Home » Archived » BIRT » CSV output
| CSV output [message #239670] |
Wed, 23 May 2007 16:04  |
Originally posted by: xxx.xxx.com
Jason, I can see your answer on how to export output to CSV as follows
but it didnt say anything about how to do that.If you can put some code
snippets, that would be perfect.
Thank You
From: Jason Weathersby <jasonweathersby@xxxxxxxxxx>
Date: Tue, 03 Apr 2007 19:53:00 -0700
Newsgroups: eclipse.birt
Organization: EclipseCorner
User-agent: Thunderbird 1.5.0.10 (Windows/20070221)
This definitely could be done using the report engine api.
To do this with the viewer will require that you mod the viewer code or
the ajax code that displays the export.
Jason
Joseph Hurley wrote:
Currently, the BIRT web viewer will allow you to export tables into csv
format. However, if your report has multiple table objects, you need to
export each table separately. Is there a way to export multiple tables
at one time? Our situation is that we have several tables in the same
format, but with certain criteria changes (work based on labor,
materials, equipment, etc). We'd like the user to be able to export all
these tables at once,if possible. Thanks.
| Re: CSV output [message #239779 is a reply to message #239670] |
Thu, 24 May 2007 11:15   |
Kris,
Look at this example. This uses the RE API.
http://wiki.eclipse.org/index.php/Data_Extract
Jason
> Thank You
> Jason
> Hello,
| Re: CSV output [message #239867 is a reply to message #239779] |
Thu, 24 May 2007 18:45   |
Jason, I tried this and it worked like a charm - thanks very much.
Right now, the resultset list extracted are a collection of resultset
for each column in the report. So when I printed, it didnt print in rows
but in columns.
Report data looks as follows
11 12 13 14 15
21 22 23 24 25
31 32 33 34 35
The printing occurred as follows
11 21 31
12 22 32
13 23 33
14 24 34
15 25 35
Is there any straight forward way to extract data and use the result set
in a row fashion?
Jason Weathersby wrote:
> Kris,
> Jason
>> code snippets, that would be perfect.
>> Thank You
>> Jason
>> Hello,
>> csv format. However, if your report has multiple table objects, you
>> need to export each table separately. Is there a way to export
>> multiple tables at one time? Our situation is that we have several
>> tables in the same format, but with certain criteria changes (work
>> based on labor, materials, equipment, etc). We'd like the user to be
>> able to export all these tables at once,if possible. Thanks.
| Re: CSV output [message #240178 is a reply to message #239867] |
Tue, 29 May 2007 11:02   |
Kris,
Is you data in one table? If you used the example and exported just
that table it should have retrieved just like your table data. If your
data is in multiple tables and you want one combined output, you will
need to store the data in a hash in your code and print it out when you
are finished. Another option is to make a new report and use the Joint
Data Set to combine your data sets, and add this new joint ds to a table
in the report.
Jason
> but in columns.
> 11 12 13 14 15
> 21 22 23 24 25
> 31 32 33 34 35
> 11 21 31
> 12 22 32
> 13 23 33
> 14 24 34
> 15 25 35
> in a row fashion?
> Thanks
>> Kris,
>> Jason
>>> follows but it didnt say anything about how to do that.If you can put
>>> some code snippets, that would be perfect.
>>> Thank You
>>> Jason
>>> Hello,
| Re: CSV output [message #240199 is a reply to message #240178] |
Tue, 29 May 2007 11:48   |
Jason, today I found an interesting thing on this behavior. The
different behavior I have been experiencing is attributed to the
component I was using to display data.I was using a grid before and when
I changed that to a table, it worked as expected. (So, it looks like
each grid column is treated as a separate "table".)
> Kris,
> in the report.
> Jason
>> rows but in columns.
>> 11 12 13 14 15
>> 21 22 23 24 25
>> 31 32 33 34 35
>> 11 21 31
>> 12 22 32
>> 13 23 33
>> 14 24 34
>> 15 25 35
>> set in a row fashion?
>> Thanks
>>> Kris,
>>> Jason
>>>> put some code snippets, that would be perfect.
>>>> Thank You
>>>> Jason
>>>> Hello,
| Re: CSV output [message #240214 is a reply to message #240199] |
Tue, 29 May 2007 14:08  |
Kris
This is due to the fact that the grid is individually bound per cell.
Jason
> Thanks
>> Kris,
>> your data is in multiple tables and you want one combined output, you
>> will need to store the data in a hash in your code and print it out
>> when you are finished. Another option is to make a new report and use
>> the Joint Data Set to combine your data sets, and add this new joint
>> ds to a table in the report.
>> Jason
>>> 11 12 13 14 15
>>> 21 22 23 24 25
>>> 31 32 33 34 35
>>> 11 21 31
>>> 12 22 32
>>> 13 23 33
>>> 14 24 34
>>> 15 25 35
>>> Thanks
>>>> Kris,
>>>> Jason
>>>>> Thank You
>>>>> code or
>>>>> Jason
>>>>> Hello,
>>>>> be able to export all these tables at once,if possible. Thanks.
Current Time: Fri Nov 07 19:30:01 EST 2025
Powered by FUDForum. Page generated in 0.04220 seconds
