Home » Newcomers » Newcomers » How do I tell eclipse how to find the SWT native libraries
How do I tell eclipse how to find the SWT native libraries [message #239696] Sun, 04 November 2007 11:55 Go to next message
Originally posted by: James.Watrous.MatrixOne.com
I am new to SWT and have only used the basics in Eclipse. I am working
on a Windows XP-Pro SP2 machine with Eclipse 3.2.1. I created my “Hello
World” program for SWT as follows:
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class hello {
Display display = new Display();
Shell shell = new Shell(display);
Label label = new Label(shell, SWT.CENTER);
label.setText("Hello, World");
label.setBounds(shell.getClientArea());
shell.open();
while (!shell.isDisposed()){
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
I added the external jar file
“org.eclipse.swt.win32.win32.x86_3.2.2.v3236.jar” from my
“eclipse/plugins” directory to the “Libraries” tab of the
“Project->Properties-> Java Build Path” Dialog. I did not add any JVM
arguments on the Run dialog.
The project now builds, but I get a “no swt-win32-3236 in
java.library.path” error at run time.
I then extracted all the .dlls from
“org.eclipse.swt.win32.win32.x86_3.2.2.v3236.jar” (swt-win32-3236.dll,
swt-awt-win32-3236.dll, swt-gdip-win32-3236.dll, swt-wgl-win32-3236.dll)
and placed them in a new directory (c:\SWT_dlls) and added this path to
the “Native Library Location” element that appeared under the
“org.eclipse.swt.win32.win32.x86_3.2.2.v3236.jar” object that was added
to the “Project->Properties-> Java Build Path->Libraries” tab above.
The program now runs.
Should I be extracting the dlls from the jar, or is there a way to run
with them still inside the SWT jar file? How does Eclipse find the SWT
native libraries?
Re: How do I tell eclipse how to find the SWT native libraries [message #239731 is a reply to message #239696] Mon, 05 November 2007 02:10 Go to previous messageGo to next message
Jim,
You'd be better of use SWT from 3.3 because then SWT takes care itself
to extract the .dlls and resolve them appropriately.
Tom
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
> native libraries?
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How do I tell eclipse how to find the SWT native libraries [message #239769 is a reply to message #239731] Mon, 05 November 2007 10:35 Go to previous messageGo to next message
Tom,
Thank you very much. That did solve the problem. Apparently SWT is doing
some magic if System.loadLibrary("swt-win32-xxxx") fails in the 3.3 version.
Tom Schindl wrote:
> Jim,
> Tom
>> “Hello World” program for SWT as follows:
>> shell.open();
>> display.sleep();
>> display.dispose();
>> swt-wgl-win32-3236.dll) and placed them in a new directory
>> (c:\SWT_dlls) and added this path to the “Native Library Location”
>> added to the “Project->Properties-> Java Build Path->Libraries” tab
>> above.
>> native libraries?
Re: How do I tell eclipse how to find the SWT native libraries [message #240100 is a reply to message #239769] Thu, 08 November 2007 21:44 Go to previous message
Originally posted by: James.Watrous.3ds.com
The
Previous Topic:JSP version mismatch: auto-complete versus build
Next Topic:Eclipse does not work on my 64 bit machine
Current Time: Wed Sep 24 15:38:15 EDT 2025
Powered by FUDForum. Page generated in 0.08890 seconds
