bug in AbstractGraphicalEditPart#refreshSourceConnection [message #238494] |
Fri, 14 September 2007 09:56  |
Originally posted by: aczerwonka.3esi.com
and refreshTargetConnections
I *think* there's a bug. In my implementation, I use very lightweight model
objects that are meant to be created as ofter as need be. When I implement
getSourceConnections(), I re-wrap real pojo's with my lightwieght UI model
objects. The trouble is that the implementation of refreshSourceConnection
uses reference equality, e.g. getModel == model, versus equality, e.g.
getModel.equals(model), so my model#equals implementation doesn't work. I
don't see any documentation as to why that choice was made, and what drove
me to a correct equals implementation is the fact that the TableViewer
requires a correct implementation to maintain selection.
Can anyone confirm that this is a *bug* and/or *design choice* or and I
missing something?
Andy Czerwonka
Re: bug in AbstractGraphicalEditPart#refreshSourceConnection [message #238551 is a reply to message #238494] |
Wed, 19 September 2007 11:27   |
Originally posted by: none.ibm.com
If the == fails, doesn't the next statement find the editpart anyway?
if (i < editParts.size()
&& ((EditPart) editParts.get(i)).getModel() == model)
continue;
editPart = (ConnectionEditPart) modelToEditPart.get(model);
if (editPart != null)
reorderSourceConnection(editPart, i);
The model->part map should use .equals(). Did you remember to implement
hashCode()?
"Andy Czerwonka" <aczerwonka@3esi.com> wrote in message
news:fce3u5$d84$1@build.eclipse.org...
> model objects that are meant to be created as ofter as need be. When I
> implement getSourceConnections(), I re-wrap real pojo's with my
> lightwieght UI model objects. The trouble is that the implementation of
> refreshSourceConnection uses reference equality, e.g. getModel == model,
> versus equality, e.g. getModel.equals(model), so my model#equals
> implementation doesn't work. I don't see any documentation as to why that
> choice was made, and what drove me to a correct equals implementation is
> the fact that the TableViewer requires a correct implementation to
> maintain selection.
> missing something?
> Andy Czerwonka
Re: bug in AbstractGraphicalEditPart#refreshSourceConnection [message #238652 is a reply to message #238551] |
Tue, 25 September 2007 17:07  |
Yup - hasCode is implemented. I overwrote
AbstractGraphicalEditPart#createOrFindConnection to get around it.
"Randy Hudson" <none@ibm.com> wrote in message
news:fcrf4i$vi8$1@build.eclipse.org...
> continue;
> hashCode()?
>> that choice was made, and what drove me to a correct equals
>> implementation is the fact that the TableViewer requires a correct
>> missing something?
>> Andy Czerwonka
FUDForum. Page generated in 0.04131 seconds
