Home » Eclipse Projects » GEF » Shortest path router draws across elements sometimes
Shortest path router draws across elements sometimes [message #238571] Thu, 20 September 2007 09:29
Originally posted by: pilgrim.us.ibm.com
In the logic example with the router set to shortest path, the connections are drawn around gates if the gates are on the base logic part. But, if the gates are inside a circuit, the wires will cross a gate.
A stick diagram:
G1 G2 G3
\______/
| G1__G2___G3 |
How would I get the same wire routing between gates when they are inside a circuit as is done when the gates are not in a circuit? Also, how does the algorithm know how much space a gate occupies in case I need to override that?
Thanks in advance.
Jeff
Previous Topic:Need help setting up GEF contributor environment
Next Topic:editpolicy & mouseDoubleClick
Current Time: Fri Oct 31 18:26:23 EDT 2025
Powered by FUDForum. Page generated in 0.03038 seconds
