Home » Modeling » TMF (Xtext) » [SOLVED] How to deploy an Xtext plugin on a clean Eclipse ?
[SOLVED] How to deploy an Xtext plugin on a clean Eclipse ? [message #1373845] Thu, 22 May 2014 06:52 Go to next message
Sorry for this probably easy question for some of you, but I spent much time on internet and with various solutions without getting a proper answer to my problem:
I need to deploy an Xtext plugin on an existing Eclipse CDT: so I need to deploy first Xtext runtime, am I wrong ?
-> I tried to do it, but when I start this Eclipse (Xtext Runtime installed) with my Xtext plugins (composed of org.xtext.example.mydsl.tests_1.0.0.201404271003.jar, org.xtext.example.mydsl.ui_1.0.0.201404271003.jar and org.xtext.example.mydsl_1.0.0.201404271003.jar) I get the following message :
!ENTRY org.eclipse.ui 2 0 2014-05-22 12:15:23.440
!MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2014-05-22 12:15:23.440
!MESSAGE Cannot bind to an undefined command: plug-in='org.eclipse.xtext.ui', id='org.eclipse.xtext.ui.editor.outline.QuickOutline'
And I cannot find any explanation on what this means. And of course, my plugin does not work (files of proper extension are not displayed as it is when I test in "Run As" configuration from my Xtext dev environment, with Xtext SDK).
Thank you by advance for your help Smile
(To be more precise, my final objective is to produce a full package that can be deployed in one shot on an existing Eclipse CDT - which does not contains any Xtext component - so if you have an easy way to achieve that I am interested !)
[Updated on: Fri, 23 May 2014 04:49] by Moderator
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1374391 is a reply to message #1373845] Thu, 22 May 2014 12:13 Go to previous messageGo to next message
Hi Etienne,
You can try to make a feature project. You can afterwards export it as a p2 repository and install it in the fresh Eclipse IDE.
You need to make sure to include all the necessary xtext plug-ins though, as well as your org.xtext.example.mydsl.ui and org.xtext.example.mydsl plug-ins.
Your feature.xml file should look something like this.[1] This is just a minimum list of dependencies that worked for me.
Hope this helps!
Best Regards,
Stefan.
[1]:
<feature
      id="org.xtext.example.mydsl.sdk"
      label="MyDsl SDK Feature "
      version="1.0.0.qualifier">
<plugin
         id="org.xtext.example.mydsl"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.xtext.example.mydsl.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.common.types.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.ecore"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.generator"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.ui.codetemplates"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.ui.codetemplates.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.ui.ecore"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.ui.shared"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.xbase"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.xbase.lib"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.xbase.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.xtext.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.apache.commons.logging"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.mwe.utils"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.mwe2.launch"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.codegen"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.builder"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.mwe2.language"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.mwe2.language.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.mwe2.lib"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.emf.mwe2.runtime"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.util"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtext.common.types"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.objectweb.asm"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="org.eclipse.xtend.lib"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
</feature>
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1374811 is a reply to message #1374391] Thu, 22 May 2014 16:20 Go to previous messageGo to next message
Thank you very much Stefan.
I tried it, I succeeded in exporting my feature (great !), so first step is ok, unfortunately I fail at deploying it in Eclipse (read some tutorial but I do not find the problem...): I do not want to use an update site, so I exported it by Selecting the "Directory" option in "Destination" tab, and in the "Options" tab if I unchek "Package as individual JAR archives", then I get two folders (plufins and features) that I copy in my target Eclipse "dropins" folder: anything happens, no error log appended in .log file, no mention of the plugin in installed plugins list, and expected behavior (editor for a given file extension) doe not appear.
I also tried to check "Package as individual JAR archives" and to copy the files and folders in "dropins", but I have the following error :
!ENTRY org.eclipse.equinox.p2.core 4 0 2014-05-22 21:34:17.514
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at jar:file:/D:/MyCLEANTest/eclipse/dropins/content.jar!/.
that makes me think that I am doing something not expected by Eclipse.
If you have any idea of how to debug or what I am doing wrong do not hesitate to tell !
I will continue to work on this tomorrow (I am french - sorry for my english - and here it is time to go to sleep...).
Etienne
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1374849 is a reply to message #1374811] Thu, 22 May 2014 16:45 Go to previous messageGo to next message
i am not sure what your problem is.
the xtext wizard creates a project yourdsl.sdk
this project can be used to create a p2 repository (update site) containing your plugins.
therefore
(1) create a new category definition in the sdk project. give it a name and add the org.xtext.example.mydsl.sdk featur
(2) rightclick on the feature.xml
(3) export -> deployable features
(4) choose a location (folder or zip)
(5) under options choose the category.xml file created before
(6) hit finish
if you add this update site + one containing xtext (you may download the all in one repo zip http://www.eclipse.org/modeling/tmf/downloads/?project=xtext), then p2 should do all dependency magic for you.
alternatively you could use build tools like buckminister or maven tycho to create the update site or even a complete product.
[Updated on: Thu, 22 May 2014 16:47] by Moderator
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1374866 is a reply to message #1374849] Thu, 22 May 2014 16:51 Go to previous messageGo to next message
P.S: and make sure you dont have any warning on build.properties files in your projects
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1375741 is a reply to message #1374811] Fri, 23 May 2014 01:39 Go to previous messageGo to next message
Hello again Etienne,
An Eclipse p2 repository should have the following layout:
<site root>/
    content.jar
    artifacts.jar
    features/
        feature archives   (eg. org.eclipse.javatools_1.0.1.jar)
    plugins/
        plug-in archives
You should not copy the folders from the p2 repository anywhere. After you export your feature in the repository, use the Eclipse update manager to install your DSL feature from that repository directly.
Here is an article on how to use eclipse update manager [1]. You will have to chose the local path to your p2 repository. (You can do this by Add New -> Local and select the repository folder).
Best Regards,
Stefan
[1] http://www.day.com/eclipse.html/
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1375952 is a reply to message #1375741] Fri, 23 May 2014 03:37 Go to previous messageGo to next message
OK thank you for both of you, indeed it seems better to deploy through an update site (I knew this procedure, but I found it more complicated than just copying files in "dropins"). Above all, I have now a precise explanation of something wrong in my dependencies :
Cannot complete the install because one or more required items could not be found.
Software being installed: MyDsl SDK Feature 1.0.0.201405230927 (org.xtext.example.mydsl.myfeature.sdk.feature.group 1.0.0.201405230927)
Missing requirement: Modeling Workflow Engine 2 Runtime 2.6.0.v201405070412 (org.eclipse.emf.mwe2.runtime 2.6.0.v201405070412) requires 'bundle com.google.inject 3.0.0' but it could not be found
Cannot satisfy dependency:
From: MWE2 Lib 2.6.0.v201405070412 (org.eclipse.emf.mwe2.lib 2.6.0.v201405070412)
To: bundle org.eclipse.emf.mwe2.runtime 2.3.0
From: MyDsl SDK Feature 1.0.0.201405230927 (org.xtext.example.mydsl.myfeature.sdk.feature.group 1.0.0.201405230927)
To: org.eclipse.emf.mwe2.lib [2.6.0.v201405070412]
But now I think I can solve this problem by myself, I will add missing dependencies to my feature until everything is allright. I keep you informed of the final resolution, thank you again you saved me !
Re: How to deploy an Xtext plugin on a clean Eclipse ? [message #1376079 is a reply to message #1375952] Fri, 23 May 2014 04:49 Go to previous message
I had several successive problems : when all dependencies seemed resolved, failing while installing : I had to uncheck "contact all update sites ..." from install window, then I had to add other dependencies in my feature, and finally, installation did not work due to a strange error about repository... But then I tried to put my plugins in the dropins folder and it worked Question
I did not understand everything, but I learned some thanks to you. It is OK for me, topic resolved, thanks again Thumbs Up !
Hope this topic will bring some help to other people at the same level of knowledge than me.
Previous Topic:Xtext 2.6 Available
Next Topic:Set values to an object by changing references.
Current Time: Tue Aug 19 10:47:52 EDT 2025
Powered by FUDForum. Page generated in 0.07722 seconds
