Home » Eclipse Projects » GEF » installEditPolicy in AbstractEditPart
installEditPolicy in AbstractEditPart [message #239400] Thu, 25 October 2007 13:01 Go to next message
As I was digging in the source code I arrived in the
install/removeEditPolicy source code of GEF. I was quite surprised to see
that the policies are kept in an Object array and that
the "installEditPolicy" do not seem to remove another policy having the
same role key.
I'm quite curious about these choices as it may make sense in another
context, why not using a HashMap or something like that ? Why bothering
about the array allocation when an edit policy is added ?
Thanks for your input,
cheers,
Cédric
Re: installEditPolicy in AbstractEditPart [message #239409 is a reply to message #239400] Thu, 25 October 2007 21:35 Go to previous messageGo to next message
Hi C
Re: installEditPolicy in AbstractEditPart [message #239428 is a reply to message #239409] Mon, 29 October 2007 03:23 Go to previous messageGo to next message
Thank you for your answer. Then I understand from it that it's done to
decrease the memory footprint of the edit parts, but then I'm still
wondering, using a GMF-based diagram editor we experienced having "doubles"
in the edit-part, for a "who know why" reason the "installEditPolicies()"
method is sometime called again. Then the memory footprint is bigger and
the behavior may seems strange some time.
I guess it's something we should track down and report a bug on GMF if (but
I'm really not sure) it comes from a use case of the GMF tooling.
Cédric
Anthony Hunter wrote:
> Hi C
Re: installEditPolicy in AbstractEditPart [message #239478 is a reply to message #239428] Tue, 30 October 2007 10:26 Go to previous message
Hi C
Previous Topic:Doubt for multipage Graphical editor
Next Topic:Any performance impact when SWGraphics.setAntialias(SWT.ON)
Current Time: Sat Nov 08 07:21:25 EST 2025
Powered by FUDForum. Page generated in 0.04031 seconds
