkwLHbcGQf9M5aop9ZN+gW Ho93+vRpV1dX
1iEAoG6nM0/3X9KfdQUAcKfegHoJuQmm1qasQwA4dZWoLesGnVOrVi2ZTFal ShXWIQCgVh1+
6nA5+zJPgKMAAHpkQ8yGX47+wroCgDuGRM+ITFhn6KLJkyfv3buXdQUAqNvR 9KNDVg1hXQEA
3LFvbZ+kSLKqbcU6BIAjLYmiWTfoKD6fHxwcPGLECNYhAKBWrce1vpZzTWAk YB0CANzxvujt
fdGbdQUARyYQ/cW6QXc5OTnJ5XKpVMo6BADU6sDtA99t+I51BQBwx6q2VZIi yb61PesQAC7s
IBrDukGn/fLLLzt37mRdAQBq1cytWXROtFAkZB0CANzxOub1Z8yfrCsAuCAn qs+6QacZGBiE
hYUNGYIThgHKl13Ju773/551BQBwR2Qjis+NrzegHusQAM2qQJRHxGedoesa NGiQmJhYsSIe
pgxQjjQc1jA2N9bI3Ih1CABwZ+y2sYHJgawrADSrO1Eo64by4ddff926davq tUAg4PF4H74G
AB2zTbbtf7v+x7oCALhjYGIQlRPVxrMN6xAADZpNtJR1Q/kgFAovXrw4YMAA IgoKCvLy8lK9
/+7rd1lZWfXu3XvBggUjR46sUKECp62gVjiAVp4tmbZkUtdJJpa4UTKAvnjz /M3i7YvnzZzH
OgRAg1oRXWXdUD68fv16woQJ3t7eVlbFuomwt7f30KFDU1NTW7ZsGRcXZ2tr q+lCACgNvzi/
CfsnsK4AAA7xKPR+aK8FvVh3AGhKDpEd64byZO7cuX5+fsU5AvDueUEhISEf nQZ0Ao4AlHNL
f146vv14ka2IdQgAcEVJC1cunPO/OXwh/g8P5ZADUQHRXdYZ2mzr1q2DBw9W vV66dOm2bdtU
r52dnTdv3kxEP/zww5EjR2Qy2f79+5s0abJ06dL69etbWlp+uCixWBwUFNS/ f3/VL5VKZdGP
/vnnH2tra81+EtAY/PVQzqWcSQm5HzLOdxzrEADgTuiK0Ozn2SPW4kmfUA7h /J8vSk1N7dev
HxEJhcIBAwZ8/fXX5ubmRDRo0KD4+HgiysrKmjFjRsOGDRUKhaen58uXLydO nOjo6GhsbPzu
coRC4bZt25KSkg4fPvzeKho0aNC8efNDhw5x9ZkAoISqta8mV8gl9hLWIQDA nUbfNorNjTW2
MP7ypAA6ZQXRr8Wb0pDIhWgWkb79/demTZs7d+4YGBh06tQpMDAwNDS0T58+ PB4vLi6uZs2a
707p5uYWFRWlen3z5s2wsDDV66CgoGnTpm3YsGHnzp18/vs7ix0cHKKjo4cO Har5jwIAZbAq
atWMUzNYVwAApzbHb554YCLrCgA1u0DUuRiTmRA9ILpGpCSSajxKuwgEgtTU VBcXl2XLlrm6
us6bN2/FihXOzs4XLlxQTdCjR4/Tp08HBwcHBwdfv35d9eaRI0eSk5O7d+9O REFBQSdPnlQo
FC1atHhv4Y6OjjExMYMGDeLyEwFAaVRpWSVZkVzBEXfsAtAjNTrVkCvk5g7m rEMA1EZA9JRI
XIwpeUSGRPX0cgBARJs3b54/f/7NmzelUmm7du2uXbvm7e2tuma3Ro0aWVlZ 7du3J6Jvvvmm
aAAQFBS0Zs2aW7duSSQS1UXAixYtiouLq1atWtFipVJpTEzM8OHDWXwmUCdc A6AX7kXeO5R6
aKIv9gUC6JHbobeP3j46xX8K6xCA97UhOkP0kCidyObtmxWJDhA9JEok6vT2 ze1Ek4k2ED0k
2k60hCidKJ+IiNYRjfv0jEqiV9x9IK0THBw8atSorKysnJycq1ev2tjYfPPN N0ePHiUi1cW+
6enpUqm0ffv2Esn/nyGVmZl54sSJRYsWqX45Z86c8PDwffv2SaX/jqG8vb0f PXoUFhYmlUql
Uum78wKANpI2kiYrkivWwxO/AfSItIE0SZFUqWkl1iEA/xFBNJmIR1SNyPDt m2eJfIkkRJ5E
t96+GUqUSzSdqBbRGCIFkT8REVkTPSNy+PSMKnp7BEAqlebm5k6aNEn1y8DA wMuXLxf9dOvW
rZmZmbGxsd99951cLvf19aW3t/40NTW9fv16WFiY6nCBQCAICAgICwtTfdeX yWSKd6juKQQA
Wm3R+UW/XfiNdQUAcGrW2VmrolaxrgD4jzCiU2+/vqvUIFISDSCqR9SM6A2R atgaSvTX22nM
iF4RrSQiop+JTn52RhW9HQB8UYUKFVQ39Tc1NTU1NX33R23bto2JiRGJcANx gHLB2sk6WZFs
2wTP7QPQI+IqYplCVrN7zS9PCsCVqkSniV4TLSVSPay+E5GSKILo4tt/2hIR USjR/HdmfEh0
lIiIEokGfXZGFQwASsfHx8fHx4d1BQCoydxzc5ddWca6AgA45bnHc5tsG+sK gPe1I8olGk9E
b3fkd/9gmncHACKiF0RPiHoRZREZfHZGFQwASkckEsXExLRkiSiZAAAgAElE QVRt2/bLkwKA
9qvgWCFJkWTXCs9QB9AjhmLDmNyYZm7NWIcA/Ks9kQERj+gqUdHtKYKJQt6e F2T29lY/7w4A
OhBdIkojyiFa/M7SPjqjCgYApda5c+fr16+/d3YQAOiq6Sen/3H9D9YVAMCp b9Z9cyT9COsK
gH8lET0iukN09O0pQERkS3Sc6A1RClE2UXsi+u8AYBrRKqKFRIVENd5Z2kdn NCX6hyifSEn0
mCiHmw9WvqxZs+b3339nXQEA6iCuIk5SJFVrX411CABwhyfgXcy62G1mN9Yh AP8Sf+J2/qJP
77DfT/Ttpxf4mRmhdCQSya1bt1q3bs06BADU4efDP/8Z8yfrCgDg1Ndzvw6/ H84T8FiHAJRS
BpEj6wZ9071792vXrhkbG7MOAYAyE9mIEnMTa/WoxToEADh1POP40D+Gsq4A KA1bor9ZN+in
DRs2LFy4kHUFAKjDhP0T/OL8WFcAAKdajGlxM+emUCRkHQJQYv2JTrBu0E8W FhZxcXHNmzdn
HQIAZWZiaRKXG1dvQD3WIQDAqQB5wP92/Y91BUCJef/3gQDApV69el2+fNnI yIh1CACUmUeA
x3bZdtYVAMCpOr3rJOYmimzxjE/QMcFEPVk36DM/P7+5c+eyrgCAMjMUG97K vdXo20asQwCA
U2turJlxagbrCoAS4BE9JrJinaHPrKys4uPjGzduzDoEAMps9JbRgcmBrCsA gFOVm1dOViRX
rFeRdQhAcdUlSmHdAAMHDrxw4YJQiIuIAHScgYlBdE5089G4sgdAvywIW7Ds yjLWFQDF5Ua0
i3UDENG2bdtmzMDxQwDd992G7w7cPsC6AgA4ZVHdAg8EBB2ynmgK6wYgoooV KyYmJjZo0IB1
CACUjcBIEJkd2cazDesQAODUlKApvnG+rCsAiiWKCE+j1RJDhw4NDQ01MDBg HQIAZTNk1ZCj
6UdZVwAAp0wsTWJzYxsOa8g6BOALjIieEeFRtNpj586dv/zyC+sKACgbnoB3 KetSx6kdWYcA
AKdcN7nuv72fdQXAFzgTXWfdAO+SSqVyudzJyYl1CACUTf8l/U9nnmZdAQCc EhgJrmRfaT+l
PesQgM+ZTPQn6wZ4z4gRI4KDg/l8PusQACgLHoXfD+8+qzvrDgDgVL/f+wXf DSYe6w6AT9tJ
NJp1A3xo3759kyZNYl0BAGXTY16PkHsh+B4AoG+C7wb3X9KfdQXAJ6UQ1WXd AB+qUqWKTCar
VasW6xAAKJvge8G9F/VmXQEAnHKZ4HIt55rASMA6BOAjLInyCPumtJSbm9up U6d4PPz3AdBl
XaZ3uZB1gSfAlgygX/am7h29ZTTrCoCP6EF0jnUDfMahQ4c8PT1ZVwBA2ZzI ODFo+SDWFQDA
qfqD68flxplam7IOAXjfPKLFrBvgM6pWrSqXy2vUqME6BADKoN3kdpezL/OF uK4fQL9svLXx
58M/s64AeN9xogGsG+Dzfvjhh2PHjrGuAICyCUoLGr52OOsKAOCUQ1uHJEVS BccKrEMA/uMB
USXWDfBFx44d++GHH1hXAEAZtBzb8kbODVwRCKBvfo/4fdH5RawrAP5fDaJM 1g1QHNWrV09K
SqpatSrrEAAog72pe139XFlXAACnrJ2skxXJVVpWYR0C8K9viA6wboBi8vT0 PHToEOsKACiD
xiMax+TGGIoNWYcAAKemnZi2Lnod6wqAf60imsa6AYqJx+OdOnXKzc2NdQgA lEFAUsDYbWNZ
VwAAp0S2ooTcBKc+TqxDAIiIIog6sm6A4qtZs6ZcLq9SBUcRAXRW/cH1Y3Nj jS2MWYcAAKfc
d7jvTNrJugKADIieEpmxzoASmTRp0r59+1hXAEAZbEnY4nnakw4Q5RE9xZMY AfSCUCS8nnPd
+bgz/U2UT2TAOgj0VVOiWNYNUFJ8Pj84OPi7775jHQIApdCI6ADVflw78UGi aaEpKYlyiHBx
P0C514YogoY8G3Li0QlSEqUQtWOdBPpqHNFm1g1QCk5OTjKZzNbWlnUIAJTU MyIlkZI2Pt44
+elkUhIlELVhXQUAmqba9gsp/GF4jxc96AaRF+sk0FdbiP7HugFKZ+rUqbt2 7WJdAQAl1Z3o
KZGSHN84yh7IzArM6BrRMNZVAKBpX/+77Xd52SXiYQQ/iU8HWSeBvoonasy6 AUpHIBCEhYUN
HTqUdQgAlFSHf78HrM1b6/XUiy4RTWWdBAAceLvtBz0KGvFkBGWx7gG9JCZ6 gitQdFn9+vUT
ExNtbGxYhwBASXUgekpV31RNepBkft2cVrHuAQBudCB6Sk1fNY35O8ZIYUQO rHtA/3QmusC6
AcpoxowZ27ZtY10BAKXQgegp+eT7zMqZRbivF4D+6ED0lPwf+4/PHk/fso4B /TODyId1A5SR
UCi8cOHCwIEDWYcAQCl0oEpPKiU/SLa6YcU6BQA41IEcnzjKHsgkmySsU0Dv HCQazroByq5R
o0YJCQlWVvj+AKCLOtDveb8veLyAdQcAcKsD+eT5zFHMYd0BeuceUTXWDaAW c+bM2bRpE+sK
ACgVUTPRxMcTWVcAANdErbDtA9eqEOWybgB1MTQ0vHz5cu/evVmHwH/g4a56 rWbNmsuXL7ew
sCgoKOBspQKB4MGDB7Nnz5bL5ZytFADeg80ftNZAorFEfVhngLo0a9Zs+/bt Li4u//zzD+sW
+BcGAPqrTp06GzZsKCwsdHJyMjQ05PG4+MOgVCpfvXqVmZn5/PlzDw+PlJQU DlYKAO/B5g/a
bAnRU6JFrDNAjRYsWCCVSseNG8c6BP6FAYD+OnTokL29vYMDmzv8xcTEPHr0 CE8JAWACmz9o
sxCipUSnWWeAGhkbG58/f3727Nlnzpxh3QJERHzWAcCMhYWFra0tq7U7OTlZ W1uzWjuAnsPm
D1qLT9ScKJJ1BqjXixcvJk2a5OPjI5HgrmJaAQMA/VVQUGBoaMhq7YaGhlye eQwA78LmD1qr
LlE20SPWGaB2V65cOXbs2G+//cY6BIjwmG09h7+DAfQWNn/QTi2x+7/8WrRo 0YULFzp37hwS
EsK6Rd9hAKDX3rx58947p6Pv/J33nMcjC5HxV1Wtq1b891CdUqkMjkmPS1c8 yHtuZy2uZmPu
UreKxNSIiF69KYi5k3tZfv/7Lg3EJv+/T/FT7wOANij75v93/vPIpKyolOya lSx6NK1Rwcy4
aFHY/KHUWhFdZd0AGvLs2bNJkyb9+eefLi4uT548YZ2j1zAA0Gsf7gJcd+z6 qzcFtSpbxqYp
0hSPN47r3r1JtYf5L8b7BqfnPh7UunadKhXSFXmHLieJjYWtnSq/ePWm9fSd 9tbi2PQHw1xq
mxoKVMv51PsAoCXKvvnP3Xnh5euCDvXtI5OyZgdcOL/4W9sKIsLmD2XTksif dQNoTkRExNmz
ZxcsWDB16lTWLXoNAwC99uEuQKVS2a5eFa8BLYjIdfXJHWHxnRvYLT145d7f +UG/9rd8u4dv
2oDmqtkFPGXE79+kK/J6LTpU8KagaIGfeh8AtETZN/8Vbu35fB4RDWtTKyHz wa7w+El9mhI2
fygDYyInopusM0Cj5s2bFxER0a5duwsXLrBu0V8YAOi1j34DKCwsVL1fraIk LP7u33lP911K
mj/cWWJs8NG/yPlEBW8KVEt7d4JPvQ8A2kAtm39h4b8vJCaGD/KeF02DzR9K pxlRHNFL1hmg
UU+fPp0yZcrq1avbtWv39OlT1jl6CncB0msFH1ASFRYqCwoKbmc/OnIttU2d Srez/1Eqqb69
5YcTFyksLCSigsLivq/C+tMD6DV1bf4FBQVx6YqbaYoejati84cywhXAeiIs LOzChQtz5sxh
HaK/cARAr31kz5xSefpmekhsZpoiv0sDu597N7x+W0FEZoaCz+zGe1Pwhog+ PNb/qfcBgDl1
bf53/34ycXP4nMHNGzlYvjsZNn8ohVZEx1k3ADdmz54dERFx5MiRS5cusW7R RxgA6LUP98Mp
lcq6VSp841LT3srMWmxMRFJzYyLK/DvfWmz0qeUUFhTS2x2KxXkfAJhTy+af rsgf53d+Uq8G
PRvbY/OHsmtJNI91A3AjPz9/6tSpq1evbt++/fPnz1nn6B0MAPTaR08CrmRh 0sDOouinlS2M
zU0Nj1y7o3rz48speKP690ePAHz4PgAwV/bN/0H+i3F+4eO61utWv/KHS8Pm DyVlTWRJlMQ6
Azhz9uzZgQMHzpw5E+cCcQ8DAL32kW8AREVXAarwidw71Vl5Iraqlekw5xoC Pq+wUHkpOdfe
SuRgbaaaRnW134fH+j/1PgAwV/bNf8XRGLGJsFl1y+xHT4jIyEAgNhEWzYvN H0qqFVEkkZJ1
BnBp5syZFy5cOHLkyLVr11i36BcMAPTaRw7NK5VKpfK99/s1tTPg05/BMt8Q udTc5PmrN7Vs
JRO61S0oKHjxumDgqpDCQiURDV8TamjAPzK1CxF96n0A0BJl3/xv3Hnw+Pnr /j7Bqik71LVd
NKQJYfOH0sIVwHron3/+mTZt2tq1azt06PDyJe7/xB0e6wBgJjg4WCAo2QN6 FHkvnr16U9VK
xOOp4U9OQUFB165dy74cACgpbP6ghU4SbSA6wjoDuOfr63vv3r0FCxawDtEj OAKg10p6cZ6l
SGgpEhYW3fobAHQWNn/QNs5EbqwbgIkZM2ZcvHjx8OHDN2/iKXAcwXMA9Bfz v8iZBwDoLeZb
H/MA0DY1ifKIcllnABMPHz6cOXPmunXrhELhl6cGdcAAQH9lZWXpeQCA3mK+ 9TEPAG3Tiugq
6wZgKCgoKCUl5ZdffmEdoi8wANBfs2fPViqZ3W5BqVTOm4fbPQOwgc0ftA2u AAYvL69Ro0Y1
bNiQdYhewABAf2VmZrq7u9+7d4/jY/GFhYX37t0bM2ZMWloal+sFgCLY/EHb YAAACoVi7ty5
a9asMTDAFaoAAAAA5ZqQ6BmRKesM0AYBAQFeXl6sKwAAAABAk5oTxbBuAC0h lUplMlndunVZ
hwAAAACAxvxI5Me6AbTHt99+W4pnlUCJ4BoAAAAAYAm3AIJ3BQYGPnz4cMKE CaxDAAAAAEAz
Eolw5xd4V+XKleVyea1atViHAAAAAIC6mRPlE+FsD3iPq6vrqVOn+HycqwIA AABQvnQlCmfd
ANrp0KFDP/74I+sKAAAAAFCrmUTLWTeAdrK3t5fL5Y6OjqxDyiEe6wAAAADQ X4eJdhDtZ51R
btSsWXP58uUWFhYFBQVFbwoEggcPHsyePVsulzNsK4WxY8cOHDiwb9++DB9e Xi5hAAAAAADM
ZBG1IspgnVE+1KlTZ8OGDYWFhU5OToaGhjwej4iUSuWrV68yMzOfP3/u4eGR kpLCOrNkjhw5
cuzYMV9fX9Yh5QoGAAAAAMCGPdE1IlvWGeXGoUOH7O3tHRwcPvrTmJiYR48e DR06lOOqMqpW
rdqZM2e6deuWnp7OuqX8wLXVAAAAwAaeAKBeFhYWtrafHE85OTlZW1tz2aMW aWlpK1euXL16
NeuQcgUDAAAAAGCjJVEk64bypKCgwNDQ8FM/NTQ0fPfCAB3y119/GRkZjR49 mnVI+YEBAAAA
ALCBIwBqV1BQ8OYTdPTbPxEplcoJEyb8+uuvdnZ2rFvKCQwAAAAAgAE+UTOi a6wzyplPfftX
YV1XeqmpqevWrfvjjz9Yh5QTGAAAAAAAA18R3SV6zDqjnCn4LNZ1ZbJ+/Xpz c/ORI0eyDikP
DFgHAAAAgD7C+T+aoNO7+T+vsLBwwoQJhw8fPnfuXFZWFusc3YYjAAAAAMAA rgDWhPJ6CpCK
XC739fVduXIl6xCdhwEAAAAAMIABgCaU41OAVFavXm1razts2DDWIboNpwAB AAAA10yJahPd
ZJ1R/pSD3fyfV1BQMH78+IMHD4aHh+fk5LDO0VU4AgAAAABca0Z0i+g164zy p9wfASCihIQE
f3//5cuXsw7RYTgCAAAAAFzDFcBq1LBhQ3d396SkJCrGEYD79+8bGBg8e/bs wYMHCoXi7t27
d+7ckclkcXFxqiXoBB8fn9DQ0EGDBh08eJB1i07isQ4AAAAAvbOX6DDRTtYZ Ok0gEPTp08fd
3b1KlSqbN2/etGnTsWPHTE1NPzPLs2fPxowZc+nSJaFQyOf/5zSQN2/evHz5 slq1apqNVp9G
jRoFBga2b9/+wYMHrFt0D44AAAAAANdaEs1i3aC7LC0tXV1dx4wZc/v27Q0b Npw8ebKwsFD1
oy+e55ORkdGyZcugoCBbW1sTE5Oi948dO/b6tS6dkxUTE7Nr166lS5eOHTuW dYvuwTUAAAAA
wCkbInOiZNYZuqh+/fqrV6+OjIx0cHD45ptvBgwYcPz48aJv/1S824Dev3+/ U6dO0dHR+fn5
qncKCgp69+79/PlzqVTK4FOV1rJly+rWrdu3b1/WIboHAwAAAADgFC4AKCk+ n9+3b98jR47s
3LkzNTW1RYsWP/30U0JCwodTFvMi4KdPnw4cOPDw4cOqMcDZs2fv37+vVCoj IiK2b9/erVs3
Hk8HzhJ/9erVhAkTlixZUqFCBdYtOkbAOgAAAAD0yyiie0ShrDN0goWFhYeH x19//eXo6Ojn
5zd16tQrV668ePHioxOPHDny81/cCwsLd+zYoXqtVCpPnz796tWrVq1aPX/+ fOfOnb///vum
TZuEQuG4ceOmT58uFovT0tKKjhJop6ysLKlU2r9//2PHjrFu0SU4AgAAAACc whGA4qhbt+7K
lSuvX7/u6Oj43Xff9evX7+jRo++e7fOhrKyszy/zwwk2bNgwbty4GjVqbNu2 jYiePXu2c+fO
Hj16DB061MLCIjQ0dPfu3b169RIItHeX8eLFi5s2bfr111+zDtElOnB8BwAA AMoNHtFDotpE
CtYl2onP5/fo0cPDw8PR0XHLli3btm17+PBhMee1t7ffsmXLpw4CKJVKd3f3 tLS04scYGRn1
7dvX1dXV0dExMDBwx44d6enpxZ+dM61atdq0aVPbtm0fP37MukU3YAAAAAAA 3KlDdJKoBusM
LWRubj5y5MixY8dmZWX5+fkdPXq0FI/uqlat2oIFCypVqvTuXT4LCwuzsrJm z56dmZlZujZH
R0dXV9fhw4cnJCRs3779+PHj2nbLoMWLF4vF4okTJ7IOAQAAAID/GkW0m3WD tqlTp46Pj09K
Ssq6desaNWrEOueThEJh//79Dxw4IJPJFixY4OjoyLro/5mamkZFRXXp0oV1 CAAAAAD811qi
n1k3aAkej9ejR4+DBw/GxsZOnTrV2tqadVFxOTg4zJo1Kz4+/ujRo0OHDjU2 NmZdRETUpk2b
W7dumZmZsQ4BAAAAgHdEErmwbmBOLBZ7enreuHHj5MmTgwYNMjDQyQezCgSC nj17BgYGJiUl
/f7773Xr1mVdRMuXL1+5ciXrCgAAAAB4y5DoGZHJlycst2rVqrV8+fLU1NQ/ //xTm8/2KZHK
lSt7eXndunXr9OnTI0eONDU1ZVUiEolu3rzZvn17VgEAAAAA8B8tiaJZNzDB 4/G6d+++b9++
+Ph4Ly+vihUrsi5SPx6P17Vr123btqWmpvr4+KhxeGNlZdW7d+8FCxaMHDny i8/86tChQ3R0
tEgkUtfaAQAAAKD0JhJtZN3AMTMzs//973+RkZFnzpwZMmSIjp7tUyI2NjZT pky5fv16SEjI
999/X/aT8jdu3Lh161ZXV9c1a9bcu3fP1tb289OvWrVq2bJlZVwpAAAAAKjB DqIxrBs44+jo
uGTJkpSUlI0bNzZr1ox1DgPt27f38/O7ffv2mjVrmjdvXurlvPtkg5CQEC8v r89PLxaLb926
1aZNm1KvEQAAAADUI4noK9YNHOjateuePXsSEhKmT58ulUpZ52hWixYt9u3b l5ycHB0dXXQj
IysrK39//+Tk5EuXLvXs2fPHH3+8cuVKSkrK1q1bV69enZycvH79ek9Pz6KF LFmyxM3N7b0Z
XVw+crn4wYMHly5d+sWqrl27RkVFmZjo8/UmAAAAAKxVIMoj4n95Ql0lEonc 3d2vXr0aHBw8
bNgwoVDIuogLx48f9/DwICJ7e/uij7x//34fHx8zM7PRo0eHh4er3gwJCbl7 925mZmZAQMCc
OXOioqJU71taWmZkZNjZ2X1qxiINGjTIyMhwdnYuTtj69et/++03tXxGAAAA ACiN7kShrBtK
SiAQFJ1/8u7r91SvXn3x4sUpKSm+vr4tWrTgMJC9oKCgPXv2qL6+qzg4OCgU ip49e9auXbtR
o0bZ2dmqwyBBQUE+Pj7m5ubu7u4XL17MyclZvny5tbW1p6fn7t27PzNj0WKj o6OHDh1azDBz
c/PY2NiWLVuq9eMCAAAAQLHNIVrCuqGkgoKCis44f/d1kU6dOgUGBspksrVr 186ZM0cPn0JV
pUqVvXv3ZmVlzZ07V/VEMBcXF4VCcfz48WNvtWrVij74DQwMDLx69Wpqaurt 27enTZv2mRmJ
yNHRMSYmZtCgQSVq69Gjx9WrV42MjNT2aQEAAACg+I4Slezrmxb41ABAJBKN GTPm8uXLISEh
o0aNksvlZ8+eVSgU5fL+nsXh7OycmJg4ZswYersjv2PHju9N894AwMXFJS0t rU+fPqmpqcHB
wdHR0QsXLvzojFKpNCYmZvjw4aUI++uvv+bPn1+KGcu3cnwmHgAAAGiRVkRX WTeUXbVq1RYt
WhQdHe3i4vLTTz917tx5x44d9evXHz9+POs0Nlq3bi0QCK5cuZKRkcHn84ko PT39/PnzkydP
Vp0XJBKJPnpX/oiIiIcPHy5btmzLli1du3Z1dXU1MTF58+bNxo0bR4wYwefz i2b09vZ+9OhR
WFiYVCqVSqUSiaT4eTNmzBg2bFiTJk3U9HEBAAAAoHiqEd1jGrB169bBgwer Xi9dunTbtm2q
187Ozps3byaiH3744ciRIzKZbP/+/UXfF9/daR0aGnr58mWZTLZw4cITJ070 79//3eXXrl1b
P48AqG7vc/369YCAANUpQERkY2Oza9eu7OzsyMjI+Pj41q1b08fOoZo+fXpu bq6Dg0PRO1Wr
Vg0LC8vNzc3KykpLS+vbty8RyWQyxTtU/72Kr1+/fhEREYaGhmX8pAAAAABQ AsOIDjENmDNn
jupLv1AolMvl2dnZ5ubmRLRs2bKff/6ZiHr37l2vXj1DQ8MNGzb4+vqq5goK Cpo5c+bo0aMv
XbqUlpa2Y8cOMzOzgwcPfvicKb0dANCn9/GbmpqW7jfE1NTU2dnZ29s7KSlp 9+7dvXv3FggE
ZSn09/efOXNmWZYAAAAAACXjQzSDaUCbNm3u3LljYGCgumw3NDS0T58+PB4v Li6uZs2a707p
5uamukOlvb39zZs3MzIy/P3927RpExQUNG3atA0bNuzcuVN1rsu79HkAoDlG RkZDhgw5fPhw
QkLCnDlzqlWrVrrlWFtbJyYmNmzYUK11AAAAAPBpF4g6Mw0QCASpqakuLi7L li1zdXWdN2/e
ihUrnJ2dL1y4oJqgR48ep0+fDg4ODg4Ojo+P37FjR1JSUnR09KJFi1QTBAUF nTx5UqFQfPRG
nxgAaJSjo+P8+fNlMtmhQ4cGDhxYimcsDB48ODw83MDAQBN5OgcXAQMAAIBm CYiaEl1j2lBQ
UBAWFtatW7fu3bufPn06JCSkQ4cOffv2PXLkCBHVqFHD399/xYoV27dvt7Gx sbCwOHPmTMOG
DdPT0/Py8ooWEhISsnHjRn9//1LviobSSU1NnT9/fv369f39/b/77ru4uLiF Cxe+d+jm8w4c
OJCZmfnTTz9pLhIAAAAA/tWYKJ51AxF9++23qampJ0+eJCJDQ8P09PTU1FQn Jyci6tWrV05O
TnJy8u7du/ft25ecnKya5aO3AV2/fv21a9fefUYV4QgAt6pWrTpz5sz4+Phj x44NGzas6OLj
z5NKpTKZrF69ejVr1rx8+fKdO3fKeGmB7sIRAAAAANCslkSRrBuIKCQkRCwW qwYAr169unTp
Um5urqWl5datW//444+0tDQTE5OvvvoqKCiosLCw6DrgD02aNEkul+/Zs0d1 P0oTE5PU1NTT
p08T0dWrVxMSEjj7RHorIyNj8eLFDRo0WLdu3YABA2JjY5csWVKvXr3Pz5WT k/Pbb78dOnQo
IiKiZs2af//9t749thkAAACAI5uIPFk3vMfY2HjkyJHh4eERERFubm4mJiZE VKFCBR6PR0Sm
pqampqasG6G4KlWq5OXlFRMTc+bMmZEjR370lkRE5ObmlpaWVnQ70XPnzunt 0xsAAAAANCuW
qCnrhiKVK1eeM2eOTCYLCAho37496xxQGx6P16VLl23btqWkpPj4+DRq1Oi9 CdLS0nJycooG
AFeuXNm6dSuLUgAAAIByTUT0jEgb7r3i7Oy8ZcuW5OTkhQsXvvvwKShnbGxs Jk+eHBUVFRoa
OmbMGLFYrHq/Zs2aSUlJd+/eVQ0A7t69Gx+vDRenAAAAAJQvHYkimAYYGRmN GDFC9Rzf77//
Huf26I927dr5+vqmpqauXbtWdbp/5cqVIyMji04EksvldnZ2rDMZ4LEOAAAA gPJsGlElIiY3
X7S1tR07duyoUaOuX7/u5+cXFhbGogIYs7S0HD58uKura2Fh4Y4dO44cObJh w4aGDRuKRKL0
9PSnT5++efOmdEsWCAQPHjyYPXu2XC5Xb7OmYQAAAAAAGrSf6ABRILcrbdmy pbu7e8eOHffs
2bNp06a0tDRu1w/ayNnZedSoUT179jx79qxUKjU3Ny8oKHBycjI0NFRd/F0i SqXy1atXmZmZ
z58/9/DwSElJ0USzhmAAAAAAABqUSdSB6DYn6zI0NBw4cKC7u7uZmdmmTZsC AwOfPn3KyZpB
Z0gkkmHDhnl4ePD5fLVcChITE/Po0aOhQ4eWfVGcwQAAAAAANMWWKJ7ISvMr kkql33//vaur
661bt/z8/M6dO6f5dYIOCw0NrVWrlpGRUdkX9fLly/3bwqcAABa+SURBVOTk 5E6dOpV9UZzR
hovyAQAAoHxqRXRVw6to3ry5u7t7586d9+/f37dv39TUVA2vEMqDgoICQ0ND tSzK0NCwoKBA
LYviDAYAAAAAoCmaGwAIhcIBAwZ4eHiYm5tv2rRp6tSpT5480cyqoHzSuW/t aoQBAAAAAGhK
SyIfdS/TxsZm9OjRbm5u8fHxy5YtO3v2rLrXAHrhw5v/vCkovJCQGRabKbUQ Nalh09qpChH9
nf88MikrKiW7ZiWLHk1rVDAzZhGrZhgAAAAAgEbwiFoQRapvgY0bNx43blzX rl0PHDjQv39/
3brvCmibD48AjF176vGzl72aVpfdexiXntuyli0Rzd154eXrgg717SOTsmYH XDi/+FvbCiIW
veqEAQAAAABohBORgujvMi/HwMCgX79+Hh4eFStW9PPz8/Lyys/PV0Mf6Lf3 jgCk5+aFxWVE
LP6mornpuxOscGvP5/OIaFibWgmZD3aFx0/q05T7WvXCAAAAAAA0omWZd/9b W1uPHj169OjR
crl81apVZ86cUSqV6omDcq+Q6BFRHFEw0W6i5Pd//t4AQMBTKpV07lb6kNa1 3l9S4b8vJCaG
D/Kel/rBYdqDzzoAAAAAyqdiXgHM5/N3796dmppqbPz/Z1c3atRo/fr1V69e tbW1HTRo0ODB
g0+fPo1v/1ACPCJLovZEC4nkRC+Jkol2EA0ikhARFfxXRYnxD12+mhN4efqO C4rHTws+EJeu
uJmm6NG46oc/Yv1RSwxHAAAAAEAjWhLt+NI0IpHo1KlTTk5OaWlpbm5umzZt 6tevn7u7u62t
7aZNm3799de8vDwuWrWWAQl4gsI3hUql8j+v4S1jC2NJFYnYViyWiiU2ErGV WGIpEZuLJc8k
YqVYXCgWK8USpUSilIitxJKeEnEP8XrD9XTtIxcBT+hR/yu7Ct4Ho4bITywd 2bpJ9YpFP7r7
95OJm8PnDG7eyMGyHBwBwIPAAAAAQCNmES0l+sx3pcqVK4eEhFhZWRHR8+fP nz179vr165SU
FF9f31OnTuFrLhFRKAVVCIrYGbF8+fL/vC6LikTtSNhW2ORpE5cXLn6r/bTk Dqp8IV9iJxHb
iiW2EnFFsaSiRGwlFluIJRYSsVgsMZOITcUSY4mZkZlEKJEYSMR8sTmZv6bX ecq8/ML8/Df5
ea/y8l/m5z3Py3+Wn9c4L5+Xn8/Pz+fl573My0vMyzfKz6uSl781/8miJ8GH gi0tLT+akffs
1dy91yJTcoLn9DM1MiCidEX+OL/zk3o16Nm46kdnefjwYdeuXTX4W6NuOAIA AAAAxVapJo1b
SSILKvzyaQ/eH32XL6C8B7Tl1xaVJAcPHiw67cfExESpVM6dO3fv3r3qDIYP rSZjU+OYJjEZ
rzIaWzQOOBLwJFb9AwCRjciskpmkkkRcUSyxkYgtxRJLiaSCxExsJhFLxCKx xEQiNhJLDCVi
A7FYIJbwJMZknEd5+YX5eQV5+a/z817m5b/Iz3+Wn/ckL/9Jfta9rPx/8vMe 5uU/yM/Pzc/L
zsvPzn+c+bjg5Sf+KKrGj+lEl4kaEpkR+RDtInr5788/tSPf1JD/S58G/Vdk XU/NaV1b+iD/
xTi/8HFd63WrX7kc7PtXwQAAAAAAiseuDk32JWUh2dUmA0Pilfw8AqWS3ryi XGOa4rdqcG1j
Y8G7P3z06FGnTp0wANC4kfSi8EV9Yf3q1atHRETQSKLpn5tcYCQwtzeXVJaI bcRiG7HYWiyx
lKh2zKu+yotNxWJjscRIIhaKJQKJmC+WkOQ5Pc9X5ucX/GfHvOqr/L179/79 Kv8wPy83L1+R
n5eVl38v/9mDZ2r+pHuJOhCZE00h+uBxEe99m09T5D988rJhVUsDAf9KUraA z6tSweTNmzcr
jsaITYTNqltmP3pCREYGArGJUM2dnMMAAAAAAIrHfTmJJCStVvol8HgkNKIq tSj1pvvVf440
E2RmZj58+NDIyEgsFlesWLFXr15qq9U2B2mr+dajfx49cOAArael7ZbaRtu6 ublRO3Ke4+ye
6T725tgfPH7oZ9uv9pvacbFx3tO9o6OjP74ocxIfEe8w2OG/zP/w4cNkRRXW Vfit828deR2V
L5WhJ0JnT5v9+PFj2k7rq6yPfhgtaSMZxRuVlZI1a8qs5Oxksa1YUkkikUqc 6jgR0ZAeQ3jV
eWKxWCKWSEQSsbFYYiwRC8ViA7GYL5bwJEISPqbHeYV5+W/y817nPXn5JO9F nmrH/KN/HmWk
Z+Q9ynvy8EmeIi9f8e+O+by7eYWvCz8ez5kXRI+JOhElfvzn7128m6bIX3jw Jp/PsxQZSUyE
s/o3lEqMCgoKbtx58Pj56/4+warJOtS1XTSkiabbNQ0DAAAAACgekQVVqKSe RVWtK7ufcv6p
/P5b9+7dU71Qz/K1UBKlfp3ar1+/A0cPCIcJB/AGmNuYm5ubP/728SDBoPj4 eLpHWRuyZlya
keKVsrrhak9PTw8Pj48sR0DCQ8Jt1ttSz6ZGyCNqdKoh9hEvt1luqDD8S/6X WXOzgf0Hnut2
LvxBuLiauCOv4wDlgCfKJ6/5rxvXbXz69Omn9DRfmZ9XkJf3Oq9AWUBEDYQN FDaK/Pz89LT0
vH/y8h/l5z3Iy1fk5+fk52fn593Le/HPC65/r9TC5As/f+8IQGtHq+O/dM76 v/buLUau8j4A
+P/MrHdZe2fM2o5tCiRcmk0hEJBqrKpJTBLSiAKCNEgJpVRJTR3lIQmVKr9E BoIaKSRRK0Uq
D4lVpOTNtYNTBepcuLQUh5rQUCsh9hocA7bxrt3F9hlfl505fdjd2d25MTZr ry+/38Nqds7/
+853LjPz/b9zO3D0gln5+T1d1YD1f/ex1gXPRhIAAKA9lXLM6pyeqjo6s5G3 77333ump7ayw
IZ760lPLL1ze8cmOj/R/5Nfv+/XifYs/uuyjT/zFE7ccvOWeX91zyfAlvx/5 ffGG4rKuZccX
Hr/5Uzd/ed2Xi33Fy3OXX/ilC6+999ri/OJ12XVX//3V98V9s2LW0r9aesvd t6RZerzj+FWV
q17sfrHvir40TTe/d/Md+Ttef/71nfN29nX27evfd/937y8tLd38tzd/Ze9X rr/++rH2XBF9
/9G3MTY+eOOD+/btm9FVMzMa3r5zcbGr2aRziQQAAGhbG9f+nue653UXLy72 LOopLi4WFhSK
C4qF3kKxt1icWyxkhc7Znev+Zd1lyWVvJ28XLy0+8ugjj8Qj3fO7f/TYj9Is zZKsN3orUSlH
eVbnrPnz5qeV9Fjl2Guvv7bm2TXpZ9Ovz/16vjt/bfna2z9z+/P/9XxExMfj wz/98I/TH3/h
T78wODgYF8fi1xffMXzHr/75V8//wfOf7/38Cz9/YevjW+PCOJgdTKqXbfRF PBXxTxFfm7k1
NaMqlUouN22Pw6pUZvp8pxMkAQAA2lauO/mhUok334hdb8TsOfGeRXHRJeOR 5fi/wRjYHVdd
F53tHjfI5XIrVqy47777CoXCpZdeOn3tPhn5rvzku1IWFhQK8wrF3mJhbqFY KBYLxUJ3odBd
KHQWip3FQr5QzBWLURyO4epdKUvDpfR4WjpaSg+naSndM7Tndx2/OzTnUFep a+XjKxfcuWDl
yMonX3ty3+P7vvPj71zxmys2Htj4uc9+7tkrnr3rH+5auXflQ594KJ6JG3tv fHnDyxu+syFu
jMPDhzcObdx4zcbVq1ffdvNtr732WrwZA7mBiOjr6xscHIxr4qryVRExMDDQ dMEuingqYlXE
8+dvArBnz56LL754GmubrqpODwkAANC2+gTgqSdi+Hi878rYPxRDg7FwcUTE yEj86IfRU0yG
9mVXfiDy7zzU2tPT88ADD9x1113d3e907vZJmbNwTuHiQnFxsbBw7Abzxd5i 4cJCoVgo9BSK
c4rF2ZPuSpkrFJJCV3TV3JXy0LFD6ZG0dKiUltLdu3aXDpTSofTQ0KF0b1oa LKV70nRX2vSu
lBHxN3HgHw98Y/gb2/q3/WLlLzqXdz589OE733vnrT+5NRbEvGxeZPH60dcX 3bJoWfeyYrHY
uJKfxf27759307y169fedvNtg9sGt2/evvnCzXd//u6XdryU+2Lu7jfvfumV l3bs2NG0Gd+N
eCvi5xFXREREMeL8OwNo1apVjz76aHISd7Kqk2XZgw8++O7rOZ0kAABA22pO ASodjN1vxJ33
RPfsKQFJxGfuiVIaj6+NSrn1iUOXX375t771rWXLluXz+RZhVR3dHXMvnTs2 ML+wMPbk19HH
RfUUij3Fnu6eYnex2DnlrpRH4sjoxa9jd6U8VkqPpqXDpVKptHv37i37t6Rv paWhUrovLe0t
lfaUSntOwV0pfxpPr3668FZhw4YNcTyGnx3+5XW/vGzgsq1bt0bEixte/NnH fvbcE88dKB14
OHv4pjk3ff/73/9i1F0HnEUsj6+u/+oPrv/BmnVrbr/19vSudMW/rvjep7+3 +Y7NuUpuy8tb
Gl89XPXx6J7f/dvf/DaX5SJi03Obju0/dvXVV0/zwp7Zdu7cuWLFioceeuii iy466XOBKpXK
nj17Vq1atXPnzult3qnmScAAQHu+/Uy8Z+ppOUcOx7+tiaUfjis/0CD+4P7k 39dnn/7LaDio
v2/nR3/ywMPffvj9V76/4UDs6v7VE4+LmlWs3pUyH/mDcbBUKaUjaWm4VBoe f/LrobRUKqUH
0tKB0lhXfvQG8wOldFealc+G5wrPj97oPfDWgWx2Nrt7dhyJI0faTkLmR2+h t/xWOU3TU9lE
zgWOAAAAbas5BairK/7omnhhY+wdiA/9cYw/1nc8uBwRURlpcOJQRESsWbum I98xko1kWdYR
HblkykDsjh07SgdL6dD446IGSqXBUro7PX7weMPazgVDsT/2R0QcjiOHT/D4 w1DsH9p/KhrF
uUcCAAC0rf5knmuui9558dILMfBm/MlHYsHCiUlZZaxIk1OA+v6w74Mf/OCS JUuWLFmydOnS
jo6OgYGBLMsWLVq0YMGC1X+9+hQtBJznJAAAQNsajuUvvihu+vP4n/+OZ5+O W++IjllTgsvl
ZkcADh06tGnTpk2bNo3+e8kll9xwww2j+cDcuXNPQeuBCAkAAHACmnTlI5+L a65PntyQ7R2M
RYvH3hwd+C83PQWoxq5du3bt2rV+/fppaSnQjAQAAGhb7V2ASnH8WMybH7lc 7B3IkiTmzJ6I
GX2RvcNdgIDTTAIAALStZiy/dDD+99eRJNHVFbM640PXR1dXlEeiXI6nfxFZ FhHxzJORy8VN
n5qR9gL1JAAAQNtqEoAFC+KmP4ujRyOfi64LpgR84pMRkTUrCMwcCQAA0LaG J/Nc0NV0EnDm
OcknnwEA553R23qembUBbZMAAADtGXrzzK0NaJsEAABoz6NfG7uu993LsvjB /dNTFXCC8jPd
AADgLHEkjd/8Z/Qtie6eSJKTrCSrxNDueOQrse+NaW0cAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJwGyUw3AAAAeFf6+/vbD+44de0A AABOj76+vjYj
c6e0HQAAwBlFAgAAAOeF7du3hwQAAADOB9u3b1+7dm24BgAAAM55r7766rp1 65YvXz7TDQEA
AN61/v7+rLlXXnnlm9/85uDg4Oi/M91YAADg3WmRAPT391d7/6+++mqWZa4B AACAc9PWrVsf
e+yx5cuXL1y4sHoNAAAAcHZreARgy5Yt1bH/bdu2VV/PdGMBAIB3pz4BaNb7 lwAAAMBZryYB
ePnllxv2/rdt2yYBAACAs97kBKCmx1/zWgIAAABnvWoC0Lr37xoAAAA4F7R+ DkCNpKt4efnt
I1n5eFYZzrJKllUisogsJnIDWQIAAO1I2piaNXldP2nyiywimRpXDc7qa0sm Ypo2KZn2bm5N
jZMb1Sw+6pp/QrOL2oIT62hschJJROSSJJfkOpJcZ77jgo7IdeZy5UpWiYjI ypGVI8siskhi
yro9mUadHg03av3GrjY+qQtrGNwwrOHsJlfScBXV7LstlmJyI7O6gJqpDWPi BDdT/X56Zm5l
AOCskFT/NJ06pnXfqUWfavRVs472RJ8tmTKXhn3tyTH1wfUmT6qdXYNFHJ2U JLXv1NSfjNec
1M+lPbXhyfhsk/HXucjlk6Qjl+9M8p0duXxXJSsnkUUuH5WRJCtHlmWRxdjp QeN/z9hu4Ttm
klUNe9QnuuPBhPqBh+r7LT63DYc6oq5Iw6+Yd2wMAJxmDX6exnu8yYn3ZM8p M7H41QQsGT8Q
kiRJEpFLcvkkNyuX78zluzq6uovlkY7KyPFKeTgqI1k2kmVZllUiyyLLIski G+v+J9UsIImk
ekxlUkc5i4mlHOuKZ5M6R8nYv2OTswbFJ79dVS3exgJPQx+ona7WNMyjneMQ 9UUaNW5Kuckr
s9FRoYni9eP+DQ+V1a3U1t3SSRtxbDc5oTV5Olb+iWnnoF2DMuMfvhZHARsk AFlk45uiYdnW
7ZkIqDYgiyyZVHbS2EI1bCym+jcazL1mWZLRT3YyVmF9QEMNs/P6xL1mjpMj Wwyf1EfWjMo0
a1L91IZlGw4aNSwS1Y0YE2uytlR1Q4wG1w9cNfngTFkDjfaTFiY+5JP3z0mv a2quX7qo7qKN
9u2Gw2ANh1harNgY/7fm3RbZdbMkPOpi6tUPArUeFmpYQ+tZvGPxBrObvGWb fJm0qK2mbQ33
8Lq5TdlL6zdQvWbDZi1qri9YH9/i/YZfIGeLFpuv2aSafaP1J67ZJyKab80W 35AtfuFr1NVc
/XFouEANq6zf3bPxLmb93NrY8u1/etsJnvSpGPvCrJ9aX2jyr8Ck4JqlavHz F3VboeE8s6kT
qr8pycRP/Xi/P5IkSXJJ5JJcRy4/K8l15mZ1/z+VXMxQvv4IwAAAAABJRU5E rkJggg==
--------------030109040609040403090101--
Re: [Zest] A couple of questions about graph connections in ZEST [message #240577 is a reply to message #240284] |
Fri, 11 January 2008 00:18   |
Originally posted by: irbull.cs.uvic.ca
213055: Labels on self connected arcs occlude node
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213055
213058: Connection label is always in the center
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213058
I have already prototyped the fix (I did this over the holidays), and I
will submit the patch tomorrow.
Thanks for the kind words on Zest.
cheers,
ian
Paul McEwan wrote:
> Hello all,
> the problem.
> Thank you,
> Paul McEwan
FUDForum. Page generated in 0.03507 seconds
