Home » Modeling » EMF » [EMF Query] Using EMF Query outside Eclipse (with OCL)
[EMF Query] Using EMF Query outside Eclipse (with OCL) [message #1368800] |
Tue, 20 May 2014 09:26 |
Bertrand Quenin Messages: 70 Registered: July 2009 |
Member |
I'm using EMF Query and OCL conditions and it works fine except when I provide a malformed OCL expression.
Basically, when I provided a malformed OCL expression, the OCLPlugin is catching the error and tries to process it but since i'm outside the eclipse platform, it leads to the following NPE:
java.lang.ExceptionInInitializerError
at org.eclipse.emf.query.ocl.internal.OCLPlugin.catching(OCLPlugin.java:480)
at org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.getOCLQueryRecord(AbstractOCLCondition.java:366)
at org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.isSatisfied(AbstractOCLCondition.java:289)
at org.eclipse.emf.query.ocl.conditions.BooleanOCLCondition.isSatisfied(BooleanOCLCondition.java:230)
at org.eclipse.emf.query.statements.WHERE.matches(WHERE.java:46)
at org.eclipse.emf.query.statements.SELECT.doResume(SELECT.java:131)
at org.eclipse.emf.query.statements.SELECT.doExecute(SELECT.java:95)
at org.eclipse.emf.query.internal.statements.QueryStatement.execute(QueryStatement.java:77)
at org.eclipse.emf.query.statements.SELECT.execute(SELECT.java:172)
at com.axway.mda.framework.ModelSingleton.freeQuery(ModelSingleton.java:412)
at com.axway.mda.flowrepository.participant.ParticipantTest.testQuery(ParticipantTest.java:182)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:27)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
at org.eclipse.emf.query.ocl.internal.OCLDebugOptions.<clinit>(OCLDebugOptions.java:29)
... 36 more
After debugging, it seems that the OCLPlugin.getPlugin() returns null.
Is there a way to enable this plugin or maybe my analysis is wrong?
BQ.
[Updated on: Tue, 20 May 2014 09:26] Report message to a moderator
Re: [EMF Query] Using EMF Query outside Eclipse (with OCL) [message #1369188 is a reply to message #1368800] |
Tue, 20 May 2014 13:14 |
Hi, BQ,
If I recall correctly, this plug-in was not designed for use except in
the Eclipse Platform run-time, so I don't expect there's a work-around
for you. Perhaps EMF Query 2 (of which I know nothing) supports
stand-alone execution? Certainly OCL, itself, does and it could be
sufficient on its own for your querying needs.
Christian
On 2014-05-20 09:26:23 +0000, Bertrand Quenin said:
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 36 more
> Regards,
> BQ.
Re: [EMF Query] Using EMF Query outside Eclipse (with OCL) [message #1369269 is a reply to message #1369188] |
Tue, 20 May 2014 13:55 |
Ed Willink Messages: 7655 Registered: July 2009 |
EMF has evolved so that EcorePlugin.ExtensionProcessor is now able to
start things up much better in a standalone environment.
This improves the capability of EMF-based appliocations tyo also run
standalone, burt as Christian syas, only if desifgned top do so.
Every OCL release occurs only after over a thousand tests have passed in
a standalone environment, so again as Christian says, try using just OCL.
Ed Willink
On 20/05/2014 14:14, Christian W. Damus wrote:
> Hi, BQ,
> Cheers,
> Christian
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 36 more
>> Regards,
>> BQ.
Re: [EMF Query] Using EMF Query outside Eclipse (with OCL) [message #1369388 is a reply to message #1369269] |
Tue, 20 May 2014 15:06 |
Member |
Ok, Thanks for your feedback.
I'll try to use OCL only, do you have any idea how I could transpose the following code snippet (using EMF Query) to OCL only, I'm not sure how?
def Set<EObject> boundQuery(EClass eClass, String oclQuery) {
val query = oclQuery ?: '''self.oclIsKindOf(«eClass.name»)'''
val condition = new BooleanOCLCondition<EClassifier, EClass, EObject>(ocl.environment, query, eClass)
val statement = new SELECT(SELECT.UNBOUNDED, false, new FROM(resource.contents), new WHERE(condition))
statement.execute.EObjects as Set<EObject>
def Set<EObject> freeQuery(String oclQuery) {
log.info("freeQuery: oclQuery = [" + oclQuery + "]")
val condition = new BooleanOCLCondition<EClassifier, EClass, EObject>(ocl.environment, oclQuery, null)
Re: [EMF Query] Using EMF Query outside Eclipse (with OCL) [message #1369618 is a reply to message #1369388] |
Tue, 20 May 2014 17:17 |
Not easily. With EMF Query you seem to get to use three languages at
once; Java+SQL+OCL; really confusing.
Try expressing your intent in clear logical words then you can transpose
to OCL.
Ed Willink
> how?
> Regards
Current Time: Fri Apr 26 17:12:02 GMT 2024
Powered by FUDForum. Page generated in 0.03788 seconds
