Re: creating pattern using bpmn2 extetion module [message #1374221 is a reply to message #1371774] |
Thu, 22 May 2014 14:33 |
Hi Lobna,
I'm not sure I quite understand what you mean by "creating patterns". Are you talking about programmatically constructing workflows using design patterns? If so, this is already handled quite well in the editor. Try one of the "Workflow Pattern" tools in the tool palette. These are all "macro" commands of sorts, that can be defined in a plug-in extension, or in a configuration file that extends the tool palette. Have a look at the documentation for the <toolPalette> extension point schema.
The current API rework should be done within a week or two, along with the developer docs, which will consist of the API extension point schema documentation and javadoc.
Bob
Re: creating pattern using bpmn2 extetion module [message #1384225 is a reply to message #1384003] |
Wed, 28 May 2014 13:07 |
OK, it's still not clear what you want to do. First, let's make sure we're talking about the same thing: when you say "patterns" I'm assuming you are talking about BPMN workflow patterns, i.e. "fragments" of workflows that can be combined (either programmatically or interactively) to build up more complex workflows.
I'm not sure what jar files have to do with this, and how or why they would be used "directly with any eclipse that contains bpmn2 plugin". Please explain.
Re: creating pattern using bpmn2 extetion module [message #1384616 is a reply to message #1384604] |
Thu, 29 May 2014 15:03 |
No bother at all I'm happy to see people using the product
I think what you're saying is that you have written an extension plugin for the BPMN2 Modeler, and now you want to distribute that plugin for other people to install and use in their own eclipse environments, correct?
If that's the case, please have a look at how the jbpm5 plugin is built (using maven) and added to the update site. There is a feature project in the git root named org.eclipse.bpmn2.modeler.runtime.jboss which defines the jbpm5 plugin and adds it to the update site.
There are lots of resources on the web that describe how to build feature projects and they can probably do a better job of explaining it than I can
HTH,
Bob
Re: creating pattern using bpmn2 extetion module [message #1404080 is a reply to message #1403692] |
Tue, 29 July 2014 13:24 |
Hi Lobna,
From the error message it looks like you probably did not specify the parent in your plugin's pom.xml. I don't know where your plugin lives in the hierarchy, but have a look at some of the other plugins to figure out what the correct path to the parent pom should be.
If you can provide me with a folder layout of your plugin hierarchy and how it relates to the BPMN2 Modeler plugins, I might be able to give you a better answer
Bob
FUDForum. Page generated in 0.03918 seconds
